Hisense 32A5710FA, TP.MS6683T.PB701, не включается
Перейти к решению Решено sidor52,
Hisense 32A5710FA
Panel: BOEI320WX-01
Шасси : TP.MS6683T.PB701
Стоит в дежурки не включается, напруги в порядке.еммс на 20 % использованна,залил с рабочей платы и BOOT1
тоже (загрузка с BOOT1) , поведение тоже самое.
Лог рабочей и дохлой прилагаю.
AC_ON
2L-SM-20170623
U03
MIU1_DQS-OK
BIST0-OK
BIST1-OK
*optee teeloader entry
CusConfig
eMMC_RPMB_Check_Program_Key
*ree_opt=00000023
Auth reeloader...
Decrypt reeloader...
reeloader_addr=20100000
NOTICE:  BL3-1: v1.1(debug):971111e4ed
NOTICE:  BL3-1: Built : 23:51:58, Aug  6 2021
INFO:    warmboot return address : 3e301c00
INFO:    BL3-1: Initializing runtime services
NOTICE:  From args : boot_mbx = 200275cc
INFO:     [Booting] mstar_send_magic_ATF 460
INFO:    BL3-1: Initializing BL3-2
[Ramlog] ramlog_init init success
INFO:    BL3-1: Preparing for EL3 exit to normal world
INFO:    BL3-1: Next image address = 0x20100000
INFO:    BL3-1: Next image spsr = 0x1d3
INFO:    BIN1_32bit mode Aug  6 2021 23:51:45
INFO:    R1 0
INFO:    R2 0
INFO:    R3 0
ree_entry
         cum
MTK_LDR
U[LDR_SysInit][300]Hardware Initialization
[LDR_SysInit][302]MsOS Initialization
[LDR_SysInit][304]MIU Initialization
[Utopia][MIU]: [MIU INFO] miu open
                                  create instance at p with private size 545791344 bytes at p
[LDR_SysInit][307]MMIO Initialization
[LDR_SysInit][309]SEM Initialization
[LDR_SysInit][313]SYS Initialization
[Utopia][SYS]: Function = SYSOpen, Line = 1655, current resource pri_shm content is: 0
[Utopia][SYS]: Function = SYSOpen, Line = 1674, [SYS INFO] OPEN INSTANCE...
create instance at p with private size 545791584 bytes at p
[LDR_SysInit][316]Enable Interrupt
[LDR_SysInit][320]Start Timer
[SetMiu][270]CONFIG_MIU0_GROUP_PRIORITY = 1:0:2:3
[SetMiu][271]CONFIG_MIU1_GROUP_PRIORITY = 1:0:2:3
[SetMiu][272]CONFIG_MIU0_GROUP_SELMIU = 1004:0024:0000:0000:005F:0000
[SetMiu][273]CONFIG_MIU1_GROUP_SELMIU = 4F6A:3FD1:0000:0000:0000:FEEF
[MDrv_MIU_SetGroupPriority_UBoot][274]IN
[MDrv_MIU_SetGroupPriority_UBoot][309]OK
[MDrv_MIU_SelectMIU_UBoot][320]IN
[MDrv_MIU_SelectMIU_UBoot][323]OK
[LDR_SysInit][326]Initialize BDMA
create instance at p with private size 545791776 bytes at p
[LDR_SysInit][334]Initialize eMMC
eMMC: HS400 200MHz
eMMC 7.28 GB [E8FFF8h]
[LDR_SysInit][349]Hardware Initialization Completed
[CALDR_Entry][103]Hello CALDR_Entry-Begin
MTKLoader v21: 20190504
Do USB upgrade ...
[EHCI] Ver.20190516 ehci init++
[EHCI] bus base miu0: 0x0, miu1: 0x80000000
[EHCI] qh_buf: 0x2051a080(0x6051a080) qh size: 64
[EHCI] qtd_buf: 0x2051c080(0x6051c080), qtd size: 32
[EHCI] ehci 0 init++
[EHCI] controller: 0x208923d0
ehc_base: 0x1f204800, utmi_base: 0x1f207500, usbc_base: 0x1f200e00
[USB] config miu select [70] [f8] [ef] ][ef]
[USB] enable miu lower bound address subtraction
[USB] init squelch level 0x2
[EHCI] ehci 0 init--
[EHCI] ehci 1 init++
[EHCI] controller: 0x208a2a30
ehc_base: 0x1f201a00, utmi_base: 0x1f207400, usbc_base: 0x1f200f00
[EHCI] ehci 1 init--
[EHCI] ehci 2 init++
[EHCI] controller: 0x208b3090
ehc_base: 0x1f227200, utmi_base: 0x1f221d00, usbc_base: 0x1f227000
[EHCI] ehci 2 init--
[EHCI] ehci init--
Musb3_init OK ++
[yl] usb_poll for controller: 0x208b3090
[yl] usb_poll loop:0, controller->devices[0]:0x208b3300
[EHCI] ehci 2 root portsc: 0x803
highspeed device
* found device (0x0e8d:0x7668, USB 2.1, MPS0: 64)
device has 1 configurations
device has 3 interfaces
NOTICE: Your device has multiple interfaces and
this driver will only use the first one. That may
be the wrong choice and cause the device to not
work correctly. Please report this case
(including the above debugging output) to
coreboot@coreboot.org to have the device added to
the list of well-known quirks.
Interface 0: class 0xe0, sub 0x1. proto 0x1
Class: unsupported class ef
usb set_address ok;device address := 1
Detaching device not used by payload
[yl] usb_poll for controller: 0x208a2a30
[yl] usb_poll loop:0, controller->devices[0]:0x208a2ca0
[yl] usb_poll for controller: 0x208923d0
[yl] usb_poll loop:0, controller->devices[0]:0x20892640
No USB device on U3 port.
No EMMC OAD flag.
No USB or eMMC medium to mount !
USB/EMMC upgrade stop !
** part_emmc_read_ddb: SKIP Driver Descript Block check
[LoadCustomerKeyBank][244]u32CKBStart=0x20108000!
[Jump2Uboot][123]Jump2Uboot-Begin
create instance at p with private size 546061072 bytes at p
UBOOT AUTH_OK
[disable_cache][130]Disable Cache
[LDR_JumpToApp][159]Jump To 0x28400000
Relocation Offset is: 01A00000
[AT][MB][start ub][2145]
U-Boot 2011.06 (Aug 08 2021 - 01:36:29)
[Mboot] ===== sw IR Config Register =====
[Mboot] ===== Attach IR Interrupt  ======
create instance at 28FF9360 with private size 108 bytes at 28FF93B0
[Utopia][MIU]: [MIU INFO] miu opencreate instance at 28FF9420 with private size 156 bytes at 28FF9470
[Utopia][MIU]:  [MDrv_MIU_SetIOMapBase][188][Utopia][MIU]: Get IOMap MS_MODULE_EXTRIU failurecreate instance at 28FF9510 with private size 60 bytes at 28FF9560
uboot held at [28DDDF60~2A800000],size=01A220A0
Uboot Relocation:  168 MiB
Now running in RAM - U-Boot at: 29E00000
eMMC: HS400 200MHz
eMMC 7.28 GB
DRAM : 512MB x 512MB
STR mode: 1
0x8709
Power Down
дохлая плата
AC_ON
2L-SM-20170623
U03
MIU1_DQS-OK
BIST0-OK
BIST1-OK
AUTH_FAIL
Дополните тему.
Что и где проверяли?
CPU/MCU:
Panel (T-CON, инвертор...) :
Прочее...
Неисправность:
Фото неисправности...
Что уже сами проверили...
Основные напряжения (PSU):
Уточните более детально где взяли дамп,с такой же платформы? Залили полностью full damp?
Не нашёл как до полнить свою тему.
Матрица : BOEI320WX-01
Рабочия плата с такого же телека, с неё снята прошивка и залита в не рабочию.
Напруги все подымаются, 1в.,1.5в и т.д.
стоит в дежурке и не каких движений.фото дефекта на верно не зачем вылаживать.
Рабочию плату подставлял - экран и подсветка живые.
Раз есть рабочий донор сними с нее карту напряжений и сопротивлений относительно дросселей по питанию и сравни!.  НDMI  я бы промерил на КЗ. Думаю все крутится вокруг проца
HDMI и юзб сразу проверил,поже проверю
1 час назад, sidor52 сказал:
года два - не проблема
для чего создавать себе трудности , а затем их преодолевать?
...когда по-логу:
- что мешает в терминале дать команду на очистку кэша?
- что мешает найти комбинацию кнопок для полного сброса и очистки памяти тв?
Power Down
дохлая плата
AC_ON
2L-SM-20170623
U03
MIU1_DQS-OK
BIST0-OK
BIST1-OK
AUTH_FAIL
Если этот лог от не рабочей платы. То там проблема с AUTH_FAIL. Ремонтировать уже нечего.
Проц ?может переходы,на станции пошатать ?
6 минут назад, sidor52 сказал:
Нечего шатать не нужно. Ключи слетели. Вот и плата мертвая. Есть привязка.
@sidor52 , родной дамп сохранил?
...если нет - на авито за майном
p/s: логи нужно снимать для верной диагностики перед ремонтом , а не после "телодвижений"
А это его родная еммс?
Может побывал в другой мастерской?
Следов замены не видно,родной где то сохранил,на рабочем майне менял еммс,майе с другой мастерской,заливал по мойму со стороны прошивку -она работает,проверю ещё раз верификацией.токи на прозвон проверил,отличия нк сильные
Запаяете новую еммс. Может прокатит.
Так и зделаю,эту потом сброшу на зоводские настройки.
Запаял новую прошитую еммс, таже хрень (AUTH_FAIL).наверно крест на этой материнке.
43 минуты назад, sidor52 сказал:
Странно как-то. На других форумах пишут что заменили еммс заработало. Плата у них тоже не включалась. :tap:
А лог програматора есть?
Подключусь уже поже программатором к новой еммс ,пошатаю ещё проц ,если тоже самое -забью,пусть клиет меняет плату.Рабочия плата на проверке у меня от другово мастера -еммс я ему менял.
58 минут назад, sidor52 сказал:
еммс я ему менял.
На такой же плате?
18 часов назад, alex2290 сказал:
На такой же плате?
Да.На ремонте пишут меняли полный труп еммс на новую и плата подымалась.
Странно как-то. Видимо что-то с процессором.
  • 3 недели спустя...
Заменил плату. дохлая у меня осталась,может быть когда нибуть покапаюсь в ней.Тему закрывать ?
  • Печально 1
@sidor52 вот так и закрывать))
После решения вопроса ремонта, необходимо указать как неисправность была устранена и что повлекло данную неисправность по Вашему мнению и нажать кнопку - Вопрос решён.
Далее модератор принимает решение о закрытии темы, поставив вашему решению оценку (лайк или дизлайк)
