I-star L40A550AN нужна помощь
Перейти к решению Решено nidevil,
Телевизор I-star L40A550AN
Main P75-2842V6.2
Панель V400HJ6-PE1
Пришел с проблемой висит на логотипе. Не могу загрузить его  в recovery mode, чтобы сделать сброс на заводские настройки. Не могу разобраться с командами...
Вот лог. В консоль захожу, но не могу сделать сброс
BI$
Hello world, 285o!{uni}[WEI][arm64]
svn:4a613103623ea907 (Dec 28 2018 13:43:11)
flash_type = 2, secure_type = 2
b8062204=a5
HW off: 146
ABCDE[RPMB]Auth Key not Ready(7)!!!
Test Print1 SB2_CTRL_REG_reg=0x0
Test Print1 SB2_CTRL_REG_reg=0x1
Test Print1 SB2_CPU_FLASH_REGION=0xba20b820
[go atf]U
U-Boot 2012.07 (Aug 03 2020 - 21:13:38) r-hdmi_test_only-1444-g641b575
Mac Address use 00:30:1B:4E:5E:1F in env
ethaddr = 00:30:1B:4E:5E:1F
Factory Address:0x2000000, Size:0x1000000!
Factory Read Only Address:0x1800000, Size:0x400000!
:Y: env_panel_set_default panel_src=1, panel_select=0
:Y: panel use [0]
No match pq file exist!no tmp/factory/bin_panel/PanelParam/vip_default_pq.bin no        tmp/factory/bin_panel/PanelParam/vip_V400HJ6_P_pq.bin
No match pq file at factory!
<<<<<<Panel: V400HJ6_PE1>>>>>>>>
<<<<<<parameter_len: 140 >>>>>>>>
logbuf fifo[0] [buffer=1ca0e000], [size=10000]
logbuf fifo[1] [buffer=1ca1e000], [size=2000]
logbuf fifo[2] [buffer=1ca20000], [size=10000]
logbuf fifo[3] [buffer=1ca30000], [size=10000]
logbuf fifo[4] [buffer=1ca40000], [size=10000]
logbuf fifo[5] [buffer=1ca50000], [size=20000]
logbuf fifo[6] [buffer=1ca70000], [size=10000]
[get_factory_platform_resource:1580]Err:------------can't find tmp/factory/vsc_r        esource.xml!, so parse fail
[get_factory_platform_resource:1597]Err:------------can't find tmp/factory/throt        tle_resource.xml!, so parse fail
[get_factory_platform_resource:1614]Err:------------can't find tmp/factory/cpu_r        esource.xml!, so parse fail
[get_factory_ir_table_from_factory:1550]Err:tmp/factory_ro/ir_table.bin parse su        c, size:272
board_init_r board.c 2021 -- (0) key=0x1b
board_init_r board.c 2021 -- (1) key=0x1b
board_init_r board.c 2021 -- (2) key=0x1b
board_init_r board.c 2021 -- (3) key=0x1b
board_init_r board.c 2021 -- (4) key=0x1b
panel initialize....
panel_init_1st 0529_1022
Disp HTotal=2199, Htotal 4x alignment=2199
den_h_start=140, den_h_end=2060
[uzu] dvtotal(b8028504 = 464)
[uzu] dhtotal(b8028508 = 8970897)
[uzu] dh den start(b8028518 = 8c080c)
[uzu] dv den start(b802851c = 100448)
[uzu] uzudtg control (b8028500 = 80000051)
[memc] dvtotal(b8028604 = 464)
[memc] dhtotal(b8028608 = 8970897)
[memc] dh den start(b802861c = 8c080c)
[memc] dv den start(b8028618 = 100448)
[memc] uzudtg control (b8028100 = 50000)
###### SFG_SFG_CTRL_0_reg : 1 ########
##### drvif_clock_set_dclk : 149000000 ###########
 After Mapping (ulFreq:596000000) (div:4)======
dclk_Temp:662222
nMCode:66, f_code:455
Panel: ulFreq:596000000, nDPLL:0, Mcode:66, Ncode:3, offset:0
 #### 0xb8000208[1c]
 #### [drvif_clock_set_dtg_uzu_div]
 #### 0xb8000208[400001c]
 #### [drvif_clock_set_dtg_memc_div]
=== Panel Type : 0 ===
=== iCONFIG_PANEL_CUSTOM_INDEX : 0 ===
=== RTD285O LVDS FHD tx phy ===[GDMA](Frome bdinfo)BUSH = 499 ; DISP = 148
=== Panel Index : 0 ===
[TCON]No demand of TCON(outputgamma,valc,OD,demura) setting.
panel_init_2nd 6264:
panel_init_2nd
rtk_hw_get_divider M_best:0 N_best:1 freq:4700000 totalcnt:254 duty_max:255
set pwm duty=211  success!!
panel_init_2nd,6313 iLVDS_TO_LIGHT_ON_ms=200
panel_init_2nd,6314 iPANEL_TO_LVDS_ON_ms=50
panel_init_2nd,6315 iLIGHT_TO_LDVS_OFF_ms=200
panel_init_2nd,6316 iLVDS_TO_PANEL_OFF_ms=40
:Y: boot current backlight is on ! [1]
bootparam is NULL. run default sscg.
In:    serial
Out:   serial
Err:   serial
Net:   r8168: REALTEK RTL8168 @0x18016000
Hit Esc or Tab key to enter console mode or rescue linux:  0
------------CONFIG_ANDROID_RECOVERY
------------CONFIG_SYS_RTK_EMMC_FLASH
Press Esc Key
Find CONFIG_BOARD_299S_TV010_BGA_EERPOM
name=PIN_KEYPAD_PWR ppcb_enum.Name=PIN_KEYPAD_PWR, ppcb_enum.info=74000a00000001
Enter console mode, disable watchdog ...
Realtek>
  • 4 месяца спустя...
Доброго всем дня. Пришло решение от пользователя popadin58.
