Yandex YNDX-00071 - не включается.
Доброго всем!
На ремонте тв от Яндекса
Модель: Yandex YNDX-00071
Шасси: CV9632-N55 EL.MT9632R-FG95
Панель: CX430DLEDM
Напряжения : 12в 1,8в 1,5в 1,17в 3,3в и 0,96в есть.
Терминальный лог показывает , подскажите дамп поврежден или хана ОЗУ части проца? Обновлений по usb на эту модель не нашел :=(
AC_ON
01-2L-SM-01-20190815
MIU0_DQS-OK
BIST0-OK
optee teeloader entry
CusConfig
eMMC_RPMB_Check_Program_Key
*ree_opt=0000007B
Auth reeloader...
Decrypt reeloader...
Version check on reeloader...
Auth CKB...
Decrypt CKB...
reeloader_addr=20100000
NOTICE:  BL3-1: v1.1(debug):3535a023
NOTICE:  BL3-1: Built : 12:20:08, May 29 2020
INFO:    warmboot return address : 7e1c1c00
INFO:    BL3-1: Initializing runtime services
NOTICE:  From args : boot_mbx = 2002808c
INFO:     [Booting] mstar_send_magic_ATF 479
INFO:    BL3-1: Initializing BL3-2
[Ramlog] ramlog_init init success
INFO:    BL3-1: Preparing for EL3 exit to normal world
INFO:    BL3-1: Next image address = 0x20100000
INFO:    BL3-1: Next image spsr = 0x1d3
INFO:    BIN1_32bit mode May 29 2020 12:20:07
INFO:    R1 0
INFO:    R2 0
INFO:    R3 0
ree_entry
         U
Relocation Offset is: 01900000
[AT][MB][start ub][556]
U-Boot 2011.06-00000-g8bf47bf-dirty (Apr 10 2024 - 12:04:40)
[Mboot] ===== sw IR Config Register =====
[Mboot] ===== Attach IR Interrupt  ======
[Utopia][SYS]: Function = SYSOpen, Line = 3585, current resource pri_shm content is: 0
[Utopia][SYS]: Function = SYSOpen, Line = 3604, [SYS INFO] OPEN INSTANCE...
create instance at 286F1868 with private size 108 bytes at 286F18B8
[Utopia][MIU]: [MIU INFO] miu opencreate instance at 286F1928 with private size 168 bytes at 286F1978
create instance at 286F1A28 with private size 60 bytes at 286F1A78
uboot held at [284DDF60~29800000],size=013220A0
Uboot Relocation:  152 MiB
Now running in RAM - U-Boot at: 28D00000
eMMC: HS400 5.1 200MHz
eMMC 14.55 GB
eMMC: used life: 0~10%
CID:0x00C89A4C
0xE2BF0652
0x3444544A
0x41000115
▒RAM : 1536MB
Пробовал залить дамп ЕММС другой
Лог:
AC_ON
MIU0_DQS-OK
BIST0-OK
CusConfig
*ree_opt=0000007B
Auth reeloader...
Auth CKB...
Try MBOOTBAK
MBOOT part not found!
ns_uboot_load_CKB failed!
Че то не пошел , если у кого есть дамп на данную модель скиньте ссылку пожалуйста.
MBOOT раздел пробовал перекидввать , получид лог как в 1 ом посте
@sus256 , где диагностика неисправности? - в принципе как и сама неисправность - "не включается" - понятие растяжимое , тем-более ты пишешь:
12 часов назад, sus256 сказал:
кстати , это не все напряжения...
Так в чём неисправность? Как ведёт себя индикатор ДР/РР? HDMI и USB на кз проверялись? Какие сигналы есть/нет? Подсветка?
...либо ты далёк от вопросов ремонта , либо ждёшь "у моря погоды"
Дамп родной сохранил?
1 час назад, sus256 сказал:
ссылку на ресурс в тему показывай!
Какая EmmC установлена?
CX430DLEDM
Это LCD-модуль!
Указывать нужно стекло - наклейка на планках!
В тему добавляй фотографии!
Есть в свободном доступе!
у кого есть дамп EmmC на данную модель
Оформляй согласно Правил и дополняй тему :excl: ((что нужно - я указал...
...а пока тему в"Корзину"
Приведёшь её в порядок - подниму в раздел
