Samsung UE55KU6300U - ищу дамп EMMC KLM4G1FEPD-b031
SAMSUNG UE55KU6300U
Panel: CY-WK055HGAV1V
Main: JAZZ_L_BUILT-IN CODE:BN41-02528A MODEL:BN41-02528
eMMC:KLM4G1FEPD b031
еще не снимал, только пришел - завтра попробую снять, клиент говорил перешивался, когда вырубили свет
@CHEBSERVIS
Connection status: XHCI:HUB3:USB 2.00 High-Speed
Interface: UFI High-Speed
Serial number: 0011-8839-6901
 Boot version: 1.04, FW version: 1.13 (Aug 19 2019 23:46:09)
Insertion test... Done
Init bus...
VCC: 3.3 V, VCCQ: 3.0 V
Bus: 1 bit (SDR 52MHz)
Access mode: sector mode
Power supply: dual-voltage (1.70-1.95V, 2.7-3.6V)
 Card/BGA: BGA (Discrete embedded) - High density MMC
 Manufacturer ID: 0x15 (Samsung)
 Product name: 4FPD3R (0x344650443352), rev: 0x02, serial number: 0xA3AEB4AD
 Manufacturing date: сен 2016
CID: 15010034 46504433 5202A3AE B4AD9310
CSD: D0270132 0F5903FF F6DBFFEF 8E40400C
EXT_CSD revision: 1.7 (MMC v5.0, v5.01)
Partition info:
 Boot1: 4096 KiB
 Boot2: 4096 KiB
 RPMB: 512 KiB
 User area: 3.64 GiB(3,909,091,328 bytes)
Reading extcsd, size: 512 bytes...
File saved to "\\%BACKUPS%\Other\4FPD3R_A3AEB4AD\ext_csd.bin" (CRC32: 0xD2DF924B)
Current partition access:
 Access to boot partition 1
Reading boot1, size: 4 MiB... Done in 1.523 s
File saved to "\\%BACKUPS%\Other\4FPD3R_A3AEB4AD\boot1.bin" (CRC32: 0xF464234F)
 Blank checking: NOT blank
 Access to boot partition 2
Reading boot2, size: 4 MiB... Done in 1.522 s
File saved to "\\%BACKUPS%\Other\4FPD3R_A3AEB4AD\boot2.bin" (CRC32: 0x1147406A)
 Blank checking: blank
 Access to user area
Reading userarea, size: 3.64 GiB...  Failed to read block 0xB4AD0000:65536 (return code: 1, CMD Error: Timeout)
cmd response: 0x900, card status: 0x0, card state: 4 (Card is in transfer state)
 status: unknown (0)
--- Try to decrease the clock speed ---
--- Make sure the connection between BOX and eMMC stable ---
--- please try again (you may RESUME the read process) ---
Видимо, флеха померла..
То, что снялось могу залить куда нить
Тему можно закрыть. Поделился участник из другого форума. гнусмас завелся
