banned Опубликовано 21 июня, 2024 Опубликовано 21 июня, 2024 KIVI 40FR52BR шасси HK.T.RT2831P639 ищу проверенный дамп eMMC H26M41204 Это скрытый контент, для просмотра сообщения Вы должны быть Участником форума. Войти или Регистрация
banned Опубликовано 21 июня, 2024 Автор Опубликовано 21 июня, 2024 (изменено) Спойлер USB VCC: Chip VCC = 3,29 LibUSB ver 1.2.6.0 FileVersion = 0.2.21.35 Using: 1bit bus Fast timing (16MHz) Use Fixed Block operation Using Ignore Errors eMMC OCR 0xC0FF8080 after 3 attempts CMD1 Get Response Error! eMMC (0) CID = 90014A483847346192A10F35BCB246 (77) CMD2 Get Response Error! Found 1 eMMC device(s) eMMC CSD = D02701320F5903FFFFFFFFE78A4000 eMMC Status: 00000700 CURRENT_STATE = Stby eMMC: Version 4.xx eMMC: Maximum speed 26,00 MHz eMMC: Read Block Length 512 byte eMMC: Write Block Length 512 byte eMMC: Card High Capacity eMMC: CSD User Partition Size = 1073741824 Byte eMMC: WP Status True eMMC: WP Size 8 erase groups eMMC: Permanent WP is False eMMC: Temorary WP is False Data0 Line is Valid Data1 Line is Invalid Data2 Line is Invalid Data3 Line is Invalid Data4 Line is Invalid Data5 Line is Invalid Data6 Line is Invalid Data7 Line is Invalid Valid mode SDR 1 bit SET: Using HS Timing e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eMMC: DRIVER_STRENGTH 1F EXTCSD: Device support 4K sector EXTCSD: Current sector size 512 byte EXTCSD: Device support HS SDR 26MHz EXTCSD: Device support HS SDR 52MHz EXTCSD: Device support HS DDR 52MHz 1.8V EXTCSD: Device support HS200 SDR 1.8V EXTCSD: Device support HS400 DDR 1.8V EXTCSD: EXT_CSD RST_n временно отключен EXTCSD: ACC Size = 16384 byte eMMC: EXT_CSD User Partition Size = 7818182656 Byte eMMC: Version 5.1 FFU SUPPORTED MODES = 0x1 FFU FEATURES = 0x0 FFU OPERATION CODE TIMEOUT = 0x0 FFU OPERATION CODE TIMEOUT = 0x0 FFU ARGUMENTS = 0xFFF0FFFA FFU NUMBER OF FW SECTORS CORRECTLY PROGRAMMED = 0x0 OPTIMAL_READ_SIZE = 0x40 OPTIMAL_WRITE_SIZE = 0x40 DEVICE VERSION = 56.5 FIRMWARE_VERSION = 1610000000 EXTCSD: FW CONFIG = 0x0 EXTCSD: PARTITION CONFIG = 0x0 EXTCSD: BOOT BUS WIDTH = 0x0 Загрузка с еММС не используется x1 (sdr) или x4 (ddr) используется при загрузке EXTCSD: Device support partitioning features EXTCSD: Device support enhanced technological features EXTCSD: Device support extended partitions attribute eMMC: Erase Group Size = 512 KByte (1024 blocks) eMMC: Boot partition size 4194304 byte eMMC: RPMB partition size 4194304 byte RPMB: Use correct key to read/write! (25) eMMC MID = 0x0090, OEM ID = 0x4A01 eMMC Product Name = H8G4a eMMC Serial number = 0xF35BCB2 eMMC Revision = 10.1 eMMC Date 4/2003 ----- eMMC 5.0 Health info ----- -> Pre EOL value = 1 Pre EOL -NORMAL- status -> Life Time SLC value = 1 0- 10% device life time used -> Life Time MLC value = 11 Exceeded its maximum estimated device life time! Number of runtime bad blocks for 0CE = 0 Number of factory bad blocks for 0CE = 0 Number of runtime bad blocks for 1CE = 0 Number of factory bad blocks for 1CE = 0 Number of runtime bad blocks for 2CE = 0 Number of factory bad blocks for 2CE = 0 Number of runtime bad blocks for 3CE = 0 Number of factory bad blocks for 3CE = 0 Вычитал. Изменено 21 июня, 2024 пользователем makar.i
Решение ильшат Опубликовано 21 июня, 2024 Решение Опубликовано 21 июня, 2024 Kivi 40FR52BR HK.T.RT2831P639 V400HJ6-PE1 H26M41204HPR EMMC Это скрытый контент, для просмотра сообщения Вы должны быть Участником форума. Войти или Регистрация 1
