LiVan Опубликовано 22 февраля, 2014 Опубликовано 22 февраля, 2014 LCD SHAPR LC-15SH1E, SHARP LC-22SV2E 2. Entering the adjustment processing mode There are the following two methods. • Setting the pin (81)(KEY4) or pin (82)(KEY5) of IC2001 (microprocessor) to GND, turn on the power. • A "POWER" key is made on with pushing an "TV/VIDEO" and "MENU" keys at the same time. (K of the inspection process mode is displayed by the upper left of the image plane.) → Next, "CH (Ù)" and "VOL (–)" keys are pushed at the same time.(It becomes the image plane of the adjustment process mode.)..... When it is canceled, it is made to turn it off.(Even off in the "MAIN POWER" key, off with R/C are good.) 3.Key operation in the adjustment process mode • The receiving channel UP/DOWN is performed with the "CH (ù)/(Ù)" keys. One push ... The UP/DOWN tuning is performed per channel. Continuous push ... The UP/DOWN search is performed until a next receivable station is found. • Various adjustments The adjustment is performed for each item by the "MENU", "Menu cursor", "CH (ù)/(Ù)" or "VOL (+)/(–)" keys (LCD TV set and remote control). • Adjustment item is chosen with the Menu cursor upward/downward keys. • The adjustment item makes a toggle operation with the "MENU" key input. (Next item) If the "MENU" key is input while the bottom item is selected, it moves to the top item on the next page. • Press the auto preset button on the remote controller in the adjustment process mode, and the top item of the next page will show up regardless of which item appears now. Page 1 → Page 2 → ... → Page 66 → Page 1 • Press the manual memory button on the remote controller in the adjustment process mode, and the top item of the same page will show up. • UP/DOWN of each adjustment vale selected is performed with the VOL (+)/(–) keys input Обычный 2. Вводя сборочную обработку способа Есть следующие два метода. o Установка штырька (81)(KEY4) или штырек (82)(KEY5) IC2001 (микропроцессор) в GND, включать мощность. o клавиша "МОЩНОСТИ" сделана на с проталкиванием "ТВ/ВИДЕО" и клавиши "МЕНЮ" в то же самое время. (K Режим процесс проверка отображен верхним слева от образа plane.)? Затем, "CH (?)" и "VOL (-)" клавиши выталкиваются в то же самое время. (Это становится плоскостью образа сборочного режима процесса.)..... When отменено, сделано, чтобы становиться этим.(Даже на клавише "ОСНОВНОЙ МОЩНОСТИ", с R/C - good.) 3.Key операция в сборочном режиме процесса o получающий канал ПО/ВНИЗ выполнен "CH (?)/(?)" клавиши. Один толчок... UP/ВНИЗ настройка выполнена за канал. Непрерывный толчок... UP/ВНИЗ поиск выполнен пока следующая годная к принятию станция не будет обнаружена. o Различные установки Установка выполнена для каждого пункта "МЕНЮ", "курсор Меню", "CH (?)/(?)" или "VOL (+)/(-)" клавиши (LCD ТВ установленное и дистанционный контроль). o пункт Установки выбран курсором Меню вверх/вниз клавиши. o сборочный пункт делает переключатель операцией с клавишей "МЕНЮ" вводиться. (Следующий пункт) Если клавиша "МЕНЮ" является вводом тогда как нижний пункт выбран, он перемещает на верхний пункт на следующей странице. o Нажмите авто инициализировать кнопку на дистанционном диспетчере в сборочном режиме процесса, и верхний пункт следующей страницы появится независимо от из которого пункт появляется теперь. Страница 1? Страница 2? ... ? Страница 66? Страница 1 o Нажмите ручную кнопку памяти на дистанционного диспетчера в сборочном режиме процесса, и верхний пункт той же самой страницы появится. o ПО/ВНИЗ каждой выбранной сборочной долины выполнен VOL клавиш (+)/ ввод(-) SHARP LCD SHARP LC-32WD1 Панель SHARP, чипсет-PHILIPS (NXP, TDA15134) нужен вход в сервис. On the remote control, press MENU. • The TV Menu screen displays. 2. Enter the PIN code “1147”. • Using the number keypad, press 1, then 1, then 4, and then 7. (Each button in the sequence must be pressed immediately after the button before it or the television will not recognize the entry code.) В дистанционном контроле, нажмите МЕНЮ. o экран Меню ТВ отображается. 2. Введите коду ШТЫРЬКА "1147". o Использование вспомогательной клавиатуры числа, нажатие 1, затем 1, затем 4, и затем 7. (Каждая кнопка в последовательности должна нажиматься немедленно после кнопки прежде, чем это или телевидение не признает код входа.) SHARP LC-32AD5RU СоставTV: IXB698WJ (VCT6993), IXB664WJ (PIC16F913) Слева направо: "vol -" "vol+" "ch-" "ch+" "enter" "power"(без фиксации) SHARP LC32P70E 1.Нажать и удерживая на тv VOL- & Input вставь розетку. 2.Одновременно на тв VOL-&-P 3.На пульте i . 4 На пульте кноп Mute . LCD SHARP LC-32D44R4-BK шасси PSD-0550 и есть надпись RUNTKA39GWJQZ БП перв. цепь собрана на К4096 иК4887 Проц.SHARP T3Z18AFG-0003 Деж.режим есть,после включения загорается зеленая на несколько секунд и вырубается обратно в деж. Трансы на лампах проверил все в норе обрыва нет . Попытался войти в сервис AV -Vol- удерживая на передней панель и включ. в розетку . Телевизор включается загорается зеленая экран не светится через несколько секунд появляется изображение и звук на 2-3 секунды и пропадает всё сервисного меню не видно как и буква"К". SHARP LC-26P50E Вход и выход из режима настройки процесса (1) Отключите кабель питания переменного тока работает телевизор, чтобы заставить выключения питания. (2) Удерживая нажатой кнопку "VOL (-)" и "INPUT" ключи на множество одновременно, подключите шнур питания, чтобы включить питание.К письму появляется на экране. Sharp LC-20S5E, вход в сервис Проц VCT 6773G B3 000, VOL DOWN на tv и 9 на ПДУ держать и POWER ON SHARP три варианта входа в сервисное меню TV Вход в сервисное меню: # Нажимаем на клавишу MENU # Входим в аудионастройки. # Далее в баланс # Быстро набираем на ПДУ --> 0532 # ТВ должекн перейти в севисный режим. # Для выхода из СМ нажимаем клавишу "сеть" на ПДУ. 2й вариант входа в сервисное меню: # ТВ должен находиться в выключеном состоянии. # Нажать и удерживать кнопки "VOLUME -- " и "MENU" на телевизоре и включить его кнопкой "ON/OFF". Кнопки "VOLUME -- " и "MENU" не отпускать пока ТВ не засветит экран. В верхнем левом углу должна засветиться надпись. # Нажать одновременно кнопки "PR-" и "MENU". # Далее навигация пультом. Для выхода из сервисного меню необходимо выключить ТВ кнопкой "ON/OFF" на телевизоре. # Нажать и удерживать кнопки "VOLUME - " и "MENU" на телевизоре включить ТВ кнопкой "ON/OFF". Кнопки "VOLUME - " и "MENU" не отпускать пока ТВ не засветит экран. 3й вариант входа в сервисное меню: # Выключаем ТВ кнопкой "Power" # Нажимаем на ТВ кнопки "Vol --" и "INPUT" # Удерживая их включаем телевизор. В левом углу появляется буквочка К # Нажимаем на ТВ кнопки "Vol--" и "P--" - появляется меню сервиса. Для выхода из сервисного меню необходимо выключить ТВ кнопкой "ON/OFF" на телевизоре. # Нажать и удерживать кнопки "VOLUME - " и "INPUT" на телевизоре включить ТВ кнопкой "ON/OFF". Кнопки "VOLUME - " и "INPUT" не отпускать пока ТВ не засветит экран. LC-15SH1E, LC-13SH1E проц. TDA 15521Е, IXA370WJ Вход в сервисное меню: Выключить ТВ.Нажать кнопки "Input" и "Volume (–)" Удерживая их, включить ТВ. шасси 4BS-C DV-6340S, DV-7032S Проц. SAB8032 Чтобы войти в сервисный режим необходимо на блоке VIDEO соединить терминалы (2) и (6). выход POWER OFF шасси 5BS 37/54AM-12SC, 37/54M-16SC, 37/54AM-23SC Проц. IX1572BMNO (SDA20561-A529) Удерживая клавиши (VOL-) и (CH +) на панели TV включить телевизор сетевой кнопкой. выход (MODE) шасси 5BS-A 54AT–15SC Удерживая клавиши (VOL-) и (CH +) на панели TV включить телевизор сетевой кнопкой. Выход POWER OFF шасси 11AK45B5 29 MF 92 ERU В рабочем режиме нажать MENU 4 7 2 5 Шасси BCTV-A DV-5935H Проц. SAB8032 Установите перемычку между выводом 2 (корпус) и выводом 6 (SV) расположены на сигнальной плате ТВ. Включите ТВ и снимите перемычку. выход Поставьте перемычку. ВЫКЛ ТВ снимите перемычку. шасси CA-1 54DT-25SC, 54DT-26SC Проц. IX1655BMN1, IX1669BMNO (SDA5222) Удерживая клавиши (VOL-) и (CH +) на панели TV включить телевизор сетевой кнопкой. выход (MENU) шасси CA-10 66DS-03H, 66DS-05H, 66ES-03H, 66ES-05H, 70DS-03S, 70DS-05S,70ES-03S, 70ES-05S Проц. IX1629BM (SAB-C161K-L16Q) Удерживая клавиши (VOL-) и (CH +) на панели TV, включить телевизор сетевой кнопкой. выход (MENU) на пульте ДУ шасси CA100, DA100 удерживая VOL- и CH+ на передней панели ТВ включите сетевую кнопку. Для выхода из меню выключите ТВ сетевой кнопкой. Шасси D3000 DV-25071S Нажмите на переключатель S1401 расположенный в модуле RWB-B выход Нажать на S1401 повторно. Шасси EURO-DS1 DV-5101H DV-5103H Проц. CCU3000 Установите перемычку между выводом 2 (корпус) и выводом 6 (SV) расположены на сигнальной плате ТВ. выход Нажать (SKIP) на ПДУ. Выключить ТВ Снять перемычку. шасси EURO-DS1 DV-5403S DIGITAL Проц. CCU3000 Для входа в сервис необходимо на плате цифрового модуля цветности кратковременно замкнуть контакты "Сервис" возле самой верхней микросхемы КМ6264BLG-10. Выход - вторично замкнуть эти контакты. Service: »Shuntar Pins 2 e 6 da ficha CN1 no modulo de Video -Navegar » Ch+/Ch- -Alterar » Vol+/Vol- -Memo » St By -sair » Shuntar os mesmos pins -Para navegar em NVM Value utilizes tecla Mono/Stereo -c/ comando Visa global » Cod 1077 -Mono/St » Tecla dupla de Menu- Ex de Valores: Sharp Service Mode V1.2 54035 Hor Phase Shift - 93 Blanking Phase - C5 Vertical Phase - 35 Vertical Size - 0A B0 S-Correction Vertical Simmetry-00 44 NVM Value - 00 AE Croma-Luma Delay- A0 VCO Adjust - 3F F9 Cut-Off Red - 20 Cut-Off Green - 20 Cut-Off Blue - 20 Drive Red - AE Drive Green - AC Drive Blue - AC шасси GA-6 21L-FG1SX, 21L-FG1RU, 21M-FG1RU, Процессор IXB725WJN1 Для входа в сервисный режим необходимо нажать одновременно клавиши (VOL-) и (CH +) на панели TV и далее включить телевизор сетевой кнопкой. Когда появится растр, нажать кнопку MENU. Выход POWER OFF шасси GA-200 32JV-76E проц. SDA6000 Удерживая клавиши (VOL-) и (CH +) на панели TV включить телевизор сетевой кнопкой. выход (STANBY) • Use the channel up and down buttons to move between the options. • Use the volume control buttons to change the data. • To store the data: use the Stand-by button(1) or Store button(11) on the remote control. • To exit the Service Mode, turn the receiver off using the Main switch. Note: In this Service Mode, by using the colour buttons of Remote Control is possible to pass directly to the adjustments that are indicated inside of each coloured box (see Figure 2), as follows. Press the RED button to access to Geometry adjustments. Press the GREEN button to access to NVM adjustments. Press the YELLOW button to access to Automatic Gain Control adjustments. Press the BLUE button to access to CUT OFF adjustments. шасси PAL-A 14D-SC, 14B-SC, 20B-SC, 14D-CM, 21D-CK1, CV-2132CK1 проц. IX1704CENI На плате телевизора установите переключатель S1008 в позицию сервисного режима. выход S1008 шасси S3B DV-5450SC, DV-5451S, DV3760 DV-3750S Проц. IX1492BMN1 IX1492BMZZ Чтобы войти в сервисный режим необходимо на блоке VIDEO соединить терминалы (2) и (6). (Замкнуть вывод 5 процессора на массу) После чего нажмите кнопку MODE на пульте ДУ. Появится сообщение -SERV-. Затем удалите перемычку. Выбор регулировки (СН-) и (СН+). выход (MODE) шасси SC 63CS-03SC, 70CS-03SC, 70AS-05S. проц. SAB-С502 Удерживая клавиши (VOL-) и (CH +) на панели TV, включить телевизор сетевой кнопкой. выход (STANBY) шасси SP-42M 25FN1, 29FN1 Проц. M37210M4-775SP На плате телевизора установите переключатель S1001 в позицию сервисного режима. Для вывода на экране поочередно режимов нажимайте на клавишу S-MODE на пульте ДУ. выход S1001 Шасси SP-51 14/21JN1 Для входа в меню необходимо подать +5 вольт на 37 ножку процессора. шасси SP-70 21FN1 Проц. IX2938CEN2 Для входа в меню необходимо установить переключатель S1006 в позицию сервисного режима. Для вывода на экране поочередно режимов нажимайте на клавишу S-MODE, S-NORM на пульте ДУ, изменение значения клавиши на пульте стрелка вверх, вниз. Значения системного меню: 1. SERVICE MODE - сервисный режим. 2. CUT OFF BKGD MODE - режим отсечки фона. 3. H-CENT50 х/15 - горизонтальное смещение (50 Hz) 4. H-CENT60 х/15 - горизонтальное смещение (60 Hz) 5. RF AGC х/63 - ? 6. VCO х/63 - ? 7. SUB CON х/127 - регулировка контрастности. 8. SUB COL х/127 - регулировка цвета. 9. SUB BRI х/127 - регулировка яркости. 10. SUB TIN х/127 - ? 11. SUB VOL х - регулировка громкости 12. RF SUB VOL х/127 - громкость 13. BB CON х/127 - регулировка контрастности синего фона 14. BB BRI х/127 - регулировка яркости синего фона 15. D-TRAP SINGLE (DOUBLE) - ? 16. F-TRAP HIGH (LOW) - ? ,где х – числовой параметр кокретного телевизора, второе число мах ругулировки, пример: “H-CENT50 5/15”. выход S1006 шасси VP-2 VT-1428M, VT-2128M Установите телевизор в дежурный режим, и нажмите кнопки на пульте в следующей последовательности CH UP в течение 2 или более секунд и одновременно нажмите кнопку POWER. Выход (MENU) шасси VP-6. Видеодвойка Sharp VT-1448M,VT-2148M 1. Вызов сервисного режима. а.Войдите в режим STBY б.На ТВ нажмите кнопку СН^ и удерживая ее в течении не менее 2сек, нажимаем на ТВ кнопку STBY. с.Телевизор перешел в сервисный режим. 2. Параметры сервисного режима высвечиваются в нижнем левом углу экрана и выбираются кнопками СН+ и СН-, а данные изменяются Vol+ b Vol-. 3. В режиме прямого доступа DIREKT MODE цифровыми кнопками ПДУ настраивают : R CUT OFF - 1 ( + ) - 4 ( - ) G CUT OFF - 3 ( + ) - 6 ( - ) B CUT OFF - 2 ( + ) - 5 ( - ) G DRIVE GAIN - 7 ( + ) - cтрелки ( - ) B DRIVE GAIN - 8 ( + ) - 0 ( - ) 4. Выход из сервисного режима. а.Нажать кнопку MENU на пульте управления. б.Переключить ТВ в режим STBY. в.Выключить сетевое питание на ТВ 14R-SC/M8/M10, 14R-W, CV-14RU, 21FN1 На плате телевизора установите переключатель S1006 в позицию сервисного режима. 21D1, 21D2 Проц. IX3368CE (TDA9381): Для входа в сервисный режим необходимо закоротить перемычки JA137 и JA138 на короткое время, находясь в рабочем режиме. Выход из режима - ещё раз закоротить перемычки. Перемычки находятся левее видеопроцессора, под ними овальная прорезь в плате. Настройки осуществлять с пользовательского ПДУ типа G1342SA: CHANELL UP/DOWN -перемещение по меню ; VOLUME +/- -изменение настроек. Запоминание автоматическое. 54DT-25SC Снятие ключа: Метод первый - Одновременно (VOL-) на TV и ключевую кнопку на пульте. Метод второй - нецивилизованным методом... одновременно нажмите кнопку звук минус и канал плюс, включите телевизор, попадете в сервис, каналом плюс доберитесь до NVM memory, затем звуком плюс доберитесь до ячейки 4D и измените её на 00. 72AS-18SN. Вход в сервис одновременно нажать СН+ и VOL- и включить телевизор. Сохранение измененной информации - на пульте нажать "STAND BY"и выключить телевизор. KenotronTV 🛠 Contact ✉ Мы здесь, чтобы ответить на ваши вопросы! 💬 Задавайте вопросы и получайте быстрые ответы.
LiVan Опубликовано 30 ноября, 2014 Автор Опубликовано 30 ноября, 2014 LCD SHARP LC-32D44R4-BK Chassis PSD-0550 (RUNTKA39GWJQZ) Power К4096, К4887 CPU SHARP T3Z18AFG-0003 Это скрытый контент, для просмотра сообщения Вы должны быть Участником форума. Войти или Регистрация Вход в сервис: нажимаем две кнопки и держим VOL- и EXT (AV), до появления буквы К слева сверху, которая указывает, что Вы вошли в сервисный режим. Потом нажимаем две кнопки VOL- и P- и входим в опции KenotronTV 🛠 Contact ✉ Мы здесь, чтобы ответить на ваши вопросы! 💬 Задавайте вопросы и получайте быстрые ответы.
brabus6655 Опубликовано 29 июля, 2018 Опубликовано 29 июля, 2018 Sharp LC-32SA1RU Выключить телевизор кнопкой "Power", нажимаем на TV кнопки "Vol -" и "->" удерживая их включаем телевизор. В левом углу появляются буквы "kkkk" Выход из сервисного меню. Находясь в "меню" выключаем телик кнопкой "Power". Нажимаем сверху на телике кнопки "Vol -" и "(-> ", удерживая их включаем телевизор. В левом углу буквы "kkkk" должны исчезнуть (если включить телик просто так - они появятся снова) Общие часто применяемые действия входа в сервис TV SHARP: - Первый вариант: Телевизор должен находиться в выключенном состоянии. Нажать и удерживать кнопки "VOL -" и "MENU" на телевизоре и включить его кнопкой "ON/OFF". Кнопки "VOL - " и "MENU" не отпускать пока ТВ не засветит экран. В верхнем левом углу должна засветиться надпись. Нажать одновременно кнопки "PR-" и "MENU". Для выхода из сервисного меню необходимо выключить ТВ кнопкой "ON/OFF" на телевизоре. Нажать и удерживать кнопки "VOLUME - " и "MENU" на телевизоре включить ТВ кнопкой "ON/OFF". Кнопки "VOL - " и "MENU" не отпускать пока ТВ не засветит экран. Для выхода из сервисного меню необходимо выключить ТВ кнопкой "ON/OFF" на телевизоре. Нажать и удерживать кнопки "VOL - " и "MENU" на телевизоре включить ТВ кнопкой "ON/OFF". Кнопки "VOL - " и "MENU" не отпускать пока ТВ не засветит экран. - Второй вариант: Выключаем ТВ кнопкой "Power" Нажимаем на ТВ кнопки "Vol -" и "INPUT" Удерживая их включаем телевизор. В левом углу появляется "К" Нажимаем на ТВ кнопки "Vol-" и "P-" - появляется меню сервиса. Для выхода из сервисного меню необходимо выключить ТВ кнопкой "ON/OFF" на телевизоре. Нажать и удерживать кнопки "VOL - " и "INPUT" на телевизоре включить ТВ кнопкой "ON/OFF". Кнопки "VOL - " и "INPUT" не отпускать пока ТВ не засветит экран. - Третий вариант: Нажимаем на клавишу MENU Входим в аудио настройки. Далее в баланс Быстро набираем на ПДУ --> 0532 ТВ должен перейти в сервисный режим. Для выхода из СМ нажимаем клавишу "сеть" на ПДУ. - Четвертый вариант: Нужно включить телевизор, нажать Menu на пульте, подождать, пока появятся все иконки и нажать на пульте 999222. Для выхода из сервисного меню нажать на пульте Menu или End ( 65х и 75х серий ТВ ). Sharp LC-32LE530E Chassis - 17MB61-3.1 MB - 17MB61-3 (V1) PSU -17PW07-2 Вход в сервис - MENU , 4725 2
brabus6655 Опубликовано 7 августа, 2019 Опубликовано 7 августа, 2019 (изменено) LC-32GD8E Выключить ТВ кнопкой питания. Нажать одновременно и удерживать клавиши INPUT Vol-- на клавиатуре TV и включить TV. Появится картинка c буквой K. Далле нажать одновременно клавиши Vol -, CH-, буква К станет фиолетовой.Что указывает ,что вошли в сервисный режим. Vol+/Vol- регулировки P+/P- навигация Чтобы "Выйти", выключить устройство и подождать 10 Сек. Изменено 7 августа, 2019 пользователем brabus6655 1
brabus6655 Опубликовано 9 августа, 2019 Опубликовано 9 августа, 2019 В 07.08.2019 в 15:49, brabus6655 сказал: LC-32GD8E Выключить ТВ кнопкой питания. Нажать одновременно и удерживать клавиши INPUT Vol-- на клавиатуре TV и включить TV. Появится картинка c буквой K. Далле нажать одновременно клавиши Vol -, CH-, буква К станет фиолетовой.Что указывает ,что вошли в сервисный режим. Vol+/Vol- регулировки P+/P- навигация Чтобы "Выйти", выключить устройство и подождать 10 Сек. Точно такой используется для Sharp LC-46LU820E
