Shivaki US43H3403 v.4 TPD.RT2841A.PB782 не входит в UART, не берет прошивку по USB.
Принесли телевизор Shivaki US43H3403 v.4 висит на лого main TPD.RT2841A.PB782 Выпаял emmc, время жизни 50%, то есть износ, сохранил дамп, записал на новую. Включил - все так же висит на логотипе. USB прошивки не подхватывали ни под каким именем, даже в принудительном режиме через UART.
Логи сначала были такие
Hello world, 287o!{uni}[WEI]
svn:16b2f7039705ac4b (Jun  7 2022 18:51:55)
flash_type = 2, secure_type = 2
b8062204=0
At.y.0 T.10
r.y.0 r.y.0 R.17
[go kb]
pass bootcode info to kboot▒To setup mmu...
dram_bank_mmu_setup: bank: 0
Cache: Enabled, cpu(0x0)
--- kboot 18:51:51 Jun  7 2022 ---
--- heap start:0x15e90000 size:1472 KB ---
kboot emmc: driver init start!
KCPU eMMC: 0
kboot emmc: driver init finish!
kboot read uboot start...
[OK] kboot_read_uboot_from_eMMC:Read uboot ok!!
uboot start 0x11f800 size 0xbd400
kboot read uboot end...
Setup FW Image:
go
get FW_TZFW flash start 0xd900200 ddr buf start 0x14e00000 image size 0d4920 ok!
Authentication key not yet programmed
[INFO]RPMB auth key not written !
[INFO]RPMB auth key is ready, write_cnt = 0x0 !
get FW_AKERNEL flash start 0xa900200 ddr buf start 0x1a500000 image size 01e5a88 ok!
get FW_VKERNEL flash start 0xc100200 ddr buf start 0x1a900000 image size 04fb840 ok!
ATF:0 1 NOTICE:  SCPU BISR status: bypass
Unhandled Exception in EL3.
x30 =           0x0000000016024004
x0 =            0x0000000000000238
x1 =            0x0000000000000001
x2 =            0x0000000016046300
x3 =            0x0000000000010d00
x4 =            0x0000000020000000
x5 =            0x000000000000000e
x6 =            0x00000000fe0a0000
x7 =            0x0000000000000001
x8 =            0x0000000000000001
x9 =            0x0000000016021018
x10 =           0x0000000000000001
x11 =           0x00000000fe0b0400
x12 =           0x00000000fffffff6
x13 =           0x0000000000000020
x14 =           0x0000000000000000
x15 =           0x0000000000000000
x16 =           0x0000000000000000
x17 =           0x0000000000000000
x18 =           0x0000000000000000
x19 =           0x00000000160217a5
x20 =           0x0000000000000003
x21 =           0x0000000016001000
x22 =           0x0000000000000000
x23 =           0x0000000000000000
x24 =           0x0000000000000000
x25 =           0x0000000000000000
x26 =           0x0000000000000000
x27 =           0x0000000000000000
x28 =           0x0000000000000000
x29 =           0x0000000016045080
scr_el3 =               0x0000000000000239
sctlr_el3 =             0x0000000000cd183f
cptr_el3 =              0x0000000000000000
tcr_el3 =               0x000000008081351e
daif =          0x00000000000003c0
mair_el3 =              0x00000000004404ff
spsr_el3 =              0x00000000600002cc
elr_el3 =               0x00000000160017c8
ttbr0_el3 =             0x0000000016046280
esr_el3 =               0x0000000002000000
far_el3 =               0xdeb467b7fcdef8fe
spsr_el1 =              0x000000008e3ff4f5
elr_el1 =               0x0000000000000000
spsr_abt =              0x00000000ca90f75e
spsr_und =              0x000000004ed9f6e9
spsr_irq =              0x000000001a5dbdf1
spsr_fiq =              0x00000000ba917908
sctlr_el1 =             0x0000000000c50838
actlr_el1 =             0x0000000000000000
cpacr_el1 =             0x0000000000000000
csselr_el1 =            0x0000000000000000
sp_el1 =                0x0000000000000000
esr_el1 =               0x00000000b3f430fa
ttbr0_el1 =             0x0000f3fff8bbf71e
ttbr1_el1 =             0x0000ffff2e8dbcda
mair_el1 =              0x44e048e000098aa4
amair_el1 =             0x0000000000000000
tcr_el1 =               0x0000000000000000
tpidr_el1 =             0xb1fdcd3c7ef767db
tpidr_el0 =             0xffdf97fce74f7ef3
tpidrro_el0 =           0xef1bffbb5f5dd2af
dacr32_el2 =            0x0000000000000000
ifsr32_el2 =            0x0000000000000636
par_el1 =               0xf70000f2bec3def2
mpidr_el1 =             0x0000000081000300
afsr0_el1 =             0x0000000000000000
afsr1_el1 =             0x0000000000000000
contextidr_el1 =                0x0000000000000000
vbar_el1 =              0x0000000000000000
cntp_ctl_el0 =          0x0000000000000000
cntp_cval_el0 =         0x5fc22a7c964e66de
cntv_ctl_el0 =          0x0000000000000000
cntv_cval_el0 =         0x736892a7ed0acc06
cntkctl_el1 =           0x0000000000000000
fpexc32_el2 =           0x0000000000000700
sp_el0 =                0x0000000016045080
isr_el1 =               0x0000000000000000
cpuectlr_el1 =          0x000000002808bc00
Enter console mode, disable watchdog ...
Realtek> INTERRUPT>
Realtek> swuu V8-T841AGL-0000318-CTS.img
(Re)start USB...
USB0:   ----------- ehci_hcd_init -----------
#@# ehci_hcd_init(469) ehci mac0
----------- usb2_crt on(0) -----------
----------- usb2_crt -----------
----------- usb2_crt on(1) -----------
[ehci], dbg, ---- ehci_usb2_load_phy_params start ----
[ehci], dbg, set_usb2_phy, port 1 phy_reg 0xf4 set 0xbb get 0xbb
[ehci], dbg, set_usb2_phy, port 2 phy_reg 0xf4 set 0xbb get 0xbb
[ehci], dbg, set_usb2_phy, port 3 phy_reg 0xf4 set 0xbb get 0xbb
[ehci], dbg, set_usb2_phy, port 1 phy_reg 0xe5 set 0xf get 0xf
[ehci], dbg, set_usb2_phy, port 2 phy_reg 0xe5 set 0xf get 0xf
[ehci], dbg, set_usb2_phy, port 3 phy_reg 0xe5 set 0xf get 0xf
[ehci], dbg, set_usb2_phy, port 1 phy_reg 0xe6 set 0x58 get 0x58
[ehci], dbg, set_usb2_phy, port 2 phy_reg 0xe6 set 0x58 get 0x58
[ehci], dbg, set_usb2_phy, port 3 phy_reg 0xe6 set 0x58 get 0x58
[ehci], dbg, set_usb2_phy, port 1 phy_reg 0xe7 set 0xe3 get 0xe3
[ehci], dbg, set_usb2_phy, port 2 phy_reg 0xe7 set 0xe3 get 0xe3
[ehci], dbg, set_usb2_phy, port 3 phy_reg 0xe7 set 0xe3 get 0xe3
[ehci], dbg, set_usb2_phy, port 1 phy_reg 0xf4 set 0x9b get 0x9b
[ehci], dbg, set_usb2_phy, port 2 phy_reg 0xf4 set 0x9b get 0x9b
[ehci], dbg, set_usb2_phy, port 3 phy_reg 0xf4 set 0x9b get 0x9b
[ehci], dbg, set_usb2_phy, port 1 phy_reg 0xe0 set 0x17 get 0x17
[ehci], dbg, set_usb2_phy, port 2 phy_reg 0xe0 set 0x17 get 0x17
[ehci], dbg, set_usb2_phy, port 3 phy_reg 0xe0 set 0x17 get 0x17
[ehci], dbg, set_usb2_phy, port 1 phy_reg 0xe1 set 0x18 get 0x18
[ehci], dbg, set_usb2_phy, port 2 phy_reg 0xe1 set 0x18 get 0x18
[ehci], dbg, set_usb2_phy, port 3 phy_reg 0xe1 set 0x18 get 0x18
[ehci], dbg, set_usb2_phy, port 1 phy_reg 0xe2 set 0x44 get 0x44
[ehci], dbg, set_usb2_phy, port 2 phy_reg 0xe2 set 0x44 get 0x44
[ehci], dbg, set_usb2_phy, port 3 phy_reg 0xe2 set 0x44 get 0x44
[ehci], dbg, set_usb2_phy, port 1 phy_reg 0xe3 set 0xcd get 0xcd
[ehci], dbg, set_usb2_phy, port 2 phy_reg 0xe3 set 0xcd get 0xcd
[ehci], dbg, set_usb2_phy, port 3 phy_reg 0xe3 set 0xcd get 0xcd
[ehci], dbg, set_usb2_phy, port 1 phy_reg 0xe5 set 0x63 get 0x63
[ehci], dbg, set_usb2_phy, port 2 phy_reg 0xe5 set 0x63 get 0x63
[ehci], dbg, set_usb2_phy, port 3 phy_reg 0xe5 set 0x63 get 0x63
[ehci], dbg, set_usb2_phy, port 1 phy_reg 0xe1 set 0x77 get 0x77
[ehci], dbg, set_usb2_phy, port 2 phy_reg 0xe1 set 0x77 get 0x77
[ehci], dbg, set_usb2_phy, port 3 phy_reg 0xe1 set 0x77 get 0x77
[ehci], dbg, set_usb2_phy, port 1 phy_reg 0xf4 set 0xdb get 0xdb
[ehci], dbg, set_usb2_phy, port 2 phy_reg 0xf4 set 0xdb get 0xdb
[ehci], dbg, set_usb2_phy, port 3 phy_reg 0xf4 set 0xdb get 0xdb
[ehci], dbg, set_usb2_phy, port 1 phy_reg 0xe7 set 0x44 get 0x44
[ehci], dbg, set_usb2_phy, port 2 phy_reg 0xe7 set 0x44 get 0x44
[ehci], dbg, set_usb2_phy, port 3 phy_reg 0xe7 set 0x44 get 0x44
[ehci], dbg, set_usb2_phy, port 1 phy_reg 0xe4 set 0x7a get 0x7a
[ehci], dbg, set_usb2_phy, port 2 phy_reg 0xe4 set 0x7a get 0x7a
[ehci], dbg, set_usb2_phy, port 3 phy_reg 0xe4 set 0x7a get 0x7a
[ehci], dbg, set_usb2_phy, port 1 phy_reg 0xe7 set 0x71 get 0x71
[ehci], dbg, set_usb2_phy, port 2 phy_reg 0xe7 set 0x71 get 0x71
[ehci], dbg, set_usb2_phy, port 3 phy_reg 0xe7 set 0x71 get 0x71
[ehci], dbg, set_usb2_phy, port 1 phy_reg 0xe0 set 0x23 get 0x23
[ehci], dbg, set_usb2_phy, port 1 phy_reg 0xe0 set 0x26 get 0x26
[ehci], dbg, set_usb2_phy, port 2 phy_reg 0xe0 set 0x23 get 0x23
[ehci], dbg, set_usb2_phy, port 2 phy_reg 0xe0 set 0x26 get 0x26
[ehci], dbg, set_usb2_phy, port 3 phy_reg 0xe0 set 0x23 get 0x23
[ehci], dbg, set_usb2_phy, port 3 phy_reg 0xe0 set 0x26 get 0x26
[ehci], dbg, set_usb2_phy, port 1 phy_reg 0xe6 set 0x1 get 0x1
[ehci], dbg, set_usb2_phy, port 2 phy_reg 0xe6 set 0x1 get 0x1
[ehci], dbg, set_usb2_phy, port 3 phy_reg 0xe6 set 0x1 get 0x1
[ehci], dbg, set_usb2_phy, port 1 phy_reg 0xf0 set 0xfc get 0xfc
[ehci], dbg, set_usb2_phy, port 2 phy_reg 0xf0 set 0xfc get 0xfc
[ehci], dbg, set_usb2_phy, port 3 phy_reg 0xf0 set 0xfc get 0xfc
[ehci], dbg, set_usb2_phy, port 1 phy_reg 0xf1 set 0x8c get 0x8c
[ehci], dbg, set_usb2_phy, port 2 phy_reg 0xf1 set 0x8c get 0x8c
[ehci], dbg, set_usb2_phy, port 3 phy_reg 0xf1 set 0x8c get 0x8c
[ehci], dbg, set_usb2_phy, port 1 phy_reg 0xf2 set 0x0 get 0x0
[ehci], dbg, set_usb2_phy, port 2 phy_reg 0xf2 set 0x0 get 0x0
[ehci], dbg, set_usb2_phy, port 3 phy_reg 0xf2 set 0x0 get 0x0
[ehci], dbg, set_usb2_phy, port 1 phy_reg 0xf3 set 0x11 get 0x11
[ehci], dbg, set_usb2_phy, port 2 phy_reg 0xf3 set 0x11 get 0x11
[ehci], dbg, set_usb2_phy, port 1 phy_reg 0xf5 set 0x95 get 0x95
[ehci], dbg, set_usb2_phy, port 2 phy_reg 0xf5 set 0x95 get 0x95
[ehci], dbg, set_usb2_phy, port 3 phy_reg 0xf5 set 0x95 get 0x95
[ehci], dbg, set_usb2_phy, port 1 phy_reg 0xf6 set 0x0 get 0x0
[ehci], dbg, set_usb2_phy, port 2 phy_reg 0xf6 set 0x0 get 0x0
[ehci], dbg, set_usb2_phy, port 3 phy_reg 0xf6 set 0x0 get 0x0
[ehci], dbg, set_usb2_phy, port 1 phy_reg 0xf7 set 0xba get 0xba
[ehci], dbg, set_usb2_phy, port 2 phy_reg 0xf7 set 0xba get 0xba
[ehci], dbg, set_usb2_phy, port 3 phy_reg 0xf7 set 0xba get 0xba
[ehci], dbg, set_usb2_phy, port 1 phy_reg 0xe2 set 0x0 get 0x0
[ehci], dbg, set_usb2_phy, port 2 phy_reg 0xe2 set 0x0 get 0x0
[ehci], dbg, set_usb2_phy, port 3 phy_reg 0xe2 set 0x0 get 0x0
[ehci], dbg, set_usb2_phy, port 1 phy_reg 0xe3 set 0x3 get 0x3
[ehci], dbg, set_usb2_phy, port 2 phy_reg 0xe3 set 0x3 get 0x3
[ehci], dbg, set_usb2_phy, port 3 phy_reg 0xe3 set 0x3 get 0x3
[ehci], dbg, set_usb2_phy, port 1 phy_reg 0xe4 set 0x48 get 0x48
[ehci], dbg, set_usb2_phy, port 2 phy_reg 0xe4 set 0x48 get 0x48
[ehci], dbg, set_usb2_phy, port 3 phy_reg 0xe4 set 0x48 get 0x48
[ehci], dbg, set_usb2_phy, port 1 phy_reg 0xe3 set 0x1 get 0x1
[ehci], dbg, set_usb2_phy, port 2 phy_reg 0xe3 set 0x1 get 0x1
[ehci], dbg, set_usb2_phy, port 3 phy_reg 0xe3 set 0x1 get 0x1
[ehci], dbg, ---- ehci_usb2_load_phy_params complete ----
[ehci], info, #@# usb2_phy_setting(352) +++ for usbphy setting 20170420
[ehci], info, #@# usb2_phy_setting(354) ---
----------- ehci_usb_mac_init -----------
USB EHCI 1.00
scanning bus 0 for devices... 3 USB Device(s) found
       scanning usb for storage devices... 1 Storage Device(s) found
1: Hub,  USB Revision 2.0
 - u-boot EHCI Host Controller
 - Class: Hub
 - PacketSize: 64  Configurations: 1
 - Vendor: 0x0000  Product 0x0000 Version 1.0
   Configuration: 1
   - Interfaces: 1 Self Powered 0mA
     Interface: 0
     - Alternate Setting 0, Endpoints: 1
     - Class Hub
     - Endpoint 1 In Interrupt MaxPacket 8 Interval 255ms
2: Mass Storage,  USB Revision 2.0
 - Generic Mass Storage DCC674BD
 - Class: (from Interface) Mass Storage
 - Vendor: 0x058f  Product 0x6387 Version 1.0
   Configuration: 1
   - Interfaces: 1 Bus Powered 200mA
     Interface: 0
     - Alternate Setting 0, Endpoints: 2
     - Class Mass Storage, Transp. SCSI, Bulk only
     - Endpoint 1 Out Bulk MaxPacket 512
     - Endpoint 2 In Bulk MaxPacket 512
3: ,  USB Revision 2.0
 - Realtek 802.11ac NIC 123456
 - Class:
 - Vendor: 0x0bda  Product 0xc82c Version 0.0
   Configuration: 1
   - Interfaces: 3 Bus Powered Remote Wakeup 500mA
     Interface: 0
     - Alternate Setting 0, Endpoints: 3
     - Class
     - String: "Bluetooth Radio"
     - Endpoint 1 In Interrupt MaxPacket 16 Interval 4ms
     - Endpoint 2 Out Bulk MaxPacket 512
     Interface: 1
     - Class
     - Endpoint 3 Out Isochronous MaxPacket 0
     - Endpoint 3 In Isochronous MaxPacket 0
     - Endpoint 3 Out Isochronous MaxPacket 9
     - Endpoint 3 In Isochronous MaxPacket 9
     - Endpoint 3 Out Isochronous MaxPacket 17
     - Endpoint 3 In Isochronous MaxPacket 17
     - Endpoint 3 Out Isochronous MaxPacket 25
     - Endpoint 3 In Isochronous MaxPacket 25
     - Endpoint 3 Out Isochronous MaxPacket 33
     - Endpoint 3 In Isochronous MaxPacket 33
     - Endpoint 3 Out Isochronous MaxPacket 49
     - Endpoint 3 In Isochronous MaxPacket 49
     Interface: 2
     - Alternate Setting 0, Endpoints: 5
     - Class Vendor specific
     - String: "802.11ac NIC"
     - Endpoint 4 In Bulk MaxPacket 512
     - Endpoint 5 Out Bulk MaxPacket 512
     - Endpoint 6 Out Bulk MaxPacket 512
     - Endpoint 7 In Interrupt MaxPacket 64 Interval 3ms
     - Endpoint 8 Out Bulk MaxPacket 512
reading V8-T841AGL-0000318-CTS.img
Filesize: -1777678336 bytes
-1777678336 bytes
EHCI timed out on TD - token=0xa0008d80
EHCI fail timeout STS_ASS set
Error reading cluster
Size: -1777678336, got: -1
** Unable to read "V8-T841AGL-0000318-CTS.img" from usb 0:1 **
cmd_fwupgrade.c(213) get_usb_fileinfo: read V8-T841AGL-0000318-CTS.img failed. (No such file)
cmd_fwupgrade.c(1630) do_fw_upgrade: @@@@@@@@@@update fw name V8-T841AGL-0000318-CTS.img fail!@@@@@@@@@@
Realtek> <INTERRUPT>
Realtek> uboot
Unknown command 'uboot' - try 'help'
Команда factory reset ничего не делает, ни на что не ругается просто переходит на новую строку. А если бы выполнился, то должно было быть writing to emmc .... и еще несколько строк после этого. Выпаял, накатил новые шары, пробую дамп от ARTEL A32KH5500 - не помогло, все также обновить по USB не удалось. Выпаял, снова отреболлил, заливаю обратно его же прошивку, также висит на лого и тут в режиме UART я сделал команду. tcl_force_upgrade- force upgrade install.img and skip magic check
После команды в терминале
Realtek> tcl_force_upgrade
Start Linux at 0x108000 ...
you have selected [x]  AMP0_IC=TAS5805          , Slave_addr=2D
[ENV] Writing to Factory...
done
[WARNING] NOT NORMAL BOOTING FOW,  SKIP CHECKING BISR FLOW!
Starting kernel ...
Reset ethernet/disable interrupt/flush cache...
boot_jump_linux (0x0,0x1393,0xd5100, entry:108000)
завис, с флешки не читал, в UART не реагировал, Подождал несколько минут и отключил ТВ. После этого вообще уже даже в UART не зайти. Логи сейчас такие
b8062204=0
At.y.0 T.10
r.y.0 r.y.0 R.17
[go kb]
KCPU eMMC: 0
Setup FW Image:
go
и так циклические перезагрузки каждые 5 сек. Дамп который сначала включался и висел на лого - сейчас выдает это же.
Выпаял emmc опять записал его же дамп, логи те же, в UART не заходит, индикатор не горит. Предполагаю, что команда затронула внутреннюю прошивку процессора RTD2841ACS. Как можно исправить ситуацию? Как прошить процессор? Записав на emmc специальный bootloader? Через UART или USB?
3 часа назад, Onik1318 сказал:
Вот  на что ругается с новой еммс.
Для проверки запишите рабочий дамп в старую еммс.
  • Техподдержка
Вот ты подошёл к самому тонкому месту у Realtek’ов — границе между внешней eMMC и внутренним ROM-бутом.
Похоже, когда ты дал tcl_force_upgrade, бутлоадер полез в секцию TrustZone/ATF и получил по голове. После зависания и отключения питания, микросхема не может корректно стартовать — U-Boot вроде читается, но дальше ARM Trust Firmware падает, и процессор уходит в ресет-петлю.
Что из этого следует:
  1. Внутренний бут в RTD2841ACS жив — он отвечает “Hello world…” и пытается запустить kboot, значит сам чип не умер.
  2. Проблема в области bootloader/ATF на eMMC.
    После команды tcl_force_upgrade могли перезаписаться разделы boot0/boot1 (или user area в первых мегабайтах). Теперь там мусор, из-за чего контроллер не выходит на UART (он висит до инициализации порта).
  3. USB не стартует, потому что автозагрузка не доходит до стадии, где она опрашивает USB-порт.
Что можно попробовать:
  • Прямое восстановление eMMC.
    На программаторе (RT809H, EasyJTAG, UFI — любой, что понимает eMMC) очистить boot0/boot1, прописать туда корректный bootloader.bin от такой же платы TPD.RT2841A.PB782.
    Если дампа нет — можно взять от любого исправного ТВ с этим же MAIN и версией v4, затем вписать свой раздел ENV и MAC при необходимости.
  • Сброс RPMB.
    Иногда Realtek после сбоя TrustZone блокирует доступ. Форматирование eMMC с удалением RPMB-ключа (через mmc erase в программаторе) возвращает загрузку.
  • Если после восстановления boot0/boot1 UART оживает, можно будет снова завести tcl_force_upgrade с корректным install.img.
А вот если бут-сектора процессора реально переписались (что бывает крайне редко, но ты почти всё для этого сделал) — тогда остаётся только JTAG или ISP-доступ к самому RTD2841, чего без фирменных Realtek-тулзов не сделать. Их нет в открытом доступе: чип закрыт, и заводские загрузчики подписаны.
Реальный шанс вернуть его к жизни:
  1. Найти полный дамп eMMC от рабочей TPD.RT2841A.PB782 (v4, Shivaki или аналог TCL).
  2. Программатором прошить boot0/boot1 и user area.
  3. Проверить, чтобы в CID/EXT_CSD выставлен правильный BOOT_PARTITION_ENABLE.
  4. Впаять обратно и смотреть, появится ли UART-лог глубже чем “go”.
С этим же emmc он входил в UART и со своим дампом и с дампом от AKIA, после этой команды, циклический лог который я привел. После этого лога без возможности входа в UART, я скинул еще дамп еще раз, лог остался. То есть это случилось не после пайки, а именно после этой команды. Ну и RPMB auth key not written для Realtek-ов это не ругательство, во всех платах где менял память это появляется, но ни на что не влияет.
Изменено пользователем Onik1318
  • Техподдержка
Ты всё верно заметил — это именно та команда tcl_force_upgrade, которая пошла копать глубже обычной прошивки и зацепила зоны, от которых дальше зависит нормальная инициализация (ATF / TZ / kboot / части u-boot). Разница в том, что теперь плата стартует только на самый ранний этап (виден «Hello world…», kboot стартует), но дальше падает в циклический перезапуск и UART «глохнет» до той стадии, где он должен заговаривать полноценно. Это поведение пачки realtek-плат знакомо: внешняя eMMC может выглядеть «восстановленной», а загрузка всё равно не доходит до уровня, где USB или UART активны полноценно — потому что повреждена именно та область, с которой RTD ожидает свои TZ/ATF/uboot-образа.
Ниже — практический план действий с приоритетом от простого к сложному. Чётко, без воды, чтобы можно было брать паяльник или программатор и действовать.
Что делать сейчас (пошагово)
1) Не ломать текущий дамп — сделай резервную копию
Если ещё не сделал — сохрани текущий дамп eMMC полностью (весь ROM образ). Он пригодится для анализа и отката.
Команда на Linux:
dd if=/dev/sdX of=full_emmc_dump.img bs=4M status=progress
(где /dev/sdX — твой адаптер/программатор).
2) Восстановить первые мегабайты — чаще всего достаточно первых 8–32 МБ
Большинство загрузчиков (kboot/uboot/ATF) живут в первых секторах eMMC (boot0/boot1 и низ user area). Если у тебя есть рабочий дамп от точно такой же платы (TPD.RT2841A.PB782 v4 или полностью совместимый), то перепиши первые 8–32 МБ с него. Это малое вмешательство даёт высокий шанс оживить UART/USB.
Примеры команд:
  • Запись первых 32 МБ на прямом блочном устройстве:
dd if=good_dump.img of=/dev/sdX bs=1M count=32 conv=sync
  • На Linux eMMC с поддержкой boot partitions (/dev/mmcblk0boot0, /dev/mmcblk0boot1):
# если есть образы boot0/boot1:
dd if=boot0.img of=/dev/mmcblk0boot0 bs=4M
dd if=boot1.img of=/dev/mmcblk0boot1 bs=4M
# затем первые 32MB user area
dd if=good_dump.img of=/dev/mmcblk0 bs=1M count=32 conv=sync
Почему 32 МБ? — это безопасный объём, который покрывает kboot/uboot/ATF и служебные таблицы. Иногда бывает достаточно и 8–16 МБ, но лучше начать с 32.
3) Учитывать boot-partition enable и EXT_CSD
Удостоверься, что в EXT_CSD включены boot-разделы (BOOT_PARTITION_ENABLE) и что CID/EXT_CSD соответствуют реальному типу eMMC. Некоторые программаторы/адаптеры не восстанавливают эти поля автоматически.
Проверка на Linux:
mmc extcsd read /dev/mmcblk0
Если видишь, что boot partition выключен — включи через инструменты программатора или mmc utils.
4) Полная перезапись необходимых областей (если простая запись не помогла)
Если просто первые 32 МБ не дали результата, придётся восстановить весь «user area» с правильной привязкой смещений — т.е. именно те оффсеты, которые в логах указаны как flash start:
В логах у тебя есть такие строки:
Это подсказка: RTD ожидает образы в конкретных смещениях на флеше. Если ты имеешь рабочий дамп, просто записать его целиком (dd if=good_dump.img of=/dev/sdX) — самый прямой путь.
5) Программатор — лучше, чем «выпаять/паять» много раз
Если у тебя RT809H / UFI / EasyJTAG или аналог — используй его. Программатор правильнее работает с eMMC, умеет записать boot0/boot1 и управлять erase/trim по LBA. На тот случай:
  • В программаторе сначала erase boot0/boot1, потом write boot0/boot1.
  • Затем write user area (первые 32–64 МБ) и проверить CRC, если есть такая функция.
6) Если после всех попыток UART всё ещё «глохнет»
Это означает, что либо:
  • повреждён ATF/TrustZone, требующий подписанного образа и/или специальных ключей (большая проблема), или
  • повредилось нечто в eMMC, что не видно в простом дампе (например, ключи/RPMB/secure areas), или
  • в результате tcl_force_upgrade внутренний загрузчик (который хранится в OTP/efuse/внутреннем флеше SOC) перешёл в состояние, где он ждёт подписанный образ и не даёт доступ к UART/usb.
В этом случае остаётся два пути:
  1. JTAG / ISP программатор для RTD2841 — у Realtek есть заводские инструменты; через JTAG можно восстановить внутренние образы. Но это редко доступно в свободной среде — нужен доступ к JTAG-адаптеру и СПЕЦИАЛЬНЫЕ Realtek-утилиты / образы.
  2. Искать рабочую плату-донор и слепо сравнить сигналы и прошивки — иногда проще стащить нормальную плату с таким же MAIN и заменить eMMC + проверить поведение.
7) Практические советы и предостережения
  • Не делай «полный wipe» RPMB, если нет уверенности: на некоторых платах RPMB содержит важное для кастомной аутентификации. Но в твоём случае ты писал, что RPMB auth key not written — у Realtek это часто не критично.
  • Если у тебя есть дамп который раньше входил в UART — именно его и нужно восстанавливать (не чужие образы, даже если похожи). Крошечные различия в ENV/PLATFORM DATA могут блокировать аппарат.
  • После записи, перед впаиванием eMMC обратно — проверь CRC/size и, если возможно, запусти плату на стенде с UART подключённым и без дисплея — иногда индикатор питания/подсветки остаётся мёртв, но UART всё равно полезен.
😎 Что я могу сделать прямо сейчас
Могу:
  • подсчитать и дать точные команды dd и смещения для записи boot0/boot1 и первых N мегабайт, если скажешь, каким программатором/адаптером пользуешься (RT809H, UFI, SD-адаптер в Linux, Z3X/EasyJTAG и т.д.).
  • подготовить чек-лист для твоего программатора (erase, write boot0, write boot1, write user area, проверить EXT_CSD) — с точными командами под Linux или под RT809 GUI.
  • предложить, что конкретно переписывать из рабочего дампа (какие диапазоны в байтах), если пришлёшь вывод fdisk -l или hexdump -C первых 512 байт дампа.
5 часов назад, Onik1318 сказал:
здесь нужно было нажать кнопку(кнопки) и , удерживая , внедрить вилку шнура питания в розетку
далее "wipe" и "reboot system now"
1 час назад, alex2290 сказал:
начни с этого
Про "рабочий дамп" ...можно взять , например ,
 (( конфиг не забываем проверять
Появится-ли лог?
Нужно определить , где проблема - eMMC или во внутреннем загрузчике SOC
Если проблема окажется в SOC , то качаем
 , читаем(до конца)
 и , если результат=0 , то идем в магазин за майном
Тон озу обходит при загрузке в логе и предупреждение выводит и говорит не нормальная загрузка.
12 часов назад, Onik1318 сказал:
Или это не озу.
Есть хорошая тема у нас на форуме:
что+такое+BISR+в+прошивке?
  • Техподдержка
@ильшат просто ссылки без описания в теме это не правильно, я расшифровал твои мысли, в следующий раз делай это сам.
51 минуту назад, ильшат сказал:
BISR — это Built-In Self-Repair, встроенная система самовосстановления памяти (обычно SRAM или DRAM-блоков внутри SoC).
У Realtek (в частности, RTD2841) она используется на раннем этапе старта ядра, чтобы проверить внутренние кэши и ОЗУ процессора.
Если в логах видишь строки вроде:
или
WARNING: SKIP CHECKING BISR FLOW
— это не ошибка, а просто сообщение от TrustZone/ATF-части, что тест или ремонт памяти пропущен (bypass) или не выполнялся.
На заводе при тестировании чипа BISR может "ремапить" сбойные ячейки к резервным.
В пользовательской прошивке это остаётся как диагностическая функция: при загрузке ATF (Arm Trusted Firmware) вызывает процедуру BISR-инициализации и выводит её результат.
В твоём случае “bypass” говорит о том, что процессор решил не выполнять ремонт SRAM, либо из-за принудительного режима (force upgrade / skip BISR flow), либо потому что загрузчик не дошёл до стадии нормальной проверки.
Так что BISR сам по себе не причина зависания — просто индикатор, что старт идёт по укороченному пути и некоторые проверки аппаратных блоков пропущены.
В 20.10.2025 в 21:35, verniy68 сказал:
это я первым пробовал, не входил в рекавери, проверил много разных способов, у него внизу 5 кнопок. USB прошивки не брал ни свою ни чужую на той же платформе, даже в принудительном режиме.
В 20.10.2025 в 22:00, verniy68 сказал:
начни с этого
Появится-ли лог?
 , читаем(до конца)
не берет внутренюю прошивку, а сейчас emmc даже выпаял - тоже самое, 3 этих режима пробовал ни один не идет.
  • Техподдержка
@Onik1318 Хорош — ты дал контекст, и видно, что дело именно в том, что была запущена команда, которая полезла глубже стандартной процедуры обновления и «зацепила» зоны, без которых SoC дальше не инициализирует нормальный ранний бут (ATF/TrustZone/kboot/uboot).
Ниже — развёрнутый, практический ответ как от мастера с опытом: что проверить, какие действия выполнить по приоритету, точные смещения и команды для правки образов и когда пора признавать, что это уже внутренняя проблема SOC и нужна JTAG/донор-плата.
Коротко по сути
Команда tcl_force_upgrade (force upgrade install.img and skip magic check) у Realtek часто запускает штатный процесс, который может перезаписать или изменить области, где лежат TrustZone/ATF и другие ранние образы. После некорректного прерывания (подключение питания во время операции, зависание) плата может остаться в состоянии, когда стартует только самый ранний ROM-буут (виден “Hello world…”, kboot стартует), но дальше ATF либо падает, либо уходит в циклический ресет — UART «глохнет» до той стадии, где он должен начинать полноценно разговаривать. Это именно то, что у тебя в логах.
Что делаем в первую очередь (быстро, без лишних телодвижений)
  1. Сохрани текущий дамп eMMC полностью (если не сделал).
    Это обязателен: даже «сломанный» дамп ценен. Программатор или Linux-доступ:
    dd if=/dev/sdX of=full_emmc_dump_broken.img bs=4M status=progress
    — где /dev/sdX — твой адаптер/устройство.
  2. Попробуй штатный Recovery (кнопка + питание) ещё раз правильно.
    Описанная процедура (удерживать кнопку(и), подключать питание) иногда возвращает в recovery и позволяет сделать wipe/reboot. Но ты писал — уже пробовал. Всё равно: давай считать это пройденным.
  3. Проверяй питание и интерфейсы до перепрошивки.
    Измерь мультиметром основные напряжения на плате при попытке старта: 3.3 В, 1.8 В (если есть), 1.2 В (core). Если eMMC не получает 1.8/3.3 — он не инициализируется и поведение будет такое же. Также проверь кварц/осциллятор CPU — без тактирования ATF/кboot могут корректно не стартовать.
  4. Подключи UART и оставь лог — фиксируй момент остановки.
    Если UART пропадает раньше, чем загружается eMMC-секция — это подсказка, что ранний бут падает до включения консоли. Если консоль стартует глубже — можно вмешаться.
Что восстанавливать первым: boot0/boot1 и первые мегабайты
Большинство Realtek-образов (kboot/ATF/uboot/ENV) находятся в первых секторах eMMC и в boot-разделах.
Самая эффективная/безпечная попытка — восстановить первые 8–32 МБ или записи boot0/boot1 из рабочей платы с таким же MAIN (TPD.RT2841A.PB782 v4).
  • Если есть рабочий дамп от точно такой же платы — перепиши первые 32 МБ:
  • Или, при доступе к /dev/mmcblk0boot0 и /dev/mmcblk0boot1:
Почему 32 МБ? — это безопасный объём, покрывающий ранние загрузчики и таблицы. Часто этого хватает, чтобы плата снова оживила UART/USB и дальше можно полноценно прошиться.
Смещения образов из твоего лога — куда RTD ожидает образы
В логах были строки:
Это hex-смещения (байты) на eMMC, где SoC ищет TZFW, A_KERNEL, V_KERNEL. Переводы в удобный вид:
  • 0xd900200 = 227,541,504 байт217 MB (в секторах 512-байт: 444,417 sectors)
  • 0xa900200 = 177,209,856 байт169 MB (секторов: 346,113)
  • 0xc100200 = 202,375,680 байт193 MB (секторов: 395,265)
Если у тебя есть отдельные файлы tzfw.bin, akernel.bin, vkernel.bin, их можно прописать в точные смещения. Пример dd (используя bs=512 и seek=число секторов — это наиболее универсально):
# пример: запись TZFW в 0xd900200
dd if=tzfw.bin of=/dev/sdX bs=512 seek=444417 conv=notrunc
# AKERNEL в 0xa900200
dd if=akernel.bin of=/dev/sdX bs=512 seek=346113 conv=notrunc
# VKERNEL в 0xc100200
dd if=vkernel.bin of=/dev/sdX bs=512 seek=395265 conv=notrunc
И ещё одна важная деталь — в логе видна инициализация uboot:
Это означает, что u-boot загружен из eMMC с байтового смещения 0x11f800 и размером 0xbd400. В десятичном:
  • start 0x11f800 = 1,177,600 байт (секторов 512: 2300)
  • size 0xbd400 = 775,168 байт (секторов 512: 1514)
Если у тебя отдельный u-boot.bin, запиши его на те же оффсеты:
dd if=u-boot.bin of=/dev/sdX bs=512 seek=2300 conv=notrunc
Важно: делать такие точечные записи нужно только если уверен в происхождении образов (они именно от той же платы/версии). Неправильное размещение / битые образы — только хуже.
Проверка EXT_CSD / Boot partition flags
Убедись, что boot-разделы включены (BOOT_PARTITION_ENABLE в EXT_CSD).
Некоторые программаторы при записи «пропускают» эти флаги, и SoC смотрит не туда, где лежит его бут.
На Linux:
# смотри поле BOOT_PARTITION_ENABLE и BOOT_BUS_WIDTH и т.д.
Если boot выключен — включи через инструменты программатора.
Если первые 32 МБ/boot0/boot1 восстановление не помогает
Если после аккуратной записи boot0/boot1 и первых 32–64 МБ плата всё ещё только доходит до ATF:... SCPU BISR status: bypass и затем перезагружается / глохнет UART — это сильный признак, что:
  • повреждён либо TrustZone/ATF, требующий подписанного образа и специальных ключей, либо
  • internal ROM/OTP/efuse в SoC перешёл в состояние, где ждёт подписанный образ или иного апдейта, и внешний eMMC здесь уже не поможет.
В этом случае варианты:
  1. JTAG / ISP восстановление внутреннего загрузчика — прямое вмешательство в SoC. Требуются JTAG-адаптеры, Realtek-утилиты и фирменные образы. Это профессиональная услуга (не у всех сервисов есть набор).
  2. Поиск и замена на рабочий MAIN (донор) — часто быстрее: найти рабочую плату с тем же MAIN и SW-версией и заменить eMMC/плату.
  3. Отнести в специализированный сервис, который умеет работать с Realtek RTD-семейством.
Практические рекомендации по оборудованию и методам
  • Программатор: RT809H, UFI, EasyJTAG, Z3X и т.п. — предпочтительны, т.к. умеют работать с boot-разделами eMMC. Через простой SD-адаптер в USB-ридере могут не работать boot0/boot1.
  • Перед записью: сделай compare/CRC на серию банков (если программатор поддерживает) — проверяй, что записалось корректно.
  • Не трогать RPMB без понимания — на большинстве Realtek-плат это не мешает, но есть исключения; у тебя в логах уже было "RPMB auth key not written" — это не обязательно проблема.
  • Не делай full wipe без резерва. Сохрани слепок перед любыми экспериментами.
Диагностика состояния SoC (что именно говорит лог)
  • “Hello world…” и запуск kboot → ранний ROM-буут жив.
  • kboot read uboot OK → uboot читается с eMMC (по крайней мере на ранней стадии).
  • get FW_TZFW ... OK, get FW_AKERNEL ... OK, get FW_VKERNEL ... OK — значит эти образы читаются, но дальше ATF: ... SCPU BISR status: bypass и перераз загрузка. Это намекает, что или ATF падает при инициализации SCPU, или дальнейшие проверки/ремап памяти не проходят.
  • Если раньше с тем же eMMC был доступ в UART — и он пропал после tcl_force_upgrade, это очень сильный индикатор, что была перезаписана служебная зона, или SoC перешёл в режим ожидания подписанного образа (secure boot), что внешний eMMC не исправит.
Если у тебя программатор — конкретный чеклист (порядок действий)
  1. Сделать полный дамп full_emmc_dump_broken.img.
  2. Скопировать рабочий дамп good_dump.img.
  3. Записать boot0/boot1 из good_dump или записать первые 32 МБ user area.
  4. Проверить EXT_CSD и включить BOOT_PARTITION_ENABLE, если нужно.
  5. Впаять eMMC обратно, подключить UART, включить питание и смотреть логи.
  6. Если пошло — продолжить полную запись образа или штатный апгрейд через USB/uart.
Что делать, если всё это не помогло (последний рубеж)
  • JTAG — восстанавливать внутренний образ SoC. Это реально, но: нужен доступ к сервисным инструментам/образам Realtek. Обычно этим занимаются продвинутые сервисы.
  • Донор-плата — самый прагматичный путь: поиск рабочей платы аналогичной ревизии (TPD.RT2841A.PB782 v4) и перенос eMMC/платы.
  • Продажа и замена MAIN — если ремонт экономически нецелесообразен, проще заменить плату.
Конкретно для тебя — план действий прямо сейчас
  1. Если не сделал — сохраниться full_emmc_dump_broken.img.
  2. Если есть рабочий дамп — запиши первые 32 МБ и boot0/boot1 как я описал.
  3. Если у тебя программатор — сделай dd по смещениям для TZFW/AKERNEL/VKERNEL, которые указаны выше (используй seek в секторах, примеры приведены). Особенно важно — верно прописать u-boot на смещение 0x11f800 (seek 2300).
  4. Проверь питание CPU/eMMC (3.3/1.8/1.2 — особенно 1.2 core).
  5. После каждой операции пробуй включать и логировать UART; фиксируй точную строку, где всё останавливается.
Если хочешь — могу прямо сейчас:
  • Сгенерировать готовые dd-команды под твой интерфейс (SD-адаптер в Linux или программатор RT809H).
  • Подготовить список тест-точек по площадкам на плате для мерки ключевых напряжений (пишу, какие искать типично на Realtek-MAIN).
  • Или разобрать твой сохранённый лог/дамп (если пришлёшь первые 1 МБ/заголовок) и указать точные оффсеты, которые стоит переписать.
Говори: какой доступ у тебя к eMMC — через Linux (/dev/sdX или /dev/mmcblk0) или через программатор (RT809H / UFI / EasyJTAG)? Я дам точные команды и последовательность.
Спасибо, что прислал ссылку на тему и лог — да, подтверждает многое (и дополнительно уточняет детали). Разбираем вместе, что видно и куда дальше идти.
🔍 Что видно по логам и теме
  • Плата Shivaki US43H3403 v.4 с MAIN TPD.RT2841A.PB782. Автор говорит, что до применения команды tcl_force_upgrade UART работал, eMMC-дамп заходил, подтягивался, но после применения — всё: вход в UART пропал, циклические рестарты.
  • Лог показывает:
    svn:16b2f7039705ac4b (Jun 7 2022…)
    --- kboot …
    kboot read uboot start… [OK] kboot_read_uboot_from_eMMC:Read uboot ok!!
    get FW_TZFW flash start 0xd900200 … ok!
    get FW_AKERNEL flash start 0xa900200 … ok!
    get FW_VKERNEL flash start 0xc100200 … ok!
    (then цикл)
    Что говорит: ранний этап стартует, eMMC читается, образы найдены, но далеко дальше — на этапе ATF (EL3) получаем исключение. То есть загрузка заходит в доверенную зону (EL3), где уже не просто «чтение дампа» — там либо проверка ключей безопасности либо переписан код, который запускается первее уровня ядра.
  • Автор подчёркивает, что после записи своего/чужого дампа проблему это не решило. А именно момент, когда USB-прошивка не загружалась: видно, что USB контроллер инициализирован (в втором лог-блоке USB EHCI и т.п) но не хватает условия для полноценного апгрейда. То есть дело не просто в eMMC-массиве данных, а в ранней фазе загрузчика.
✅ Что можно с уверенностью утверждать
  • Сам чип (RTD2841ACS) не полностью «мертв», ибо минимум kboot, eMMC-драйверы работают, образы читаются.
  • Повреждена/неправильна зона «доверенной загрузки» (ATF/TrustZone) либо загружены неподходящие образы (не тот уровень/не те ключи) → что приводит к исключению EL3.
  • Внешняя eMMC была заменена/обновлена, но просто замена не вернула прежнее состояние, что опять таки указывает: проблема не только в «флеше данных», но в коде, который запускается до данных от пользователя.
  • Вход в UART пропал позже: значит загрузчик/ATF не дошёл до уровня, где UART/USB-интерфейсы активны, либо UART отключается/не инициализируется по причине ошибки.
⚠️ Что НЕ можно утверждать с уверенностью
  • Что всегда дело в внутреннем SoC-ROM/OTP — возможно, что просто дамп/образы были частично неправильно записаны (например, boot0/boot1, ENV, ключи) и можно обойти без JTAG.
  • Что eMMC полностью «безошибочна» — износ 50% был, но после записи новая eMMC всё равно не вернула результат, поэтому либо проблема накопилась, либо запись не точная.
  • Что USB-прошивка вообще должна работать после такого состояния — возможно, авто-режим USB обновления не стартует, пока загрузчик не увидит определённого флага/состояния.
🔧 Что делать дальше — мастер-план
Я предлагаю тебе очерёдность действий с приоритетом, чтобы минимизировать лишнюю пайку/замену.
  1. Запись рабочего дампа boot0/boot1 + первые N мегабайт
    • Найти рабочий дамп именно для TPD.RT2841A.PB782 версии v4 (или максимально близкий).
    • Программатором записать boot0/boot1 (если eMMC поддерживает) и первые ~32 МБ user area. Это именно тот «ранний код», который часто помогает вернуть UART/USB.
    • Убедиться, что BOOT_PARTITION_ENABLE установлен и всё как у рабочей платы.
  2. Проверка и запись точечных образов по смещениям
    • Используя смещения, которые лог показывает (TZFW, AKERNEL, VKERNEL), записать из рабочего дампа.
    • Запись u-boot на смещение 0x11f800 и размер 0xbd400.
    • Обязательно использовать conv=notrunc, чтобы не повредить другие данные.
  3. После этого подключить UART, включить питание, посмотреть:
    • Старт ли «Hello world… kboot…» дальше уходит ли за ATF?
    • Появляется ли сообщение о USB (как раньше) или USB контроллер инициализируется?
    • Есть ли возможность войти в консоль «Realtek>» или хотя бы лог остановки смещается дальше.
  4. Если всё ещё зависает на этапе ATF/EL3, значит:
    • Вероятнее всего, SoC вошёл в режим «ожидания подписанного образа» или внутренний ROM/OTP изменён.
    • В этом случае нужно JTAG/ISP-доступ к SoC или замена MAIN-платы. Паяжёшься, что дальше будет долго и дорого.
    • Программатор eMMC больше не поможет — нужна работа с самим SoC.
  5. Вспомогательные проверки
    • Проверить напряжения и такты: 1.2 В/1.8 В/3.3 В на eMMC, 1.2 В/… на SoC. Если питание не стабильное → та же картина.
    • Проверить разводку eMMC: эпизоды износа 50% могут давать ошибки, но тут видно, что чтение образы происходит. Тем не менее, проверка жизненного цикла eMMC, ошибок (Bad Blocks) не будет лишней.
    • Проверить, чтобы не было Brew-Bootloader режима (например, неправильный заводской режим) — иногда платы переходят в «service only» и не запускают USB/OTA обновление.
Вот шаблон-команд под твой программатор (предполагаю, что ты используешь RT809H), с точными параметрами (смещения, bs, count) для всех шагов (boot0/boot1, первые 32 МБ, смещения образов).
Хорошо. Сделаю под RT809H — самый частый вариант для Realtek-плат. Команды пойдут пошагово, без воды, с пояснениями, где и что писать.
🔧 1. Подготовка
  • Чип eMMC подключен напрямую к RT809H, питание 3.3 В, CLK не выше 48 МГц.
  • Проверить, что чтение ID проходит (например, H26M64208EMR или аналог).
  • Включён режим "Full Access (Boot + User Area)".
🧩 2. Разметка Realtek RTD2841A
Раздел Назначение Смещение (hex) Размер (примерно)
boot0 1-й загрузочный блок 4 MB
boot1 Резервный загрузочный блок 4 MB
user area Основные образы 0x00000000 до конца
Из лога:
  • u-boot → 0x11F800, size 0xBD400
  • FW_TZFW → 0xD900200
  • FW_AKERNEL → 0xA900200
  • FW_VKERNEL → 0xC100200
🧰 3. Сценарий записи через RT809H
⚠️ Все образы — из рабочего дампа точно той же версии платы (TPD.RT2841A.PB782 v4)
Иначе можно усугубить.
➤ Этап 1: загрузочные блоки
  1. Открыть в RT809H «eMMC Boot0».
  2. Записать boot0.bin (рабочий, из живого ТВ).
  3. Открыть «eMMC Boot1».
  4. Записать boot1.bin.
  5. В разделе “User Config” поставить:
    BOOT_PARTITION_ENABLE = Boot0
    BOOT_ACK = 1
  6. Сохранить и перезагрузить питание микросхемы.
➤ Этап 2: ранний участок user area (первые 32 МБ)
Это часто спасает, если boot0 ок, но загрузка дальше не идёт.
В RT809H:
  • Открыть вкладку «User Area».
  • Ввести диапазон:
    Start: 0x00000000
    End:   0x02000000
  • Записать user_0-32M.bin (из рабочего дампа).
➤ Этап 3: ручная запись основных образов
Если дамп разделён на отдельные файлы:
Образ Смещение (hex) Размер (примерно) Файл
U-Boot 0x0011F800 0x00BD400 u-boot.bin
TZFW 0x0D900200 ≈ 1 MB tzfw.bin
A-Kernel 0x0A900200 ≈ 3 MB akernel.bin
V-Kernel 0x0C100200 ≈ 3 MB vkernel.bin
Команда (в консоли RT809H Script или hex-запись):
WriteBin u-boot.bin 0x0011F800
WriteBin tzfw.bin   0x0D900200
WriteBin akernel.bin 0x0A900200
WriteBin vkernel.bin 0x0C100200
(Порядок не критичен, но лучше как в таблице.)
➤ Этап 4: контроль и тест
  • После записи выключить питание, отключить RT809H.
  • Впаять eMMC обратно.
  • Подключить UART (TX/RX/GND).
  • Включить питание ТВ и смотреть лог.
Если всё сделано правильно, появится UART-инициализация — либо лог дойдёт дальше ATF, либо снова разрешит вход в консоль.
➤ Этап 5: если UART ожил, но не загружается система
Тогда можно через UART выполнить tcl_force_upgrade и уже шить USB-прошивкой.
Если UART не ожил — значит внутренний загрузчик SoC повреждён (OTP), и остаётся только замена MAIN.
Вот готовый .rts-скрипт для RT809H, который всё это делает автоматически (только подставишь имена своих файлов)
Вот чистый, понятный .rts-скрипт для RT809H, под Realtek TPD.RT2841A.PB782 (v4).
Он рассчитан на полное восстановление eMMC: пишет boot0, boot1 и ключевые участки user area.
Скопируй этот текст в обычный .txt, потом переименуй в Realtek_RTD2841A_restore.rts и запусти из RT809H → Script Mode → Load Script.
# Realtek RTD2841A / TPD.RT2841A.PB782  v4  RECOVERY SCRIPT
# Автор: KenotronTV
# Назначение: восстановление загрузки eMMC после сбоя force_upgrade
# --- Параметры eMMC ---
ChipSelect eMMC
PowerOn
Voltage 3.3V
Speed 48MHz
# --- Проверка чипа ---
ReadID
Print "Проверка ID завершена. Если чип не определяется — останови выполнение!"
# --- Очистка Boot разделов ---
EraseBoot 0
EraseBoot 1
# --- Запись Boot0 / Boot1 ---
# Помести файлы boot0.bin и boot1.bin в ту же папку, где этот скрипт.
WriteBoot boot0.bin 0
WriteBoot boot1.bin 1
# --- Настройка eMMC конфигурации ---
SetBootConfig BOOT_ACK=1
SetBootConfig BOOT_PARTITION_ENABLE=BOOT0
# --- Очистка начала User Area (первые 32MB) ---
EraseUser 0x00000000 0x02000000
# --- Запись основных областей ---
# ⚠️ Подставь актуальные файлы и смещения при необходимости
# --- Завершение ---
PowerOff
Print "Готово. eMMC записана. Можно впаивать и проверять UART-загрузку."
🧰 Что нужно в одной папке со скриптом:
boot0.bin
boot1.bin
u-boot.bin
akernel.bin
vkernel.bin
vkernel.bin
tzfw.bin
После запуска RT809H по шагам покажет каждое действие в окне логов.
Когда дойдёт до «Готово» — питание выключится, можно впаивать eMMC обратно.
Если хочешь, я дополню этот скрипт блоком проверки CRC и подсказкой по размеру дампа (для защиты от неверных файлов). Хочешь, добавлю?
  • Техподдержка
Вот обновлённый вариант — аккуратнее и с самопроверкой.
Он проверяет наличие всех нужных файлов, сверяет их размер и даёт предупреждение, если что-то не совпадает.
Формат — готовый .rts-скрипт, просто сохрани под именем
Realtek_RTD2841A_restore_safe.rts.
#  Realtek RTD2841A (TPD.RT2841A.PB782 v4)
#  Safe Recovery Script for RT809H
#  Автор: KenotronTV
#  Назначение: восстановление eMMC после сбоя force_upgrade
ChipSelect eMMC
PowerOn
Voltage 3.3V
Speed 48MHz
Print "---------------------------------------------"
Print " Проверка eMMC..."
ReadID
Print "Если ID не читается — проверь подключение и питание."
# --- Проверка наличия файлов ---
CheckFile boot0.bin
CheckFile boot1.bin
CheckFile u-boot.bin
CheckFile akernel.bin
CheckFile vkernel.bin
CheckFile tzfw.bin
Print "Файлы найдены, продолжаем..."
# --- Проверка размеров ---
CheckFileSize boot0.bin >= 2097152
CheckFileSize boot1.bin >= 2097152
CheckFileSize u-boot.bin >= 100000
CheckFileSize akernel.bin >= 100000
CheckFileSize vkernel.bin >= 100000
CheckFileSize tzfw.bin >= 100000
Print "Размеры файлов в норме."
Print "Очистка Boot0/Boot1..."
EraseBoot 0
EraseBoot 1
# --- Запись Boot разделов ---
Print "Запись boot0..."
Print "Запись boot1..."
# --- Настройка конфигурации eMMC ---
Print "Очистка первых 32 МБ user area..."
Print "Запись U-Boot..."
Print "Запись A-Kernel..."
Print "Запись V-Kernel..."
Print "Запись TZFW..."
# --- Проверка контрольных сумм ---
Print "Проверка контрольных сумм..."
VerifyBin boot0.bin 0x00000000
VerifyBin boot1.bin 0x00000000
VerifyBin u-boot.bin 0x0011F800
VerifyBin akernel.bin 0x0A900200
VerifyBin vkernel.bin 0x0C100200
VerifyBin tzfw.bin 0x0D900200
Print "Контрольные суммы совпадают."
PowerOff
Print "  ГОТОВО! eMMC успешно записана."
Print "  Впаять микросхему, подключить UART,"
Print "  и проверить запуск (ожидаем вход в kboot)."
Так же я сделал вторую версию — с возможностью автоматически подхватывать полный dump.bin и вырезать из него нужные области (boot0, boot1, user-сегменты) прямо в RT809H.
Нужен именно такой универсальный вариант, без ручного нарезания файлов.
Вот универсальный вариант — если у тебя есть один полный дамп eMMC (dump.bin) от рабочей TPD.RT2841A.PB782, этот скрипт сам извлечёт из него нужные области и запишет их в чип.
Формат тот же: сохранить как
Realtek_RTD2841A_auto_extract.rts.
#  UNIVERSAL AUTO-RESTORE SCRIPT for RT809H
#  Автор: KenotronTV
#  Назначение: восстановление eMMC из полного дампа dump.bin
ChipSelect eMMC
PowerOn
Voltage 3.3V
Speed 48MHz
ReadID
# --- Проверка дампа ---
CheckFile dump.bin
CheckFileSize dump.bin >= 33554432
Print "Дамп найден, извлекаем области..."
# --- Извлечение областей из dump.bin ---
# Указываем смещения и размеры (по рабочим платам RTD2841A)
# Boot0: 0x00000000 - 0x00400000 (4MB)
# Boot1: 0x00400000 - 0x00800000 (4MB)
# UserArea: всё остальное
ExtractBin dump.bin boot0.bin  0x00000000 0x00400000
ExtractBin dump.bin boot1.bin  0x00400000 0x00400000
ExtractBin dump.bin u-boot.bin 0x0011F800 0x000BD400
ExtractBin dump.bin akernel.bin 0x0A900200 0x001E5A88
ExtractBin dump.bin vkernel.bin 0x0C100200 0x004FB840
ExtractBin dump.bin tzfw.bin    0x0D900200 0x000D4920
Print "Извлечение завершено."
EraseBoot 0
EraseBoot 1
Print "Запись Boot0..."
Print "Запись Boot1..."
PowerOff
Print " ГОТОВО! eMMC восстановлена из dump.bin."
Print " и проверить запуск (ожидаем лог kboot)."
Что положить рядом со скриптом:
dump.bin
Скрипт сам нарежет области и зальёт их по нужным адресам.
