ARTEL UA43H3502 - не включается
Доброго всем!
На ремонте апарат:
Модель ARTEL UA43H3502
Шасси TD.RT2851M.783 (N)
EMMC FEMDRM016G-58A43
Не включается, не загорается индикатор
Напряжения 3,3в 1,8в 1,5в 1в, 12в, 5в - присутствуют.
Обновления по usb не берет.
Терминальный лог.
Hello world, 288o!{uni}[WEI][arm64]
svn:44fc8d7c27afdb5b (Jun 20 2022 18:56:10)
flash_type = 2, secure_type = 2
b8062204=0
slot info 0 0x0 info 1 0x0
invalid reg slot status 0x0,get slot info from flash!
g_gpt_blk_start 0x1  g_offline_gpt 0x0 last_usable_lba 0x1d28ff3 num_partition_entries 0x29
start 0x52ef7e00 clt_blk 0x1a977c3 ctrl size 0x20
index 0 priority=7, tries_remaining=7, successful_boot=1, verity_corrupted=0
index 1 priority=7, tries_remaining=7, successful_boot=0, verity_corrupted=0
choose active index 0
part name bootloader ative_slot _a real part name bootloader_a
part name hwsetting start 0x100000 size 0xa200
part name ext_fw start 0x10a200 size 0x4400
part name kboot start 0x10e600 size 0xe400
part name uboot start 0x11ca00 size 0xc8400
flash offset = 82d
ASCPU BISR: Done[go kb]
pass bootcode info to kbo▒[ERR] Verify_Head_Img_SHA256_hash: hash value not match header size 0x0 len 0xc8300
[ERR] kboot_read_uboot_from_eMMC: verify uboot hash fail
kboot_read_uboot_from_eMMC 342 uboot error 0xab,watch dog reset!
b8062204=20100
slot info 0 0x52336200 info 1 0x52336200
change slot, now active slot is _b change slot 1
part name bootloader ative_slot _b real part name bootloader_b
part name hwsetting start 0x500000 size 0xa200
part name ext_fw start 0x50a200 size 0x4400
part name kboot start 0x50e600 size 0xe400
part name uboot start 0x51ca00 size 0xc8400
flash offset = 282d
b8062204=20200
slot info 0 0x52336101 info 1 0x52336101
boot fail, you change slot again!!!
Лог еммс
OCR 0xC0FF8080 (3V3/1V8)
CID D6010335384134334110AAD4C6A069D9 (Manufacturer 0xD6 58A43A, SN 0xAAD4C6A0 (2866071200), Июн 2022)
CSD D0FFFF329F5903FFFFFFFFE79640001D
Ревизия устройства [192] 0x08 (MMC v5.1)
Тип устройства [196] 0x57 (SDR HS52, HS200, HS400)
Классы команд 0x9F5 (Class 0, 2, 4, 5, 6, 7, 8, 11)
Скорость обмена 0x32 (26МГц)
Информация о конце жизни 0x01 (Норма)
Время жизни памяти типа A 0x01 (0-10% использовано)
Время жизни памяти типа B 0x00 (Не определено)
Функция Reset [162] 0x00 (Временно выключен (по умолчанию))
Конфигурация загрузки [179] 0x00 (Нет загрузки, access to USER)
Шина загрузки [177] 0x00 (1-Bit SDR, Reset to 1-Bit)
Поддержка разделов [160] 0x07 (Yes, ENH, EXT)
Разделы завершены [155] 0x01 (Yes)
FFU режим [443] 0x03 (Поддерживается, VSM)
USER раздел, размер 0x03A5200000 (14.58 ГиБ)
BOOT1 раздел, размер 0x0000400000 (4 МиБ)
BOOT2 раздел, размер 0x0000400000 (4 МиБ)
RPMB раздел, размер 0x0000400000 (4 МиБ) Счетчик 279 (0x117)
Пробовал заливать прошивку вот от
, терминальный лог тот же, без изменений.
Слегка подул на проц, RTD2851MCA, лог изменился, даже увидел картинку висящую на заставке.
b8062204=0
flash offset = 82d
pass bootcode info to kbo▒part name:FW_TZFW active_slot:_a 2 real part name:FW_TZFW_a
verify image len 0xcfc38 OK!
part name:FW_AKERNEL active_slot:_a 2 real part name:FW_AKERNEL_a
verify image len 0x297f68 OK!
part name:FW_VKERNEL active_slot:_a 2 real part name:FW_VKERNEL_a
verify image len 0x4f18f8 OK!
ATF:0 1 NOTICE:  SCPU BISR status: bypass
U
▒▒▒▒zzCqpyyyyq
h▒▒▒▒▒zzz▒▒▒` 1 2022 z▒qtzsyzpuI
▒▒▒▒Żp▒p▒zp▒rtpppq
▒▒▒▒▒▒0▒q▒zp▒qpppp▒
▒▒▒▒▒p▒r▒zp▒p
▒▒▒▒▒p▒s▒zp▒0
▒▒▒▒Żp▒t▒zp▒p
▒▒▒▒▒▒0▒u▒zp▒p
▒▒▒▒▒p▒v▒zp▒0
▒▒▒▒Żp▒w▒zp▒p
▒▒▒▒▒p▒8▒:p▒p
▒▒▒▒Żp▒y▒zp▒p
▒▒▒▒▒▒0▒▒zp▒p
▒▒▒▒▒p▒▒▒:0▒0
▒▒▒▒Żp▒ýzp▒p
▒▒▒▒▒p▒▒▒:p▒x
▒▒▒▒▒p▒Žzp▒▒▒qprrpw
▒▒▒▒▒p▒▒zp▒▒p5▒▒▒04
▒▒▒▒Żp▒qp▒zp▒▒▒054▒pp
▒▒▒▒Żp▒qq▒zp▒xp▒w▒00
▒▒▒▒Żp▒1r▒zp▒p
▒▒▒▒Żp▒qs▒zp▒p
▒▒▒▒▒p▒qt▒zp▒p
▒▒▒▒▒p▒qu▒zp▒0
▒▒▒▒▒p▒16▒:0▒s
▒▒▒▒Żp▒qw▒zp▒p
▒▒▒▒Żp▒18▒:0▒0
▒▒▒▒Żp▒19▒:0▒p
▒▒▒▒Żp▒q▒zp▒0
▒▒▒▒Żp▒q▒zp▒p
▒▒▒▒▒▒0▒q▒zp▒p
▒▒▒▒▒▒0▒q▒zp▒tppps▒
▒▒▒▒▒▒0▒q▒zp▒uvtpppqr
▒▒▒▒▒▒0▒qƽzp▒p
jjjj▒▒▒▒▒▒▒ ▒▒▒▒*JJJ
▒qqpp▒}p▒xpppr
▒110▒▒}p▒qprpxppp
PwNum:0x20x0 M
0xa, 0xas
После ребола проца, лог стал прежним, ничего не изменилось.
Прошу помощи по логам, странно что он после прогрева запустился 1 рас и все, и может есть у кого дамп от этого телевизора слитый ufpi?
13 часов назад, sus256 сказал:
Проверь резисторные сборки.
Резисторы проверенны и пропаяны , изменений никаких.
Обвязка еммс какая то минимальная
9 часов назад, verniy68 сказал:
Под микроскопом проверь непропаи
Смотрел глазел, пропаял все вокруг проца и флеш, так и нет у меня нормальной загрузки, кстати сколько бы я не пробовал диагностически нагреть проц, повторно он у меня не разу не загрузился. Заказал плату , как придет сверю сопротивления, обязательно отпишусь.
@sus256
В 03.08.2024 в 18:41, sus256 сказал:
...ошибка uboot 0xab, сброс настроек watch dog!
Как исправить ошибку uboot ( Mediatek - как пример ... у тебя Realtek ) :
А вот где найти такой файлик в дампе от телевизора, смысл попытки понятен, вот только где ее найти. Имею в виду этот чексум в прошивке телевизора
Фото если это твоё в теме, на распине еммс, что резистора по clk не видно.
Снес наверное чего во время ребола
10 часов назад, ильшат сказал:
Фото не мое, но у меня все так же как на фото, я все сверил уже по 3 разу ;)
@sus256 , хорошая тема -
 (( мож поможет...
p/s: ...я не вникал :)
 emmc ((программатор не знаю - не распаковывал
там-же есть по usb...
Попробую осилить, обнова есть но с раширением img я такие не распаковывал
А может кто подскажет где скачать эту чудесную программу rtice ?
12 часов назад, sus256 сказал:
в свободном доступе , при наличии внимательности изучения и умения работать и вытягивать нужный материал из предоставленных ссылок , ну и желания
В 06.08.2024 в 17:19, verniy68 сказал:
хорошая тема -
По данному процу нужна программа rtice под данный проц rt2851 ,пока найти не могу ее. Может у кого есть ссылка на данную программулину?
А так очень много полезного есть вот по этой
Изменено пользователем sus256
Ты на верном пути. Если не найдешь , то вечером скину.
p/s: посмотри , что на скрине в теме на "мониторе" указано(какой программой участник работает- отсюда и пляши :)
@sus256 , подсказываю:
Ты на верном пути.
...только страница седьмая
Полезности изучают с первой страницы
 ...далее
(родную сохраняем)
А не проще-ли с родным дампом поработать?
Да в том то и дело что дамп то скорее всего цел, а вот загрузчк в проце.
Пришла плата , заказанная с авито и по замерам сильно отличаются сопротивления по питанию 3,3в на моей 38 ом, а на рабочей 10ком. Еще есть отличия по сопротивлениям питания 1vcore, что ставит под сомнение исправность процессора.
Европейский форум пока буду изучать , может и удастся что нить с майном сделать, а телевизор победили путем заменой майна.
