SAMTRON 55SA701 нужен дамп EMMC
Доброго всем!
Шасси: MT5522S.PC822
Панель: HV550QUB-N5M
Нужен рабочий дамп emmc, от данного шасси, пофигу от какого тв , после прошивки просто по usb накачу обнову.
Большая просьба если у кого есть дайте ссылку пожалуйста.
Лог:
Boot-
DDR_III_x5
DRAM Channel A Calibration.
1T = (83-12) = 71 delay cells
Clock frequency = 900 MHz, Clock period = 1111 ps, 1 delay cell = 15 ps
Byte 0 : Gating(-33 ~ 33), Size=67.
Byte 1 : Gating(-32 ~ 32), Size=65.
Byte 2 : Gating(-33 ~ 33), Size=67.
Byte 3 : Gating(-33 ~ 33), Size=67.
error on bit 16 ,setup_time =hold_time =0!!
 error on bit 17 ,setup_time =hold_time =0!!
 error on bit 18 ,setup_time =hold_time =0!!
 error on bit 19 ,setup_time =hold_time =0!!
 error on bit 20 ,setup_time =hold_time =0!!
 error on bit 21 ,setup_time =hold_time =0!!
 error on bit 22 ,setup_time =hold_time =0!!
 error on bit 23 ,setup_time =hold_time =0!!
 error on bit 24 ,setup_time =hold_time =0!!
 error on bit 25 ,setup_time =hold_time =0!!
 error on bit 26 ,setup_time =hold_time =0!!
 error on bit 27 ,setup_time =hold_time =0!!
 error on bit 28 ,setup_time =hold_time =0!!
 error on bit 29 ,setup_time =hold_time =0!!
 error on bit 30 ,setup_time =hold_time =0!!
 error on bit 31 ,setup_time =hold_time =0!!
 HW Byte 0 : DQS(-6 ~ 20), Size 27, Set 7.
HW Byte 1 : DQS(-7 ~ 18), Size 26, Set 6.
HW Byte 2 : DQS(0 ~ 0), Size 0, Set 0.
HW Byte 3 : DQS(0 ~ 0), Size 0, Set 0.
RX DQ/DQS calibration fail!
    DATLAT calibration
DATLAT Default value = 0x0x0000000f
DATLAT calibration fail, no DATLAT taps pass, write back to default values!
default tx dq PI delay value(8) is fail on bit 16!!
default tx dq PI delay value(8) is fail on bit 17!!
default tx dq PI delay value(8) is fail on bit 18!!
default tx dq PI delay value(8) is fail on bit 19!!
default tx dq PI delay value(8) is fail on bit 20!!
default tx dq PI delay value(8) is fail on bit 21!!
default tx dq PI delay value(8) is fail on bit 22!!
default tx dq PI delay value(8) is fail on bit 23!!
default tx dq PI delay value(8) is fail on bit 24!!
default tx dq PI delay value(8) is fail on bit 25!!
default tx dq PI delay value(8) is fail on bit 26!!
default tx dq PI delay value(8) is fail on bit 27!!
default tx dq PI delay value(8) is fail on bit 28!!
default tx dq PI delay value(8) is fail on bit 29!!
default tx dq PI delay value(8) is fail on bit 30!!
default tx dq PI delay value(8) is fail on bit 31!!
TX HW Byte 0 : DQS(1 ~ 12), Size 12, Set 6.
TX HW Byte 1 : DQS(2 ~ 12), Size 11, Set 7.
TX HW Byte 2 : DQS(-8 ~ -16), Size -7, Set 16.
TX HW Byte 3 : DQS(-8 ~ -16), Size -7, Set 16.
TX DQ/DQS calibration fail!
Bypass DRAM Channel B Calibration.
DRAM B Size = 0 Mbytes.
DRAM Channel C Calibration.
1T = (99-30) = 69 delay cells
Clock frequency = 900 MHz, Clock period = 1111 ps, 1 delay cell = 16 ps
Byte 0 : Gating(-31 ~ 32), Size=64.
Byte 1 : Gating(-31 ~ 32), Size=64.
HW Byte 0 : DQS(-12 ~ 17), Size 30, Set 3.
HW Byte 1 : DQS(-12 ~ 17), Size 30, Set 3.
    DATLAT calibration
first_step=12 total pass=11 best_step=13
TX HW Byte 0 : DQS(3 ~ 14), Size 12, Set 8.
TX HW Byte 1 : DQS(4 ~ 14), Size 11, Set 8.
Изменено пользователем sus256
Справился, залил от дпугой модели , потом накатил обнову по usb
