LiVan Опубликовано 9 марта, 2014 Опубликовано 9 марта, 2014 Oчень простой SPI Flash memory программатор SPI программатор, для LPT-порта. Это скрытый контент, для просмотра сообщения Вы должны быть Участником форума. Войти или Регистрация SPI FlashROM Programmer 1.6 © 2008-2009 by Martin Rehak; rayer@seznam.czCompiled by GCC 3.4.5 (mingw-vista special r3) at 22:49:21, Jan 21 2009(Win9x/NT/2K/XP compatability) SYNTAX: spipgm /i|r|d|e|p [filename] [address] [/l=iobase] [/d=delay]/i - identify SPI FlashROM/r address size - read & display data block (0x prefix = hexa number)/d filename - dump entire FlashROM to file/p filename - program entire FlashROM from file (without erase)/e - erase entire FlashROM/u - unlock write protection bits (may depend on WP# level)/l= LPT port I/O base address (default is 378h - LPT1)/d= additional delay for SPI clock pulse width [usec] (default is 0) LPT to SPI pin assignment (based on BSD AVR programmer):pin 7 = D5 -> CS#pin 8 = D6 -> SCK (CLK)pin 9 = D7 -> MOSI (DIO)pin 10 = ACK -> MISO (DO)pin 18 = GND -> GND 1) Идентифицируем флешку ===> SPIPGMW.EXE /i spipgm>SPIPGMW.EXE /i SPI FlashROM Programmer 1.6 © 2008-2009 by Martin Rehak; rayer@seznam.czCompiled by GCC 3.4.5 (mingw-vista special r3) at 22:49:21, Jan 21 2009(Win9x/NT/2K/XP compatability) SPI connected to LPT port at I/O base address: 378h, SCK pulse width: t+0usFlashROM JEDEC ID, type: 010214hSpansion S25FL016A (2MB)Status = 00h (SRP, RES, TB , BP2, BP1, BP0, WEL, BSY)0 0 0 0 0 0 0 0 2) Делаем дамп SPIPGMW.EXE /d spipgm>SPIPGMW.EXE /d flash.bin SPI FlashROM Programmer 1.6 © 2008-2009 by Martin Rehak; rayer@seznam.czCompiled by GCC 3.4.5 (mingw-vista special r3) at 22:49:21, Jan 21 2009(Win9x/NT/2K/XP compatability) SPI connected to LPT port at I/O base address: 378h, SCK pulse width: t+0usFlashROM JEDEC ID, type: 010214hSpansion S25FL016A (2MB)Reading sector at: 001FF000h (100%)3) Разблокируем флешку для записи ===> SPIPGMW.EXE /uspipgm>SPIPGMW.EXE /uSPI FlashROM Programmer 1.6 © 2008-2009 by Martin Rehak; rayer@seznam.czCompiled by GCC 3.4.5 (mingw-vista special r3) at 22:49:21, Jan 21 2009(Win9x/NT/2K/XP compatability)SPI connected to LPT port at I/O base address: 378h, SCK pulse width: t+0usFlashROM JEDEC ID, type: 010214hSpansion S25FL016A (2MB)Status = 02h, WE bit is enabledUnlocking...Status = 00h, device is unlocked now 4) Стираем флешку ! ===> SPIPGMW.EXE /e spipgm>SPIPGMW.EXE /e SPI FlashROM Programmer 1.6 © 2008-2009 by Martin Rehak; rayer@seznam.czCompiled by GCC 3.4.5 (mingw-vista special r3) at 22:49:21, Jan 21 2009(Win9x/NT/2K/XP compatability) SPI connected to LPT port at I/O base address: 378h, SCK pulse width: t+0usFlashROM JEDEC ID, type: 010214hSpansion S25FL016A (2MB)Status = 02h, WE bit is enabledPlease wait... done. 5) Запишим дамп ===> SPIPGMW.EXE /p spipgm>SPIPGMW.EXE /p Flash.bin SPI FlashROM Programmer 1.6 © 2008-2009 by Martin Rehak; rayer@seznam.czCompiled by GCC 3.4.5 (mingw-vista special r3) at 22:49:21, Jan 21 2009(Win9x/NT/2K/XP compatability) SPI connected to LPT port at I/O base address: 378h, SCK pulse width: t+0usFlashROM JEDEC ID, type: 010214hSpansion S25FL016A (2MB)Programming page at: 001FFF00h (100%)6) Сделаем дамп что бы проверить успешность записи ===> SPIPGMW.EXE /dspipgm>SPIPGMW.EXE /d flash.binSPI FlashROM Programmer 1.6 © 2008-2009 by Martin Rehak; rayer@seznam.czCompiled by GCC 3.4.5 (mingw-vista special r3) at 22:49:21, Jan 21 2009(Win9x/NT/2K/XP compatability)SPI connected to LPT port at I/O base address: 378h, SCK pulse width: t+0usFlashROM JEDEC ID, type: 010214hSpansion S25FL016A (2MB)Reading sector at: 001FF000h (100%) Поддерживаемые памяти:AMIC: A25L05PU/PT (64kB)A25L10PU/PT (128kB)A25L20PU/PT (256kB)A25L40PU/PT (512kB)A25L80PU/PT (1MB)A25L16PU/PT (2MB)A25L32PU/PT (4MB)A25L64PU/PT (8MB)A25L512 (64kB)A25L010 (128kB)A25L020 (256kB)A25L040 (512kB)A25L080 (1MB)Atmel:AT26F004 (512kB)AT26DF041 (512kB)AT26DF081A (1MB)AT26DF161A (2MB)AT26DF321 (4MB)EON:EN25P16 (2MB)EN25P32 (4MB)EN25P64 (8MB)EN25P128 (16MB)EN25F20 (256kB)EN25F40 (512kB)EN25F80 (1024B)EN25F16 (2MB)EN25F32 (4MB)EN25F64 (8MB)EN25F128 (16MB)ESMT:F25L004A (512kB)F25S04PA (512kB)F25L08PA (1024B)F25L16PA (2MB)F25L32PA (4MB)F25L32QA (4MB)Macronix:MX25L1005 (128kB)MX25L2005 (256kB)MX25L4005 (512kB)MX25L8005 (1MB)MX25L1605 (2MB)MX25L3205 (4MB)MX25L6405 (8MB)PMC:Pm25LV512A (64kB)Pm25LV010A (128kB)Pm25LV020 (256kB)Pm25LV040 (512kB)Pm25LV080B (1MB)Pm25LV016B (2MB)Pm25LV032B (4MB)Pm25LV064B (8MB)Spansion:S25FL004A (512kB)S25FL008A (1MB)S25FL016A (2MB)S25FL032A (4MB)S25FL064A (8MB)S25FL128P (16MB)SST:SST25VF010 (128kB)SST25VF020 (256kB)SST25VF040 (512kB)SST25VF080 (1MB)SST25VF016 (2MB)SST25VF032 (4MB)SST25VF064 (8MB)SST25VF128 (16MB)SST26VF016 (2MB)SST26VF032 (4MB)SST26VF064 (8MB)SST25VF064C (8MB)ST Microelectronic:M25P10 (128kB)M25P20 (256kB)M25P40 (512kB)M25P80 (1MB)M25P16 (2MB)M25P32 (4MB)M25P64 (8MB)M25P128 (16MB)Winbond:W25Q10 (128kB)W25Q20BV (256kB)W25Q40BV (512kB)W25Q80BV (1MB)W25Q16BV (2MB)W25Q32BV (4MB)W25Q64BV (8MB)W25Q128BV (16MB)W25X10 (128kB)W25X20 (256kB)W25X40 (512kB)W25X80 (1MB)W25X16 (2MB)W25X32 (4MB)W25X64 (8MB) Это скрытый контент, для просмотра сообщения Вы должны быть Участником форума. Войти или Регистрация P.SХороший программатор, но при стирании памяти вылезло следующее сообщение: 10h, unlock failed,set WP# PIN AT HIGH LEVEL для решения этой проблемы подаем на 3 ногу (WP) логический ноль, т.е. спаиваем 3 и 4 ногу вместе. KenotronTV 🛠 Contact ✉ Мы здесь, чтобы ответить на ваши вопросы! Задавайте вопросы и получайте быстрые ответы. Подписывайтесь и оставайтесь на связи!
