Asano 42LF7110T нужна прошивку USB
Asano 42LF7110T
main TP.SK506S.PB802
panel JE415D3HA0L
С кнопки включается, далее "Asano", "Wisdom-share" и висит, на кнопки и пульт не реагирует. Вторичные питания все в норме.
Лог с терминала под спойлером. Прерывание по CTRL+C, Esc, CTRL+Esc, Enter не работает. Пробовал разные терминальные программы, ничего.
Нужна прошивка USB, либо дампы EMMC
UART_115200
AC_ON
2L-SM-20170623
U03
MIU1_DQS-OK
BIST0-OK
BIST1-OK
optee teeloader entry
CusConfig
eMMC_RPMB_Check_Program_Key
*ree_opt=0000003B
Auth reeloader...
Decrypt reeloader...
Version check on reeloader...
Auth CKB...
Decrypt CKB...
reeloader_addr=20100000
NOTICE:  BL3-1: v1.1(debug):
NOTICE:  BL3-1: Built : 14:56:07, Dec  4 2020
INFO:    warmboot return address : 3e201c00
INFO:    BL3-1: Initializing runtime services
NOTICE:  From args : boot_mbx = 20028044
INFO:     [Booting] mstar_send_magic_ATF 460
INFO:    BL3-1: Initializing BL3-2
[Ramlog] ramlog_init init success
INFO:    BL3-1: Preparing for EL3 exit to normal world
INFO:    BL3-1: Next image address = 0x20100000
INFO:    BL3-1: Next image spsr = 0x1d3
INFO:    BIN1_32bit mode Dec  4 2020 14:56:00
INFO:    R1 0
INFO:    R2 0
INFO:    R3 0
ree_entry
         cumU
Relocation Offset is: 01A00000
[AT][MB][start ub][552]
U-Boot 2011.06-dirty (Jun 30 2021 - 20:24:47)
[Mboot] ===== sw IR Config Register =====
[Mboot] ===== Attach IR Interrupt  ======
[Utopia][SYS]: Function = SYSOpen, Line = 3585, current resource pri_shm content is: 0
[Utopia][SYS]: Function = SYSOpen, Line = 3604, [SYS INFO] OPEN INSTANCE...
create instance at 28FF95A0 with private size 108 bytes at 28FF95F0
[Utopia][MIU]: [MIU INFO] miu opencreate instance at 28FF9660 with private size 168 bytes at 28FF96B0
[Utopia][MIU]:  [MDrv_MIU_SetIOMapBase][188][Utopia][MIU]: Get IOMap MS_MODULE_EXTRIU failurecreate instance at 28FF9760 with private size 60 bytes at 28FF97B0
uboot held at [28DDDF60~2A800000],size=01A220A0
Uboot Relocation:  168 MiB
Now running in RAM - U-Boot at: 29E00000
eMMC: HS400 200MHz
eMMC 7.28 GB
eMMC: used life: 0~10%
CID:0x00A7988E
0xB9750652
0x34465447
0x38000115
ъSTR mode: 1 x 512MB
0x8709
UART_115200
AC_ON
2L-SM-20170623
U03
MIU1_DQS-OK
BIST0-OK
BIST1-OK
CusConfig
*ree_opt=0000003B
Auth reeloader...
Auth CKB...
Decrypt CKB...
INFO:    R1 0
INFO:    R2 0
INFO:    R3 0
ree_entry
         cumU
[AT][MB][start ub][535]
eMMC: HS400 200MHz
eMMC 7.28 GB
CID:0x00A7988E
0xB9750652
0x34465447
0x38000115
ъRAM : 512MB x 512MB
15 минут назад, snst сказал:
Asano 42LF7110T
panel JE415D3HA0L
  Показать контент
UART_115200
AC_ON
2L-SM-20170623
U03
MIU1_DQS-OK
BIST0-OK
BIST1-OK
CusConfig
*ree_opt=0000003B
Auth reeloader...
Auth CKB...
Decrypt CKB...
INFO:    R1 0
INFO:    R2 0
INFO:    R3 0
ree_entry
         cumU
eMMC: HS400 200MHz
eMMC 7.28 GB
CID:0x00A7988E
0xB9750652
0x34465447
0x38000115
0x8709
UART_115200
AC_ON
2L-SM-20170623
U03
MIU1_DQS-OK
BIST0-OK
BIST1-OK
CusConfig
*ree_opt=0000003B
Auth reeloader...
Auth CKB...
Decrypt CKB...
INFO:    R1 0
INFO:    R2 0
INFO:    R3 0
ree_entry
         cumU
eMMC: HS400 200MHz
eMMC 7.28 GB
CID:0x00A7988E
0xB9750652
0x34465447
0x38000115
не всякую флешку подхватывает это шасси, с этим файлом попадаем в рекавери и если EMMC жив, восстанавливаем систему!
Спасибо, все получилось
