Telefunken L55F249N3CW не включается
Main: 17MB98
PSU: 17IPS20
PANEL: VES550UNEL-2D-S01
T-con: 6870-0471D
Аппарат не включается, мигает только синий индикатор
Блок питания находится в рабочем режиме (UСвх.=390В)
На майн присутствует все напряжения:
L100=5,0
L101=3,3
U105=3,3
U132=3,3
L103=1,5
L104=1,28
Короткого нет (R больше 150 Ом везде)
Флешку с прошивкой не подхватывает
Логи считал
BIST1-OK
[23456789AB]369C369C]47ADU[AT][MB][start ub][212]
U-Boot 2011.06 (Jun 18 2015 - 18:37:11)
DRAM:  256 MiB
Hello U-Boot
Stack Pointer at: 8feba340
mem initial, start 0x8e1d0180, len 0x1020000
Flash is detected (0x0507, 0xC2, 0x20, 0x15)
offset 0x0, size 0x10000
initialization done!
uboot held at [8f000000~90000000]
Now running in RAM - U-Boot at: 8f1f0180
msIR_Initialize
[LGPS]: u16LongPulseThr = 07D0
[INTG]: u16IntegrationThr = 0052
[WDOG]: u8WatchDogCount = 0024
NAND:  [NC_ProbeDDRNAND]        SDR NAND is detected
CIS is found @Blk0
FCIE is set to 60MHz
256 MiB
*** Warning - set default for mtdparts, using default environment
Creating 1 MTD partitions on "nand0":
0x000000640000-0x000000a40000 : "mtd=2"
Bad block table found at page 131008, version 0x01
Bad block table found at page 130944, version 0x01
UBI: attaching mtd1 to ubi0
UBI: physical eraseblock size:   131072 bytes (128 KiB)
UBI: logical eraseblock size:    126976 bytes
UBI: smallest flash I/O unit:    2048
UBI: VID header offset:          2048 (aligned 2048)
UBI: data offset:                4096
UBI: attached mtd1 to ubi0
UBI: MTD device name:            "mtd=2"
UBI: MTD device size:            4 MiB
UBI: number of good PEBs:        32
UBI: number of bad PEBs:         0
UBI: max. allowed volumes:       128
UBI: wear-leveling threshold:    250
UBI: number of internal volumes: 1
UBI: number of user volumes:     1
UBI: available PEBs:             1
UBI: total number of reserved PEBs: 31
UBI: number of PEBs reserved for bad PEB handling: 2
UBI: max/mean erase counter: 1278/1271
Volume  not found!
NAND read: device 0 offset 0x1c0000, size 0xa8
 168 bytes read: OK
Volume "MPOOL" found at volume id 0
UBI: mtd1 is detached from ubi0
Volume  not found!
u32EnvRescueOffset = 0x20f000
*** Warning - bad CRC, using default environment
In:    serial
Out:   serial
Err:   serial
Net:   No ethernet found.
 Set MAC default
MAC:  0x0: 0x78: 0x85: 0x0:0x0: 0x1
[CMDFLAG] : get_cmd_flag : 0
msIR_Initialize
uart spi offset = 0x1e1a23, value = 0x0
UART Disabled
IST1-OK
[123456789AD259C358BE369CU[AT][MB][start ub][212]
DRAM:  256 MiB
Hello U-Boot
msIR_Initialize
CIS is found @Blk0
256 MiB
UBI: max/mean erase counter: 1278/1272
Volume  not found!
 168 bytes read: OK
Volume  not found!
In:    serial
Out:   serial
Err:   serial
 Set MAC default
msIR_Initialize
UART Disabled
считал 25L1605 (U120):
Флешку пробовал подключать на оба разъёмы USB: питание на них есть, а сигналов осциллографом не наблюдается
  • ☆ VIP(PERMANENT)
@Alex1101 поделись прошивкой ПО USB
По USB3 идет опрос флешки (мигает led на флешке)
но прошивку не подхватывает
Лог тот же
BIST1-OK
[123456789AD259C358BE369DU[AT][MB][start ub][212]
DRAM:  256 MiB
Hello U-Boot
msIR_Initialize
CIS is found @Blk0
256 MiB
UBI: max/mean erase counter: 1287/1278
Volume  not found!
 168 bytes read: OK
Volume  not found!
In:    serial
Out:   serial
Err:   serial
 Set MAC default
msIR_Initialize
UART Disabled
22 часа назад, Неизвестный сказал:
прошивка с открытых источников (17MB98)
Проверил USB и HDMI порты, короткого не нашёл
По USB2 идёт так же опрос флешки, но дальше ничего
По USB1 флешку не видит
По HDMI2 можно также считать прошивку MX25L1605
  • ☆ VIP(PERMANENT)
@Alex1101 ссылку можно что скачивал, а я посмотрю и сравню с тем что у меня есть (от производителя)
14 часов назад, Alex1101 сказал:
поведение при "чужом" содержимом spi ((привязка spi+nand
был до тебя где?
p/s: другой комплект прошивок + родное usb
Дай фото всех наклеек на майне с обеих сторон
15 часов назад, Alex1101 сказал:
...посредством клавиши "Tab"
1 час назад, verniy68 сказал:
был до тебя где?
Да, апарат вскрывали до меня, но что делали: установить не представляется возможным
На майно только одна наклейка
1 час назад, Неизвестный сказал:
Скинул в ЛС
Только что, Alex1101 сказал:
spi паяная?
Пробовал и так
Реакции не было
(счас буду пробовать ещё)
Но флешка стартует при нажатии Ок на пульте
(есть только первые несколько секунд миганий опроса флешки)
spi паяная?
Нет
@Alex1101 , читал , что прошивки 17MB97 = 17MB98 ((
...лично не проверял
P/S :
 (usb)
@Alex1101 , здесь :
...первый и четвёртый , думаю , оно самое
...третий - поднятие ютуба
 - дисплей
Нашёл другую прошивку для telefunken 65"
(Из четырёх файлов)
Это прописалась и аппарат заработал , но неправильные цвета (несовпадение битности или формата LVDS)
Обновление прошивки через интернет: новое программное обеспечения не найдено
В 10.08.2024 в 12:47, verniy68 сказал:
Это прошло
Теперь осталось найти родную прошивку
В сервисном меню нужных опций не нашел
7 часов назад, Alex1101 сказал:
Nalezen další firmware pro telefunken 65"
(ze čtyř souborů)
Toto bylo zaregistrováno a zařízení fungovalo, ale barvy byly nesprávné (neshoda bitové hloubky nebo formátu LVDS)
панель должна быть отредактирована классически с помощью файла PQ в сервисном меню
8 часов назад, Alex1101 сказал:
Саша , я-ж тебе ссылку по панели дал:
18 часов назад, verniy68 сказал:
 - дисплей
19 минут назад, pavelmuskar сказал:
там всё это указано
Переключение панели на t-con в данном аппарате не принесло результата, сейчас попробую загрузить файл PQ
Нужного кода панели  там нет, знать бы какой мне подойдет
(мой 23315019?)
(мой 23315019?)
думаю нет
наклейку на lcd-module аккуратно поправь
считал профиль тот что сейчас:
Там первые две 28, тоже нет такой
57 минут назад, Alex1101 сказал:
Přepnutí panelu na t-con v tomto zařízení nepřineslo žádné výsledky, nyní zkusím načíst soubor PQ
Прочитайте файл PQ и измените его в редакторе панелей Vestel.
В 10.08.2024 в 14:14, verniy68 сказал:
P/S :
 (usb)
@Alex1101 , пробовал? - даже бренд твой
Провёл следующие эксперименты
Зашил в аппарат ещё одну прошивку, цвета всё о'кей, но поменянный соседние вертикальные строки между собой
Зато хотя бы всё видно в сервисном меню
6 часов назад, verniy68 сказал:
 - дисплей
Подставлял отсюда файлы наугад несколько штук, никаких изменений не произошло
(там все VESTEL_D1_Plus_PNL.bin)
Затем подкинул этот же файл от предыдущей прошивки, тоже никаких изменений
Затем от предыдущей прошивки взял файлы
D7L_Main.bin
D7L_Main_Text.bin
Также никаких изменений
А должны были цвета уйти в соляризацию
Есть подозрение что что-то не то делаю, хотя сегодня впервые этим и занимаюсь
Где именно содержится информация о панели?
Снял только что профиль PQ
Před 1 hodinou Alex1101 řekl:
Provedl následující experimenty
Flashnul jsem do zařízení další firmware, barvy jsou v pořádku, ale sousední nezávislé čáry se změnily
Ale alespoň je vše vidět v servisním menu
Soud jsem náhodou nahradil několik souborů, nedošlo k žádným změnám
(vše je VESTEL_D1_Plus_PNL.bin)
Pak jsem přidal stejný soubor z předchozího firmwaru, také žádné změny
Pak jsem vzal soubory z předchozího firmwaru
D7L_Main.bin
D7L_Hlavní_Text.bin
Takhle
A barvy měly jít do solarizace
Mám podezření, že něco dělám špatně, ačkoli dnes je to poprvé, co to dělám.
Kde přesně jsou informace o panelu obsaženy?
Právě jsem si udělal PQ profil
Ниже на видео ссылка для скачивания программы
Изменено пользователем pavelmuskar
уточнение информации
