Тайваньский  производитель микросхем SILERGY Сorporation известен нам всем по
AC/DC, DC/DC, LED Drivers ...,под маркировкой SYxxxx
  • SY6288C4CAC (AExxx) MSOP-8
    SY6288DCAC (ABxxx) MSOP-8 -аналог G547B
    SY7200AABC (DQxxx) SOT23-6
    SY7208ABC (CAxxx) SOT23-6
    SY8002BABC (NTxxx) SOT23-6 - аналог SY8065ABC
    SY8003DFC (JDxxx) DFN-8
    SY8009BABC (CUxxx) SOT23-6
    SY8032ABC (FKxxx) SOT23-6 - аналог SY8065ABC
  • SY8063 (ECxxx) DFN-10 3X3 - аналог SY8036LDBC
    SY8065ABC (AExxx) SOT23-6
    SY8120ABC (WBxxx) SOT23-6
    SY6280 (COxxx) SOT23-5
    SY6288AFAC (AAJxxx) SO8
    SY6288BFAC (AALxxx) SO8
    SY6288BCAC (ABDxxx) MSOP8
    SY6288BAAC (CGxxx) SOT23-5
    SY6288CFAC (AAMxxx) SO8
    SY6288DFAC (AANxxx) SO8
    SY6288DCAC (ABExxx) MSOP8
    SY6288DAAC (BUxxx) SOT23-5
  • SY6912A (AIQxxx) SO8E
    SY6952B (ALBxxx) SO8E
    SY7152 (LExxx) SOT23-6
    SY7200 (DWxxx) SOT23-6
    SY7200A (HYxxx) SOT23-6
    SY7201 (DQxxx) SOT23-6
    SY7201ABC (DQxxx) SOT23-6
    SY7201ADC (GJxxx) TSOT23-6
    SY7201AABC (FDxxx) SOT23-6
    SY7208 (CAxxx) SOT23-6
    SY7208B (BLxxx) SOT23-6
  • SY8008AAAC (AAxxx) SOT23-5
    SY8008BAAC (ABxxx) SOT23-5
    SY8008CAAC (ACxxx) SOT23-5
    SY8008AACC (BIxxx) TSOT23-5
    SY8008BACC (BGxxx) TSOT23-5
    SY8009AAAC (ADxxx) SOT23-5
    SY8009BEBC (ASxxx) SSOT23-6
  • SY8088AAC (LDxxx) SOT23-5
    SY8101AEBC (CFxxx) SSOT23-6
    SY8101BEBC (BJxxx) SSOT23-6
    SY8101CEBC (BMxxx) SSOT23-6
    SY8101DEBC (CGxxx) SSOT23-6
    SY8113ADC (MLxxx) TSOT23-6
    SY8133 (AAWxxx) SO8E
    SY8152FAC (ABPxxx) SO8
  • SY8290ABC (TExxx) SOT23-6
    SY8292ABC (HDxxx) SOY23-6
    SY8087AAC (HLxxx) SOT23-5
    SY6874DBC (JTxxx) DFN3x3-10
    SY8086AAC (BExxx) SOT23-5
    SY8089AAC (JXxxx) SOT23-5
    SY8089AAAC (KVxxx) SOT23-5
DC Input LED Lighting Driver
SY8710 - 1MHz , max.30V , max I -2A SOT-236
SY8006 - 1.5MHz ,max.6V , max I- 2.4A SOT-235
Step Up LED Backlight Regulator
SY7201-  Dimming Freq.: 20kHz~1MHz, max. 30V, max I- 300mA , SOT-236. Применяются в  PAD, GPS, MID, Tablet
SY7706 - max 33V , max I- 30mA , поддерживает 6 светодиодов, DFN3x316. Применяются в NB, PAD, Tablet
SY7220 - max.30V , max. 140mA, Применяются в  PAD, GPS, MID, Tablet
SY7201A - max.30V, max. I- 300mA, Применяются в  PAD, GPS, MID, Tablet
Новые микросхемы:
 - High Efficiency, 15A Synchronous Step Up Regulator
 - High Current Step Up Regulator
 - 1.8V Minimum Input and 5. 5V Maximum Output
 - 5.5V Maximum Output, 3A Valley Current, 1MHz Sync Boost
 - 1.5MHz, 5A Continuous/6A Peak, 18V Input Buck
 - High Efficiency, Built-in Inductor, 2MHz, 2A, 23V Input Sync Buck
 - High Efficiency 3MHz, 3A Inductor Built-in Synchronous Buck
 - High Efficiency Fast Response 8A, 23V Input Sync Buck
 - High Efficiency Fast Response 8A Continuous, 16A Peak, 23V Input Buck
 - High Efficiency, Fast Response, 6A, 18V Input Synchronous Buck with I2C Interface
 - High Efficiency Fast Response, 3A, 23V Input Sync Buck
 - Smart-Plug, Smart-Lighting Energy Measurement Processor
 - Common Mode Filter for EMI Solution
 - Compact high power factor/low-THD buck LED driver IC
 - Compact low-ripple buck LED driver IC
 - Compact non-dimmable LED controller IC
AC/DC Converters, WLED Driver, LED backlight, Package Information
