TL866 Application Software
Просмотреть файл
Version: V6.60 Support:14177 --2017.5.09
В архиве: TL866 Application software for win2000/xp/2003/2008/VISAT/win7/win8/WIN10
ADD:
IS25LQ080B/IS25LQ016B /IS25LQ032B
PN25F04A/PN25F04C/PN25F08/PN25F08B
PN25F16/PN25F16B/"PN25F32/PN25F32B
PN25F64/PN25F64B/PN25F128B
GD25LQ05B/GD25LQ10B/GD25LQ20B/GD25LQ40B/GD25LQ80B
GD25LQ16/GD25LQ32C/GD25LQ32D/GD25LQ64C
GD25LQ128/GD25VQ21B/GD25VQ40C/GD25VQ80C
GD25VQ16C/GD25VQ32C/GD25VQ32C/GD25VQ64C
version: V6.50 Support:14037 --2015.12.25
ADD:Support 25 Flash OTP programm
Support 1.8V 25 serials Flash (Need special Adapter DIY)
Ic Support up to 14000+, more detail see IC supported List.
Version: V6.17 Support:13216 --2015.07.11
Fix:ATMEGA48 Algorithm for Compatibility
Version: V6.16 Support:13216 --2015.06.12
Fix:some ATMEGA8 Fuse bits Program
Version: V6.13 Support: 13216 --2015.06.09
Add: Write and Read for DS1245/DS1249/DS1250.
Fix : AM2716B SM8958A(TQFP44) Algorithm
Version: V6.10 Support13207 --2014.07.16
Add:
BG25Q40A BG25Q800A BG25Q160A W25Q16DV W25Q32FV W25Q40CL W25Q64FV W25Q80DV W25Q128FV
Fix : AT25128/AT25160/AT25320 Algorithm for Compatibility.
Ver: V6.00 Support : 13183 --2014.01.07
Add function:
A. Automatic Install for WIN8 System
B. Support simultaneously burn with 4 Programmers each computer.
C. support different DPI display modes for WINDOWS systems.
D. Limited a Fake TSOP48 Adapter
Add:
MD25D40/80/16 GD25Q128C GD25Q128B N25Q032A N25Q064A AT25DF641 Micropchip 93LC46X/56X/66X/76X etc.
Fix:Micropchip 24LC65
Version: V5.91 Support:13143 --2013.03.09
Add:
AB28F200B5-T AB28F200B5-B AB28F400B5-T AB28F400B5-B AB28F800B5-T AB28F800B5-B
Fix:ATTINY24/44/84/25/45/85 Fuse Bits Program
Version: V5.90 Support : 13137 --2013.03.04
Add:
SST 39VF088 AB28F200BX-T AB28F200BX-B AB28F400BX-T AB28F400BX-B JS28F800B3T JS28F800B3B JS28F800C3T JS28F800C3B JS28F160B3T JS28F160B3B JS28F160C3T JS28F160C3B JS28F320B3T JS28F320B3B JS28F320C3T JS28F320C3B
ATTINY24/ATTINY24A/ATTINY24V ATTINY44/ATTINY44A/ATTINY44V ATTINY84/ATTINY84A/ATTINY84V
QB25F016S33B QB25F160S33B QB25F320S33B QB25F640S33B QH25F016S33B QH25F160S33B QH25F320S33B QH25F640S33B
M25P128(25P28V6G) @FPN8 M25P128(25P28V6G) @SOP16 MX25L1605D/3205D/6405D
MX29LV160EB MX29LV160ET MX29LV320EB MX29LV320ET MX29LV640EB MX29LV640ET EN29LV320AT EN29LV320AB EN29LV640B EN29LV640T
Fix:MBM29DL640 Algorithm and Sotware Project Compatibility
Version: V5.80 Support: 13071 --2012.11.01
Add :
1、28C04/16/64/256 @PLCC32
2、M27C801 (DIP32/PLCC32/TSOP32) M25PX80/16
3、Nantronics N25S10/20/40/80/16 MX25L5121E MX25L1021E
4、SST 36VF1601/36VF1602/36VF3203/36VF3204
5、PIC16F72
6、Read and write for DALLAS DS12xxx
7、25 series automatic identification
Fix:SM59R05/09/16G6 Encrypt Algorithm、PIC12C508A Config bits Program
Version: V5.70 Support: 12938 --2012.08.27
Add:
PIC16F/LF722A PIC16F/LF723A PIC16F716(DIP18/SOIC18/SSOP20)
PCF8582 PCF8594 PCF8598 AM24LC21 AM24LC21B BR24C21(F/FJ/FV)
AT24C21 MICROCHIP 24C21 24C21A CAT24C21 ST24FC21 ST24LC21B
ST M29W640FB/FT W25Q128BV
S29JL032Hxxxx, S29JL064Hxxxx S29JL032Jxxxx, S29JL064Jxxxx
Fix: W29C040,PIC16F722/723,S29GLXXXX Compatibility problem.
  • 9 месяцев спустя...
Вышел свежий софт
   (походу последний)
что добавили :    (firmware  обновляется)
ADD:
AK6410/6420/6440/6480 AK6510/6512/6514/6516 BY25Q10/20/40/80/16/32/64/128 K8D1616x/1716x/3216x/6316x K8P1615U/K8P3215U/K8P6415U
Fix:MX25L6475E @SOP16 Algorithm and BR93Hxx Algorithm.
Ну и появилась новая версия программатора  TL866II Plus  (с поддержкой  NAND)
вот чем отличается
Изменено пользователем lyutiy
  • 1 месяц спустя...
Кто-нибудь пробовал нового программиста?TL866II
1. Поддерживает компьютер, одновременно записывающий 4 программиста.
2. Наименьший объем и самое низкое потребление энергии. Единственный интегрированный программист, который на самом деле не нагревается.
3. Все чипы не используют внешний источник питания. Низкое энергопотребление гарантирует, что порт USB может обеспечить достаточную мощность.
4. Лучшая внутренняя 40-контактная защита от перенапряжения, самая сильная VPP, максимальная токовая защита VCC. Короткое замыкание не сбрасывает ПК или программиста. VCC с напряжением от 1,8 до 6,5 В
5. Широкий диапазон поддержки чипов 15000+, поддержка серийной серии, параллельная серия FLASH FLASH 40/44 / 48PIN, поддержка NAND Flash большой емкости.
6. Уникальное последовательное программирование Интерфейс ICSP поддерживает последовательную загрузку и высокоскоростное параллельное высоковольтное программирование.
7. Могут реально протестировать интегральную схему серии 74/54 CMOS4000. Может найти ошибку схемы затвора.
8. Функция серийного номера чипа является наиболее полной и практичной.
9. Оригинальная поддержка микроконтроллера AVR с внутренним байтом коррекции RC. Калибровка операций по объему чипа. Сделать скотч-принудительное программное обеспечение не может работать непосредственно на другом чипе той же модели.
10. Автоматическое обнаружение плохого контакта или неправильная установка штырей микросхемы во избежание повреждения устройства.
  • 2 месяца спустя...
TL866A/CS Application Software( V6.82 )  Support:14318--2018.07.24
ADD: MB85R256H
BQ4010YMA/BQ4011YMA/BQ4013YMA/BQ4014YMA/BQ4015YMA
BQ4011LYMA/BQ4013LYMA/BQ4014LYMA/BQ4015LYMA
FIXED: DS1245/DS1250 Algorithm(read and write)
TL866A/CS  (Old Hardware) новый софт  для старичка (обновляет firmware программатора )
VERSION: V6.85 Support:14337--2018.10.19
ADD: ATF20V8B
FIXED: GAL22V10B M95320W M95128W
