Asano 50LF7030S, TP.MT5510S PC822, не включается, ищу дамп eMMC
Перейти к решению Решено Batix,
Asano 50LF7030S
MAIN - TP.MT5510S PC822
Panel - CV500U1-T01
Первоначально со слов телевизор был с проблемой зависал на заставке андроид, принесли уже с проблемой не включается. Горит красный индикатор. Подключил к терминалу
Лог
Boot-
EFUSE=3;
DRAM Channel A Calibration.
1T = (103 - 32) = 71 delay cells
Clock frequency = 864 MHz, Clock period = 1157 ps, 1 delay cell =16 ps
Byte 0 : Gating(-25 ~ 26), Size=52 .
Byte 1 : Gating(-25 ~ 25), Size=51 .
Byte 2 : Gating(-25 ~ 25), Size=51 .
Byte 3 : Gating(-25 ~ 25), Size=51 .
HW Byte 0 : DQS(-12 ~ 12), Size 25 , Set 0.
HW Byte 1 : DQS(-12 ~ 12), Size 25 , Set 0.
HW Byte 2 : DQS(-12 ~ 11), Size 24 , Set 0.
HW Byte 3 : DQS(-12 ~ 12), Size 25 , Set 0.
DATLAT calibration
first_step= 17 total pass= 6 best_step=19 .
TX HW Byte 0 : DQS(26 ~ 50), Size 25, Set 38.
TX HW Byte 1 : DQS(26 ~ 51), Size 26, Set 38.
TX HW Byte 2 : DQS(27 ~ 50), Size 24, Set 38.
TX HW Byte 3 : DQS(28 ~ 51), Size 24, Set 39.
DRAM A Size = 1024 Mbytes.
Boot
Start Pmain
EMMC boot
CID:0xd8af7603
:0x5206fe03
:0x47544634
:0x15010038
LZHS addr:0x00100040
LZHS size:0x000f2620
LZHS size:0x0005f97c
LZHS checksum:0x000000f1
LZHS begin
LZHS ok
Boot
Start Lmain
MT5863 Boot Loader v0.9
MUSB_Init : ++
It has 2 USB Port,is 1, 1, 0, 0(1=using, 0=not use).
USB0: Set GPIO-1 = 1.
USB0: Set GPIO-1 error.
USB1: Set GPIO-1 = 1.
USB1: Set GPIO-1 error.
USB Port 0 is initial.
USB Port 1 is initial.
Set port-0 to Host mode.
Set port-1 to Host mode.
Support network![MSDC] LOADER FAST READ EMMC!
[MSDC] Init config, cid = 0x15010038, dsc=0xd8af7603, rca=0x5206fe03, ocr=0x4754
4634
[MSDC] loader RCA  1, 1
[MSDC] ---MSDC Set FIFO path and Init---
[MSDC] MT22627:15010038:47544634:5206fe03:d8af7603
[MSDC] id1:00384754 id2:46345206
[MSDC] eMMC Name: UNKNOWN
[MSDC] Prepare set msdc  Bus Clock as HS25(MHz),src 12 ,mode 0, div 4
[MSDC] Set Bus Clock as HS25(MHz) Success!,src 12 ,mode 0, div 4
[MSDC] MsdcSmapleDelay: u4IC_Value = 0x5863
[MSDC] Use NEW AutoK idea ,ignore the old ett param
[MSDC] Set pad driving as 5 !
[MSDC] [eMMC2DRAM]enter into SDR50 Mode, max dtr 200000000
[MSDC] Prepare set msdc  Bus Clock as HS0(MHz),src 0 ,mode 0, div 16
[MSDC] Set Bus Clock as HS0(MHz) Success!,src 0 ,mode 0, div 16
[MSDC] Set pad driving as 0 !
[MSDC] Prepare set msdc  Bus Clock as HS50(MHz),src 12 ,mode 0, div 2
[MSDC] Set Bus Clock as HS50(MHz) Success!,src 12 ,mode 0, div 2
[MSDC]
Saved info: id1 = 0x76035206, id2=0xfe034754,flag 0xaabbccdd,speedmode 5, dlycel
l 71
[MSDC] Support HS400, card type ext_csd[196]0x57
[MSDC] Support HS200, card type ext_csd[196]0x57
[MSDC] u4mask = 0x3
[MSDC] ID: 0x15010038, 0x47544634, 0x5206fe03, 0xd8af7603
[MSDC]
 Cur info: id1 = 0x76035206, id2=0xfe034754,flag 0xaabbccdd,speedmode 5, dlycell
 71
[MSDC]
-----The information is match, Alrady run autok before, ignore this time--
[MSDC] Load Param:
[MSDC] K_IOCON: 0x2000008
[MSDC] K_PAD_TUNE0: 0x2d2000
[MSDC] K_PAD_TUNE1: 0x0
[MSDC] K_PATCH_BIT0: 0x403c0006
[MSDC] K_PATCH_BIT1: 0xfffe4309
[MSDC] K_PATCH_BIT2: 0x448a1803
[MSDC] K_EMMC50_CFG0: 0xe88832
[MSDC] K_DAT_RD_DLY0: 0x4030404
[MSDC] K_DAT_RD_DLY1: 0x4020404
[MSDC] K_DAT_RD_DLY2: 0x0
[MSDC] K_DAT_RD_DLY3: 0x0
[MSDC] K_EMMC50_PAD_DS_TUNE: 0x11025
[MSDC] K_EMMC50_PAD_CMD_TUNE: 0x0
[MSDC] K_EMMC50_PAD_DAT01_TUNE: 0x0
[MSDC] K_EMMC50_PAD_DAT23_TUNE: 0x0
[MSDC] K_EMMC50_PAD_DAT45_TUNE: 0x0
[MSDC] K_EMMC50_PAD_DAT67_TUNE: 0x0
[MSDC] Current speed mode 1, clock 50.
[MSDC] --ENTER RPMB--
[MSDC] --EXIT RPMB--
[MSDC] Clock frequency = 864 MHz, Clock period = 1157 ps, 1 delay cell = 16 ps
[MSDC] TCMGET_DLYCELL_PERT = 71
1st MAC in EEP is valid (c0:8a:cd:a7:c9:08)
Boot reason: A/C power on!!11111 u1AtmosEnable = 10
Remove Quiet Boot misc control in eeprom when Watchdog reason.
Normal zcc Start,using customer ir
IR DATA register : 0x       0
T8032 init A/C on case loader stage...
Load T8032 FW (addr: 0x  dbb9f8, size: 21076)success!!
T8032 FW version: 6
T8032 change to loader stage...
LDR_FlashCopy 0xf010 0x69d80 0x80
<5507> getenv flag=0x1a01, len=0x0b
[readRecoveryCmd] readRecoveryCmd start
recovery cmd:,para:
Do USB upgrade
u1USBBlock = 0x01d09dc0
USB: Vbus turn up time = 314 ms, Max =1000 ms.
MUSB_GetInsert return 0
 No USB device.
 prLdrData->rDtvCfg.u1Upgrade_Ext :0x0
 _fgDeviceType :0x1
USB upgrade stop
LDR_EEPUserDrvCheckMagic u4HeaderData=0x25125539, u4Magic=0x25125539
<5508> getenv flag=0x1a09, val=0x00
<5508> LDR_IsGoBootup prLdrData->u4WakeupReason:6
<5508> getenv flag=0x1a08, val=0x00
<5508> setenv flag=0x1421, val=0xff
<5508> LDR_IsGoBootup AT_READ_FLAG=0, AT_B_FLAG=0
go to standby when ac on at factory mode 0.
Error: Open file FAC_BOOT_WB_CONFIG_MTK5510.txt fail, RT710.dbg Loader_RT710_Sta
ndby
rt710.dbg ucI2cWrite_tuner OK
joe.dbg LDR I2C OK
 cvte R842 standby
qiujunshuai R842_Init
qiujunshuai R842_Standby
Servoadc Channel1 frist update!!!, value is 1023
Servoadc Channel1 finish update!!!, value is 1023
Disable VGA wakeup
powerdown usb port2
support WOL
wol off, MAC register switch to arm
star:mtcmos poweroff eth
 loader The output gpio is 209  pfgSet0
 loader The output gpio is 209  pfgSetis null
Standby
PDWNC_EnterPowerDown(200100,6)
SWITCH_T8032
CTRL+C что бы вышло приглашение в терминале сделать не получается, может не правильно что делаю. Или есть у кого дамп EMMC с дальнейшим обновлением по USB. Сам файл обновления есть.
21 час назад, Алексей сказал:
Опять не правильно? Файл который вы пытаетесь скормить какой? pkg  :privet:
Изменено пользователем Batix
2 минуты назад, Batix сказал:
Я говорю по поводу как через терминал дойти до приглашения, для ввода команд.
Нашел в чем проблема была что не включался с кнопок. Видимо кто открывал корпус, завернули винт в шлейф кнопок, была дыра. Случайно заметил. Восстановил. Сейчас включается и висит на андроид. Уже что то. Вставил флешку с обновлением, зажимаю кнопку включения и в сеть. Пошли логи обновления, несколько минут и надпись No space left on device (На устройсте нет свободного места), и так циклично. Пока больше ничего не делал. Нужно как то добиться приглашения mt5863 #. Пока не получается.
26 минут назад, Алексей сказал:
:komp: Алексей  файл  переименуй на  allupgrade_5510_sos.pkg в корень флешки .
Установить флешку зажать сеть на тв  включить в сеть начнёт моргать дежурка медленно.
Когда заморгает быстро вытащить флешку. И тв
Дерзай!!
12 минут назад, Batix сказал:
Все я понял. Делаю
22 часа назад, Алексей сказал:
53 минуты назад, Алексей сказал:
...ну так ты-ж не говоришь , как делаешь - последовательность своих действий расскажи :tap:
verniy68  Очень там сложно очень я 3 день с Алексем общаюсь по ЛС один подняли и опять наступает на те-же грабли.
Зажимаю ctrl+C и нажимаю кнопку включения.
15 часов назад, Batix сказал:
Все телек прошился, заработал. :privet:.
