sus256 Опубликовано 22 марта, 2024 Опубликовано 22 марта, 2024 Доброго всем! На ремонте ТВ Витязь Модель HI VHIX-24H152WSY Шасси cv6681-k24 Панель PT236AT02-1 ТВ включается, но на матрице идет перебирание цветов, как тест матрицы. Напряжение: 12v 3.3v 1.51v 1.02v 1.03v 5v присутствуют. Терминальный лог: Спойлер UART_115200 AC_ON 2L-SM-20170623 U03 MIU1_DQS-OK BIST0-OK BIST1-OK optee teeloader entry CusConfig eMMC_RPMB_Check_Program_Key *ree_opt=0000003B Auth reeloader... Decrypt reeloader... Version check on reeloader... Auth CKB... Decrypt CKB... reeloader_addr=20100000 NOTICE: BL3-1: v1.1(debug):68fd0926 NOTICE: BL3-1: Built : 12:16:51, May 29 2020 INFO: warmboot return address : 3e201c00 INFO: BL3-1: Initializing runtime services NOTICE: From args : boot_mbx = 20028044 INFO: [Booting] mstar_send_magic_ATF 460 INFO: BL3-1: Initializing BL3-2 [Ramlog] ramlog_init init success INFO: BL3-1: Preparing for EL3 exit to normal world INFO: BL3-1: Next image address = 0x20100000 INFO: BL3-1: Next image spsr = 0x1d3 INFO: BIN1_32bit mode May 29 2020 12:16:48 INFO: R1 0 INFO: R2 0 INFO: R3 0 ree_entry cum MTK_LDR U[LDR_SysInit][301]Hardware Initialization [LDR_SysInit][303]MsOS Initialization LIBCODE:Utopia LIBVER:2.1533808479 BUILDHASH:1d48c21 BUILDDATE:2018080917 [LDR_SysInit][305]MIU Initialization [Utopia][MIU]: [MIU INFO] miu open create instance at p with private size 545791024 bytes at p [LDR_SysInit][308]MMIO Initialization [LDR_SysInit][310]SEM Initialization [LDR_SysInit][314]SYS Initialization [Utopia][SYS]: Function = SYSOpen, Line = 1649, current resource pri_shm content is: 0 [Utopia][SYS]: Function = SYSOpen, Line = 1668, [SYS INFO] OPEN INSTANCE... create instance at p with private size 545791248 bytes at p [LDR_SysInit][317]Enable Interrupt [LDR_SysInit][321]Start Timer [SetMiu][271]CONFIG_MIU0_GROUP_PRIORITY = 1:0:2:3 [SetMiu][272]CONFIG_MIU1_GROUP_PRIORITY = 1:0:2:3 [SetMiu][273]CONFIG_MIU0_GROUP_SELMIU = 1004:0024:0000:0000:005F:0000 [SetMiu][274]CONFIG_MIU1_GROUP_SELMIU = 4F6A:3FD1:0000:0000:0000:FEEF [MDrv_MIU_SetGroupPriority_UBoot][274]IN Change miu0 group priority:e1 [MDrv_MIU_SetGroupPriority_UBoot][309]OK [MDrv_MIU_SetGroupPriority_UBoot][274]IN Change miu1 group priority:e1 [MDrv_MIU_SetGroupPriority_UBoot][309]OK [MDrv_MIU_SelectMIU_UBoot][320]IN [MDrv_MIU_SelectMIU_UBoot][323]OK [MDrv_MIU_SelectMIU_UBoot][320]IN [MDrv_MIU_SelectMIU_UBoot][323]OK [LDR_SysInit][327]Initialize BDMA create instance at p with private size 545791440 bytes at p [LDR_SysInit][335]Initialize eMMC eMMC: HS400 200MHz eMMC 7.28 GB [E8FFF8h] [LDR_SysInit][351]Hardware Initialization Completed [CALDR_Entry][102]Hello CALDR_Entry-Begin MTKLoader v19: 20190107 Do USB upgrade ... [EHCI] ehci init++ [EHCI] bus base miu0: 0x0, miu1: 0x80000000 [EHCI] qh_buf: 0x20519080(0x60519080) qh size: 64 [EHCI] qtd_buf: 0x2051b080(0x6051b080), qtd size: 32 [EHCI] ehci 0 init++ [EHCI] controller: 0x20892280 ehc_base: 0x1f204800, utmi_base: 0x1f207500, usbc_base: 0x1f200e00 [USB] config miu select [70] [f8] [ef] ][ef] [USB] enable miu lower bound address subtraction [USB] init squelch level 0x2 [EHCI] ehci 0 init-- [EHCI] ehci 1 init++ [EHCI] controller: 0x208a28e0 ehc_base: 0x1f201a00, utmi_base: 0x1f207400, usbc_base: 0x1f200f00 [USB] config miu select [70] [f8] [ef] ][ef] [USB] enable miu lower bound address subtraction [USB] init squelch level 0x2 [EHCI] ehci 1 init-- [EHCI] ehci 2 init++ [EHCI] controller: 0x208b2f40 ehc_base: 0x1f227200, utmi_base: 0x1f221d00, usbc_base: 0x1f227000 [USB] config miu select [70] [f8] [ef] ][ef] [USB] enable miu lower bound address subtraction [USB] init squelch level 0x2 [EHCI] ehci 2 init-- [EHCI] ehci init-- Musb3_init OK ++ [yl] usb_poll for controller: 0x208b2f40 [yl] usb_poll loop:0, controller->devices[0]:0x208b31b0 [EHCI] ehci 2 root portsc: 0x803 highspeed device * found device (0x0bda:0xd723, USB 2.0, MPS0: 64) device has 1 configurations device has 3 interfaces NOTICE: Your device has multiple interfaces and this driver will only use the first one. That may be the wrong choice and cause the device to not work correctly. Please report this case (including the above debugging output) to coreboot@coreboot.org to have the device added to the list of well-known quirks. Interface 0: class 0xe0, sub 0x1. proto 0x1 Class: unsupported class ef usb set_address ok;device address := 1 Detaching device not used by payload [yl] usb_poll for controller: 0x208a28e0 [yl] usb_poll loop:0, controller->devices[0]:0x208a2b50 [yl] usb_poll for controller: 0x20892280 [yl] usb_poll loop:0, controller->devices[0]:0x208924f0 [EHCI] ehci 0 root portsc: 0x803 highspeed device * found device (0x0951:0x1625, USB 2.0, MPS0: 64) device has 1 configurations device has 1 interfaces Interface 0: class 0x8, sub 0x6. proto 0x50 Class: MSC usb set_address ok;device address := 1 it uses SCSI transparent command set it uses Bulk-Only Transport protocol using endpoint 81 as in, 2 as out has 1 luns Waiting for device to become ready....ok. Reading capacity of mass storage device. 3907364 512-byte sectors (2000 MB) usb_msc_init OK [yl] usb_poll loop:1, controller->devices[1]:0x208c35a0 Waiting for device to become ready...ok. Reading capacity of mass storage device. 3907364 512-byte sectors (2000 MB) Find msc device Find USB device on U3 port. No EMMC OAD flag. Wait USB medium to be mounted... /dev is created. /mnt is already existed, That is OK. /dev/usb is created. {x_fm_parse_drive 3904} ui4_sec_size=512, ui4_align_bytes=64. {x_fm_parse_drive 4003} it is mbr. /mnt/usb_0 is created. /dev/usb_0 is mounted as /mnt/usb_0. Error: No upgradexxx.pkg was found Error: No valid upgrade file found in USB medium. USB/EMMC upgrade stop ! [Jump2Uboot][146]Jump2Uboot-Begin ** part_emmc_read_ddb: SKIP Driver Descript Block check [disable_cache][131]Disable Cache [LDR_JumpToApp][160]Jump To 0x28400000 Relocation Offset is: 01A00000 [AT][MB][start ub][2220] U-Boot 2011.06-00000-gccc6dd7-dirty (Dec 18 2020 - 23:39:45) [Mboot] ===== sw IR Config Register ===== [Mboot] ===== Attach IR Interrupt ====== [Utopia][SYS]: Function = SYSOpen, Line = 1655, current resource pri_shm content is: 0 [Utopia][SYS]: Function = SYSOpen, Line = 1674, [SYS INFO] OPEN INSTANCE... create instance at 28FF9360 with private size 108 bytes at 28FF93B0 [Utopia][MIU]: [MIU INFO] miu opencreate instance at 28FF9420 with private size 156 bytes at 28FF9470 [Utopia][MIU]: [MDrv_MIU_SetIOMapBase][188][Utopia][MIU]: Get IOMap MS_MODULE_EXTRIU failurecreate instance at 28FF9510 with private size 60 bytes at 28FF9560 uboot held at [28DDDF60~2A800000],size=01A220A0 Uboot Relocation: 168 MiB Now running in RAM - U-Boot at: 29E00000 eMMC: HS400 200MHz eMMC 7.28 GB eMMC: used life: 0~10% CID:0x008863F4 0x07A60652 0x34465447 0x38000115 DRAM : 512MB x 512MB Как я понял он не видит emmc и не подхватывает обновления с флешки. Emmc перезаписана другой прошивкой. Я так понимаю там все от салют тв. Пните в нужное направление пожалуйста, именно по обновлению с юсб под него что то я не чего не нашел в просторах интернета. И получается мой дамп который я записал в emmc просто не подошел?
rav2023 Опубликовано 22 марта, 2024 Опубликовано 22 марта, 2024 Так тв пришел с эти дефектом или вы его прошили и все это стало?
sus256 Опубликовано 22 марта, 2024 Автор Опубликовано 22 марта, 2024 С этим дефектом , прошивка результата не дала
verniy68 Опубликовано 22 марта, 2024 Опубликовано 22 марта, 2024 1 час назад, sus256 сказал: прошивка результата не дала ссылку на прошивку в тему покажи сигналы lvds осцилом смотрел?
verniy68 Опубликовано 22 марта, 2024 Опубликовано 22 марта, 2024 2 часа назад, sus256 сказал: Как я понял он не видит emmc видит ... и даже говорит , что она в отличном состоянии 2 часа назад, sus256 сказал: не подхватывает обновления с флешки верно...он ищет файл с нужным названием 2 часа назад, sus256 сказал: Ошибка: не найден файл updatexxx.pkg. ...разбирайся 1 1
sus256 Опубликовано 22 марта, 2024 Автор Опубликовано 22 марта, 2024 46 минут назад, verniy68 сказал: видит ... и даже говорит , что она в отличном состоянии верно...он ищет файл с нужным названием ...разбирайся Да , но файлы с обновлениями в расширении bin. я пробовал изменить расширение в формат pkg , не прокатило, или нужно было полностью переименовать в updatexxx.pkg? ссылку на прошивку дам завтра.
sus256 Опубликовано 23 марта, 2024 Автор Опубликовано 23 марта, 2024 Это скрытый контент, для просмотра сообщения Вы должны быть Участником форума. Войти или Регистрация Это скрытый контент, для просмотра сообщения Вы должны быть Участником форума. Войти или Регистрация снял плату, положил на стол и что то по usb не одно обновление накатить не получается
verniy68 Опубликовано 23 марта, 2024 Опубликовано 23 марта, 2024 @sus256 , меня интересует ресурс , где ты взял прошивку p/s: родную , надеюсь , сохранил?
sus256 Опубликовано 23 марта, 2024 Автор Опубликовано 23 марта, 2024 (изменено) 27 минут назад, verniy68 сказал: @sus256 , меня интересует ресурс , где ты взял прошивку p/s: родную , надеюсь , сохранил? да конечно родную сохранил. а вот то что залил нашлось на ремауде По поводу родной прошивки, может как то есть у кого нить возможность ее проверить ? Изменено 23 марта, 2024 пользователем sus256
verniy68 Опубликовано 23 марта, 2024 Опубликовано 23 марта, 2024 3 минуты назад, sus256 сказал: да конечно в тему добавляй 3 минуты назад, sus256 сказал: меня интересует ресурс , где ты взял прошивку ссылку...
alex1277 Опубликовано 23 марта, 2024 Опубликовано 23 марта, 2024 (изменено) Error: No upgradexxx.pkg was found Изменено 23 марта, 2024 пользователем alex1277
sus256 Опубликовано 23 марта, 2024 Автор Опубликовано 23 марта, 2024 (изменено) Спойлер UART_115200 AC_ON 2L-SM-20170623 U03 MIU1_DQS-OK BIST0-OK BIST1-OK optee teeloader entry CusConfig eMMC_RPMB_Check_Program_Key *ree_opt=0000003B Auth reeloader... Decrypt reeloader... Version check on reeloader... Auth CKB... Decrypt CKB... reeloader_addr=20100000 NOTICE: BL3-1: v1.1(debug):68fd0926 NOTICE: BL3-1: Built : 12:16:51, May 29 2020 INFO: warmboot return address : 3e201c00 INFO: BL3-1: Initializing runtime services NOTICE: From args : boot_mbx = 20028044 INFO: [Booting] mstar_send_magic_ATF 460 INFO: BL3-1: Initializing BL3-2 [Ramlog] ramlog_init init success INFO: BL3-1: Preparing for EL3 exit to normal world INFO: BL3-1: Next image address = 0x20100000 INFO: BL3-1: Next image spsr = 0x1d3 INFO: BIN1_32bit mode May 29 2020 12:16:48 INFO: R1 0 INFO: R2 0 INFO: R3 0 ree_entry cum MTK_LDR U[LDR_SysInit][301]Hardware Initialization [LDR_SysInit][303]MsOS Initialization LIBCODE:Utopia LIBVER:2.1533808479 BUILDHASH:1d48c21 BUILDDATE:2018080917 [LDR_SysInit][305]MIU Initialization [Utopia][MIU]: [MIU INFO] miu open create instance at p with private size 545791024 bytes at p [LDR_SysInit][308]MMIO Initialization [LDR_SysInit][310]SEM Initialization [LDR_SysInit][314]SYS Initialization [Utopia][SYS]: Function = SYSOpen, Line = 1649, current resource pri_shm content is: 0 [Utopia][SYS]: Function = SYSOpen, Line = 1668, [SYS INFO] OPEN INSTANCE... create instance at p with private size 545791248 bytes at p [LDR_SysInit][317]Enable Interrupt [LDR_SysInit][321]Start Timer [SetMiu][271]CONFIG_MIU0_GROUP_PRIORITY = 1:0:2:3 [SetMiu][272]CONFIG_MIU1_GROUP_PRIORITY = 1:0:2:3 [SetMiu][273]CONFIG_MIU0_GROUP_SELMIU = 1004:0024:0000:0000:005F:0000 [SetMiu][274]CONFIG_MIU1_GROUP_SELMIU = 4F6A:3FD1:0000:0000:0000:FEEF [MDrv_MIU_SetGroupPriority_UBoot][274]IN Change miu0 group priority:e1 [MDrv_MIU_SetGroupPriority_UBoot][309]OK [MDrv_MIU_SetGroupPriority_UBoot][274]IN Change miu1 group priority:e1 [MDrv_MIU_SetGroupPriority_UBoot][309]OK [MDrv_MIU_SelectMIU_UBoot][320]IN [MDrv_MIU_SelectMIU_UBoot][323]OK [MDrv_MIU_SelectMIU_UBoot][320]IN [MDrv_MIU_SelectMIU_UBoot][323]OK [LDR_SysInit][327]Initialize BDMA create instance at p with private size 545791440 bytes at p [LDR_SysInit][335]Initialize eMMC eMMC: HS400 200MHz eMMC 7.28 GB [E8FFF8h] [LDR_SysInit][351]Hardware Initialization Completed [CALDR_Entry][102]Hello CALDR_Entry-Begin MTKLoader v19: 20190107 Do USB upgrade ... [EHCI] ehci init++ [EHCI] bus base miu0: 0x0, miu1: 0x80000000 [EHCI] qh_buf: 0x20519080(0x60519080) qh size: 64 [EHCI] qtd_buf: 0x2051b080(0x6051b080), qtd size: 32 [EHCI] ehci 0 init++ [EHCI] controller: 0x20892280 ehc_base: 0x1f204800, utmi_base: 0x1f207500, usbc_base: 0x1f200e00 [USB] config miu select [70] [f8] [ef] ][ef] [USB] enable miu lower bound address subtraction [USB] init squelch level 0x2 [EHCI] ehci 0 init-- [EHCI] ehci 1 init++ [EHCI] controller: 0x208a28e0 ehc_base: 0x1f201a00, utmi_base: 0x1f207400, usbc_base: 0x1f200f00 [USB] config miu select [70] [f8] [ef] ][ef] [USB] enable miu lower bound address subtraction [USB] init squelch level 0x2 [EHCI] ehci 1 init-- [EHCI] ehci 2 init++ [EHCI] controller: 0x208b2f40 ehc_base: 0x1f227200, utmi_base: 0x1f221d00, usbc_base: 0x1f227000 [USB] config miu select [70] [f8] [ef] ][ef] [USB] enable miu lower bound address subtraction [USB] init squelch level 0x2 [EHCI] ehci 2 init-- [EHCI] ehci init-- Musb3_init OK ++ [yl] usb_poll for controller: 0x208b2f40 [yl] usb_poll loop:0, controller->devices[0]:0x208b31b0 [EHCI] ehci 2 root portsc: 0x803 highspeed device * found device (0x0bda:0xd723, USB 2.0, MPS0: 64) device has 1 configurations device has 3 interfaces NOTICE: Your device has multiple interfaces and this driver will only use the first one. That may be the wrong choice and cause the device to not work correctly. Please report this case (including the above debugging output) to coreboot@coreboot.org to have the device added to the list of well-known quirks. Interface 0: class 0xe0, sub 0x1. proto 0x1 Class: unsupported class ef usb set_address ok;device address := 1 Detaching device not used by payload [yl] usb_poll for controller: 0x208a28e0 [yl] usb_poll loop:0, controller->devices[0]:0x208a2b50 [yl] usb_poll for controller: 0x20892280 [yl] usb_poll loop:0, controller->devices[0]:0x208924f0 No USB device on U3 port. No EMMC OAD flag. No USB or eMMC medium to mount ! USB/EMMC upgrade stop ! [Jump2Uboot][146]Jump2Uboot-Begin ** part_emmc_read_ddb: SKIP Driver Descript Block check [disable_cache][131]Disable Cache [LDR_JumpToApp][160]Jump To 0x28400000 Relocation Offset is: 01A00000 [AT][MB][start ub][1820] U-Boot 2011.06-00000-gccc6dd7-dirty (Dec 18 2020 - 23:39:45) [Mboot] ===== sw IR Config Register ===== [Mboot] ===== Attach IR Interrupt ====== [Utopia][SYS]: Function = SYSOpen, Line = 1655, current resource pri_shm content is: 0 [Utopia][SYS]: Function = SYSOpen, Line = 1674, [SYS INFO] OPEN INSTANCE... create instance at 28FF9360 with private size 108 bytes at 28FF93B0 [Utopia][MIU]: [MIU INFO] miu opencreate instance at 28FF9420 with private size 156 bytes at 28FF9470 [Utopia][MIU]: [MDrv_MIU_SetIOMapBase][188][Utopia][MIU]: Get IOMap MS_MODULE_EXTRIU failurecreate instance at 28FF9510 with private size 60 bytes at 28FF9560 uboot held at [28DDDF60~2A800000],size=01A220A0 Uboot Relocation: 168 MiB Now running in RAM - U-Boot at: 29E00000 eMMC: HS400 200MHz eMMC 7.28 GB eMMC: used life: 0~10% CID:0x008863F4 0x07A60652 0x34465447 0x38000115 -STR mode: 1 x 512MB 0x8709 UART_115200 AC_ON 2L-SM-20170623 U03 MIU1_DQS-OK BIST0-OK BIST1-OK optee teeloader entry CusConfig eMMC_RPMB_Check_Program_Key *ree_opt=0000003B Auth reeloader... Decrypt reeloader... Version check on reeloader... Auth CKB... Decrypt CKB... reeloader_addr=20100000 NOTICE: BL3-1: v1.1(debug):68fd0926 NOTICE: BL3-1: Built : 12:16:51, May 29 2020 INFO: warmboot return address : 3e201c00 INFO: BL3-1: Initializing runtime services NOTICE: From args : boot_mbx = 20028044 INFO: [Booting] mstar_send_magic_ATF 460 INFO: BL3-1: Initializing BL3-2 [Ramlog] ramlog_init init success INFO: BL3-1: Preparing for EL3 exit to normal world INFO: BL3-1: Next image address = 0x20100000 INFO: BL3-1: Next image spsr = 0x1d3 INFO: BIN1_32bit mode May 29 2020 12:16:48 INFO: R1 0 INFO: R2 0 INFO: R3 0 ree_entry cum MTK_LDR U[LDR_SysInit][301]Hardware Initialization [LDR_SysInit][303]MsOS Initialization LIBCODE:Utopia LIBVER:2.1533808479 BUILDHASH:1d48c21 BUILDDATE:2018080917 [LDR_SysInit][305]MIU Initialization [Utopia][MIU]: [MIU INFO] miu open create instance at p with private size 545791024 bytes at p [LDR_SysInit][308]MMIO Initialization [LDR_SysInit][310]SEM Initialization [LDR_SysInit][314]SYS Initialization [Utopia][SYS]: Function = SYSOpen, Line = 1649, current resource pri_shm content is: 0 [Utopia][SYS]: Function = SYSOpen, Line = 1668, [SYS INFO] OPEN INSTANCE... create instance at p with private size 545791248 bytes at p [LDR_SysInit][317]Enable Interrupt [LDR_SysInit][321]Start Timer [SetMiu][271]CONFIG_MIU0_GROUP_PRIORITY = 1:0:2:3 [SetMiu][272]CONFIG_MIU1_GROUP_PRIORITY = 1:0:2:3 [SetMiu][273]CONFIG_MIU0_GROUP_SELMIU = 1004:0024:0000:0000:005F:0000 [SetMiu][274]CONFIG_MIU1_GROUP_SELMIU = 4F6A:3FD1:0000:0000:0000:FEEF [MDrv_MIU_SetGroupPriority_UBoot][274]IN Change miu0 group priority:e1 [MDrv_MIU_SetGroupPriority_UBoot][309]OK [MDrv_MIU_SetGroupPriority_UBoot][274]IN Change miu1 group priority:e1 [MDrv_MIU_SetGroupPriority_UBoot][309]OK [MDrv_MIU_SelectMIU_UBoot][320]IN [MDrv_MIU_SelectMIU_UBoot][323]OK [MDrv_MIU_SelectMIU_UBoot][320]IN [MDrv_MIU_SelectMIU_UBoot][323]OK [LDR_SysInit][327]Initialize BDMA create instance at p with private size 545791440 bytes at p [LDR_SysInit][335]Initialize eMMC eMMC: HS400 200MHz eMMC 7.28 GB [E8FFF8h] [LDR_SysInit][351]Hardware Initialization Completed [CALDR_Entry][102]Hello CALDR_Entry-Begin MTKLoader v19: 20190107 Do USB upgrade ... [EHCI] ehci init++ [EHCI] bus base miu0: 0x0, miu1: 0x80000000 [EHCI] qh_buf: 0x20519080(0x60519080) qh size: 64 [EHCI] qtd_buf: 0x2051b080(0x6051b080), qtd size: 32 [EHCI] ehci 0 init++ [EHCI] controller: 0x20892280 ehc_base: 0x1f204800, utmi_base: 0x1f207500, usbc_base: 0x1f200e00 [USB] config miu select [70] [f8] [ef] ][ef] [USB] enable miu lower bound address subtraction [USB] init squelch level 0x2 [EHCI] ehci 0 init-- [EHCI] ehci 1 init++ [EHCI] controller: 0x208a28e0 ehc_base: 0x1f201a00, utmi_base: 0x1f207400, usbc_base: 0x1f200f00 [USB] config miu select [70] [f8] [ef] ][ef] [USB] enable miu lower bound address subtraction [USB] init squelch level 0x2 [EHCI] ehci 1 init-- [EHCI] ehci 2 init++ [EHCI] controller: 0x208b2f40 ehc_base: 0x1f227200, utmi_base: 0x1f221d00, usbc_base: 0x1f227000 [USB] config miu select [70] [f8] [ef] ][ef] [USB] enable miu lower bound address subtraction [USB] init squelch level 0x2 [EHCI] ehci 2 init-- [EHCI] ehci init-- Musb3_init OK ++ [yl] usb_poll for controller: 0x208b2f40 [yl] usb_poll loop:0, controller->devices[0]:0x208b31b0 [EHCI] ehci 2 root portsc: 0x803 highspeed device * found device (0x0bda:0xd723, USB 2.0, MPS0: 64) device has 1 configurations device has 3 interfaces NOTICE: Your device has multiple interfaces and this driver will only use the first one. That may be the wrong choice and cause the device to not work correctly. Please report this case (including the above debugging output) to coreboot@coreboot.org to have the device added to the list of well-known quirks. Interface 0: class 0xe0, sub 0x1. proto 0x1 Class: unsupported class ef usb set_address ok;device address := 1 Detaching device not used by payload [yl] usb_poll for controller: 0x208a28e0 [yl] usb_poll loop:0, controller->devices[0]:0x208a2b50 [yl] usb_poll for controller: 0x20892280 [yl] usb_poll loop:0, controller->devices[0]:0x208924f0 No USB device on U3 port. No EMMC OAD flag. No USB or eMMC medium to mount ! USB/EMMC upgrade stop ! [Jump2Uboot][146]Jump2Uboot-Begin ** part_emmc_read_ddb: SKIP Driver Descript Block check [disable_cache][131]Disable Cache [LDR_JumpToApp][160]Jump To 0x28400000 Relocation Offset is: 01A00000 [AT][MB][start ub][1820] U-Boot 2011.06-00000-gccc6dd7-dirty (Dec 18 2020 - 23:39:45) [Mboot] ===== sw IR Config Register ===== [Mboot] ===== Attach IR Interrupt ====== [Utopia][SYS]: Function = SYSOpen, Line = 1655, current resource pri_shm content is: 0 [Utopia][SYS]: Function = SYSOpen, Line = 1674, [SYS INFO] OPEN INSTANCE... create instance at 28FF9360 with private size 108 bytes at 28FF93B0 [Utopia][MIU]: [MIU INFO] miu opencreate instance at 28FF9420 with private size 156 bytes at 28FF9470 [Utopia][MIU]: [MDrv_MIU_SetIOMapBase][188][Utopia][MIU]: Get IOMap MS_MODULE_EXTRIU failurecreate instance at 28FF9510 with private size 60 bytes at 28FF9560 uboot held at [28DDDF60~2A800000],size=01A220A0 Uboot Relocation: 168 MiB Now running in RAM - U-Boot at: 29E00000 eMMC: HS400 200MHz eMMC 7.28 GB eMMC: used life: 0~10% CID:0x008863F4 0x07A60652 0x34465447 0x38000115 -UART_115200 x 512MB AC_ON 2L-SM-20170623 U03 MIU1_DQS-OK BIST0-OK BIST1-OK optee teeloader entry CusConfig eMMC_RPMB_Check_Program_Key *ree_opt=0000003B Auth reeloader... Decrypt reeloader... Version check on reeloader... Auth CKB... Decrypt CKB... reeloader_addr=20100000 NOTICE: BL3-1: v1.1(debug):68fd0926 NOTICE: BL3-1: Built : 12:16:51, May 29 2020 INFO: warmboot return address : 3e201c00 INFO: BL3-1: Initializing runtime services NOTICE: From args : boot_mbx = 20028044 INFO: [Booting] mstar_send_magic_ATF 460 INFO: BL3-1: Initializing BL3-2 [Ramlog] ramlog_init init success INFO: BL3-1: Preparing for EL3 exit to normal world INFO: BL3-1: Next image address = 0x20100000 INFO: BL3-1: Next image spsr = 0x1d3 INFO: BIN1_32bit mode May 29 2020 12:16:48 INFO: R1 0 INFO: R2 0 INFO: R3 0 ree_entry cum MTK_LDR U[LDR_SysInit][301]Hardware Initialization [LDR_SysInit][303]MsOS Initialization LIBCODE:Utopia LIBVER:2.1533808479 BUILDHASH:1d48c21 BUILDDATE:2018080917 [LDR_SysInit][305]MIU Initialization [Utopia][MIU]: [MIU INFO] miu open create instance at p with private size 545791024 bytes at p [LDR_SysInit][308]MMIO Initialization [LDR_SysInit][310]SEM Initialization [LDR_SysInit][314]SYS Initialization [Utopia][SYS]: Function = SYSOpen, Line = 1649, current resource pri_shm content is: 0 [Utopia][SYS]: Function = SYSOpen, Line = 1668, [SYS INFO] OPEN INSTANCE... create instance at p with private size 545791248 bytes at p [LDR_SysInit][317]Enable Interrupt [LDR_SysInit][321]Start Timer [SetMiu][271]CONFIG_MIU0_GROUP_PRIORITY = 1:0:2:3 [SetMiu][272]CONFIG_MIU1_GROUP_PRIORITY = 1:0:2:3 [SetMiu][273]CONFIG_MIU0_GROUP_SELMIU = 1004:0024:0000:0000:005F:0000 [SetMiu][274]CONFIG_MIU1_GROUP_SELMIU = 4F6A:3FD1:0000:0000:0000:FEEF [MDrv_MIU_SetGroupPriority_UBoot][274]IN Change miu0 group priority:e1 [MDrv_MIU_SetGroupPriority_UBoot][309]OK [MDrv_MIU_SetGroupPriority_UBoot][274]IN Change miu1 group priority:e1 [MDrv_MIU_SetGroupPriority_UBoot][309]OK [MDrv_MIU_SelectMIU_UBoot][320]IN [MDrv_MIU_SelectMIU_UBoot][323]OK [MDrv_MIU_SelectMIU_UBoot][320]IN [MDrv_MIU_SelectMIU_UBoot][323]OK [LDR_SysInit][327]Initialize BDMA create instance at p with private size 545791440 bytes at p [LDR_SysInit][335]Initialize eMMC eMMC: HS400 200MHz eMMC 7.28 GB [E8FFF8h] [LDR_SysInit][351]Hardware Initialization Completed [CALDR_Entry][102]Hello CALDR_Entry-Begin MTKLoader v19: 20190107 Do USB upgrade ... [EHCI] ehci init++ [EHCI] bus base miu0: 0x0, miu1: 0x80000000 [EHCI] qh_buf: 0x20519080(0x60519080) qh size: 64 [EHCI] qtd_buf: 0x2051b080(0x6051b080), qtd size: 32 [EHCI] ehci 0 init++ [EHCI] controller: 0x20892280 ehc_base: 0x1f204800, utmi_base: 0x1f207500, usbc_base: 0x1f200e00 [USB] config miu select [70] [f8] [ef] ][ef] [USB] enable miu lower bound address subtraction [USB] init squelch level 0x2 [EHCI] ehci 0 init-- [EHCI] ehci 1 init++ [EHCI] controller: 0x208a28e0 ehc_base: 0x1f201a00, utmi_base: 0x1f207400, usbc_base: 0x1f200f00 [USB] config miu select [70] [f8] [ef] ][ef] [USB] enable miu lower bound address subtraction [USB] init squelch level 0x2 [EHCI] ehci 1 init-- [EHCI] ehci 2 init++ [EHCI] controller: 0x208b2f40 ehc_base: 0x1f227200, utmi_base: 0x1f221d00, usbc_base: 0x1f227000 [USB] config miu select [70] [f8] [ef] ][ef] [USB] enable miu lower bound address subtraction [USB] init squelch level 0x2 [EHCI] ehci 2 init-- [EHCI] ehci init-- Musb3_init OK ++ [yl] usb_poll for controller: 0x208b2f40 [yl] usb_poll loop:0, controller->devices[0]:0x208b31b0 [EHCI] ehci 2 root portsc: 0x803 highspeed device * found device (0x0bda:0xd723, USB 2.0, MPS0: 64) device has 1 configurations device has 3 interfaces NOTICE: Your device has multiple interfaces and this driver will only use the first one. That may be the wrong choice and cause the device to not work correctly. Please report this case (including the above debugging output) to coreboot@coreboot.org to have the device added to the list of well-known quirks. Interface 0: class 0xe0, sub 0x1. proto 0x1 Class: unsupported class ef usb set_address ok;device address := 1 Detaching device not used by payload [yl] usb_poll for controller: 0x208a28e0 [yl] usb_poll loop:0, controller->devices[0]:0x208a2b50 [yl] usb_poll for controller: 0x20892280 [yl] usb_poll loop:0, controller->devices[0]:0x208924f0 No USB device on U3 port. No EMMC OAD flag. No USB or eMMC medium to mount ! USB/EMMC upgrade stop ! [Jump2Uboot][146]Jump2Uboot-Begin ** part_emmc_read_ddb: SKIP Driver Descript Block check [disable_cache][131]Disable Cache [LDR_JumpToApp][160]Jump To 0x28400000 Relocation Offset is: 01A00000 [AT][MB][start ub][1750] U-Boot 2011.06-00000-gccc6dd7-dirty (Dec 18 2020 - 23:39:45) [Mboot] ===== sw IR Config Register ===== [Mboot] ===== Attach IR Interrupt ====== [Utopia][SYS]: Function = SYSOpen, Line = 1655, current resource pri_shm content is: 0 [Utopia][SYS]: Function = SYSOpen, Line = 1674, [SYS INFO] OPEN INSTANCE... create instance at 28FF9360 with private size 108 bytes at 28FF93B0 [Utopia][MIU]: [MIU INFO] miu opencreate instance at 28FF9420 with private size 156 bytes at 28FF9470 [Utopia][MIU]: [MDrv_MIU_SetIOMapBase][188][Utopia][MIU]: Get IOMap MS_MODULE_EXTRIU failurecreate instance at 28FF9510 with private size 60 bytes at 28FF9560 uboot held at [28DDDF60~2A800000],size=01A220A0 Uboot Relocation: 168 MiB Now running in RAM - U-Boot at: 29E00000 eMMC: HS400 200MHz eMMC 7.28 GB eMMC: used life: 0~10% CID:0x008863F4 0x07A60652 0x34465447 0x38000115 -STR mode: 1 x 512MB 0x8709 Power Down Вот новый лог с моими попытками обновлениями по usb/ Может что то не так делаю? флешка usb 2 гб, пробовал как в fat, fat32 и ntfs . Вставил в верхний порт usb. Изменено 23 марта, 2024 пользователем sus256
sus256 Опубликовано 23 марта, 2024 Автор Опубликовано 23 марта, 2024 (изменено) Я уже пробую несколько обновлений 1. CtvUpgrade.bin От тв Hyundai H-LED24GS5101 CV6681H-K24 PT236AT02 2. CtvUpgrade.bin CtvUpgrade_10045903_order_id.bin mboot.bin MD5.txt rom_emmc_boot.bin От тв Liberton 24TP1HDTA1 CV6681-K24 PT236AT02-4 3. CtvUpgrade.bin mboot.bin rom_emmc_boot.bin От тв HARTENS_317_HTY-24HDR06B Как то так Иесли просто подготовить флешку в формате ntfs то получаю No USB device on U3 port. Изменено 23 марта, 2024 пользователем sus256
banned Опубликовано 23 марта, 2024 Опубликовано 23 марта, 2024 sus256 как не посмотрю , что не ремонт у тебя так сразу "шить"!!! А тестер main подключить , reset сделать .. не судьба изначально . 1
sus256 Опубликовано 23 марта, 2024 Автор Опубликовано 23 марта, 2024 3 минуты назад, makar.i сказал: sus256 как не посмотрю , что не ремонт у тебя так сразу "шить"!!! А тестер main подключить , reset сделать .. не судьба изначально . Извините, какой тестер ?
banned Опубликовано 23 марта, 2024 Опубликовано 23 марта, 2024 питание на матрас подай , подсветку зажги ...
sus256 Опубликовано 23 марта, 2024 Автор Опубликовано 23 марта, 2024 Если вы про тв160 такой у меня отсутствует , правильно ли я понимаю что без сигналов лвдс матрица будет входить в тестовый режим?
banned Опубликовано 23 марта, 2024 Опубликовано 23 марта, 2024 27 минут назад, makar.i сказал: питание на матрас подай , подсветку зажги ... 1
LiVan Опубликовано 23 марта, 2024 Опубликовано 23 марта, 2024 @sus256 не нужно отвечать на вопрос своим вопросом. Если вам нужна помощь, внимательно читайте что у вас спрошивают и пишите подробно в своем ответе! KenotronTV 🛠 Contact ✉ Мы здесь, чтобы ответить на ваши вопросы! Задавайте вопросы и получайте быстрые ответы. Остаемся на связи! Переходим в MAX Подписывайтесь и оставайтесь на связи!
verniy68 Опубликовано 23 марта, 2024 Опубликовано 23 марта, 2024 1 час назад, sus256 сказал: правильно ли я понимаю что без сигналов лвдс матрица будет входить в тестовый режим? как ты думаешь , для чего я тебе это писал: 19 часов назад, verniy68 сказал: сигналы lvds осцилом смотрел? 1
rav2023 Опубликовано 23 марта, 2024 Опубликовано 23 марта, 2024 (изменено) SUS256 прошивка по USB происходит при предварительном полном форматировании eFAT или FAT32 !!! Объем флешки 4-8 г лучше брать.Возможно что твой дефект связан с тем что кто-то влез в Сервисное меню и запустил тест матрицыAGING MODE .Решить проблему можно 1 прошивкой оригинальной ее нет у тебя.. и 2 это нажатием кнопки POWER на самом тв-может и прокатит . (выключаем) Затем пробуешь включить с ПДУ . Это я к тому что это должны быть твои первые действия,делел это? Если да, то verniy68 написал что делать далее. Изменено 23 марта, 2024 пользователем rav2023 1
rav2023 Опубликовано 23 марта, 2024 Опубликовано 23 марта, 2024 39 минут назад, verniy68 сказал: как ты думаешь , для чего я тебе это писал: такое поведение возможно из-за того что до матрицы не доходят сигналы со скаллера. 2
rav2023 Опубликовано 23 марта, 2024 Опубликовано 23 марта, 2024 5 часов назад, sus256 сказал: Это скрытый контент, для просмотра сообщения Вы должны быть Участником форума. Войти или Регистрация снял плату, положил на стол и что то по usb не одно обновление накатить не получается Так от чего дамп этот ???? Модель Бренд???
