SAMSUNG GU50TU7179U Циклическое пропадание изображения?
4) SVC
  • Ответов 88
  • Создана
  • Последний ответ
Топ авторов темы
это...
((буду позже-делишки...
лог1
<0>zAC
V2
0084(Jan  8 2021 10:55:46)
load tcon fail
load tcon (40000) fail
444mA
d
boot-up
(Jan  8 2021 - 10:55:47)
0084(6250644)
r
J001
S11
E11
0 p
GPT
D
DTB 0
xdt1.5G
SECDRV 0
or003.0
SECOS 0
kr003.0
KERNEL 0
z[1-0.0575] cma: [swapper/0(1)] cma_alloc(): returned ec507000 range 81000 - 81040
[1-0.0601] I2C IRQ init_timer start(0517_Tizen4.0)
[1-0.0669] [DEBUG]register base fd6f0000
[1-0.0670] [DEBUG] interregister base d
[1-0.0670] gzip support fifo mode
[1-0.0672] (NULL device *): ~get gpio base-val: 0xed096000, 0x0
[1-0.0673] nvt,auth fd770000.auth: hw auth support fifo mode, 1090309
[0-0.0939] type=2000 audit(0.091:1): initialized
[1-0.1002] Novatek UART Direct I/O Driver Init.
[1-0.1003] nvt-udio fd092000.uart: io_base ed0a8000
[1-0.1003] nvt-udio fd092000.uart: clock rate 100000000
[1-0.1003] nvt-udio fd092000.uart: baud rate 115200
[1-0.1004] nvt-udio fd092000.uart: irq 11
[1-0.1005] nvt-udio fd092000.uart: probing completed
[1-0.1562] [NTKETHMAC]: synopGMAC_probe.
[1-0.1563] [NTKETHMAC]: Now Registering the netdevice
[1-0.1673] mmcblk0: mmc0:0001 4FTE4R 3.64 GiB
[0-0.1818]  Ver : 6340677, release
[0-0.1818]  TV, Kant.SU2-Tizen, release, Trunk_2020_MP
[0-0.1818]  Linux version 4.1.10 (abuild@A1312DKG) (gcc version 6.2.1 20161213 (Tizen/Linaro GCC 6.2.1 2016.12/VDCosmos-20190704 7.8) ) #1 SMP PREEMPT Fri Jan 8 11:04:50 UTC 2021
[0-0.1819]  dtsversion=6290398_kantsu2-1.5G-cma console=ttyS0,115200 rs232=0 earlyprintk maxcpus=4 no_console_suspend only_entry_model root=/dev/mmcblk0p18 KDUMP=16 SELP_ENABLE=20208724 _nvtca9-16m rootfstype=vdfs ro init=/sbin/init mem=808M@32M mem=56M@968M mem=256M@2048M vmalloc=300M rootwait quiet bdinfo=00000091 model=4kbtin   pba_none
[/sbin/init] Start init process!!!!!!!!!!!!!!!!
[1-0.3590] vdfs4-WARN: SB: bad signature - , expected - VDFSmount: /mnt/systemrw: wrong fs type, bad option, bad superblock on /dev/mmcblk0p20, missing codepage or helper program, or other error.
[0-2.1602] [NTKETHMAC]: Trim RTER_RX = 0x3, 0368[70]
[0-2.1602] [NTKETHMAC]: Trim RTER_TX = 0x3, 0368[6c]
[0-2.1602] [NTKETHMAC]: Trim TX_ROUT = 0x4, 0374[25]
[0-2.1603] [NTKETHMAC]: Trim TX_SWING = 0x1, 0378[21]
systemrw_backup.xz isn't exist
[0-3.3774] vdfs4-WARN: SB: bad signature - , expected - VDFSmount: /mnt/systemrw: wrong fs type, bad option, bad superblock on /dev
data_backup.xz isn't exist
/sbin/init: line 46: /sys/kernel/debug/tracing/trace_marker: No such file or directory
[Info] Initailize T-trace
error opening /sys/kernel/debug/tracing/options/overwrite: No such file or direc[2-3.5029] init: lwipc
tory (2)
Tags: [3-3.5030] init: logger
0x1, excludedTags: 0x0
error op[2-3.5055] lwipc mod ld(0xbe800000)
ening /sys/kerne[3-3.5063] logger mod ld(0xbe805000)
l/debug/tracing/tracing_on: No such file or directory (2)
unable to start tracing
[cynara-launcher] launch cynara( 115 )
[cynara-launcher] wait socket files:300
[3-3.5743] init: tztv_bootmode
[3-3.5745] tztv_bootmode mod ld(0xbe81d000)
Booting from tztv mode
boot mode: normal
Cynara db update success
[security-manager-launcher(154)]  > Starting Security Manager Launcher...
[secu[0-3.6748] [FB:INIT] fast init start
rity-manager-lau[0-3.6749] [FB:INIT] insmod file : index.json
ncher(154)]  > security-manager(pid : 169) is launched successfully...
[0-3.6888] [FB:INIT] [prebasic Start]
[0-3.6888] [FB:INIT] cmd[prebasic:insmod]
[0-3.6889] [FB:INIT] prebasic 0 start
Set Buxton env
build: 20210108_144709
keymap: 20210108_144709
We have a keymap cache version file
[eeprom op[0-3.7104] init: PreInit
en wait]
[0-3.7113] ================================================================================
[prdv_attr: /dev/null]
[0-3.7113]  Pre Initiation
[eeprom open wait]
[0-3.7113]  Version : Kantsu2_Onemain_2020_KantSU2_Trunk2020_MP_v0.201016.0_r93d41424e63.
[3.72 13.47][BXT[0-3.7113] ================================================================================
] buxton2d started
cat: /run/user/5001/.launchp[0-3.7486] DynBoost3.1.8
ad.pid: No such [2-3.7682] [TEMP_MSGBOX] #################
file or director[2-3.7682] [TEMP_MSGBOX] MessageBox Drive_init
y
[eeprom open [2-3.7682] [TEMP_MSGBOX] MessageBox Drive_init
wait]
[2-3.7690] genirq: Flags mismatch irq 11. 00000080 (ntk_serial) vs. 00000000 (fd092000.uart)
[eeprom open wai[2-3.7690] PreInit mod ld(0xbe821000)
t]
[2-3.7692] [FB:INIT] prebasic 0 end
[2-3.7692] [FB:INIT] prebasic 1 start
[0-3.8208] init: tztv_eeprom
FP_NVRAM_FASTBOOT_IN_PRODUCTION [0-3.8212] client = 0xebdfe200
[0]
non-factory[0-3.8218] tztv_eeprom mod ld(0xbe88d000)
 production mode[0-3.8220] [FB:INIT] prebasic 1 end
[0-3.8220] [FB:INIT] prebasic 2 start
[1-3.8384] init: tztv_micom
[prdv_attr: /dev/tty]
[prdv_attr: /dev/bptime]
[prdv_attr: /dev/snd/timer]
[prdv_attr: /dev/uinput]
[prdv_attr: /dev/eeprom]
[prdv_attr: /dev/zero]
[prdv_attr: /dev/micom-cec]
[0-3.8717] tztv_micom mod ld(0xbe893000)
[0-3.8718] [FB:INIT] prebasic 2 end
[0-3.8718] [FB:INIT] prebasic 3 start
[2-3.8813] [MC:S][3.8812][kthread_watchdo]Rollback
[2-3.8887] [MC:A][3.8887]TV ver 1010_R(1)
[2-3.8942] [MC:A][3.8941]boot_reason(0) [TV ver 1010_R(1)]
[1-3.8942] [SBH] get_boot_reason is (0)
[0-3.8970] init: videobuf2_core
[0-3.8973] videobuf2_core mod ld(0xbe8a5000)
[0-3.8974] [FB:INIT] prebasic 3 end
[0-3.8974] [FB:INIT] prebasic 4 start
[2-3.8982] [MC:A][3.8982][PwrOnMode:1][PrePOM:0][Res: 0][T-TV-1010_R(1)]
[2-3.9048] init: videobuf2_memops
[2-3.9049] videobuf2_memops mod ld(0xbe8ad000)
[2-3.9051] [FB:INIT] prebasic 4 end
[2-3.9051] [FB:INIT] prebasic 5 start
[2-3.9144] init: videobuf2_vmalloc
[2-3.9153] videobuf2_vmalloc mod ld(0xbe8af000)
[prdv_attr: /dev[2-3.9156] [FB:INIT] prebasic 5 end
/mali0]
[prdv_a[2-3.9157] [FB:INIT] [prebasic End time:227]
ttr: /dev/dmabuf_kds]
[2-3.9158] [FB:INIT] fi_util_mq_send_cmd: cmd(122)
[2-3.9160] [FB:INIT] [fi_depList_init:763] index_path [/tmp/FACTORY_PRODCU[FB:INIT] no flag file:/tmp/FACTORY_PRODCUTION
[2-3.9162] [FB:INIT] [fi_depList_init:763] index_path [/opt/usr/apps/MCS_m[FB:INIT] no flag file:/opt/usr/apps/MCS_mode
[2-3.9182] [FB:INIT] [fi_depList_init:763] index_path [/opt/usr/apps/org.t[FB:INIT] no flag file:/opt/usr/apps/org.tizen.btapp/data/tv_so[FB:INIT] [fi_depList_init:763] index_path []
[2-3.9182] [FB:INIT] no flag file:
[2-3.9182] [FB:INIT] Index path Null
[PKGMGR] /opt/dbspace/.pkgmgr_pa[2-3.9182] [FB:INIT] INIT index_path[index]
rser.db file siz[2-3.9187] [FB:INIT] [fw Start]
e 948
[PKGMGR] [2-3.9188] [FB:INIT] cmd[fw:insmod]
integrity : ok
[2-3.9188] [FB:INIT] fw 0 start
[3-3.9263] [FB:INIT] [tzdev Start]
[3-3.9263] [FB:INIT] cmd[tzdev:insmod]
[3-3.9264] [FB:INIT] tzdev 0 start
[3-3.9353] init: tzdev
[1-3.9428] [FB:LOGO] panel_enable(1)
[2-3.9476] init: mali
[2-3.9520] mali mod ld(0xbe8d6000)
[2-3.9522] [FB:INIT] fw 0 end
[2-3.9524] [FB:INIT] fw 1 start
[PKGMGR] /opt/dbspace/.pkgmgr_ce[1-3.9531] [FB:LOGO] logo mode(0)
rt.db file size [3-4.0222] tzdev mod ld(0xbe8b1000)
184
[PKGMGR] in[3-4.0224] [FB:INIT] tzdev 0 end
tegrity : ok
[3-4.0224] [FB:INIT] cmd[tzdev:chmod]
[3-4.0224] [FB:INIT] [tzdev End time:96]
[3-4.0225] [FB:INIT] create path(/tmp/tzdev_insmod_done)
/usr/bin/firstscreen.sh: line 20: /sys/kernel/debug/tracing/trace_marker: No such file or directory
cat: /opt/data/DeviceTracker/htPolicyState: No such file or directory
[PKGMGR] /opt/dbspace/user/5001/.pkgmgr_parser.db file size 148
[PKGMGR] integrity : ok
Buffer main is set
argc = 10, optind = 9, Kb 1024, rotate 1
[PKGMGR] /var/lib/package-manager/restriction.db file size 16
[PKGMGR] /opt/dbspace/.widget.db file size 28
[security-manager-launcher(154)]  > inotify event is received for /run/security-manager.socket
[PKGMGR] /opt/usr/home/owner/.applications/dbspace/.widget.db file size 28
[PKGMGR] /opt/dbspace/.appsvc.db file size 40
[3-4.2964] init: ntkdriver
[1-4.3056] [SBH] bw_get_boot_mode() : 0, BOOT_TYPE_ISP(1) BOOT_TYPE_RVU(2)
[1-4.3264] [SBH] create boot mode file(/tmp/normal_mode)
netlink recv: No buffer space available
[3-4.3368] ================================================================================
[3-4.3368]  NTK Driver
[3-4.3368]  Version : Kantsu2_Onemain_2020_KantSU2_Trunk2020_MP_v0.201016.0_r93d41424e63.
[PKGMGR] /opt/db[3-4.3368] ntkdrvs: NOVATEK drivers loaded begin.
space/user/5001/[1-4.3522] nvt_dt cannot find video_es_tbl!
.appsvc.db file [1-4.3523] ksb cann't find video_es_tbl node
size 40
[prdv_attr: /dev/sdp_mem]
[0-4.3918] [HDMI-CMD]:Trim.Valid=1
[0-4.3918] [HDMI-CMD]:EARCTrim.Valid=1
No such file /dev/nvt/ntkstbc
[0-4.4190] Novatek FRE Driver loaded
waiting firstscreen launch
Leon2 decoder is built at 14:25:19, May  5 2
code revision: bd10666ebb1, 2020-03-20
_CPU_Initialize ... OK
_Reload_text(304) ... OK
_Reload_data(12288) ... OK
TC = c400a810
start ...
[3-4.4827] [perfm]1.4.18
RO and RW is same version
/home/owner/.dotnet/corefx/cryptograp[0-4.4930] cma: [fastinit(269)] cma_alloc(): returned ec507800 range 81040 - 81048
hy/x509stores/ is already created
mkdir: cannot create directory `/opt/usr/home/owner/share/dotnet/': Fil[0-4.5323] [hdmi leon2] hdmi_leon2 find pool node ERROR !!!
e exists
[0-4.5323] [hdmi leon2] driver loaded > ERROR !!!
[0-4.5329] ntkdriver mod ld(0xbe922000)
[0-4.5330] [FB:INIT] fw 1 end
[0-4.5332] [FB:INIT] [fw End time:615]
[2-4.5333] [FB:INIT] [pq Start]
[2-4.5334] [FB:INIT] cmd[pq:insmod]
[2-4.5334] [FB:INIT] pq 0 start
[0-4.5385] [FB:INIT] [kfactory Start]
[0-4.5386] [FB:INIT] cmd[kfactory:insmod]
[0-4.5386] [FB:INIT] kfactory 0 start
[3-4.5848] init: ntkndp_pq
[0-4.5868] init: kfactory_drv
Recreate Seed
[0-4.5877] kfactory_drv mod ld(0xbf198000)
[0-4.5878] [FB:INIT] kfactory 0 end
[0-4.5878] [FB:INIT] cmd[kfactory:execute]
[2-4.5907] [FB] fastvideo start
[2-4.5909] [FB] fb_insmod_wait_lock: mode(12) start
[2-4.5910] [FB] fb_insmod_wait_lock: mode(12) end
[2-4.5980] [FB] Hotel mode : 0:0
[2-4.5980] [FB] Hotel mode disable
[3-4.5993] msg-wt61p807 msg-wt61p807: received unknown cmd ack
[0-4.5998] [FB] fb_insmod_wait_lock: mode(13) start
[0-4.6065] [FB:INIT] cmd[kfactory:insmod]
[0-4.6066] [FB:INIT] kfactory 0 start
[0-4.6066] [FB:INIT] kfactory 0 end
[0-4.6066] [FB:INIT] kfactory 1 start
[0-4.6168] [FB] fb_insmod_wait_lock: mode(13) end
[2-4.6176] ntkndp_pq mod ld(0xbf17d000)
[2-4.6177] [FB:INIT] pq 0 end
[2-4.6177] [FB:INIT] pq 1 start
[0-4.6279] [FB] boot_mode,channel_lock:3,0
[0-4.6279] [FB] invalied bootmode(3)!!
[2-4.6280] [FB] video_show_done(skip/fail)
[0-4.6390] [FB] fb_status_fail: fastvideo SKIP. ( reason : [ 8 ] )
[0-4.6830] init: system_drv_api
[0-4.6832] system_drv_api mod ld(0xbe803000)
/usr/bin/dotnet-[0-4.6833] [FB:INIT] kfactory 1 end
developer-mode.s[0-4.6833] [FB:INIT] kfactory 2 start
h found
[2-4.7017] init: ntkndptcon
[1-4.7025] init: system_drv
[1-4.7040] KER_TCON_DrvInit: _tcon_mbxisr_ready
[kfactoryd] rest[3-4.7123] ESTART(main) 4.71117
ore daemon!!
[3-4.7126] ESTART: 0.00130 [0.00130] - Begin Startup
[PKGMGR] /opt/dbspace/.app-context.db file size 48
[3-4.7259] ESTART: 0.01458 [0.01328] - Signal Trap
[3-4.7262] ESTART: 0.01485 [0.00027] - Signal Trap Done
[3-4.7262] ESTART: 0.01487 [0.00002] - Eina Init
[2-4.7368] ESTART: 0.02550 [0.01062] - Eina Init Done
[2-4.7369] ESTART: 0.02556 [0.00006] - E_Object Hash Init
[2-4.7382] ESTART: 0.02681 [0.00125] - E_Object Hash Init Done
[2-4.7382] ESTART: 0.02687 [0.00006] - E_Log Init
Develope mode is off
[2-4.7383] ESTART: 0.02699 [0.00012] - E_Log Init Done
[2-4.7383] ESTART: 0.02701 [0.00002] - Determine Prefix
[1-4.7422] ESTART: 0.03084 [0.00384] - Determine Prefix Done
[1-4.7422] ESTART: 0.03088 [0.00004] - Parse Arguments
[1-4.7422] ESTART: 0.03089 [0.00001] - Parse Arguments Done
[1-4.7422] ESTART: 0.03090 [0.00001] - Eet Init
[0-4.7424] ESTART: 0.03104 [0.00014] - Eet Init Done
[0-4.7424] ESTART: 0.03107 [0.00003] - Ecore Init
[2-4.7540] ESTART: 0.04269 [0.01162] - Ecore Init Done
[2-4.7540] ESTART: 0.04273 [0.00005] - EIO Init
[2-4.7543] ESTART: 0.04297 [0.00024] - EIO Init Done
[2-4.7543] ESTART: 0.04300 [0.00002] - Ecore Event Handlers
[2-4.7543] ESTART: 0.04302 [0.00002] - Ecore Event Handlers Done
[2-4.7544] ESTART: 0.04307 [0.00006] - Ecore_File Init
[0-4.7578] ntkndptcon mod ld(0xbf1a1000)
[0-4.7579] [FB:INIT] pq 1 end
[0-4.7579] [FB:INIT] [pq End time:224]
[1-4.7591] system_drv mod ld(0xbf1b4000)
[prdv_attr: /dev[1-4.7592] [FB:INIT] kfactory 2 end
/video28]
[1-4.7593] [FB:INIT] kfactory 3 start
[1-4.7593] [FB:INIT] kfactory 3 end
[1-4.7593] [FB:INIT] [kfactory End time:221]
[1-4.7597] [FB:INIT] [logo Start]
[1-4.7597] [FB:INIT] cmd[logo:insmod]
[1-4.7597] [FB:INIT] logo 0 start
[1-4.7598] [FB:INIT] [extin Start]
[1-4.7598] [FB:INIT] cmd[extin:insmod]
[1-4.7598] [FB:INIT] extin 0 start
[1-4.7606] cma: [KTCON_INIT(413)] cma_alloc(): returned ec507a00 range 81050 - 81060
[2-4.7740] ESTART: 0.06262 [0.01955] - Ecore_File Init Done
[2-4.7740] ESTART: 0.06268 [0.00006] - E_Util_File_Monitor Init
[2-4.7740] ESTART: 0.06273 [0.00004] - E_Util_File_Monitor Init Done
[2-4.7741] ESTART: 0.06283 [0.00010] - XDG_DATA_DIRS Init
[2-4.7742] ESTART: 0.06291 [0.00008] - XDG_DATA_DIRS Init Done
[2-4.7742] ESTART: 0.06293 [0.00002] - Ecore_Evas Init
[1-4.7795] init: ntkndplogo
[2-4.7842] init: ntkndpextin
[0-4.8472] ntkndplogo mod ld(0xbf14c000)
[0-4.8473] [FB:INIT] logo 0 end
[0-4.8473] [FB:INIT] [logo End time:88]
[2-4.8474] [FB:INIT] [tuner Start]
[1-4.8475] [FB:INIT] [frc Start]
[0-4.8476] [FB:INIT] [hdmi1 Start]
[2-4.8476] [FB:INIT] [audio Start]
[0-4.8477] [FB:INIT] fi_util_mq_send_cmd: cmd(108)
[0-4.8478] [FB:INIT] [alsa Start]
[2-4.8478] [FB:INIT] cmd[hdmi1:insmod]
[0-4.8479] [FB:INIT] hdmi1 0 start
[1-4.8479] [FB:INIT] cmd[frc:insmod]
[1-4.8480] [FB:INIT] frc 0 start
[2-4.8480] [FB:INIT] cmd[audio:insmod]
[2-4.8480] [FB:INIT] audio 0 start
[1-4.8480] [FB:INIT] cmd[alsa:insmod]
[0-4.8480] [FB:INIT] cmd[tuner:insmod]
[0-4.8481] [FB:INIT] tuner 0 start
[1-4.8481] [FB:INIT] alsa 0 start
[3-4.8504] cma: [KTCON_INIT(413)] cma_alloc(): returned ec507a00 range 81050 - 81060
[2-4.8548] [FB:LOGO] panel unmute
[2-4.8566] [FB:LOGO] BootLogo start
[1-4.8601] init: tztv_frc_tcon_api
[3-4.8602] [MC:S][4.8504][fastlogo]Inv-1
[3-4.8602] [MC:A][4.8547]Inv(0)
[1-4.8608] tztv_frc_tcon_api mod ld(0xbf15f000)
[0-4.8610] init: ntkndphdmi
[0-4.8621] set g_ndp_hdmi_port_max  = 3
[0-4.8623] Can not find hdmi_hpd -> HDMI_HPD_PORTB in dtb file
[0-4.8623] Can not find hdmi_hpd -> HDMI_HPD_PORTD in dtb file
[0-4.8623] brdType = 1
[0-4.8623] eHDMI_HOT_PLUG[0] = 160
[0-4.8623] eHDMI_HOT_PLUG[2] = 163
[0-4.8684] [FB:INIT] frc 0 end
[0-4.8684] [FB:INIT] frc 1 start
[0-4.8685] ntkndphdmi mod ld(0xbf1bc000)
[0-4.8686] [FB:INIT] hdmi1 0 end
[0-4.8686] [FB:INIT] hdmi1 1 start
[0-4.9050] [HDMI-CMD]:[AUD]_hdmi_Initialize:En(0)
[0-4.9050] [HDMI-CMD]:[AUD]HDMI_Ctrl_Set_AudIPU-Mux(2)En(0)
[0-4.9053] [HDMI-CMD]:_4HDMI Initial Done
[0-4.9157] cma: [KTCON_INIT(413)] cma_alloc(): returned ec507a00 range 81050 - 81060
[0-4.9204] init: tztv_frc_tcon
[2-4.9221] cma: [fastinit(425)] cma_alloc(): returned ec508000 range 81080 - 810e6
[2-4.9226] cma: [fastinit(425)] cma_alloc(): returned ec509000 range 81100 - 81166
[1-4.9239] ntkndpextin mod ld(0xbf151000)
[1-4.9240] [FB:INIT] extin 0 end
[1-4.9240] [FB:INIT] extin 1 start
[2-4.9272] init: ntkndpalsa
[0-4.9284] init: tztv_audio_amp_api
[0-4.9297] tztv_audio_amp_api mod ld(0xbf230000)
[0-4.9299] [FB:INIT] audio 0 end
[0-4.9299] [FB:INIT] audio 1 start
[0-4.9341] init: tztv_hdmi_switch_api
[0-4.9351] tztv_hdmi_switch_api mod ld(0xbf292000)
[2-4.9365] [FB:INIT] hdmi1 1 end
[2-4.9365] [FB:INIT] [hdmi1 End time:89]
[2-4.9414] [FB:INIT] [hdmi2 Start]
[2-4.9415] [FB:INIT] cmd[hdmi2:insmod]
[2-4.9415] [FB:INIT] hdmi2 0 start
[0-4.9420] init: ntkndpmisc
[0-4.9424] ndp_power_probe
[0-4.9425] ntkndpmisc mod ld(0xbf175000)
[0-4.9426] [FB:INIT] extin 1 end
[0-4.9427] [FB:INITT: 2.88948 [0.00048] -              e-mod-tizen-video-tv Module Enable Done 1
[0-7.6008] ESTART: 2.88952 [0.00004] - e-mod-tizen-keyrouter-tv Module Open
[1-7.6014] [ALSA-CTRL] speaker out gain: put 15 [462:avocd]
[0-7.6151] [ALSA-CTRL] hp/line out gain: put 100 [462:avocd]
[0-7.6206] [ALSA-CTRL] speaker out mute: put 0 [462:avocd]
[0-7.6208] [ALSA-CTRL] spdif out mute: put 0 [462:avocd]
[0-7.6210] [ALSA-CTRL] main out bt/acm pcm mute: put 1 [462:avocd]
[0-7.6219] [ALSA-CTRL] hp/line out enable: put 0 [462:avocd]
[0-7.6232] [ALSA-CTRL] spdif out mute: put 1 [462:avocd]
[0-7.6234] [ALSA-CTRL] spdif out signal: put 1 [462:avocd]
[0-7.6234] [ALSA-CTRL] spdif out signal: [Error] put is not implemented yet
[0-7.6235] [ALSA-CTRL] spdif out mute: put 0 [462:avocd]
[0-7.6252] [ALSA-CTRL] spdif out delay: put 0 [462:avocd]
[0-7.6252] [ALSA-CTRL] pass through out delay: put 0 [462:avocd]
[0-7.6254] [ALSA-CTRL] main out delay: put 0 [462:avocd]
[0-7.6254] [ALSA-CTRL] hp/line out delay: put 0 [462:avocd]
[0-7.6254] [ALSA-CTRL] spdif out format: put PCM [462:avocd]
[0-7.6258] [ALSA-CTRL] pass through out: put 0 [462:avocd]
[0-7.6261] [ALSA-CTRL] output mix only: put 0 [462:avocd]
[0-7.9011] ESTART: 3.18978 [0.30026] - e-mod-tizen-keyrouter-tv Module Open Done m:0x38e7f0
[0-7.9011] ESTART: 3.18981 [0.00004] - e-mod-tizen-keyrouter-tv Module Enable
[0-8.1807] ESTART: 3.46942 [0.27960] - e-mod-tizen-keyrouter-tv Module Enable Done 1
[0-8.1808] ESTART: 3.46947 [0.00005] - e-mod-tizen-devicemgr Module Open
[0-8.2070] [MC:A][8.2070][PwrOnMode:1][PrePOM:0][Res: 0][T-TV-1010_R(1)]
[5.903724][PWR] [2-8.2200]  Ver : 6340677, release
boot reason : (0[2-8.2200]  TV, Kant.SU2-Tizen, release, Trunk_2020_MP
[5.904975][[2-8.2200]  Linux version 4.1.10 (abuild@A1312DKG) (gcc version 6.2.1 20161213 (Tizen/Linaro GCC 6.2.1 2016.12/VDCosmos-20190704 7.8) ) #1 SMP PREEMPT Fri Jan 8 11:04:50 UTC 2021
PWR] 1970-01-01T[2-8.2200]  dtsversion=6290398_kantsu2-1.5G-cma console=ttyS0,115200 rs232=0 earlyprintk maxcpus=4 no_console_suspend only_entry_model root=/dev/mmcblk0p18 KDUMP=16 SELP_ENABLE=20208724 _nvtca9-16m rootfstype=vdfs ro init=/sbin/init mem=808M@32M mem=56M@968M mem=256M@2048M vmalloc=300M rootwait quiet bdinfo=00000091 model=4kbtin   pba_none
03:00:05+0300
[2-8.2200]
[2-8.2200] Last Exception point
[5.906446][PWR][2-8.2201] --------------------------------------------------------------------------------------
 changed state <[2-8.2201] PC, LR MEMINFO
lcdon> by pid(47[2-8.2201] --------------------------------------------------------------------------------------
4:deviced)
[6[2-8.2201] PC:43db2e8a, LR:43db2e8b
.948751][EXTCON][2-8.2201] --------------------------------------------------------------------------------------
 Changed FAN dev[2-8.2201] PC meminfo (0x43db328a to 0x43db328a)
ice : 0 -> 1
[6[2-8.2201] 3280:
.969807][EXTCON][2-8.2202] --------------------------------------------------------------------------------------
 Changed OCM dev[2-8.2202] LR meminfo (0x43db268b to 0x43db328b)
ice : -1 -> 1
[[2-8.2202] 2680:                            2010f8cb 3f18f84a e8def7fb 4a374603 20014931
7. 15690][EXTCON[2-8.2202] 26a0: 6058447a 60983248 f8c31d18 601ab00c 603b5864 a000f8c4 e8506063 33013f00
] Changed H1_c d[2-8.2202] 26c0: 3fe2e8c0 d1f82a00 8f5bf3bf f7fb6878 4a2aed2a 4620492a 4479447a e92cf7fb
evice : 0 -> 1
[2-8.2202] 26e0: 4618683b fdbcf039 f7fce779 f7fbe96c f8dbeb0a 46583000 4798685b ec62f7fc
[7. 71398][EXTCO[2-8.2203] 2700: 211c4604 f7fb4658 6878ed5c ece6f7fb 46304b1c f103447b f103011c 62390234
N] Changed H2_c [2-8.2203] 2720: 637a3354 f03863bb 4640ff73 ff70f038 f7fc4620 4604ef18 eda0f7fc 4604e7e5
device : 0 -> 1
[2-8.2203] 2740: 4604e7e3 f0384630 e7eeff63 00074e60 00000b90 0007441a 0005622c 00000bb8
[7.267510][EXTC[2-8.2203] 2760: 000573a6 00000e20 00074390 00072c9c 00074342 00074324 0007299c 00075b28
ON] Changed H3_c[2-8.2203] 2780: 0003889f 0007427c e59f3014 e59f2014 e08f3003 e7932002 e3520000 012fff1e
 device : 0 -> 1[2-8.2203] 27a0: eafff3f3 00074c30 00000df8 48084b07 4a08447b 33034478 447a1a1b d9032b06
[7.272382][EXT[2-8.2203] 27c0: 58d34b05 4718b103 bf004770 00075b04 00075b00 00074c0a 00000dc0 48094908
CON] Changed H4_[2-8.2204] 27e0: 4b094479 1a094478 1089447b 71d1eb01 d0031049 589b4a05 4718b103 bf004770
c device : 0 -> [2-8.2204] 2800: 00075ad4 00075ad0 00074bdc 00000e04 4b0ab508 447b4a0a 781b447a 4b09b96b
1
[7.276722][EX[2-8.2204] 2820: b12358d3 447b4b08 f7fc6818 f7ffefec 4b06ffbd 447b2201 bd08701a 00075a9e
TCON] enable rec[2-8.2204] 2840: 00074bac 00000e10 000759da 00075a7e b5084807 68024478 447b4b06 e8bdb912
eiving kernel ue[2-8.2204] 2860: e7bb4008 589b4a04 d0f82b00 e7f64798 00072560 00074b6a 00000cf4 00000000
vent
[2-8.2204] 2880: 1d03b480 af006840 fab01ac0 0940f080 f85d46bd 47707b04 41f0e92d f8d04606
[2-8.2204] 28a0: af008004 45a86885 4644bf18 6823d006 34304620 4798681b d1f842a5 8008f8c6
[2-8.2204] 28c0: 81f0e8bd 6842b480 6880af00 fab01a10 0940f080 f85d46bd 47707b04 6843b480
[2-8.2204] 28e0: 6083af00 f85d46bd 47707b04 6842b480 6880af00 fab01a10 0940f080 f85d46bd
[2-8.2205] 2900: 47707b04 2301b480 7303af00 f85d46bd 47707b04 4604b598 af006843 46186882
[2-8.2205] 2920: 689b681b b1084798 73232300 bf00bd98 4605b5f8 af004606 0f04f855 d00542a8
[2-8.2205] 2940: f7fb6804 4620eecc d1f942ac 60752300 60f360b5 bf00bdf8 4605b5f8 46064b08
[2-8.2205] 2960: 447baf00 60033308 0f04f855 d00542a8 f7fb6804 4620eeb4 d1f942ac bdf84630
[2-8.2205] 2980: 00072456 43f8e92d af004681 4f04f859 d012454c 4688460e f7fa200c 68a3ef5c
[2-8.2205] 29a0: 60834641 f7fa4605 68b3ef62 60b33301 8000f8d5 45a16824 e8bdd1ee bf0083f8
[2-8.2205] 29c0: 2104b598 af004604 ebfaf7fb bd984620 4605b5f8 46064b0a 447baf00 60033308
[2-8.2205] 29e0: 0f04f855 d00542a8 f7fb6804 4620ee78 d1f942ac 21144630 ebe2f7fb bdf84630
[2-8.2205] 2a00: 000723de 4604b598 4a0b4b0a 0120f100 6980447b 4288af00 f103589b 60230308
[2-8.2206] 2a20: f7fbd001 4620ee5c f7fb2130 4620ebca bf00bd98 000749b4 00000b50 4604b598
[2-8.2206] 2a40: 4a0f4b0e 013cf100 6b40447b 4288af00 f103589b 60230308 f7fbd001 6a61ee40
[2-8.2206] 2a60: 001cf104 f836f04b 1d2068e1 f848f04b 214c4620 eba4f7fb bd984620 0007497c
[2-8.2206] 2a80: 00000c00 4604b598 4a0f4b0e 013cf100 6b40447b 4288af00 f103589b 60230308
[2-8.2206] 2aa0: f7fbd001 6a61ee1c 001cf104 f812f04b 1d2068e1 f824f04b 214c4620 eb80f7fb
[2-8.2206] 2ac0: bd984620 00074934 00000c00 4604b598 4a0f4b0e 013cf100 6b40447b 4288af00
[2-8.2206] 2ae0: f103589b 60230308 f7fbd001 6a61edf8 001cf104 ffeef04a 1d2068e1 f800f04b
[2-8.2206] 2b00: 214c4620 eb5cf7fb bd984620 000748ec 00000c00 4604b598 4a0f4b0e 013cf100
[2-8.2206] 2b20: 6b40447b 4288af00 f103589b 60230308 f7fbd001 6a61edd4 001cf104 ffcaf04a
[2-8.2207] 2b40: 1d2068e1 ffdcf04a 214c4620 eb38f7fb bd984620 000748a4 00000c00 b083b590
[2-8.2207] 2b60: 693caf02 f7fa9400 3704efc6 bd9046bd f44fb580 4b047222 af004904 447b4804
[2-8.2207] 2b80: 44784479 edc8f7fb 0004dde2 0004e058 0004e082 47f0e92d 4b214606 4c21b084
[2-8.2207] 2ba0: af00447b f04f6900 4a1f0900 8004f853 9004f8c7 6803447a 4000f8d8 689c60fc
[2-8.2207] 2bc0: d1284294 0510f107 4608468a 9d08f845 f7fc4629 4604e896 46504629 0401f084
[2-8.2207] 2be0: 9008f8c7 eae0f7fb b2e06078 200cb150 ee30f7fa 6083687b f7fa1d31 68f3ee38
[2-8.2207] 2c00: 60f33301 f8d868fa 429a3000 3710d106 e8bd46bd 1d3a87f0 e7e747a0 eed2f7fb
[2-8.2207] 2c20: 00074824 00000b90 0003ed39 3458f8df 2458f8df e92d447b b0b943f0 af04589e
[2-8.2207] 2c40: f8c76833 f7fb30cc 2300ecea f7fb607b 4601e92c f1072200 f7fc0008 f7fbe84c
[2-8.2208] 2c60: 4604ec96 280068b8 81d3f000 ec74f7fc 1d3b4601 22004620 eab2f7fc f0002800
[2-8.2208] 2c80: efc08186 68b80010 0410f107 edc4613c 617c0b01 f0002800 214781bc ec9ef7fc
[2-8.2208] 2ca0: 695b6803 46034798 0824f107 801cf8c7 001cf107 0006e893 f047440a 2024f80f
[2-8.2208] 2cc0: 637b2300 edc6f7fa f10069fb 46050c10 c008f8c0 f0004543 6a7a818c 61026083
[2-8.2208] 2ce0: 46286a3b 46216b7a 230060eb 623b622a 3024f887 801cf8c7 edb8f7fa 69f869bb
[2-8.2208] 2d00: 61bb3301 d0014540 ece8f7fb 280068b8 817ff000 f7fc214d 6803ec8.2283] 4640b000-4640c000 r--p 0003b000 b3:12 11502      /usr/lib/libcryptocore.so.0.1.0
[2-8.2283] 4640c000-4640e000 rw-p 0003c000 b3:12 11502      /usr/lib/libcryptocore.so.0.1.0
[2-8.2283] 464a0000-464a2000 r-xp 00000000 b3:12 16938      /usr/lib/libaul-ex.so.0.1.0
[2-8.2284] 464a2000-464b1000 ---p 00002000 b3:12 16938      /usr/lib/libaul-ex.so.0.1.0
[2-8.2284] 464b1000-464b2000 r--p 00001000 b3:12 16938      /usr/lib/libaul-ex.so.0.1.0
[2-8.2284] 464b2000-464b3000 rw-p 00002000 b3:12 16938      /usr/lib/libaul-ex.so.0.1.0
[2-8.2284] 46500000-46501000 r-xp 00000000 b3:12 11793      /usr/lib/libnvram.so.0.1
[2-8.2284] 46501000-46510000 ---p 00001000 b3:12 11793      /usr/lib/libnvram.so.0.1
[2-8.2284] 46510000-46511000 r--p 00000000 b3:12 11793      /usr/lib/libnvram.so.0.1
[2-8.2284] 46511000-46512000 rw-p 00001000 b3:12 11793      /usr/lib/libnvram.so.0.1
[2-8.2284] 46540000-46591000 r-xp 00000000 b3:12 11783      /usr/lib/libcurl.so.4.5.0
[2-8.2284] 46591000-465a1000 ---p 00051000 b3:12 11783      /usr/lib/libcurl.so.4.5.0
[2-8.2284] 465a1000-465a2000 r--p 00051000 b3:12 11783      /usr/lib/libcurl.so.4.5.0
[2-8.2285] 465a2000-465a3000 rw-p 00052000 b3:12 11783      /usr/lib/libcurl.so.4.5.0
[2-8.2285] 466a0000-466c8000 r-xp 00000000 b3:12 16112      /usr/lib/libsecurestorage-client.so.1.0.0
[2-8.2285] 466c8000-466d7000 ---p 00028000 b3:12 16112      /usr/lib/libsecurestorage-client.so.1.0.0
[2-8.2285] 466d7000-466d8000 r--p 00027000 b3:12 16112      /usr/lib/libsecurestorage-client.so.1.0.0
[2-8.2285] 466d8000-466d9000 rw-p 00028000 b3:12 16112      /usr/lib/libsecurestorage-client.so.1.0.0
[2-8.2285] 46710000-46727000 r-xp 00000000 b3:12 16823      /usr/lib/libnghttp2.so.14.17.1
[2-8.2285] 46727000-46736000 ---p 00017000 b3:12 16823      /usr/lib/libnghttp2.so.14.17.1
[2-8.2285] 46736000-46738000 r--p 00016000 b3:12 16823      /usr/lib/libnghttp2.so.14.17.1
[2-8.2285] 46738000-46739000 rw-p 00018000 b3:12 16823      /usr/lib/libnghttp2.so.14.17.1
[2-8.2285] 46740000-46746000 r-xp 00000000 b3:12 12103      /usr/lib/libcapi-system-tvtimer.so
[2-8.2286] 46746000-46755000 ---p 00006000 b3:12 12103      /usr/lib/libcapi-system-tvtimer.so
[2-8.2286] 46755000-46756000 r--p 00005000 b3:12 12103      /usr/lib/libcapi-system-tvtimer.so
[2-8.2286] 46756000-46757000 rw-p 00006000 b3:12 12103      /usr/lib/libcapi-system-tvtimer.so
[2-8.2286] 46760000-4676b000 r-xp 00000000 b3:12 11922      /usr/lib/libcares.so.2.2.0
[2-8.2286] 4676b000-4677a000 ---p 0000b000 b3:12 11922      /usr/lib/libcares.so.2.2.0
[2-8.2286] 4677a000-4677b000 r--p 0000a000 b3:12 11922      /usr/lib/libcares.so.2.2.0
[2-8.2286] 4677b000-4677c000 rw-p 0000b000 b3:12 11922      /usr/lib/libcares.so.2.2.0
[2-8.2286] 46780000-46784000 r-xp 00000000 b3:12 15191      /usr/lib/libnode-manager.so.0.1
[2-8.2286] 46784000-46794000 ---p 00004000 b3:12 15191      /usr/lib/libnode-manager.so.0.1
[2-8.2286] 46794000-46795000 r--p 00004000 b3:12 15191      /usr/lib/libnode-manager.so.0.1
[2-8.2287] 46795000-46796000 rw-p 00005000 b3:12 15191      /usr/lib/libnode-manager.so.0.1
[2-8.2287] 46796000-46799000 rw-p 00000000 00:00 0
[2-8.2287] 467e0000-4682b000 r-xp 00000000 b3:12 16703      /usr/lib/libci-api.so
[2-8.2287] 4682b000-4683a000 ---p 0004b000 b3:12 16703      /usr/lib/libci-api.so
[2-8.2287] 4683a000-4683c000 r--p 0004a000 b3:12 16703      /usr/lib/libci-api.so
[2-8.2287] 4683c000-4683d000 rw-p 0004c000 b3:12 16703      /usr/lib/libci-api.so
[2-8.2287] 4683d000-4683e000 rw-p 00000000 00:00 0
[2-8.2287] 468a0000-468e6000 r-xp 00000000 b3:12 16766      /usr/lib/libsso_api.so
[2-8.2287] 468e6000-468f5000 ---p 00046000 b3:12 16766      /usr/lib/libsso_api.so
[2-8.2287] 468f5000-468f6000 r--p 00045000 b3:12 16766      /usr/lib/libsso_api.so
[2-8.2288] 468f6000-468f7000 rw-p 00046000 b3:12 16766      /usr/lib/libsso_api.so
[2-8.2288] 46980000-4699a000 r-xp 00000000 b3:12 16146      /usr/lib/libVDCurl.so.0.9
[2-8.2288] 4699a000-469a9000 ---p 0001a000 b3:12 16146      /usr/lib/libVDCurl.so.0.9
[2-8.2288] 469a9000-469aa000 r--p 00019000 b3:12 16146      /usr/lib/libVDCurl.so.0.9
[2-8.2288] 469aa000-469ab000 rw-p 0001a000 b3:12 16146      /usr/lib/libVDCurl.so.0.9
[2-8.2288] 46a00000-46a06000 r-xp 00000000 b3:12 16924      /usr/lib/libcomss-api.so
[2-8.2288] 46a06000-46a15000 ---p 00006000 b3:12 16924      /usr/lib/libcomss-api.so
[2-8.2288] 46a15000-46a16000 r--p 00005000 b3:12 16924      /usr/lib/libcomss-api.so
[2-8.2288] 46a16000-46a17000 rw-p 00006000 b3:12 16924      /usr/lib/libcomss-api.so
[2-8.2288] 46a60000-46bc1000 r-xp 00000000 b3:12 16213      /usr/lib/libtvs-parser.so
[2-8.2289] 46bc1000-46bd0000 ---p 00161000 b3:12 16213      /usr/lib/libtvs-parser.so
[2-8.2289] 46bd0000-46bd7000 r--p 00160000 b3:12 16213      /usr/lib/libtvs-parser.so
[2-8.2289] 46bd7000-46bdb000 rw-p 00167000 b3:12 16213      /usr/lib/libtvs-parser.so
[2-8.2289] 46be0000-46c28000 r-xp 00000000 b3:12 10913      /usr/lib/libpvr-service-api.so
[2-8.2289] 46c28000-46c37000 ---p 00048000 b3:12 10913      /usr/lib/libpvr-service-api.so
[2-8.2289] 46c37000-46c3b000 r--p 00047000 b3:12 10913      /usr/lib/libpvr-service-api.so
[2-8.2289] 46c3b000-46c3c000 rw-p 0004b000 b3:12 10913      /usr/lib/libpvr-service-api.so
[2-8.2289] 46c40000-46c59000 r-xp 00000000 b3:12 16748      /usr/lib/libca-api.so
[2-8.2289] 46c59000-46c68000 ---p 00019000 b3:12 16748      /usr/lib/libca-api.so
[2-8.2290] 46c68000-46c69000 r--p 00018000 b3:12 16748      /usr/lib/libca-api.so
[2-8.2290] 46c69000-46c6a000 rw-p 00019000 b3:12 16748      /usr/lib/libca-api.so
[2-8.2290] 46c70000-46c8a000 r-xp 00000000 b3:12 15149      /usr/lib/libnagsam-api.so
[2-8.2290] 46c8a000-46c9a000 ---p 0001a000 b3:12 15149      /usr/lib/libnagsam-api.so
[2-8.2290] 46c9a000-46c9b000 r--p 0001a000 b3:12 15149      /usr/lib/libnagsam-api.so
[2-8.2290] 46c9b000-46c9c000 rw-p 0001b000 b3:12 15149      /usr/lib/libnagsam-api.so
[2-8.2290] 46d40000-46d4a000 r-xp 00000000 b3:12 16332      /usr/lib/libpvr-security.so
[2-8.2290] 46d4a000-46d59000 ---p 0000a000 b3:12 16332      /usr/lib/libpvr-security.so
[2-8.2290] 46d59000-46d5a000 r--p 00009000 b3:12 16332      /usr/lib/libpvr-security.so
[2-8.2290] 46d5a000-46d5b000 rw-p 0000a000 b3:12 16332      /usr/lib/libpvr-security.so
[2-8.2290] 46d5b000-46d5d000 rw-p 00000000 00:00 0
[2-8.2291] 46d60000-46d6d000 r-xp 00000000 b3:12 14839      /usr/lib/libres-lookup.so.0.1
[2-8.2291] 46d6d000-46d7c000 ---p 0000d000 b3:12 14839      /usr/lib/libres-lookup.so.0.1
[2-8.2291] 46d7c000-46d7d000 r--p 0000c000 b3:12 14839      /usr/lib/libres-lookup.so.0.1
[2-8.2291] 46d7d000-46d7e000 rw-p 0000d000 b3:12 14839      /usr/lib/libres-lookup.so.0.1
[2-8.2291] 46e90000-46ea4000 r-xp 00000000 b3:12 13871      /usr/lib/libtv-resource-information.so.1.24
[2-8.2291] 46ea4000-46eb3000 ---p 00014000 b3:12 13871      /usr/lib/libtv-resource-information.so.1.24
[2-8.2291] 46eb3000-46eb4000 r--p 00013000 b3:12 13871      /usr/lib/libtv-resource-information.so.1.24
[2-8.2292] 46eb4000-46eb5000 rw-p 00014000 b3:12 13871      /usr/lib/libtv-resource-information.so.1.24
[2-8.2292] 46fb0000-46fb2000 r-xp 00000000 b3:12 16089      /usr/lib/libcapi-screensaver.so
[2-8.2292] 46fb2000-46fc1000 ---p 00002000 b3:12 16089      /usr/lib/libcapi-screensaver.so
[2-8.2292] 46fc1000-46fc2000 r--p 00001000 b3:12 16089      /usr/lib/libcapi-screensaver.so
[2-8.2292] 46fc2000-46fc3000 rw-p 00002000 b3:12 16089      /usr/lib/libcapi-screensaver.so
[2-8.2292] 47030000-47103000 r-xp 00000000 b3:12 12102      /usr/lib/libgstreamer-1.0.so.0.1202.0
[2-8.2292] 47103000-47113000 ---p 000d3000 b3:12 12102      /usr/lib/libgstreamer-1.0.so.0.1202.0
[2-8.2292] 47113000-47116000 r--p 000d3000 b3:12 12102      /usr/lib/libgstreamer-1.0.so.0.1202.0
[2-8.2293] 47116000-47118000 rw-p 000d6000 b3:12 12102      /usr/lib/libgstreamer-1.0.so.0.1202.0
[2-8.2293] 47118000-47119000 rw-p 00000000 00:00 0
[2-8.2293] 471e0000-47232000 r-xp 00000000 b3:12 11879      /usr/lib/libgstvideo-1.0.so.0.1202.0
[2-8.2293] 47232000-47242000 ---p 00052000 b3:12 11879      /usr/lib/libgstvideo-1.0.s[2-18.6165] [wlan][928](SW4 EVENT) 1x sending done PKT[0xd9e06cc0] WIDX:PID[3:4] Status[0]
[3-18.6183] [wlan][560](RSN EVENT) mtk_cfg80211_add_key
[2-18.6207] [wlan][928](RSN EVENT) EVENT_ID_ADD_PKEY_DONE BSSIDX=0 ff:ff:ff:ff:ff:ff
[1-18.6281] ESTART: 13,91675 [0,27271] -             E_BG_Zone Update Done
[1-18.6281] ESTART: 13,91682 [0,00007] -             E_Comp_Wl_Deferred
[1-18.6313] ESTART: 13,91992 [0,00310] -             E_Comp_Wl_Deferred Done
[1-18.6313] ESTART: 13,91996 [0,00004] - [DEFERRED] Compositor's deferred job Done
[1-18.6313] ESTART: 13,91997 [0,00001] - [DEFERRED] E_Policy's deferred job
[1-18.6313] ESTART: 13,92002 [0,00004] - [DEFERRED] E_Policy's deferred job Done
[1-18.6313] ESTART: 13,92003 [0,00001] - [DEFERRED] E_Module's deferred job
[1-18.6314] ESTART: 13,92007 [0,00004] - [DEFERRED] E_Module's deferred job Done
[2-18.6377] [wlan][467](SW4 EVENT) DHCP client DISCOVERY sending >>> PKT[0xdee3d9c0] XID[0xd38a729f]
[2-18.6473] [wlan][928](SW4 EVENT) DHCP sending done <<< PKT[0xdee3d9c0] WIDX:PID[3:5] Status[0]
[2-18.6610] [wlan][76](INIT EVENT) wlanSetMulticastListWorkQueue prDev->flags:0x9203
[2-18.6610] === u4PacketFilter:0xc ====
[2-18.6977] [Extended-Mincore] [tvs-daemon | 711] Waiting for get_coredump_config to return..
[2-18.7388] [wlan][467](SW4 EVENT) DHCP client DISCOVERY sending >>> PKT[0xd9dd5d80] XID[0xd38a729f]
[2-18.7459] [wlan][928](SW4 EVENT) DHCP sending done <<< PKT[0xd9dd5d80] WIDX:PID[3:6] Status[0]
[2-18.9003] [Extended-Mincore] [tvs-daemon | 711] Waiting for get_coredump_config to return..
[2-18.9818] [wlan][467](SW4 EVENT) DHCP client DISCOVERY sending >>> PKT[0xda82a3c0] XID[0xd38a729f]
[2-18.9889] [wlan][928](SW4 EVENT) DHCP sending done <<< PKT[0xda82a3c0] WIDX:PID[3:7] Status[0]
[2-19.1042] [Extended-Mincore] [tvs-daemon | 711] Waiting for get_coredump_config to return..
[2-19.3082] [Extended-Mincore] [tvs-daemon | 711] Waiting for get_coredump_config to return..
[2-19.3842] [wlan][467](SW4 EVENT) DHCP client DISCOVERY sending >>> PKT[0xde07d900] XID[0xd38a729f]
[2-19.3978] [wlan][928](SW4 EVENT) DHCP sending done <<< PKT[0xde07d900] WIDX:PID[3:8] Status[0]
[2-19.5123] [Extended-Mincore] [tvs-daemon | 711] Waiting for get_coredump_config to return..
[2-19.7162] [Extended-Mincore] [tvs-daemon | 711] Waiting for get_coredump_config to return..
[2-19.7839] [wlan][866](RSN EVENT) Recv DHCP Offer
[2-19.7849] [wlan][467](SW4 EVENT) DHCP client REQUEST sending >>> PKT[0xd9adb000] XID[0xd38a729f]
[2-19.7920] [wlan][928](SW4 EVENT) DHCP sending done <<< PKT[0xd9adb000] WIDX:PID[3:9] Status[0]
[2-19.9202] [Extended-Mincore] [tvs-daemon | 711] Waiting for get_coredump_config to return..
[0-20.0252] [send_micom_msg] send msg success for on
[0-20.0252] [set_3G_port] set 3g on success
[2-20.1283] [Extended-Mincore] [tvs-daemon | 711] Waiting for get_coredump_config to return..
[2-20.3002] [wlan][928](BSS ERROR) ### nicUpdateBss
[2-20.3003] [wlan][928](BSS ERROR) ### nicUpdateBss nicTxDirectClearBssAbsentQ
[2-20.3403] [Extended-Mincore] [tvs-daemon | 711] Waiting for get_coredump_config to return..
[0-20.4910] logger: enlightenment (p:199) exceeds the log limit:800
[2-20.5442] [Extended-Mincore] [tvs-daemon | 711] Waiting for get_coredump_config to return..
[2-20.7482] [Extended-Mincore] [tvs-daemon | 711] Waiting for get_coredump_config to return..
[2-20.8078] [wlan][1103](RSN EVENT) Recv DHCP Offer
[2-20.9602] [Extended-Mincore] [tvs-daemon | 711] Waiting for get_coredump_config to return..
[2-21.0012] [wlan][467](SW4 EVENT) DHCP client REQUEST sending >>> PKT[0xd417d0c0] XID[0xd38a729f]
[2-21.0083] [wlan][928](SW4 EVENT) DHCP sending done <<< PKT[0xd417d0c0] WIDX:PID[3:10] Status[0]
[2-21.1642] [Extended-Mincore] [tvs-daemon | 711] Waiting for get_coredump_config to return..
[0-21.2858] nvt,auth fd770000.auth: req_idx...=500((0x500))
[2-21.3682] [Extended-Mincore] [tvs-daemon | 711] Waiting for get_coredump_config to return..
[2-21.5724] [Extended-Mincore] [tvs-daemon | 711] Waiting for get_coredump_config to return..
[2-21.7762] [Extended-Mincore] [tvs-daemon | 711] Waiting for get_coredump_config to return..
[2-21.8320] [wlan][1177](RSN EVENT) Recv DHCP Offer
[2-21.9842] [Extended-Mincore] [tvs-daemon | 711] Waiting for get_coredump_config to return..
[0-21.9889] kdbus: message queue overflow at [P:ci-daemon(464) C:26] by [P:btapp(1225)]
[2-22.0010] [wlan][467](SW4 EVENT) DHCP client REQUEST sending >>> PKT[0xd9a4fc00] XID[0xd38a729f]
[0-22.0031] kdbus: message queue overflow at [P:ci-daemon(464) C:26] by [P:FSLazyThread(364)]
[0-22.0042] kdbus: message queue overflow at [P:ci-daemon(464) C:26] by [P:FSLazyThread(364)]
[0-22.0052] kdbus: message queue overflow at [P:ci-daemon(464) C:26] by [P:FSLazyThread(364)]
[2-22.0191] [wlan][928](SW4 EVENT) DHCP sending done <<< PKT[0xd9a4fc00] WIDX:PID[3:11] Status[0]
[2-22.0352] kdbus: message queue overflow at [P:ci-daemon(464) C:26] by [P:ContentServiceM(1177)]
[0-22.0369] kdbus: message queue overflow at [P:ci-daemon(464) C:26] by [P:appbinary-manag(1222)]
[0-22.0535] kdbus: message queue overflow at [P:ci-daemon(464) C:26] by [P:btapp(1225)]
[1-22.0575] kdbus: message queue overflow at [P:ci-daemon(464) C:26] by [P:storaged(1094)]
[1-22.0581] kdbus: message queue overflow at [P:ci-daemon(464) C:26] by [P:DN_sung.tv.csfs(364)]
[0-22.0709] kdbus: message queue overflow at [P:ci-daemon(464) C:26] by [P:btapp(1225)]
[0-22.0755] kdbus: message queue overflow at [P:ci-daemon(464) C:26] by [P:btapp(1225)]
[0-22.1009] kdbus: message queue overflow at [P:ci-daemon(464) C:26] by [P:btapp(1225)]
[2-22.1159] kdbus: message queue overflow at [P:ci-daemon(464) C:26] by [P:ContentServiceM(1177)]
[2-22.1482] logger: bt-service (p:463) exceeds the log limit:800
[2-22.1694] kdbus: message queue overflow at [P:ci-daemon(464) C:26] by [P:btapp(1225)]
[2-22.1882] [Extended-Mincore] [tvs-daemon | 711] Waiting for get_coredump_config to return..
[1-22.2847] kdbus: message queue overflow at [P:ci-daemon(464) C:26] by [P:app-control-ser(1121)]
[1-22.2855] kdbus: message queue overflow at [P:ci-daemon(464) C:26] by [P:app-control-ser(1121)]
[1-22.2926] kdbus: message queue overflow at [P:ci-daemon(464) C:26] by [P:scenario-mgr-tv(1336)]
[1-22.3111] kdbus: message queue overflow at [P:ci-daemon(464) C:26] by [P:scenario-mgr-tv(1336)]
[0-22.3199] kdbus: message queue overflow at [P:ci-daemon(464) C:26] by [P:background_upda(1157)]
[0-22.3564] kdbus: message queue overflow at [P:ci-daemon(464) C:26] by [P:slive-provider-(1096)]
[0-22.3577] kdbus: message queue overflow at [P:ci-daemon(464) C:26] by [P:slive-provider-(1096)]
[0-22.3585] kdbus: message queue overflow at [P:ci-daemon(464) C:26] by [P:slive-provider-(1096)]
[2-22.3922] [Extended-Mincore] [tvs-daemon | 711] Waiting for get_coredump_config to return..
[0-22.4257] kdbus: message queue overflow at [P:ci-daemon(464) C:26] by [P:FCRFChUpdater(1096)]
[0-22.4264] kdbus: message queue overflow at [P:ci-daemon(464) C:26] by [P:FCRFChUpdater(1096)]
[0-22.4271] kdbus: message queue overflow at [P:ci-daemon(464) C:26] by [P:FCRFChUpdater(1096)]
[2-22.4419] kdbus: message queue overflow at [P:ci-daemon(464) C:26] by [P:data-provider-m(1343)]
[2-22.4518] kdbus: message queue overflow at [P:ci-daemon(464) C:26] by [P:data-provider-m(1343)]
[1-22.4857] kdbus: message queue overflow at [P:ci-daemon(464) C:26] by [P:settings-servic(1097)]
[1-22.4866] kdbus: message queue overflow at [P:ci-daemon(464) C:26] by [P:settings-servic(1097)]
[0-22.5543] kdbus: message queue overflow at [P:ci-daemon(464) C:26] by [P:slive-provider-(1096)]
[0-22.5644] kdbus: message queue overflow at [P:ci-daemon(464) C:26] by [P:scenario-mgr-tv(1375)]
[0-22.5650] kdbus: message queue overflow at [P:ci-daemon(464) C:26] by [P:scenario-mgr-tv(1375)]
[0-22.5951] kdbus: message queue overflow at [P:ci-daemon(464) C:26] by [P:gkdbus(1375)]
[2-22.5962] [Extended-Mincore] [tvs-daemon | 711] Waiting for get_coredump_config to return..
[2-22.6252] kdbus: message queue overflow at [P:ci-daemon(464) C:26] by [P:slive-provider-(1096)]
[3-22.7245] kdbus: message queue overflow[0-26.2764] [Extended-Mincore] [tvs-daemon | 711] Waiting for get_coredump_config to return..
[0-26.4802] [Extended-Mincore] [tvs-daemon | 711] Waiting for get_coredump_config to return..
[0-26.6842] [Extended-Mincore] [tvs-daemon | 711] Waiting for get_coredump_config to return..
[0-26.8882] [Extended-Mincore] [tvs-daemon | 711] Waiting for get_coredump_config to return..
[0-27.0924] [Extended-Mincore] [tvs-daemon | 711] Waiting for get_coredump_config to return..
[0-27.2962] [Extended-Mincore] [tvs-daemon | 711] Waiting for get_coredump_config to return..
[0-27.5002] [Extended-Mincore] [tvs-daemon | 711] Waiting for get_coredump_config to return..
[0-27.7042] [Extended-Mincore] [tvs-daemon | 711] Waiting for get_coredump_config to return..
[0-27.9084] [Extended-Mincore] [tvs-daemon | 711] Waiting for get_coredump_config to return..
[0-28.1122] [Extended-Mincore] [tvs-daemon | 711] Waiting for get_coredump_config to return..
[0-28.3162] [Extended-Mincore] [tvs-daemon | 711] Waiting for get_coredump_config to return..
[0-28.5202] [Extended-Mincore] [tvs-daemon | 711] Waiting for get_coredump_config to return..
[0-28.7244] [Extended-Mincore] [tvs-daemon | 711] Waiting for get_coredump_config to return..
[0-28.7804] init: proc_entry
[0-28.7806] proc_entry mod ld(0xbe891000)
[2-28.9282] [Extended-Mincore] [tvs-daemon | 711] Waiting for get_coredump_config to return..
[0-29.1322] [Extended-Mincore] [tvs-daemon | 711] Waiting for get_coredump_config to return..
[0-29.3362] [Extended-Mincore] [tvs-daemon | 711] Waiting for get_coredump_config to return..
[0-29.5402] [Extended-Mincore] [tvs-daemon | 711] Waiting for get_coredump_config to return..
[1-29.7442] [Extended-Mincore] [tvs-daemon | 711] Waiting for get_coredump_config to return..
[1-29.9482] [Extended-Mincore] [tvs-daemon | 711] Waiting for get_coredump_config to return..
[0-30.0011] [FB] model_type : 0
[1-30.1522] [Extended-Mincore] [tvs-daemon | 711] Waiting for get_coredump_config to return..
[0-30.3562] [Extended-Mincore] [tvs-daemon | 711] Waiting for get_coredump_config to return..
[2-30.5602] [Extended-Mincore] [tvs-daemon | 711] Waiting for get_coredump_config to return..
[0-30.7642] [Extended-Mincore] [tvs-daemon | 711] Waiting for get_coredump_config to return..
[0-30.9682] [Extended-Mincore] [tvs-daemon | 711] Waiting for get_coredump_config to return..
[3-31.1722] [Extended-Mincore] [tvs-daemon | 711] Waiting for get_coredump_config to return..
[1-31.3762] [Extended-Mincore] [tvs-daemon | 711] Waiting for get_coredump_config to return..
[1-31.5802] [Extended-Mincore] [tvs-daemon | 711] Waiting for get_coredump_config to return..
[1-31.7842] [Extended-Mincore] [tvs-daemon | 711] Waiting for get_coredump_config to return..
[1-31.9882] [Extended-Mincore] [tvs-daemon | 711] Waiting for get_coredump_config to return..
[0-32.1922] [Extended-Mincore] [tvs-daemon | 711] Waiting for get_coredump_config to return..
[0-32.3962] [Extended-Mincore] [tvs-daemon | 711] Waiting for get_coredump_config to return..
[1-32.6002] [Extended-Mincore] [tvs-daemon | 711] Waiting for get_coredump_config to return..
[1-32.8043] [Extended-Mincore] [tvs-daemon | 711] Waiting for get_coredump_config to return..
[0-33.0082] [Extended-Mincore] [tvs-daemon | 711] Waiting for get_coredump_config to return..
[0-33.2122] [Extended-Mincore] [tvs-daemon | 711] Waiting for get_coredump_config to return..
[0-33.4162] [Extended-Mincore] [tvs-daemon | 711] Waiting for get_coredump_config to return..
[0-33.6202] [Extended-Mincore] [tvs-daemon | 711] Waiting for get_coredump_config to return..
[2-33.8242] [Extended-Mincore] [tvs-daemon | 711] Waiting for get_coredump_config to return..
[2-34.0282] [Extended-Mincore] [tvs-daemon | 711] Waiting for get_coredump_config to return..
[0-34.0384] logger: enlightenment (p:199)'s 134 logs were dropped from 24 tags
[0-34.2322] [Extended-Mincore] [tvs-daemon | 711] Waiting for get_coredump_config to return..
[3-34.4362] [Extended-Mincore] [tvs-daemon | 711] Waiting for get_coredump_config to return..
[0-34.6402] [Extended-Mincore] [tvs-daemon | 711] Waiting for get_coredump_config to return..
[2-34.8442] [Extended-Mincore] [tvs-daemon | 711] Waiting for get_coredump_config to return..
[3-34.9226] [MC:S][34.9223][AVEMonDIM]Inv-1
[0-34.9271] [MC:A][34.9266]Inv(0)
[1-35.0049] [wlan][1148](INIT EVENT) wlanSetMulticastListWorkQueue prDev->flags:0x9203
[1-35.0049] === u4PacketFilter:0xc ====
[2-35.0482] [Extended-Mincore] [tvs-daemon | 711] Waiting for get_coredump_config to return..
[2-35.2522] [Extended-Mincore] [tvs-daemon | 711] Waiting for get_coredump_config to return..
[2-35.4562] [Extended-Mincore] [tvs-daemon | 711] Waiting for get_coredump_config to return..
[3-35.5133] logger: bt-service (p:463)'s 53 logs were dropped from 29 tags
[2-35.6602] [Extended-Mincore] [tvs-daemon | 711] Waiting for get_coredump_config to return..
[1-35.8642] [Extended-Mincore] [tvs-daemon | 711] Waiting for get_coredump_config to return..
[35.906118][PWR] 2022-06-05T18:57:03+0300
[2-36.0682] [Extended-Mincore] [tvs-daemon | 711] Waiting for get_coredump_config to return..
[1-36.2722] [Extended-Mincore] [tvs-daemon | 711] Waiting for get_coredump_config to return..
[1-36.4762] [Extended-Mincore] [tvs-daemon | 711] Waiting for get_coredump_config to return..
[1-36.6802] [Extended-Mincore] [tvs-daemon | 711] Waiting for get_coredump_config to return..
[1-36.8842] [Extended-Mincore] [tvs-daemon | 711] Waiting for get_coredump_config to return..
[1-36.9081] logger: enlightenment (p:199) exceeds the log limit:800
[1-37.0882] [Extended-Mincore] [tvs-daemon | 711] Waiting for get_coredump_config to return..
[1-37.2922] [Extended-Mincore] [tvs-daemon | 711] Waiting for get_coredump_coю
лог2
7] 44893000-44894000 rw-p 00003000 b3:12 16928      /usr/lib/libcapi-appfw-app-common.so.0.8.4
[1-137.0317] 448a0000-448a9000 r-xp 00000000 b3:12 17111      /usr/lib/libcapi-appfw-app-manager.so.0.8.2
[1-137.0317] 448a9000-448b8000 ---p 00009000 b3:12 17111      /usr/lib/libcapi-appfw-aa0c f7fb4628 4620e944 ea04f7fc 00074314
[1-145.5023] 3160: 00000bd8 00000cc0 0004daf4 0004dbc2 0004d83a 0004dbc4 200db580 af004903
[1-145.5023] 3180: f7fa4479 f7fbef58 bd80e858 0004db80 b5b04b1d 4a1d4604 6885447b 589baf00
[1-145.5023] 31a0: 60033308 1d2bb15d 2f00e853 e8c31e51 28001fe0 f3bfd1f8 2a018f5b 4620d005
[1-145.5023] 31c0: f7fa210c 4620effe 682bbdb0 689b4628 f1054798 e8530308 1e512f00 1fe0e8c3
[1-145.5023] 31e0: d1f82800 8f5bf3bf d1e82a01 4b08682a 68d1447b d1034299 46286853 e7de4798
[1-145.5023] 3200: 47884628 bf00e7db 0007422c 00000c6c 00037801 b5b04b1d 4a1d4604 6885447b
[1-145.5023] 3220: 589baf00 60033308 1d2bb15d 2f00e853 e8c31e51 28001fe0 f3bfd1f8 2a018f5b
[1-145.5023] 3240: 4620d005 f7fa210c 4620efbc 682bbdb0 689b4628 f1054798 e8530308 1e512f00
[1-145.5023] 3260: 1fe0e8c3 d1f82800 8f5bf3bf d1e82a01 4b08682a 68d1447b d1034299 46286853
[1-145.5023] 3280: e7de4798 47884628 bf00e7db
[1-145.5024] --------------------------------------------------------------------------------------
[1-145.5024]
[1-145.5024] CPU: 1 PID: 3442 Comm: tvs-daemon Tainted: PO 4.1.10 #1 PPID: 1 PComm: systemd
[1-145.5024] Hardware name: Novatek-Cortex CA53
[1-145.5024] task: c71a4280 ti: d6b90000 task.ti: d6b90000
[1-145.5024] pc : [<43db2e8a>]    lr : [<43db2e8b>]    psr: a0000030
[1-145.5024] sp : b46fe3e8  ip : 43e276b0  fp : b46fe6b4
[1-145.5024] r10: b46fe620  r9 : b46fe480  r8 : b46fe470
[1-145.5024] r7 : b46fe3f8  r6 : 00071ec8  r5 : b5c0bc08  r4 : b46fe408
[1-145.5024] r3 : 00000004  r2 : 00000000  r1 : b46fe408  r0 : 00000000
[1-145.5024] Flags: NzCv  IRQs on  FIQs on  Mode USER_32  ISA Thumb  Segment user
[1-145.5024] Control: 10c5383d  Table: 0e1ac06a  DAC: 00000015
[1-145.5024] * dump maps on pid (3442 - tvs-daemon)
[1-145.5024] 00010000-00060000 r-xp 00000000 b3:12 10680      /usr/bin/tvs-daemon
[1-145.5024] 0006f000-00070000 r--p 0004f000 b3:12 10680      /usr/bin/tvs-daemon
[1-145.5024] 00070000-00073000 rw-p 00050000 b3:12 10680      /usr/bin/tvs-daemon
[1-145.5024] 00082000-000c9000 rw-p 00052000 b3:12 10680      /usr/bin/tvs-daemon
[1-145.5024] 000c9000-0010f000 rw-p 00000000 00:00 0          [heap]
[1-145.5025] 41000000-41020000 r-xp 00000000 b3:12 16495      /usr/lib/ld-2.24.so
[1-145.5025] 4102f000-41030000 r--p 0001f000 b3:12 16495      /usr/lib/ld-2.24.so
[1-145.5025] 41030000-41031000 rw-p 00020000 b3:12 16495      /usr/lib/ld-2.24.so
[1-145.5025] 41040000-41041000 r-xp 00000000 b3:12 14788      /usr/lib/libpower-defs.so.0.1.1
[1-145.5025] 41041000-41050000 ---p 00001000 b3:12 14788      /usr/lib/libpower-defs.so.0.1.1
[1-145.5025] 41050000-41051000 r--p 00000000 b3:12 14788      /usr/lib/libpower-defs.so.0.1.1
[1-145.5025] 41051000-41052000 rw-p 00001000 b3:12 14788      /usr/lib/libpower-defs.so.0.1.1
[1-145.5025] 41060000-42a4d000 r--p 00000000 b3:12 11120      /usr/lib/libicudata.so.63.2
[1-145.5025] 42a4d000-42a5c000 ---p 019ed000 b3:12 11120      /usr/lib/libicudata.so.63.2
[1-145.5025] 42a5c000-42a5d000 r--p 019ec000 b3:12 11120      /usr/lib/libicudata.so.63.2
[1-145.5025] 42a5d000-42a5e000 rw-p 019ed000 b3:12 11120      /usr/lib/libicudata.so.63.2
[1-145.5025] 42a60000-42a62000 r-xp 00000000 b3:12 15500      /usr/lib/libproc-stat.so.5.5.0
[1-145.5025] 42a62000-42a71000 ---p 00002000 b3:12 15500      /usr/lib/libproc-stat.so.5.5.0
[1-145.5025] 42a71000-42a72000 r--p 00001000 b3:12 15500      /usr/lib/libproc-stat.so.5.5.0
[1-145.5025] 42a72000-42a73000 rw-p 00002000 b3:12 15500      /usr/lib/libproc-stat.so.5.5.0
[1-145.5025] 42a80000-42ba5000 r-xp 00000000 b3:12 12215      /usr/lib/libc-2.24.so
[1-145.5026] 42ba5000-42bb4000 ---p 00125000 b3:12 12215      /usr/lib/libc-2.24.so
[1-145.5026] 42bb4000-42bb6000 r--p 00124000 b3:12 12215      /usr/lib/libc-2.24.so
[1-145.5026] 42bb6000-42bb8000 rw-p 00126000 b3:12 12215      /usr/lib/libc-2.24.so
[1-145.5026] 42bb8000-42bba000 rw-p 00000000 00:00 0
[1-145.5026] 42bc0000-42bd9000 r-xp 00000000 b3:12 10911      /usr/lib/libgcc_s.so.1
[1-145.5026] 42bd9000-42be8000 ---p 00019000 b3:12 10911      /usr/lib/libgcc_s.so.1
[1-145.5026] 42be8000-42be9000 r--p 00018000 b3:12 10911      /usr/lib/libgcc_s.so.1
[1-145.5026] 42be9000-42bea000 rw-p 00019000 b3:12 10911      /usr/lib/libgcc_s.so.1
[1-145.5026] 42bf0000-42c05000 r-xp 00000000 b3:12 12269      /usr/lib/libpthread-2.24.so
[1-145.5026] 42c05000-42c14000 ---p 00015000 b3:12 12269      /usr/lib/libpthread-2.24.so
[1-145.5026] 42c14000-42c15000 r--p 00014000 b3:12 12269      /usr/lib/libpthread-2.24.so
[1-145.5026] 42c15000-42c16000 rw-p 00015000 b3:12 12269      /usr/lib/libpthread-2.24.so
[1-145.5026] 42c16000-42c18000 rw-p 00000000 00:00 0
[1-145.5026] 42c20000-42c23000 r-xp 00000000 b3:12 15184      /usr/lib/libdl-2.24.so
[1-145.5026] 42c23000-42c32000 ---p 00003000 b3:12 15184      /usr/lib/libdl-2.24.so
[1-145.5026] 42c32000-42c33000 r--p 00002000 b3:12 15184      /usr/lib/libdl-2.24.so
[1-145.5027] 42c33000-42c34000 rw-p 00003000 b3:12 15184      /usr/lib/libdl-2.24.so
[1-145.5027] 42c40000-42d34000 r-xp 00000000 b3:12 16580      /usr/lib/libstdc++.so.6.0.22
[1-145.5027] 42d34000-42d44000 ---p 000f4000 b3:12 16580      /usr/lib/libstdc++.so.6.0.22
[1-145.5027] 42d44000-42d48000 r--p 000f4000 b3:12 16580      /usr/lib/libstdc++.so.6.0.22
[1-145.5027] 42d48000-42d4b000 rw-p 000f8000 b3:12 16580      /usr/lib/libstdc++.so.6.0.22
[1-145.5027] 42d4b000-42d4d000 rw-p 00000000 00:00 0
[1-145.5027] 42d50000-42dc2000 r-xp 00000000 b3:12 10909      /usr/lib/libm-2.24.so
[1-145.5027] 42dc2000-42dd1000 ---p 00072000 b3:12 10909      /usr/lib/libm-2.24.so
[1-145.5027] 42dd1000-42dd2000 r--p 00071000 b3:12 10909      /usr/lib/libm-2.24.so
[1-145.5027] 42dd2000-42dd3000 rw-p 00072000 b3:12 10909      /usr/lib/libm-2.24.so
[1-145.5027] 42de0000-42ded000 r-xp 00000000 b3:12 16172      /usr/lib/libcapi-base-common.so.0.4.54
[1-145.5027] 42ded000-42dfd000 ---p 0000d000 b3:12 16172      /usr/lib/libcapi-base-common.so.0.4.54
[1-145.5027] 42dfd000-42dff000 r--p 0000d000 b3:12 16172      /usr/lib/libcapi-base-common.so.0.4.54
[1-145.5027] 42dff000-42e00000 rw-p 0000f000 b3:12 16172      /usr/lib/libcapi-base-common.so.0.4.54
[1-145.5027] 42e10000-42e13000 r-xp 00000000 b3:12 11408      /usr/lib/libdlog.so.0.0.0
[1-145.5027] 42e13000-42e22000 ---p 00003000 b3:12 11408      /usr/lib/libdlog.so.0.0.0
[1-145.5028] 42e22000-42e23000 r--p 00002000 b3:12 11408      /usr/lib/libdlog.so.0.0.0
[1-145.5028] 42e23000-42e24000 rw-p 00003000 b3:12 11408      /usr/lib/libdlog.so.0.0.0
[1-145.5028] 42e30000-42e5b000 r-xp 00000000 b3:12 13572      /usr/lib/libcynara-commons.so.0.14.24
[1-145.5028] 42e5b000-42e6a000 ---p 0002b000 b3:12 13572      /usr/lib/libcynara-commons.so.0.14.24
[1-145.5028] 42e6a000-42e6c000 r--p 0002a000 b3:12 13572      /usr/lib/libcynara-commons.so.0.14.24
[1-145.5028] 42e6c000-42e6d000 rw-p 0002c000 b3:12 13572      /usr/lib/libcynara-commons.so.0.14.24
[1-145.5028] 42e70000-42e85000 r-xp 00000000 b3:12 16133      /usr/lib/libdbuspolicy1.so.1.1.0
[1-145.5028] 42e85000-42e94000 ---p 00015000 b3:12 16133      /usr/lib/libdbuspolicy1.so.1.1.0
[1-145.5028] 42e94000-42e95000 r--p 00014000 b3:12 16133      /usr/lib/libdbuspolicy1.so.1.1.0
[1-145.5028] 42e95000-42e96000 rw-p 00015000 b3:12 16133      /usr/lib/libdbuspolicy1.so.1.1.0
[1-145.5028] 42ea0000-42eb6000 r-xp 00000000 b3:12 16277      /usr/lib/libexpat.so.1.6.9
[1-145.5028] 42eb6000-42ec5000 ---p 00016000 b3:12 16277      /usr/lib/libexpat.so.1.6.9
[1-145.5028] 42ec5000-42ec7000 r--p 00015000 b3:12 16277      /usr/lib/libexpat.so.1.6.9
[1-145.5028] 42ec7000-42ec8000 rw-p 00017000 b3:12 16277      /usr/lib/libexpat.so.1.6.9
[1-145.5028] 42ed0000-42ed6000 r-xp 00000000 b3:12 13472      /usr/lib/libcynara-client-commons.so.0.14.24
[1-145.5028] 42ed6000-42ee5000 ---p 00006000 b3:12 13472      /usr/lib/libcynara-client-commons.so.0.14.24
[1-145.5029] 42ee5000-42ee6000 r--p 00005000 b3:12 13472      /usr/lib/libcynara03d000 rw-p 0000c000 b3:12 11641      /usr/lib/libapputil.so.0.1.0
[1-145.5064] 46060000-46062000 r-xp 00000000 b3:12 15331      /usr/lib/libbptime.so
[1-145.5064] 46062000-46071000 ---p 00002000 b3:12 15331      /usr/lib/libbptime.so
[1-145.5064] 46071000-46072000 r--p 00001000 b3:12 15331      /usr/lib/libbptime.so
[1-145.5065] 46072000-46073000 rw-p 00002000 b3:12 15331      /usr/lib/libbptime.so
[1-145.5065] 46080000-4608b000 r-xp 00000000 b3:12 10910      /usr/lib/libfbclient.so.0.1.2
[1-145.5065] 4608b000-4609a000 ---p 0000b000 b3:12 10910      /usr/lib/libfbclient.so.0.1.2
[1-145.5065] 4609a000-4609b000 r--p 0000a000 b3:12 10910      /usr/lib/libfbclient.so.0.1.2
[1-145.5065] 4609b000-4609c000 rw-p 0000b000 b3:12 10910      /usr/lib/libfbclient.so.0.1.2
[1-145.5065] 4609c000-4609d000 rw-p 00000000 00:00 0
[1-145.5065] 460a0000-460a1000 r-xp 00000000 b3:12 16333      /usr/lib/libnvram-c-glue.so.0.1
[1-145.5065] 460a1000-460b0000 ---p 00001000 b3:12 16333      /usr/lib/libnvram-c-glue.so.0.1
[1-145.5065] 460b0000-460b1000 rw-p 00000000 b3:12 16333      /usr/lib/libnvram-c-glue.so.0.1
[1-145.5065] 460c0000-460ca000 r-xp 00000000 b3:12 13588      /usr/lib/libIrbCtrlApi.so
[1-145.5065] 460ca000-460d9000 ---p 0000a000 b3:12 13588      /usr/lib/libIrbCtrlApi.so
[1-145.5065] 460d9000-460da000 r--p 00009000 b3:12 13588      /usr/lib/libIrbCtrlApi.so
[1-145.5065] 460da000-460db000 rw-p 0000a000 b3:12 13588      /usr/lib/libIrbCtrlApi.so
[1-145.5065] 460e0000-461d4000 r-xp 00000000 b3:12 13496      /usr/lib/libtvs-scan.so
[1-145.5065] 461d4000-461e3000 ---p 000f4000 b3:12 13496      /usr/lib/libtvs-scan.so
[1-145.5065] 461e3000-461e8000 r--p 000f3000 b3:12 13496      /usr/lib/libtvs-scan.so
[1-145.5066] 461e8000-461ec000 rw-p 000f8000 b3:12 13496      /usr/lib/libtvs-scan.so
[1-145.5066] 46360000-4639f000 r-xp 00000000 b3:12 11808      /usr/lib/libteec.so
[1-145.5066] 4639f000-463af000 ---p 0003f000 b3:12 11808      /usr/lib/libteec.so
[1-145.5066] 463af000-463b0000 rw-p 0003f000 b3:12 11808      /usr/lib/libteec.so
[1-145.5066] 463c0000-463fc000 r-xp 00000000 b3:12 11502      /usr/lib/libcryptocore.so.0.1.0
[1-145.5066] 463fc000-4640b000 ---p 0003c000 b3:12 11502      /usr/lib/libcryptocore.so.0.1.0
[1-145.5066] 4640b000-4640c000 r--p 0003b000 b3:12 11502      /usr/lib/libcryptocore.so.0.1.0
[1-145.5066] 4640c000-4640e000 rw-p 0003c000 b3:12 11502      /usr/lib/libcryptocore.so.0.1.0
[1-145.5066] 464a0000-464a2000 r-xp 00000000 b3:12 16938      /usr/lib/libaul-ex.so.0.1.0
[1-145.5066] 464a2000-464b1000 ---p 00002000 b3:12 16938      /usr/lib/libaul-ex.so.0.1.0
[1-145.5066] 464b1000-464b2000 r--p 00001000 b3:12 16938      /usr/lib/libaul-ex.so.0.1.0
[1-145.5066] 464b2000-464b3000 rw-p 00002000 b3:12 16938      /usr/lib/libaul-ex.so.0.1.0
[1-145.5066] 46500000-46501000 r-xp 00000000 b3:12 11793      /usr/lib/libnvram.so.0.1
[1-145.5066] 46501000-46510000 ---p 00001000 b3:12 11793      /usr/lib/libnvram.so.0.1
[1-145.5066] 46510000-46511000 r--p 00000000 b3:12 11793      /usr/lib/libnvram.so.0.1
[1-145.5066] 46511000-46512000 rw-p 00001000 b3:12 11793      /usr/lib/libnvram.so.0.1
[1-145.5066] 46540000-46591000 r-xp 00000000 b3:12 11783      /usr/lib/libcurl.so.4.5.0
[1-145.5067] 46591000-465a1000 ---p 00051000 b3:12 11783      /usr/lib/libcurl.so.4.5.0
[1-145.5067] 465a1000-465a2000 r--p 00051000 b3:12 11783      /usr/lib/libcurl.so.4.5.0
[1-145.5067] 465a2000-465a3000 rw-p 00052000 b3:12 11783      /usr/lib/libcurl.so.4.5.0
[1-145.5067] 466a0000-466c8000 r-xp 00000000 b3:12 16112      /usr/lib/libsecurestorage-client.so.1.0.0
[1-145.5067] 466c8000-466d7000 ---p 00028000 b3:12 16112      /usr/lib/libsecurestorage-client.so.1.0.0
[1-145.5067] 466d7000-466d8000 r--p 00027000 b3:12 16112      /usr/lib/libsecurestorage-client.so.1.0.0
[1-145.5067] 466d8000-466d9000 rw-p 00028000 b3:12 16112      /usr/lib/libsecurestorage-client.so.1.0.0
[1-145.5067] 46710000-46727000 r-xp 00000000 b3:12 16823      /usr/lib/libnghttp2.so.14.17.1
[1-145.5067] 46727000-46736000 ---p 00017000 b3:12 16823      /usr/lib/libnghttp2.so.14.17.1
[1-145.5067] 46736000-46738000 r--p 00016000 b3:12 16823      /usr/lib/libnghttp2.so.14.17.1
[1-145.5067] 46738000-46739000 rw-p 00018000 b3:12 16823      /usr/lib/libnghttp2.so.14.17.1
[1-145.5067] 46740000-46746000 r-xp 00000000 b3:12 12103      /usr/lib/libcapi-system-tvtimer.so
[1-145.5067] 46746000-46755000 ---p 00006000 b3:12 12103      /usr/lib/libcapi-system-tvtimer.so
[1-145.5067] 46755000-46756000 r--p 00005000 b3:12 12103      /usr/lib/libcapi-system-tvtimer.so
[1-145.5067] 46756000-46757000 rw-p 00006000 b3:12 12103      /usr/lib/libcapi-system-tvtimer.so
[1-145.5067] 46760000-4676b000 r-xp 00000000 b3:12 11922      /usr/lib/libcares.so.2.2.0
[1-145.5068] 4676b000-4677a000 ---p 0000b000 b3:12 11922      /usr/lib/libcares.so.2.2.0
[1-145.5068] 4677a000-4677b000 r--p 0000a000 b3:12 11922      /usr/lib/libcares.so.2.2.0
[1-145.5068] 4677b000-4677c000 rw-p 0000b000 b3:12 11922      /usr/lib/libcares.so.2.2.0
[1-145.5068] 46780000-46784000 r-xp 00000000 b3:12 15191      /usr/lib/libnode-manager.so.0.1
[1-145.5068] 46784000-46794000 ---p 00004000 b3:12 15191      /usr/lib/libnode-manager.so.0.1
[1-145.5068] 46794000-46795000 r--p 00004000 b3:12 15191      /usr/lib/libnode-manager.so.0.1
[1-145.5068] 46795000-46796000 rw-p 00005000 b3:12 15191      /usr/lib/libnode-manager.so.0.1
[1-145.5068] 46796000-46799000 rw-p 00000000 00:00 0
[1-145.5068] 467e0000-4682b000 r-xp 00000000 b3:12 16703      /usr/lib/libci-api.so
[1-145.5068] 4682b000-4683a000 ---p 0004b000 b3:12 16703      /usr/lib/libci-api.so
[1-145.5068] 4683a000-4683c000 r--p 0004a000 b3:12 16703      /usr/lib/libci-api.so
[1-145.5068] 4683c000-4683d000 rw-p 0004c000 b3:12 16703      /usr/lib/libci-api.so
[1-145.5068] 4683d000-4683e000 rw-p 00000000 00:00 0
[1-145.5068] 468a0000-468e6000 r-xp 00000000 b3:12 16766      /usr/lib/libsso_api.so
[1-145.5068] 468e6000-468f5000 ---p 00046000 b3:12 16766      /usr/lib/libsso_api.so
[1-145.5068] 468f5000-468f6000 r--p 00045000 b3:12 16766      /usr/lib/libsso_api.so
[1-145.5068] 468f6000-468f7000 rw-p 00046000 b3:12 16766      /usr/lib/libsso_api.so
[1-145.5069] 46980000-4699a000 r-xp 00000000 b3:12 16146      /usr/lib/libVDCurl.so.0.9
[1-145.5069] 4699a000-469a9000 ---p 0001a000 b3:12 16146      /usr/lib/libVDCurl.so.0.9
[1-145.5069] 469a9000-469aa000 r--p 00019000 b3:12 16146      /usr/lib/libVDCurl.so.0.9
[1-145.5069] 469aa000-469ab000 rw-p 0001a000 b3:12 16146      /usr/lib/libVDCurl.so.0.9
[1-145.5069] 46a00000-46a06000 r-xp 00000000 b3:12 16924      /usr/lib/libcomss-api.so
[1-145.5069] 46a06000-46a15000 ---p 00006000 b3:12 16924      /usr/lib/libcomss-api.so
[1-145.5069] 46a15000-46a16000 r--p 00005000 b3:12 16924      /usr/lib/libcomss-api.so
[1-145.5069] 46a16000-46a17000 rw-p 00006000 b3:12 16924      /usr/lib/libcomss-api.so
[1-145.5069] 46a60000-46bc1000 r-xp 00000000 b3:12 16213      /usr/lib/libtvs-parser.so
[1-145.5069] 46bc1000-46bd0000 ---p 00161000 b3:12 16213      /usr/lib/libtvs-parser.so
[1-145.5069] 46bd0000-46bd7000 r--p 00160000 b3:12 16213      /usr/lib/libtvs-parser.so
[1-145.5069] 46bd7000-46bdb000 rw-p 00167000 b3:12 16213      /usr/lib/libtvs-parser.so
[1-145.5069] 46be0000-46c28000 r-xp 00000000 b3:12 10913      /usr/lib/libpvr-service-api.so
[1-145.5069] 46c28000-46c37000 ---p 00048000 b3:12 10913      /usr/lib/libpvr-service-api.so
[1-145.5069] 46c37000-46c3b000 r--p 00047000 b3:12 10913      /usr/lib/libpvr-service-api.so
[1-145.5069] 46c3b000-46c3c000 rw-p 0004b000 b3:12 10913      /usr/lib/libpvr-service-api.so
[1-145.5070] 46c40000-46c59000 r-xp 00000000 b3:12 16748      /usr/lib/libca-api.so
[1-145.5070] 46c59000-46c68000 ---p 00019000 b3:12 16748      /usr/lib/libca-api.so
[1-145.5070] 46c68000-46c69000 r--p 00018000 b3:12 16748      /usr/lib/libca-api.so
[1-145.5070] 46c69000-46c6a000 rw-p 00019000 b3:12 16748      /usr/lib/libca-api.so
[1-145.5070] 46c70000-46c8a000 r-xp 00000000 b3:12 15149      /usr/lib/libnagsam-api.so
[1-145.5070] 46c8a000-46c9a000 ---p 0001a000 b r--p 0003c000 b3:12 16910      /usr/lib/libssl.so.1.0.0
[0-154.0568] 43c2e000-43c32000 rw-p 0003e000 b3:12 16910      /usr/lib/libssl.so.1.0.0
[0-154.0568] 43c40000-43c52000 r-xp 00000000 b3:12 16498      /usr/lib/libdeviced.so.1.0.3
[0-154.0568] 43c52000-43c61000 ---p 00012000 b3:12 16498      /usr/lib/libdeviced.so.1.0.3
[0-154.0568] 43c61000-43c62000 r--p 00011000 b3:12 16498      /usr/lib/libdeviced.so.1.0.3
[0-154.0568] 43c62000-43c63000 rw-p 00012000 b3:12 16498      /usr/lib/libdeviced.so.1.0.3
[0-154.0568] 43c70000-43c8c000 r-xp 00000000 b3:12 16443      /usr/lib/libjsoncpp.so.0.10.4
[0-154.0568] 43c8c000-43c9b000 ---p 0001c000 b3:12 16443      /usr/lib/libjsoncpp.so.0.10.4
[0-154.0568] 43c9b000-43c9c000 r--p 0001b000 b3:12 16443      /usr/lib/libjsoncpp.so.0.10.4
[0-154.0568] 43c9c000-43c9d000 rw-p 0001c000 b3:12 16443      /usr/lib/libjsoncpp.so.0.10.4
[0-154.0568] 43ca0000-43ca1000 r-xp 00000000 b3:12 16800      /usr/lib/libdisplay-panel-c-glue.so.0.1
[0-154.0568] 43ca1000-43cb0000 ---p 00001000 b3:12 16800      /usr/lib/libdisplay-panel-c-glue.so.0.1
[0-154.0568] 43cb0000-43cb1000 rw-p 00000000 b3:12 16800      /usr/lib/libdisplay-panel-c-glue.so.0.1
[0-154.0568] 43cc0000-43cc1000 r-xp 00000000 b3:12 12189      /usr/lib/libdisplay-panel.so.0.1
[0-154.0568] 43cc1000-43cd1000 ---p 00001000 b3:12 12189      /usr/lib/libdisplay-panel.so.0.1
[0-154.0568] 43cd1000-43cd2000 r--p 00001000 b3:12 12189      /usr/lib/libdisplay-panel.so.0.1
[0-154.0569] 43cd2000-43cd3000 rw-p 00002000 b3:12 12189      /usr/lib/libdisplay-panel.so.0.1
[0-154.0569] 43ce0000-43cea000 r-xp 00000000 b3:12 16696      /usr/lib/libdrm.so.2.4.0
[0-154.0569] 43cea000-43cf9000 ---p 0000a000 b3:12 16696      /usr/lib/libdrm.so.2.4.0
[0-154.0569] 43cf9000-43cfa000 r--p 00009000 b3:12 16696      /usr/lib/libdrm.so.2.4.0
[0-154.0569] 43cfa000-43cfb000 rw-p 0000a000 b3:12 16696      /usr/lib/libdrm.so.2.4.0
[0-154.0569] 43d00000-43d08000 r-xp 00000000 b3:12 16151      /usr/lib/libmmfcommon.so.0.0.0
[0-154.0569] 43d08000-43d17000 ---p 00008000 b3:12 16151      /usr/lib/libmmfcommon.so.0.0.0
[0-154.0569] 43d17000-43d18000 r--p 00007000 b3:12 16151      /usr/lib/libmmfcommon.so.0.0.0
[0-154.0569] 43d18000-43d19000 rw-p 00008000 b3:12 16151      /usr/lib/libmmfcommon.so.0.0.0
[0-154.0569] 43d20000-43d21000 r-xp 00000000 b3:12 13540      /usr/lib/libpower-control-c-glue.so.0.1
[0-154.0569] 43d21000-43d30000 ---p 00001000 b3:12 13540      /usr/lib/libpower-control-c-glue.so.0.1
[0-154.0569] 43d30000-43d31000 rw-p 00000000 b3:12 13540      /usr/lib/libpower-control-c-glue.so.0.1
[0-154.0569] 43d40000-43d41000 r-xp 00000000 b3:12 12451      /usr/lib/libpower-control.so.0.1
[0-154.0569] 43d41000-43d50000 ---p 00001000 b3:12 12451      /usr/lib/libpower-control.so.0.1
[0-154.0569] 43d50000-43d51000 r--p 00000000 b3:12 12451      /usr/lib/libpower-control.so.0.1
[0-154.0569] 43d51000-43d52000 rw-p 00001000 b3:12 12451      /usr/lib/libpower-control.so.0.1
[0-154.0569] 43d60000-43d63000 r-xp 00000000 b3:12 15171      /usr/lib/libsec-video-tuner-check.so.0.1.0
[0-154.0570] 43d63000-43d72000 ---p 00003000 b3:12 15171      /usr/lib/libsec-video-tuner-check.so.0.1.0
[0-154.0570] 43d72000-43d73000 r--p 00002000 b3:12 15171      /usr/lib/libsec-video-tuner-check.so.0.1.0
[0-154.0570] 43d73000-43d74000 rw-p 00003000 b3:12 15171      /usr/lib/libsec-video-tuner-check.so.0.1.0
[0-154.0570] 43d80000-43e15000 r-xp 00000000 b3:12 11717      /usr/lib/libtvs-chms.so
[0-154.0570] 43e15000-43e24000 ---p 00095000 b3:12 11717      /usr/lib/libtvs-chms.so
[0-154.0570] 43e24000-43e27000 r--p 00094000 b3:12 11717      /usr/lib/libtvs-chms.so
[0-154.0570] 43e27000-43e29000 rw-p 00097000 b3:12 11717      /usr/lib/libtvs-chms.so
[0-154.0570] 43e29000-43e2a000 rw-p 00000000 00:00 0
[0-154.0570] 43e40000-43e54000 r-xp 00000000 b3:12 15393      /usr/lib/libboost_filesystem.so.1.58.0
[0-154.0570] 43e54000-43e63000 ---p 00014000 b3:12 15393      /usr/lib/libboost_filesystem.so.1.58.0
[0-154.0570] 43e63000-43e64000 r--p 00013000 b3:12 15393      /usr/lib/libboost_filesystem.so.1.58.0
[0-154.0570] 43e64000-43e65000 rw-p 00014000 b3:12 15393      /usr/lib/libboost_filesystem.so.1.58.0
[0-154.0570] 43e70000-43e8d000 r-xp 00000000 b3:12 16466      /usr/lib/liblibtv-plpmanager.so
[0-154.0570] 43e8d000-43e9c000 ---p 0001d000 b3:12 16466      /usr/lib/liblibtv-plpmanager.so
[0-154.0570] 43e9c000-43e9d000 r--p 0001c000 b3:12 16466      /usr/lib/liblibtv-plpmanager.so
[0-154.0570] 43e9d000-43e9e000 rw-p 0001d000 b3:12 16466      /usr/lib/liblibtv-plpmanager.so
[0-154.0570] 43ea0000-43ebc000 r-xp 00000000 b3:12 17035      /usr/lib/libsensor-genuine.so.4.0.4
[0-154.0571] 43ebc000-43ecb000 ---p 0001c000 b3:12 17035      /usr/lib/libsensor-genuine.so.4.0.4
[0-154.0571] 43ecb000-43ecc000 rw-p 0001b000 b3:12 17035      /usr/lib/libsensor-genuine.so.4.0.4
[0-154.0571] 43ed0000-43ee1000 r-xp 00000000 b3:12 15268      /usr/lib/libsensord-shared.so
[0-154.0571] 43ee1000-43ef0000 ---p 00011000 b3:12 15268      /usr/lib/libsensord-shared.so
[0-154.0571] 43ef0000-43ef1000 r--p 00010000 b3:12 15268      /usr/lib/libsensord-shared.so
[0-154.0571] 43ef1000-43ef2000 rw-p 00011000 b3:12 15268      /usr/lib/libsensord-shared.so
[0-154.0571] 43f00000-43f08000 r-xp 00000000 b3:12 12157      /usr/lib/libappcore-common.so.1.14.1
[0-154.0571] 43f08000-43f17000 ---p 00008000 b3:12 12157      /usr/lib/libappcore-common.so.1.14.1
[0-154.0571] 43f17000-43f18000 r--p 00007000 b3:12 12157      /usr/lib/libappcore-common.so.1.14.1
[0-154.0571] 43f18000-43f19000 rw-p 00008000 b3:12 12157      /usr/lib/libappcore-common.so.1.14.1
[0-154.0571] 43f20000-43f22000 r-xp 00000000 b3:12 17099      /usr/lib/libboost_system.so.1.58.0
[0-154.0571] 43f22000-43f31000 ---p 00002000 b3:12 17099      /usr/lib/libboost_system.so.1.58.0
[0-154.0571] 43f31000-43f32000 r--p 00001000 b3:12 17099      /usr/lib/libboost_system.so.1.58.0
[0-154.0571] 43f32000-43f33000 rw-p 00002000 b3:12 17099      /usr/lib/libboost_system.so.1.58.0
[0-154.0571] 43f40000-43f44000 r-xp 00000000 b3:12 17021      /usr/lib/libcapi-appfw-app-control-uri.so.0.11.11
[0-154.0571] 43f44000-43f53000 ---p 00004000 b3:12 17021      /usr/lib/libcapi-appfw-app-control-uri.so.0.11.11
[0-154.0572] 43f53000-43f54000 r--p 00003000 b3:12 17021      /usr/lib/libcapi-appfw-app-control-uri.so.0.11.11
[0-154.0572] 43f54000-43f55000 rw-p 00004000 b3:12 17021      /usr/lib/libcapi-appfw-app-control-uri.so.0.11.11
[0-154.0572] 43f60000-43f67000 r-xp 00000000 b3:12 11187      /usr/lib/libcapi-appfw-app-control.so.0.11.11
[0-154.0572] 43f67000-43f76000 ---p 00007000 b3:12 11187      /usr/lib/libcapi-appfw-app-control.so.0.11.11
[0-154.0572] 43f76000-43f77000 r--p 00006000 b3:12 11187      /usr/lib/libcapi-appfw-app-control.so.0.11.11
[0-154.0572] 43f77000-43f78000 rw-p 00007000 b3:12 11187      /usr/lib/libcapi-appfw-app-control.so.0.11.11
[0-154.0572] 43f80000-43fe4000 r-xp 00000000 b3:12 11221      /usr/lib/libtvs-pvr.so
[0-154.0572] 43fe4000-43ff4000 ---p 00064000 b3:12 11221      /usr/lib/libtvs-pvr.so
[0-154.0572] 43ff4000-43ff5000 r--p 00064000 b3:12 11221      /usr/lib/libtvs-pvr.so
[0-154.0572] 43ff5000-43ff7000 rw-p 00065000 b3:12 11221      /usr/lib/libtvs-pvr.so
[0-154.0572] 44000000-44061000 r-xp 00000000 b3:12 12282      /usr/lib/libsecurity-manager-commons.so.1.0.2
[0-154.0572] 44061000-44071000 ---p 00061000 b3:12 12282      /usr/lib/libsecurity-manager-commons.so.1.0.2
[0-154.0572] 44071000-44073000 rw-p 00061000 b3:12 12282      /usr/lib/libsecurity-manager-commons.so.1.0.2
[0-154.0572] 44080000-440d3000 r-xp 00000000 b3:12 16185      /usr/lib/libboost_serialization.so.1.58.0
[0-154.0572] 440d3000-440e3000 ---p 00053000 b3:12 16185      /usr/lib/libboost_serialization.so.1.58.0
[0-154.0573] 440e3000-440e4000 r--p 00053000 b3:12 16185      /usr/lib/libboost_serialization.so.1.58.0
[0-154.0573] 440e4000-440e6000 rw-p 00054000 b3:12 16185      /usr/lib/libboost_serialization.so.1.58.0
[0-154.0573] 440f0000-44130000 r-xp 00000000 b3:12 11420      /usr/lib/libtvs-dbms.so
[0-154.0573] 44130000-4413f000 ---p 0004[Pid:3481][VDLP COREDUMP] SIGNR:11
[1-162.4502]
[1-162.4504] [Extended-Mincore] do_minimal_core called for signal 11 and comm tvs-daemon and group_leader_comm tvs-daemon
[1-162.4504] [Extended-Mincore] [tvs-daemon | 3481] Waiting for get_coredump_config to return..
[issue_report_agent][isCoreDumpExpected:411]error_kind = SIGSEGV
[issue_report_agent][read_fault_info_in_proc:1154]error_count is max(10)
[1-162.6522] [Extended-Mincore] [tvs-daemon | 3481] get_coredump_config returned with core_type = 0
[1-163.0080] Before Recovery:
[1-163.0080] Code: f000 80c6 f7fb e8ee (6803) 695b
[1-163.0080] After Recovery:
[1-163.0080] send signal from KERNEL, SIG : 11, tvs-daemon(3551), handler:0x0 force_sig_info
[1-163.0082] tvs-daemon: unhandled page fault (11) at 0x00000000, code 0x017
[1-163.0414]  Ver : 6340677, release
[1-163.0414]  TV, Kant.SU2-Tizen, release, Trunk_2020_MP
[1-163.0414]  Linux version 4.1.10 (abuild@A1312DKG) (gcc version 6.2.1 20161213 (Tizen/Linaro GCC 6.2.1 2016.12/VDCosmos-20190704 7.8) ) #1 SMP PREEMPT Fri Jan 8 11:04:50 UTC 2021
[1-163.0414]  dtsversion=6290398_kantsu2-1.5G-cma console=ttyS0,115200 rs232=0 earlyprintk maxcpus=4 no_console_suspend only_entry_model root=/dev/mmcblk0p18 KDUMP=16 SELP_ENABLE=20208724 _nvtca9-16m rootfstype=vdfs ro init=/sbin/init mem=808M@32M mem=56M@968M mem=256M@2048M vmalloc=300M rootwait quiet bdinfo=00000091 model=4kbtin   pba_none
[1-163.0414]
[1-163.0414] Last Exception point
[1-163.0414] --------------------------------------------------------------------------------------
[1-163.0414] PC, LR MEMINFO
[1-163.0414] PC:43db2e8a, LR:43db2e8b
[1-163.0414] PC meminfo (0x43db328a to 0x43db328a)
[1-163.0414] 3280:
[1-163.0414] LR meminfo (0x43db268b to 0x43db328b)
[1-163.0414] 2680:                            2010f8cb 3f18f84a e8def7fb 4a374603 20014931
[1-163.0414] 26a0: 6058447a 60983248 f8c31d18 601ab00c 603b5864 a000f8c4 e8506063 33013f00
[1-163.0414] 26c0: 3fe2e8c0 d1f82a00 8f5bf3bf f7fb6878 4a2aed2a 4620492a 4479447a e92cf7fb
[1-163.0414] 26e0: 4618683b fdbcf039 f7fce779 f7fbe96c f8dbeb0a 46583000 4798685b ec62f7fc
[1-163.0415] 2700: 211c4604 f7fb4658 6878ed5c ece6f7fb 46304b1c f103447b f103011c 62390234
[1-163.0415] 2720: 637a3354 f03863bb 4640ff73 ff70f038 f7fc4620 4604ef18 eda0f7fc 4604e7e5
[1-163.0415] 2740: 4604e7e3 f0384630 e7eeff63 00074e60 00000b90 0007441a 0005622c 00000bb8
[1-163.0415] 2760: 000573a6 00000e20 00074390 00072c9c 00074342 00074324 0007299c 00075b28
[1-163.0415] 2780: 0003889f 0007427c e59f3014 e59f2014 e08f3003 e7932002 e3520000 012fff1e
[1-163.0415] 27a0: eafff3f3 00074c30 00000df8 48084b07 4a08447b 33034478 447a1a1b d9032b06
[1-163.0415] 27c0: 58d34b05 4718b103 bf004770 00075b04 00075b00 00074c0a 00000dc0 48094908
[1-163.0415] 27e0: 4b094479 1a094478 1089447b 71d1eb01 d0031049 589b4a05 4718b103 bf004770
[1-163.0415] 2800: 00075ad4 00075ad0 00074bdc 00000e04 4b0ab508 447b4a0a 781b447a 4b09b96b
[1-163.0415] 2820: b12358d3 447b4b08 f7fc6818 f7ffefec 4b06ffbd 447b2201 bd08701a 00075a9e
[1-163.0415] 2840: 00074bac 00000e10 000759da 00075a7e b5084807 68024478 447b4b06 e8bdb912
[1-163.0415] 2860: e7bb4008 589b4a04 d0f82b00 e7f64798 00072560 00074b6a 00000cf4 00000000
[1-163.0415] 2880: 1d03b480 af006840 fab01ac0 0940f080 f85d46bd 47707b04 41f0e92d f8d04606
[1-163.0416] 28a0: af008004 45a86885 4644bf18 6823d006 34304620 4798681b d1f842a5 8008f8c6
[1-163.0416] 28c0: 81f0e8bd 6842b480 6880af00 fab01a10 0940f080 f85d46bd 47707b04 6843b480
[1-163.0416] 28e0: 6083af00 f85d46bd 47707b04 6842b480 6880af00 fab01a10 0940f080 f85d46bd
[1-163.0416] 2900: 47707b04 2301b480 7303af00 f85d46bd 47707b04 4604b598 af006843 46186882
[1-163.0416] 2920: 689b681b b1084798 73232300 bf00bd98 4605b5f8 af004606 0f04f855 d00542a8
[1-163.0416] 2940: f7fb6804 4620eecc d1f942ac 60752300 60f360b5 bf00bdf8 4605b5f8 46064b08
[1-163.0416] 2960: 447baf00 60033308 0f04f855 d00542a8 f7fb6804 4620eeb4 d1f942ac bdf84630
[1-163.0416] 2980: 00072456 43f8e92d af004681 4f04f859 d012454c 4688460e f7fa200c 68a3ef5c
[1-163.0416] 29a0: 60834641 f7fa4605 68b3ef62 60b33301 8000f8d5 45a16824 e8bdd1ee bf0083f8
[1-163.0416] 29c0: 2104b598 af004604 ebfaf7fb bd984620 4605b5f8 46064b0a 447baf00 60033308
[1-163.0416] 29e0: 0f04f855 d00542a8 f7fb6804 4620ee78 d1f942ac 21144630 ebe2f7fb bdf84630
[1-163.0416] 2a00: 000723de 4604b598 4a0b4b0a 0120f100 6980447b 4288af00 f103589b 60230308
[1-163.0416] 2a20: f7fbd001 4620ee5c f7fb2130 4620ebca bf00bd98 000749b4 00000b50 4604b598
[1-163.0416] 2a40: 4a0f4b0e 013cf100 6b40447b 4288af00 f103589b 60230308 f7fbd001 6a61ee40
[1-163.0416] 2a60: 001cf104 f836f04b 1d2068e1 f848f04b 214c4620 eba4f7fb bd984620 0007497c
[1-163.0417] 2a80: 00000c00 4604b598 4a0f4b0e 013cf100 6b40447b 4288af00 f103589b 60230308
[1-163.0417] 2aa0: f7fbd001 6a61ee1c 001cf104 f812f04b 1d2068e1 f824f04b 214c4620 eb80f7fb
[1-163.0417] 2ac0: bd984620 00074934 00000c00 4604b598 4a0f4b0e 013cf100 6b40447b 4288af00
[1-163.0417] 2ae0: f103589b 60230308 f7fbd001 6a61edf8 001cf104 ffeef04a 1d2068e1 f800f04b
[1-163.0417] 2b00: 214c4620 eb5cf7fb bd984620 000748ec 00000c00 4604b598 4a0f4b0e 013cf100
[1-163.0417] 2b20: 6b40447b 4288af00 f103589b 60230308 f7fbd001 6a61edd4 001cf104 ffcaf04a
[1-163.0417] 2b40: 1d2068e1 ffdcf04a 214c4620 eb38f7fb bd984620 000748a4 00000c00 b083b590
[1-163.0417] 2b60: 693caf02 f7fa9400 3704efc6 bd9046bd f44fb580 4b047222 af004904 447b4804
[1-163.0417] 2b80: 44784479 edc8f7fb 0004dde2 0004e058 0004e082 47f0e92d 4b214606 4c21b084
[1-163.0417] 2ba0: af00447b f04f6900 4a1f0900 8004f853 9004f8c7 6803447a 4000f8d8 689c60fc
[1-163.0417] 2bc0: d1284294 0510f107 4608468a 9d08f845 f7fc4629 4604e896 46504629 0401f084
[1-163.0417] 2be0: 9008f8c7 eae0f7fb b2e06078 200cb150 ee30f7fa 6083687b f7fa1d31 68f3ee38
[1-163.0417] 2c00: 60f33301 f8d868fa 429a3000 3710d106 e8bd46bd 1d3a87f0 e7e747a0 eed2f7fb
[1-163.0417] 2c20: 00074824 00000b90 0003ed39 3458f8df 2458f8df e92d447b b0b943f0 af04589e
[1-163.0417] 2c40: f8c76833 f7fb30cc 2300ecea f7fb607b 4601e92c f1072200 f7fc0008 f7fbe84c
[1-163.0418] 2c60: 4604ec96 280068b8 81d3f000 ec74f7fc 1d3b4601 22004620 eab2f7fc f0002800
[1-163.0418] 2c80: efc08186 68b80010 0410f107 edc4613c 617c0b01 f0002800 214781bc ec9ef7fc
[1-163.0418] 2ca0: 695b6803 46034798 0824f107 801cf8c7 001cf107 0006e893 f047440a 2024f80f
[1-163.0418] 2cc0: 637b2300 edc6f7fa f10069fb 46050c10 c008f8c0 f0004543 6a7a818c 61026083
[1-163.0418] 2ce0: 46286a3b 46216b7a 230060eb 623b622a 3024f887 801cf8c7 edb8f7fa 69f869bb
[1-163.0418] 2d00: 61bb3301 d0014540 ece8f7fb 280068b8 817ff000 f7fc214d 6803ec62 4798695b
[1-163.0418] 2d20: f1074603 f8c70840 f1078038 e8930038 440a0006 ffd2f046 23002024 f7fa653b
[1-163.0418] 2d40: 6bbbed8a 0c10f100 f8c04605 4543c008 8157f000 60836c3a 6bfb6102 6d3a4628
[1-163.0418] 2d60: 60eb4621 622a2300 f88763fb f8c73040 f7fa8038 69bbed7c 33016bb8 454061bb
[1-163.0418] 2d80: f7fbd001 68b8ecac f0002800 214f8142 ec24f7fc 695b6803 46034798 085cf107
[1-163.0418] 2da0: 8054f8c7 0054f107 0006e893 f046440a 2024ff95 66fb2300 ed4cf7fa f1006d7b
[1-163.0418] 2dc0: 46050c10 c008f8c0 f0004543 6dfa80fa 61026083 46286dbb 46216efa 230060eb
[1-163.0418] 2de0: 65bb622a 305cf887 8054f8c7 ed3ef7fa 6d7869bb 61bb3301 d0014540 ec6ef7fb
[1-163.0418] 2e00: 280068b8 8105f000 f7fc214c 6803ebe8 4798695b f1074603 f8c70878 f1078070
[1-163.0418] 2e20: e8930070 440a0006 ff58f046 23002024 3088f8c7 ed0ef7fa f1006f3b 46050c10
[1-163.0419] 2e40: c008f8c0 f0004543 6fba80cc 61026083 46286f7b 2088f8d7 60eb4621 622a2300
[1-163.0419] 2e60: f887677b f8c73078 f7fa8070 69bbed00 33016f38 454061bb f7fbd001 68b8ec30
[1-163.0419] 2e80: f0002800 f7fb80c6 6803e8ee 4798695b f1074603 f8c70894 f107808c e893008c
[1-163.0419] 2ea0: 444d56000-44d57000 rw-p 00000000 00:00 0
[1-163.0451] 44d60000-44e7d000 r-xp 00000000 b3:12 15445      /usr/lib/libtv_player.so.0.0.0
[1-163.0451] 44e7d000-44e8d000 ---p 0011d000 b3:12 15445      /usr/lib/libtv_player.so.0.0.0
[1-163.0451] 44e8d000-44e8e000 r--p 0011d000 b3:12 15445      /usr/lib/libtv_player.so.0.0.0
[1-163.0451] 44e8e000-44e92000 rw-p 0011e000 b3:12 15445      /usr/lib/libtv_player.so.0.0.0
[1-163.0451] 44e92000-44e94000 rw-p 00000000 00:00 0
[1-163.0451] 44eb0000-44edb000 r-xp 00000000 b3:12 15462      /usr/lib/libnotification.so.0.5.45
[1-163.0451] 44edb000-44eea000 ---p 0002b000 b3:12 15462      /usr/lib/libnotification.so.0.5.45
[1-163.0451] 44eea000-44eeb000 r--p 0002a000 b3:12 15462      /usr/lib/libnotification.so.0.5.45
[1-163.0451] 44eeb000-44eec000 rw-p 0002b000 b3:12 15462      /usr/lib/libnotification.so.0.5.45
[1-163.0451] 44ef0000-44f6f000 r-xp 00000000 b3:12 13866      /usr/lib/libtvs-guide.so
[1-163.0451] 44f6f000-44f7f000 ---p 0007f000 b3:12 13866      /usr/lib/libtvs-guide.so
[1-163.0451] 44f7f000-44f81000 r--p 0007f000 b3:12 13866      /usr/lib/libtvs-guide.so
[1-163.0451] 44f81000-44f83000 rw-p 00081000 b3:12 13866      /usr/lib/libtvs-guide.so
[1-163.0451] 44f90000-44fac000 r-xp 00000000 b3:12 13546      /usr/lib/libtvs-ewbs.so
[1-163.0451] 44fac000-44fbb000 ---p 0001c000 b3:12 13546      /usr/lib/libtvs-ewbs.so
[1-163.0451] 44fbb000-44fbc000 r--p 0001b000 b3:12 13546      /usr/lib/libtvs-ewbs.so
[1-163.0451] 44fbc000-44fbd000 rw-p 0001c000 b3:12 13546      /usr/lib/libtvs-ewbs.so
[1-163.0452] 44fc0000-44fca000 r-xp 00000000 b3:12 11814      /usr/lib/libalarm.so.0.10.2
[1-163.0452] 44fca000-44fd9000 ---p 0000a000 b3:12 11814      /usr/lib/libalarm.so.0.10.2
[1-163.0452] 44fd9000-44fda000 r--p 00009000 b3:12 11814      /usr/lib/libalarm.so.0.10.2
[1-163.0452] 44fda000-44fdb000 rw-p 0000a000 b3:12 11814      /usr/lib/libalarm.so.0.10.2
[1-163.0452] 44fe0000-44fe2000 r-xp 00000000 b3:12 14789      /usr/lib/libappsvc.so.0.1.0
[1-163.0452] 44fe2000-44ff1000 ---p 00002000 b3:12 14789      /usr/lib/libappsvc.so.0.1.0
[1-163.0452] 44ff1000-44ff2000 r--p 00001000 b3:12 14789      /usr/lib/libappsvc.so.0.1.0
[1-163.0452] 44ff2000-44ff3000 rw-p 00002000 b3:12 14789      /usr/lib/libappsvc.so.0.1.0
[1-163.0452] 45000000-45049000 r-xp 00000000 b3:12 16420      /usr/lib/libtvs-udm.so
[1-163.0452] 45049000-45058000 ---p 00049000 b3:12 16420      /usr/lib/libtvs-udm.so
[1-163.0452] 45058000-45059000 r--p 00048000 b3:12 16420      /usr/lib/libtvs-udm.so
[1-163.0452] 45059000-4505b000 rw-p 00049000 b3:12 16420      /usr/lib/libtvs-udm.so
[1-163.0452] 45060000-45063000 r-xp 00000000 b3:12 15426      /usr/lib/libcapi-hbbtv-tv.so.0.1
[1-163.0452] 45063000-45072000 ---p 00003000 b3:12 15426      /usr/lib/libcapi-hbbtv-tv.so.0.1
[1-163.0452] 45072000-45073000 r--p 00002000 b3:12 15426      /usr/lib/libcapi-hbbtv-tv.so.0.1
[1-163.0452] 45073000-45074000 rw-p 00003000 b3:12 15426      /usr/lib/libcapi-hbbtv-tv.so.0.1
[1-163.0452] 45074000-45075000 rw-p 00000000 00:00 0
[1-163.0453] 45080000-45248000 r-xp 00000000 b3:12 16404      /usr/lib/libicui18n.so.63.2
[1-163.0453] 45248000-45257000 ---p 001c8000 b3:12 16404      /usr/lib/libicui18n.so.63.2
[1-163.0453] 45257000-4525f000 r--p 001c7000 b3:12 16404      /usr/lib/libicui18n.so.63.2
[1-163.0453] 4525f000-45261000 rw-p 001cf000 b3:12 16404      /usr/lib/libicui18n.so.63.2
[1-163.0453] 45270000-4539b000 r-xp 00000000 b3:12 11529      /usr/lib/libicuuc.so.63.2
[1-163.0453] 4539b000-453aa000 ---p 0012b000 b3:12 11529      /usr/lib/libicuuc.so.63.2
[1-163.0453] 453aa000-453b4000 r--p 0012a000 b3:12 11529      /usr/lib/libicuuc.so.63.2
[1-163.0453] 453b4000-453b5000 rw-p 00134000 b3:12 11529      /usr/lib/libicuuc.so.63.2
[1-163.0453] 453b5000-453b9000 rw-p 00000000 00:00 0
[1-163.0453] 453c0000-453d3000 r-xp 00000000 b3:12 13530      /usr/lib/libsec-video-drm-helper.so.0.1.0
[1-163.0453] 453d3000-453e2000 ---p 00013000 b3:12 13530      /usr/lib/libsec-video-drm-helper.so.0.1.0
[1-163.0453] 453e2000-453e3000 r--p 00012000 b3:12 13530      /usr/lib/libsec-video-drm-helper.so.0.1.0
[1-163.0453] 453e3000-453e4000 rw-p 00013000 b3:12 13530      /usr/lib/libsec-video-drm-helper.so.0.1.0
[1-163.0453] 453f0000-453f8000 r-xp 00000000 b3:12 15919      /usr/lib/libsec-audio.so.0.1
[1-163.0453] 453f8000-45407000 ---p 00008000 b3:12 15919      /usr/lib/libsec-audio.so.0.1
[1-163.0453] 45407000-45408000 r--p 00007000 b3:12 15919      /usr/lib/libsec-audio.so.0.1
[1-163.0453] 45408000-45409000 rw-p 00008000 b3:12 15919      /usr/lib/libsec-audio.so.0.1
[1-163.0454] 45410000-45429000 r-xp 00000000 b3:12 16948      /usr/lib/libv4lconvert.so.0.0.0
[1-163.0454] 45429000-45438000 ---p 00019000 b3:12 16948      /usr/lib/libv4lconvert.so.0.0.0
[1-163.0454] 45438000-4543a000 r--p 00018000 b3:12 16948      /usr/lib/libv4lconvert.so.0.0.0
[1-163.0454] 4543a000-4543b000 rw-p 0001a000 b3:12 16948      /usr/lib/libv4lconvert.so.0.0.0
[1-163.0454] 4543b000-4548d000 rw-p 00000000 00:00 0
[1-163.0454] 45490000-45492000 r-xp 00000000 b3:12 15315      /usr/lib/libeeprom-map.so.0.1
[1-163.0454] 45492000-454a1000 ---p 00002000 b3:12 15315      /usr/lib/libeeprom-map.so.0.1
[1-163.0454] 454a1000-454a2000 r--p 00001000 b3:12 15315      /usr/lib/libeeprom-map.so.0.1
[1-163.0454] 454a2000-454a3000 rw-p 00002000 b3:12 15315      /usr/lib/libeeprom-map.so.0.1
[1-163.0454] 454b0000-454ec000 r-xp 00000000 b3:12 16376      /usr/lib/libtvs-av.so
[1-163.0454] 454ec000-454fc000 ---p 0003c000 b3:12 16376      /usr/lib/libtvs-av.so
[1-163.0454] 454fc000-454fd000 rw-p 0003c000 b3:12 16376      /usr/lib/libtvs-av.so
[1-163.0454] 454fd000-454fe000 rw-p 00000000 00:00 0
[1-163.0454] 45500000-45509000 r-xp 00000000 b3:12 11708      /usr/lib/libfbproxyserver.so.0.1.2
[1-163.0454] 45509000-45519000 ---p 00009000 b3:12 11708      /usr/lib/libfbproxyserver.so.0.1.2
[1-163.0454] 45519000-4551a000 r--p 00009000 b3:12 11708      /usr/lib/libfbproxyserver.so.0.1.2
[1-163.0454] 4551a000-4551b000 rw-p 0000a000 b3:12 11708      /usr/lib/libfbproxyserver.so.0.1.2
[1-163.0454] 4551b000-4551c000 rw-p 00000000 00:00 0
[1-163.0455] 45520000-45535000 r-xp 00000000 b3:12 15196      /usr/lib/libcapi-system-system-settings.so.0.0.6
[1-163.0455] 45535000-45544000 ---p 00015000 b3:12 15196      /usr/lib/libcapi-system-system-settings.so.0.0.6
[1-163.0455] 45544000-45545000 r--p 00014000 b3:12 15196      /usr/lib/libcapi-system-system-settings.so.0.0.6
[1-163.0455] 45545000-45549000 rw-p 00015000 b3:12 15196      /usr/lib/libcapi-system-system-settings.so.0.0.6
[1-163.0455] 45550000-4556d000 r-xp 00000000 b3:12 12050      /usr/lib/libtvsystem.so.0.1
[1-163.0455] 4556d000-4557c000 ---p 0001d000 b3:12 12050      /usr/lib/libtvsystem.so.0.1
[1-163.0455] 4557c000-4557d000 r--p 0001c000 b3:12 12050      /usr/lib/libtvsystem.so.0.1
[1-163.0455] 4557d000-4557e000 rw-p 0001d000 b3:12 12050      /usr/lib/libtvsystem.so.0.1
[1-163.0455] 45580000-45587000 r-xp 00000000 b3:12 16092      /usr/lib/libv4l2.so.0.0.0
[1-163.0455] 45587000-45596000 ---p 00007000 b3:12 16092      /usr/lib/libv4l2.so.0.0.0
[1-163.0455] 45596000-45597000 r--p 00006000 b3:12 16092      /usr/lib/libv4l2.so.0.0.0
[1-163.0455] 45597000-4559b000 rw-p 00007000 b3:12 16092      /usr/lib/libv4l2.so.0.0.0
[1-163.0455] 455b0000-455c4000 r-xp 00000000 b3:12 16380      /usr/lib/libmmfile_utils.so.0.0.0
[1-163.0455] 455c4000-455d3000 ---p 00014000 b3:12 16380      /usr/lib/libmmfile_utils.so.0.0.0
[1-163.0455] 455d3000-455d4000 r--p 00013000 b3:12 16380      /usr/lib/libmmfile_utils.so.0.0.0
[1-163.0455] 455d4000-455d5000 rw-p 00014000 b3:12 16380      /usr/lib/libmmfile_utils.so.0.0.0
[1-163.0455] 455e0000-45613000 r-xp 00000000 b3:12 11784      /usr/lib/libtvs-nrt.so
[1-163.0456] 45613000-45622000 ---p 00033000 b3:12 11784      /usr/lib/libtvs-nrt.so
[1-163.0456] 45622000-45623000 r--p 00032000 b3:12 11784      /usr/lib/libtvs-nrt.so
[1-163.0456] 45623000-45625000 rw-p 00033000 b3:12 11784      /usr/lib/libtvs-nrt.so
[1-163.0456] 456300.so.0.5200.2
[2-171.5864] 431d0000-4321f000 r-xp 00000000 b3:12 13870      /usr/lib/libpcre.so.1.2.11
[2-171.5864] 4321f000-4322e000 ---p 0004f000 b3:12 13870      /usr/lib/libpcre.so.1.2.11
[2-171.5864] 4322e000-4322f000 r--p 0004e000 b3:12 13870      /usr/lib/libpcre.so.1.2.11
[2-171.5865] 4322f000-43230000 rw-p 0004f000 b3:12 13870      /usr/lib/libpcre.so.1.2.11
[2-171.5865] 43240000-43285000 r-xp 00000000 b3:12 11617      /usr/lib/libgobject-2.0.so.0.5200.2
[2-171.5865] 43285000-43294000 ---p 00045000 b3:12 11617      /usr/lib/libgobject-2.0.so.0.5200.2
[2-171.5865] 43294000-43295000 r--p 00044000 b3:12 11617      /usr/lib/libgobject-2.0.so.0.5200.2
[2-171.5865] 43295000-43296000 rw-p 00045000 b3:12 11617      /usr/lib/libgobject-2.0.so.0.5200.2
[2-171.5865] 432a0000-432b2000 r-xp 00000000 b3:12 16583      /usr/lib/libresolv-2.24.so
[2-171.5865] 432b2000-432c1000 ---p 00012000 b3:12 16583      /usr/lib/libresolv-2.24.so
[2-171.5865] 432c1000-432c2000 r--p 00011000 b3:12 16583      /usr/lib/libresolv-2.24.so
[2-171.5865] 432c2000-432c3000 rw-p 00012000 b3:12 16583      /usr/lib/libresolv-2.24.so
[2-171.5865] 432c3000-432c5000 rw-p 00000000 00:00 0
[2-171.5866] 432d0000-432df000 r-xp 00000000 b3:12 16219      /usr/lib/libz.so.1.2.11
[2-171.5866] 432df000-432ef000 ---p 0000f000 b3:12 16219      /usr/lib/libz.so.1.2.11
[2-171.5866] 432ef000-432f0000 r--p 0000f000 b3:12 16219      /usr/lib/libz.so.1.2.11
[2-171.5866] 432f0000-432f1000 rw-p 00010000 b3:12 16219      /usr/lib/libz.so.1.2.11
[2-171.5866] 43300000-4330c000 r-xp 00000000 b3:12 12033      /usr/lib/libbuxton2.so.1.1
[2-171.5866] 4330c000-4331b000 ---p 0000c000 b3:12 12033      /usr/lib/libbuxton2.so.1.1
[2-171.5866] 4331b000-4331c000 r--p 0000b000 b3:12 12033      /usr/lib/libbuxton2.so.1.1
[2-171.5866] 4331c000-4331d000 rw-p 0000c000 b3:12 12033      /usr/lib/libbuxton2.so.1.1
[2-171.5866] 43320000-43325000 r-xp 00000000 b3:12 15155      /usr/lib/libffi.so.6.0.2
[2-171.5867] 43325000-43334000 ---p 00005000 b3:12 15155      /usr/lib/libffi.so.6.0.2
[2-171.5867] 43334000-43335000 r--p 00004000 b3:12 15155      /usr/lib/libffi.so.6.0.2
[2-171.5867] 43335000-43336000 rw-p 00005000 b3:12 15155      /usr/lib/libffi.so.6.0.2
[2-171.5867] 43340000-43342000 r-xp 00000000 b3:12 16916      /usr/lib/libgmodule-2.0.so.0.5200.2
[2-171.5867] 43342000-43352000 ---p 00002000 b3:12 16916      /usr/lib/libgmodule-2.0.so.0.5200.2
[2-171.5867] 43352000-43353000 r--p 00002000 b3:12 16916      /usr/lib/libgmodule-2.0.so.0.5200.2
[2-171.5867] 43353000-43354000 rw-p 00003000 b3:12 16916      /usr/lib/libgmodule-2.0.so.0.5200.2
[2-171.5867] 43360000-43365000 r-xp 00000000 b3:12 12010      /usr/lib/libtzplatform-config-2.0.so.2.0.0
[2-171.5867] 43365000-43374000 ---p 00005000 b3:12 12010      /usr/lib/libtzplatform-config-2.0.so.2.0.0
[2-171.5867] 43374000-43375000 r--p 00004000 b3:12 12010      /usr/lib/libtzplatform-config-2.0.so.2.0.0
[2-171.5868] 43375000-43376000 rw-p 00005000 b3:12 12010      /usr/lib/libtzplatform-config-2.0.so.2.0.0
[2-171.5868] 43376000-4337b000 rw-p 00000000 00:00 0
[2-171.5868] 43380000-43386000 r-xp 00000000 b3:12 11608      /usr/lib/libvconf.so.0.3.1
[2-171.5868] 43386000-43395000 ---p 00006000 b3:12 11608      /usr/lib/libvconf.so.0.3.1
[2-171.5868] 43395000-43396000 r--p 00005000 b3:12 11608      /usr/lib/libvconf.so.0.3.1
[2-171.5868] 43396000-43397000 rw-p 00006000 b3:12 11608      /usr/lib/libvconf.so.0.3.1
[2-171.5868] 433a0000-433df000 r-xp 00000000 b3:12 11604      /usr/lib/libfactory-interface-DVB.so
[2-171.5868] 433df000-433ef000 ---p 0003f000 b3:12 11604      /usr/lib/libfactory-interface-DVB.so
[2-171.5868] 433ef000-433f1000 r--p 0003f000 b3:12 11604      /usr/lib/libfactory-interface-DVB.so
[2-171.5869] 433f1000-433f3000 rw-p 00041000 b3:12 11604      /usr/lib/libfactory-interface-DVB.so
[2-171.5869] 43400000-43401000 r-xp 00000000 b3:12 11304      /usr/lib/liblwipc.so
[2-171.5869] 43401000-43410000 ---p 00001000 b3:12 11304      /usr/lib/liblwipc.so
[2-171.5869] 43410000-43411000 r--p 00000000 b3:12 11304      /usr/lib/liblwipc.so
[2-171.5869] 43411000-43412000 rw-p 00001000 b3:12 11304      /usr/lib/liblwipc.so
[2-171.5869] 43420000-43425000 r-xp 00000000 b3:12 14730      /usr/lib/libopen-debugmenu_rel.so
[2-171.5869] 43425000-43434000 ---p 00005000 b3:12 14730      /usr/lib/libopen-debugmenu_rel.so
[2-171.5869] 43434000-43435000 r--p 00004000 b3:12 14730      /usr/lib/libopen-debugmenu_rel.so
[2-171.5869] 43435000-43436000 rw-p 00005000 b3:12 14730      /usr/lib/libopen-debugmenu_rel.so
[2-171.5869] 43440000-43459000 r-xp 00000000 b3:12 11655      /usr/lib/liblzma.so.5.2.4
[2-171.5870] 43459000-43468000 ---p 00019000 b3:12 11655      /usr/lib/liblzma.so.5.2.4
[2-171.5870] 43468000-43469000 r--p 00018000 b3:12 11655      /usr/lib/liblzma.so.5.2.4
[2-171.5870] 43469000-4346a000 rw-p 00019000 b3:12 11655      /usr/lib/liblzma.so.5.2.4
[2-171.5870] 43470000-43475000 r-xp 00000000 b3:12 15161      /usr/lib/libcapi-system-info.so.0.2.1
[2-171.5870] 43475000-43484000 ---p 00005000 b3:12 15161      /usr/lib/libcapi-system-info.so.0.2.1
[2-171.5870] 43484000-43485000 r--p 00004000 b3:12 15161      /usr/lib/libcapi-system-info.so.0.2.1
[2-171.5870] 43485000-43486000 rw-p 00005000 b3:12 15161      /usr/lib/libcapi-system-info.so.0.2.1
[2-171.5870] 43490000-43493000 r-xp 00000000 b3:12 11867      /usr/lib/libfconfig.so
[2-171.5870] 43493000-434a2000 ---p 00003000 b3:12 11867      /usr/lib/libfconfig.so
[2-171.5871] 434a2000-434a3000 r--p 00002000 b3:12 11867      /usr/lib/libfconfig.so
[2-171.5871] 434a3000-434a4000 rw-p 00003000 b3:12 11867      /usr/lib/libfconfig.so
[2-171.5871] 434b0000-43506000 r-xp 00000000 b3:12 11119      /usr/lib/libsystemd.so.0.16.0
[2-171.5871] 43506000-43515000 ---p 00056000 b3:12 11119      /usr/lib/libsystemd.so.0.16.0
[2-171.5871] 43515000-43517000 r--p 00055000 b3:12 11119      /usr/lib/libsystemd.so.0.16.0
[2-171.5871] 43517000-43518000 rw-p 00057000 b3:12 11119      /usr/lib/libsystemd.so.0.16.0
[2-171.5871] 43520000-4356d000 r-xp 00000000 b3:12 16685      /usr/lib/libdbus-1.so.3.14.6
[2-171.5871] 4356d000-4357c000 ---p 0004d000 b3:12 16685      /usr/lib/libdbus-1.so.3.14.6
[2-171.5871] 4357c000-4357d000 r--p 0004c000 b3:12 16685      /usr/lib/libdbus-1.so.3.14.6
[2-171.5871] 4357d000-4357e000 rw-p 0004d000 b3:12 16685      /usr/lib/libdbus-1.so.3.14.6
[2-171.5872] 43580000-435ba000 r-xp 00000000 b3:12 12421      /usr/lib/libmount.so.1.1.0
[2-171.5872] 435ba000-435ca000 ---p 0003a000 b3:12 12421      /usr/lib/libmount.so.1.1.0
[2-171.5872] 435ca000-435cb000 r--p 0003a000 b3:12 12421      /usr/lib/libmount.so.1.1.0
[2-171.5872] 435cb000-435cc000 rw-p 0003b000 b3:12 12421      /usr/lib/libmount.so.1.1.0
[2-171.5872] 435cc000-435cf000 rw-p 00000000 00:00 0
[2-171.5872] 435e0000-4360c000 r-xp 00000000 b3:12 15306      /usr/lib/libblkid.so.1.1.0
[2-171.5872] 4360c000-4361b000 ---p 0002c000 b3:12 15306      /usr/lib/libblkid.so.1.1.0
[2-171.5872] 4361b000-4361e000 r--p 0002b000 b3:12 15306      /usr/lib/libblkid.so.1.1.0
[2-171.5872] 4361e000-4361f000 rw-p 0002e000 b3:12 15306      /usr/lib/libblkid.so.1.1.0
[2-171.5872] 4361f000-43620000 rw-p 00000000 00:00 0
[2-171.5873] 43630000-43633000 r-xp 00000000 b3:12 12251      /usr/lib/libiniparser.so.0
[2-171.5873] 43633000-43642000 ---p 00003000 b3:12 12251      /usr/lib/libiniparser.so.0
[2-171.5873] 43642000-43643000 r--p 00002000 b3:12 12251      /usr/lib/libiniparser.so.0
[2-171.5873] 43643000-43644000 rw-p 00003000 b3:12 12251      /usr/lib/libiniparser.so.0
[2-171.5873] 43650000-43655000 r-xp 00000000 b3:12 16131      /usr/lib/libsmack.so.1.3.1
[2-171.5873] 43655000-43664000 ---p 00005000 b3:12 16131      /usr/lib/libsmack.so.1.3.1
[2-171.5873] 43664000-43665000 r--p 00004000 b3:12 16131      /usr/lib/libsmack.so.1.3.1
[2-171.5873] 43665000-43666000 rw-p 00005000 b3:12 16131      /usr/lib/libsmack.so.1.3.1
[2-171.5873] 43670000-43673000 r-xp 00000000 b3:12 14693      /usr/lib/libuuid.so.1.3.0
[2-171.5873] 43673000-43682000 ---p 00003000 b3:12 14693      /usr/l[2-171.5935] 45fe2000-45fe3000 rw-p 00002000 b3:12 11244      /usr/lib/libcapi-appfw-application.so.0.5.21
[2-171.5935] 45ff0000-45ff6000 r-xp 00000000 b3:12 12218      /usr/lib/libnative-logger.so.0.1.0
[2-171.5935] 45ff6000-46005000 ---p 00006000 b3:12 12218      /usr/lib/libnative-logger.so.0.1.0
[2-171.5935] 46005000-46006000 r--p 00005000 b3:12 12218      /usr/lib/libnative-logger.so.0.1.0
[2-171.5936] 46006000-46007000 rw-p 00006000 b3:12 12218      /usr/lib/libnative-logger.so.0.1.0
[2-171.5936] 46020000-4602c000 r-xp 00000000 b3:12 11641      /usr/lib/libapputil.so.0.1.0
[2-171.5936] 4602c000-4603b000 ---p 0000c000 b3:12 11641      /usr/lib/libapputil.so.0.1.0
[2-171.5936] 4603b000-4603c000 r--p 0000b000 b3:12 11641      /usr/lib/libapputil.so.0.1.0
[2-171.5936] 4603c000-4603d000 rw-p 0000c000 b3:12 11641      /usr/lib/libapputil.so.0.1.0
[2-171.5936] 46040000-46044000 r-xp 00000000 b3:12 16936      /usr/lib/libautoinput.so.0.0.54
[2-171.5936] 46044000-46053000 ---p 00004000 b3:12 16936      /usr/lib/libautoinput.so.0.0.54
[2-171.5936] 46053000-46054000 r--p 00003000 b3:12 16936      /usr/lib/libautoinput.so.0.0.54
[2-171.5936] 46054000-46055000 rw-p 00004000 b3:12 16936      /usr/lib/libautoinput.so.0.0.54
[2-171.5936] 46060000-46062000 r-xp 00000000 b3:12 15331      /usr/lib/libbptime.so
[2-171.5937] 46062000-46071000 ---p 00002000 b3:12 15331      /usr/lib/libbptime.so
[2-171.5937] 46071000-46072000 r--p 00001000 b3:12 15331      /usr/lib/libbptime.so
[2-171.5937] 46072000-46073000 rw-p 00002000 b3:12 15331      /usr/lib/libbptime.so
[2-171.5937] 46080000-4608d000 r-xp 00000000 b3:12 14763      /usr/lib/libvd-win-util.so.0.0.218
[2-171.5937] 4608d000-4609c000 ---p 0000d000 b3:12 14763      /usr/lib/libvd-win-util.so.0.0.218
[2-171.5937] 4609c000-4609d000 r--p 0000c000 b3:12 14763      /usr/lib/libvd-win-util.so.0.0.218
[2-171.5937] 4609d000-4609e000 rw-p 0000d000 b3:12 14763      /usr/lib/libvd-win-util.so.0.0.218
[2-171.5937] 460a0000-461fc000 r-xp 00000000 b3:12 16957      /usr/lib/libcrypto.so.1.1
[2-171.5937] 461fc000-4620b000 ---p 0015c000 b3:12 16957      /usr/lib/libcrypto.so.1.1
[2-171.5938] 4620b000-46221000 r--p 0015b000 b3:12 16957      /usr/lib/libcrypto.so.1.1
[2-171.5938] 46221000-46223000 rw-p 00171000 b3:12 16957      /usr/lib/libcrypto.so.1.1
[2-171.5938] 46223000-46226000 rw-p 00000000 00:00 0
[2-171.5938] 46230000-46233000 r-xp 00000000 b3:12 11190      /usr/lib/libcapi-appfw-app-operation-tv.so.0.1.0
[2-171.5938] 46233000-46242000 ---p 00003000 b3:12 11190      /usr/lib/libcapi-appfw-app-operation-tv.so.0.1.0
[2-171.5938] 46242000-46243000 r--p 00002000 b3:12 11190      /usr/lib/libcapi-appfw-app-operation-tv.so.0.1.0
[2-171.5938] 46243000-46244000 rw-p 00003000 b3:12 11190      /usr/lib/libcapi-appfw-app-operation-tv.so.0.1.0
[2-171.5938] 46250000-46287000 r-xp 00000000 b3:12 16514      /usr/lib/libgtest_gmock.so.1.7.0
[2-171.5938] 46287000-46296000 ---p 00037000 b3:12 16514      /usr/lib/libgtest_gmock.so.1.7.0
[2-171.5939] 46296000-46297000 r--p 00036000 b3:12 16514      /usr/lib/libgtest_gmock.so.1.7.0
[2-171.5939] 46297000-46298000 rw-p 00037000 b3:12 16514      /usr/lib/libgtest_gmock.so.1.7.0
[2-171.5939] 46298000-46299000 rw-p 00000000 00:00 0
[2-171.5939] 462a0000-462b9000 r-xp 00000000 b3:12 12099      /usr/lib/libsource-api.so
[2-171.5939] 462b9000-462c8000 ---p 00019000 b3:12 12099      /usr/lib/libsource-api.so
[2-171.5939] 462c8000-462c9000 r--p 00018000 b3:12 12099      /usr/lib/libsource-api.so
[2-171.5939] 462c9000-462ca000 rw-p 00019000 b3:12 12099      /usr/lib/libsource-api.so
[2-171.5939] 462d0000-462d2000 r-xp 00000000 b3:12 12058      /usr/lib/libscreencontroller.so.0.0.218
[2-171.5939] 462d2000-462e1000 ---p 00002000 b3:12 12058      /usr/lib/libscreencontroller.so.0.0.218
[2-171.5939] 462e1000-462e2000 r--p 00001000 b3:12 12058      /usr/lib/libscreencontroller.so.0.0.218
[2-171.5940] 462e2000-462e3000 rw-p 00002000 b3:12 12058      /usr/lib/libscreencontroller.so.0.0.218
[2-171.5940] 462f0000-462f3000 r-xp 00000000 b3:12 17102      /usr/lib/libwind.so.0.0.218
[2-171.5940] 462f3000-46302000 ---p 00003000 b3:12 17102      /usr/lib/libwind.so.0.0.218
[2-171.5940] 46302000-46303000 r--p 00002000 b3:12 17102      /usr/lib/libwind.so.0.0.218
[2-171.5940] 46303000-46304000 rw-p 00003000 b3:12 17102      /usr/lib/libwind.so.0.0.218
[2-171.5940] 46310000-4633e000 r-xp 00000000 b3:12 12234      /usr/lib/libopencv_objdetect.so.3.4.1
[2-171.5940] 4633e000-4634e000 ---p 0002e000 b3:12 12234      /usr/lib/libopencv_objdetect.so.3.4.1
[2-171.5940] 4634e000-4634f000 r--p 0002e000 b3:12 12234      /usr/lib/libopencv_objdetect.so.3.4.1
[2-171.5940] 4634f000-46350000 rw-p 0002f000 b3:12 12234      /usr/lib/libopencv_objdetect.so.3.4.1
[2-171.5941] 46360000-4639f000 r-xp 00000000 b3:12 11808      /usr/lib/libteec.so
[2-171.5941] 4639f000-463af000 ---p 0003f000 b3:12 11808      /usr/lib/libteec.so
[2-171.5941] 463af000-463b0000 rw-p 0003f000 b3:12 11808      /usr/lib/libteec.so
[2-171.5941] 463c0000-463fc000 r-xp 00000000 b3:12 11502      /usr/lib/libcryptocore.so.0.1.0
[2-171.5941] 463fc000-4640b000 ---p 0003c000 b3:12 11502      /usr/lib/libcryptocore.so.0.1.0
[2-171.5941] 4640b000-4640c000 r--p 0003b000 b3:12 11502      /usr/lib/libcryptocore.so.0.1.0
[2-171.5941] 4640c000-4640e000 rw-p 0003c000 b3:12 11502      /usr/lib/libcryptocore.so.0.1.0
[2-171.5941] 46410000-46432000 r-xp 00000000 b3:12 13462      /usr/lib/libwas_db_api.so
[2-171.5941] 46432000-46441000 ---p 00022000 b3:12 13462      /usr/lib/libwas_db_api.so
[2-171.5941] 46441000-46442000 r--p 00021000 b3:12 13462      /usr/lib/libwas_db_api.so
[2-171.5942] 46442000-46443000 rw-p 00022000 b3:12 13462      /usr/lib/libwas_db_api.so
[2-171.5942] 46450000-46469000 r-xp 00000000 b3:12 14857      /usr/lib/libcoreapp-fw.so.0.1.0
[2-171.5942] 46469000-46478000 ---p 00019000 b3:12 14857      /usr/lib/libcoreapp-fw.so.0.1.0
[2-171.5942] 46478000-46479000 r--p 00018000 b3:12 14857      /usr/lib/libcoreapp-fw.so.0.1.0
[2-171.5942] 46479000-4647a000 rw-p 00019000 b3:12 14857      /usr/lib/libcoreapp-fw.so.0.1.0
[2-171.5942] 46480000-46482000 r-xp 00000000 b3:12 11409      /usr/lib/libambient-linker.so.0.0.218
[2-171.5942] 46482000-46491000 ---p 00002000 b3:12 11409      /usr/lib/libambient-linker.so.0.0.218
[2-171.5942] 46491000-46492000 r--p 00001000 b3:12 11409      /usr/lib/libambient-linker.so.0.0.218
[2-171.5942] 46492000-46493000 rw-p 00002000 b3:12 11409      /usr/lib/libambient-linker.so.0.0.218
[2-171.5943] 464a0000-464a2000 r-xp 00000000 b3:12 16938      /usr/lib/libaul-ex.so.0.1.0
[2-171.5943] 464a2000-464b1000 ---p 00002000 b3:12 16938      /usr/lib/libaul-ex.so.0.1.0
[2-171.5943] 464b1000-464b2000 r--p 00001000 b3:12 16938      /usr/lib/libaul-ex.so.0.1.0
[2-171.5943] 464b2000-464b3000 rw-p 00002000 b3:12 16938      /usr/lib/libaul-ex.so.0.1.0
[2-171.5943] 464c0000-464c4000 r-xp 00000000 b3:12 11161      /usr/lib/libcynara-creds-commons.so.0.14.24
[2-171.5943] 464c4000-464d3000 ---p 00004000 b3:12 11161      /usr/lib/libcynara-creds-commons.so.0.14.24
[2-171.5943] 464d3000-464d4000 r--p 00003000 b3:12 11161      /usr/lib/libcynara-creds-commons.so.0.14.24
[2-171.5943] 464d4000-464d5000 rw-p 00004000 b3:12 11161      /usr/lib/libcynara-creds-commons.so.0.14.24
[2-171.5943] 464e0000-464e9000 r-xp 00000000 b3:12 16917      /usr/lib/libemanual.so
[2-171.5943] 464e9000-464f8000 ---p 00009000 b3:12 16917      /usr/lib/libemanual.so
[2-171.5944] 464f8000-464f9000 r--p 00008000 b3:12 16917      /usr/lib/libemanual.so
[2-171.5944] 464f9000-464fa000 rw-p 00009000 b3:12 16917      /usr/lib/libemanual.so
[2-171.5944] 46500000-46502000 r-xp 00000000 b3:12 16874      /usr/lib/libcynara-creds-socket.so.0.14.24
[2-171.5944] 46502000-46511000 ---p 00002000 b3:12 16874      /usr/lib/libcynara-creds-socket.so.0.14.24
[2-171.5944] 46511000-46512000 r--p 00001000 b3:12 16874      /usr/lib/libcynara-creds-socket.so.0.14.24
[2-171.5944] 46512000-46513000 rw-p 00002000 b3:12 16874      /usr/lib/libcynara-creds-socket.so.0.14.24
[2-171.5944] 46520000-46528000 r-xp 000000000 00:00 0
[2-171.6003] b2bdc000-b2ddb000 rwxp 00000000 00:00 0          [tstack: mali-cmar-backe: 906]
[2-171.6003] b2ddb000-b2ddc000 ---p 00000000 00:00 0
[2-171.6003] b2ddc000-b2fdb000 rwxp 00000000 00:00 0          [tstack: mali-utility-wo: 905]
[2-171.6004] b2fdb000-b2fdc000 ---p 00000000 00:00 0
[2-171.6004] b2fdc000-b31db000 rwxp 00000000 00:00 0          [tstack: mali-utility-wo: 904]
[2-171.6004] b31db000-b31dc000 ---p 00000000 00:00 0
[2-171.6004] b31dc000-b33db000 rwxp 00000000 00:00 0          [tstack: mali-utility-wo: 903]
[2-171.6004] b33db000-b33dc000 ---p 00000000 00:00 0
[2-171.6004] b33dc000-b35db000 rwxp 00000000 00:00 0          [tstack: mali-utility-wo: 902]
[2-171.6004] b35db000-b35dc000 ---p 00000000 00:00 0
[2-171.6004] b35dc000-b37db000 rwxp 00000000 00:00 0          [tstack: mali-mem-purge: 901]
[2-171.6004] b37db000-b382a000 rw-p 00000000 00:00 0
[2-171.6004] b382a000-b382b000 ---p 00000000 00:00 0
[2-171.6005] b382b000-b3a2a000 rwxp 00000000 00:00 0          [tstack: tv-viewer: 898]
[2-171.6005] b3a2a000-b47a7000 r-xp 00000000 b3:12 15909      /usr/lib/driver/libmali.so
[2-171.6005] b47a7000-b47b7000 ---p 00d7d000 b3:12 15909      /usr/lib/driver/libmali.so
[2-171.6005] b47b7000-b480f000 rw-p 00d7d000 b3:12 15909      /usr/lib/driver/libmali.so
[2-171.6005] b480f000-b4828000 rw-p 00000000 00:00 0
[2-171.6005] b4828000-b4829000 ---p 00000000 00:00 0
[2-171.6005] b4829000-b4a28000 rwxp 00000000 00:00 0          [tstack: Evas-sw-thread-: 870]
[2-171.6005] b4a28000-b4a29000 ---p 00000000 00:00 0
[2-171.6005] b4a29000-b4c28000 rwxp 00000000 00:00 0          [tstack: Evas-gl-thread-: 869]
[2-171.6005] b4c28000-b4cec000 r-xp 00000000 b3:12 16593      /usr/lib/evas/modules/engines/gl_generic/v-1.23/module.so
[2-171.6006] b4cec000-b4cfb000 ---p 000c4000 b3:12 16593      /usr/lib/evas/modules/engines/gl_generic/v-1.23/module.so
[2-171.6006] b4cfb000-b4cfc000 r--p 000c3000 b3:12 16593      /usr/lib/evas/modules/engines/gl_generic/v-1.23/module.so
[2-171.6006] b4cfc000-b4cfd000 rw-p 000c4000 b3:12 16593      /usr/lib/evas/modules/engines/gl_generic/v-1.23/module.so
[2-171.6006] b4cfd000-b4d00000 rw-p 00000000 00:00 0
[2-171.6006] b4d00000-b4d21000 rw-p 00000000 00:00 0
[2-171.6006] b4d21000-b4e00000 ---p 00000000 00:00 0
[2-171.6006] b4e01000-b4e03000 r--s 00000000 b3:18 18967      /common/usr/ug/ug-hostug-efl/res/edje/ug-hostug-efl.edj
[2-171.6006] b4e03000-b4e05000 r-xp 00000000 b3:12 13494      /usr/lib/libvideo-mm-control.so.0.1.0
[2-171.6006] b4e05000-b4e14000 ---p 00002000 b3:12 13494      /usr/lib/libvideo-mm-control.so.0.1.0
[2-171.6007] b4e14000-b4e15000 r--p 00001000 b3:12 13494      /usr/lib/libvideo-mm-control.so.0.1.0
[2-171.6007] b4e15000-b4e16000 rw-p 00002000 b3:12 13494      /usr/lib/libvideo-mm-control.so.0.1.0
[2-171.6007] b4e16000-b4e31000 rw-p 00000000 00:00 0
[2-171.6007] b4e32000-b4e35000 r-xp 00000000 b3:12 13660      /usr/lib/libdrm-util.so.0.1.0
[2-171.6007] b4e35000-b4e44000 ---p 00003000 b3:12 13660      /usr/lib/libdrm-util.so.0.1.0
[2-171.6007] b4e44000-b4e45000 rw-p 00002000 b3:12 13660      /usr/lib/libdrm-util.so.0.1.0
[2-171.6007] b4e45000-b4e4c000 r--s 00000000 b3:12 14683      /usr/lib/gconv/gconv-modules.cache
[2-171.6007] b4e4c000-b4e4e000 r--p 00000000 b3:12 5103       /usr/share/locale/de/LC_MESSAGES/efl.mo
[2-171.6007] b4e4e000-b4e4f000 r-xp 00000000 b3:12 15503      /usr/lib/libtizen-surface-client.so.0.0.0
[2-171.6008] b4e4f000-b4e5e000 ---p 00001000 b3:12 15503      /usr/lib/libtizen-surface-client.so.0.0.0
[2-171.6008] b4e5e000-b4e5f000 r--p 00000000 b3:12 15503      /usr/lib/libtizen-surface-client.so.0.0.0
[2-171.6008] b4e5f000-b4e60000 rw-p 00001000 b3:12 15503      /usr/lib/libtizen-surface-client.so.0.0.0
[2-171.6008] b4e60000-b4e8b000 r-xp 00000000 b3:12 11369      /usr/lib/libtpl-egl.so.1.6.9
[2-171.6008] b4e8b000-b4e9a000 ---p 0002b000 b3:12 11369      /usr/lib/libtpl-egl.so.1.6.9
[2-171.6008] b4e9a000-b4e9b000 r--p 0002a000 b3:12 11369      /usr/lib/libtpl-egl.so.1.6.9
[2-171.6008] b4e9b000-b4e9c000 rw-p 0002b000 b3:12 11369      /usr/lib/libtpl-egl.so.1.6.9
[2-171.6008] b4e9d000-b4ea0000 r--s 00000000 b3:18 16878      /common/usr/ug/ug-info-sm-more/res/edje/ug-info-sm-more.edj
[2-171.6008] b4ea0000-b4ea1000 rw-s b4ea0000 00:06 2091       /dev/mali0
[2-171.6009] b4ea1000-b4ea3000 r--p 00000000 b3:12 6058       /usr/share/locale/en_US/LC_MESSAGES/efl.mo
[2-171.6009] b4ea3000-b4ea9000 r--s 00000000 b3:15 9918       /opt/usr/home/owner/.cache/evas_gl_common_caches/ARM::OpenGL ES 3.2 r11p0-01rel0.git_rev_unknown.git_date_unknown::Mali-G51::v-1.23.99::binary_shader.eet
[2-171.6009] b4ea9000-b4eaa000 r--p 00000000 b3:12 3427       /usr/share/apputil/res/locale/de_DE/LC_MESSAGES/apputil.mo
[2-171.6009] b4eaa000-b4eb0000 r-xp 00000000 b3:12 16787      /usr/lib/bufmgr/libtbm_kants.so.0.0.0
[2-171.6009] b4eb0000-b4ebf000 ---p 00006000 b3:12 16787      /usr/lib/bufmgr/libtbm_kants.so.0.0.0
[2-171.6009] b4ebf000-b4ec0000 r--p 00005000 b3:12 16787      /usr/lib/bufmgr/libtbm_kants.so.0.0.0
[2-171.6009] b4ec0000-b4ec1000 rw-p 00006000 b3:12 16787      /usr/lib/bufmgr/libtbm_kants.so.0.0.0
[2-171.6009] b4ec1000-b4ec9000 r-xp 00000000 b3:12 16602      /usr/lib/evas/modules/engines/wayland_egl/v-1.23/module.so
[2-171.6010] b4ec9000-b4ed8000 ---p 00008000 b3:12 16602      /usr/lib/evas/modules/engines/wayland_egl/v-1.23/module.so
[2-171.6010] b4ed8000-b4ed9000 r--p 00007000 b3:12 16602      /usr/lib/evas/modules/engines/wayland_egl/v-1.23/module.so
[2-171.6010] b4ed9000-b4eda000 rw-p 00008000 b3:12 16602      /usr/lib/evas/modules/engines/wayland_egl/v-1.23/module.so
[2-171.6010] b4eda000-b4ee3000 r-xp 00000000 b3:12 15383      /usr/lib/ecore_evas/engines/wayland/v-1.23/module.so
[2-171.6010] b4ee3000-b4ef2000 ---p 00009000 b3:12 15383      /usr/lib/ecore_evas/engines/wayland/v-1.23/module.so
[2-171.6010] b4ef2000-b4ef3000 r--p 00008000 b3:12 15383      /usr/lib/ecore_evas/engines/wayland/v-1.23/module.so
[2-171.6010] b4ef3000-b4ef4000 rw-p 00009000 b3:12 15383      /usr/lib/ecore_evas/engines/wayland/v-1.23/module.so
[2-171.6010] b4ef4000-b4efb000 r--s 00000000 b3:18 10899      /common/usr/apps/com.samsung.tv.theme-resource/shared/res/org.tizen.tv-viewer/edje/tv-viewer-theme.edj
[2-171.6010] b4efb000-b4efc000 ---p 00000000 00:00 0
[2-171.6011] b4efc000-b50fb000 rwxp 00000000 00:00 0          [tstack: aul+: 846]
[2-171.6011] b50fb000-b50fe000 r-xp 00000000 b3:12 16569      /usr/lib/elementary/modules/web/none/v-1.23/module.so
[2-171.6011] b50fe000-b510d000 ---p 00003000 b3:12 16569      /usr/lib/elementary/modules/web/none/v-1.23/module.so
[2-171.6011] b510d000-b510e000 r--p 00002000 b3:12 16569      /usr/lib/elementary/modules/web/none/v-1.23/module.so
[2-171.6011] b510e000-b510f000 rw-p 00003000 b3:12 16569      /usr/lib/elementary/modules/web/none/v-1.23/module.so
[2-171.6011] b510f000-b511c000 r-xp 00000000 b3:12 16391      /usr/lib/ecore_imf/modules/wayland/v-1.23/module.so
[2-171.6011] b511c000-b512c000 ---p 0000d000 b3:12 16391      /usr/lib/ecore_imf/modules/wayland/v-1.23/module.so
[2-171.6011] b512c000-b512d000 r--p 0000d000 b3:12 16391      /usr/lib/ecore_imf/modules/wayland/v-1.23/module.so
[2-171.6012] b512d000-b512e000 rw-p 0000e000 b3:12 16391      /usr/lib/ecore_imf/modules/wayland/v-1.23/module.so
[2-171.6012] b512e000-b5143000 r-xp 00000000 b3:12 11385      /usr/lib/edje/modules/elm/v-1.23/module.so
[2-171.6012] b5143000-b5153000 ---p 00015000 b3:12 11385      /usr/lib/edje/modules/elm/v-1.23/module.so
[2-171.6012] b5153000-b5154000 r--p 00015000 b3:12 11385      /usr/lib/edje/modules/elm/v-1.23/module.so
[2-171.6012] b5154000-b5158000 rw-p 00016000 b3:12 11385      /usr/lib/edje/modules/elm/v-1.23/module.so
[2-171.6012] b5158000-b5b0e000 r--s 00000000 b3:12 6758       /usr/share/elementary/themes/default.edj
[2-171.6012] b5b0e000-b5ec8000 r--s 00000000 b3:12 6757       /usr/share/elementary/themes/vd-efl-theme-tizen.edj
[2-ib/libstdc++.so.6.0.22
[0-187.8645] 42d48000-42d4b000 rw-p 000f8000 b3:12 16580      /usr/lib/libstdc++.so.6.0.22
[0-187.8645] 42d4b000-42d4d000 rw-p 00000000 00:00 0
[0-187.8645] 42d50000-42dc2000 r-xp 00000000 b3:12 10909      /usr/lib/libm-2.24.so
[0-187.8645] 42dc2000-42dd1000 ---p 00072000 b3:12 10909      /usr/lib/libm-2.24.so
[0-187.8645] 42dd1000-42dd2000 r--p 00071000 b3:12 10909      /usr/lib/libm-2.24.so
[0-187.8645] 42dd2000-42dd3000 rw-p 00072000 b3:12 10909      /usr/lib/libm-2.24.so
[0-187.8645] 42de0000-42ded000 r-xp 00000000 b3:12 16172      /usr/lib/libcapi-base-common.so.0.4.54
[0-187.8645] 42ded000-42dfd000 ---p 0000d000 b3:12 16172      /usr/lib/libcapi-base-common.so.0.4.54
[0-187.8645] 42dfd000-42dff000 r--p 0000d000 b3:12 16172      /usr/lib/libcapi-base-common.so.0.4.54
[0-187.8645] 42dff000-42e00000 rw-p 0000f000 b3:12 16172      /usr/lib/libcapi-base-common.so.0.4.54
[0-187.8645] 42e10000-42e13000 r-xp 00000000 b3:12 11408      /usr/lib/libdlog.so.0.0.0
[0-187.8645] 42e13000-42e22000 ---p 00003000 b3:12 11408      /usr/lib/libdlog.so.0.0.0
[0-187.8645] 42e22000-42e23000 r--p 00002000 b3:12 11408      /usr/lib/libdlog.so.0.0.0
[0-187.8645] 42e23000-42e24000 rw-p 00003000 b3:12 11408      /usr/lib/libdlog.so.0.0.0
[0-187.8645] 42e30000-42e5b000 r-xp 00000000 b3:12 13572      /usr/lib/libcynara-commons.so.0.14.24
[0-187.8645] 42e5b000-42e6a000 ---p 0002b000 b3:12 13572      /usr/lib/libcynara-commons.so.0.14.24
[0-187.8646] 42e6a000-42e6c000 r--p 0002a000 b3:12 13572      /usr/lib/libcynara-commons.so.0.14.24
[0-187.8646] 42e6c000-42e6d000 rw-p 0002c000 b3:12 13572      /usr/lib/libcynara-commons.so.0.14.24
[0-187.8646] 42e70000-42e85000 r-xp 00000000 b3:12 16133      /usr/lib/libdbuspolicy1.so.1.1.0
[0-187.8646] 42e85000-42e94000 ---p 00015000 b3:12 16133      /usr/lib/libdbuspolicy1.so.1.1.0
[0-187.8646] 42e94000-42e95000 r--p 00014000 b3:12 16133      /usr/lib/libdbuspolicy1.so.1.1.0
[0-187.8646] 42e95000-42e96000 rw-p 00015000 b3:12 16133      /usr/lib/libdbuspolicy1.so.1.1.0
[0-187.8646] 42ea0000-42eb6000 r-xp 00000000 b3:12 16277      /usr/lib/libexpat.so.1.6.9
[0-187.8646] 42eb6000-42ec5000 ---p 00016000 b3:12 16277      /usr/lib/libexpat.so.1.6.9
[0-187.8646] 42ec5000-42ec7000 r--p 00015000 b3:12 16277      /usr/lib/libexpat.so.1.6.9
[0-187.8646] 42ec7000-42ec8000 rw-p 00017000 b3:12 16277      /usr/lib/libexpat.so.1.6.9
[0-187.8646] 42ed0000-42ed6000 r-xp 00000000 b3:12 13472      /usr/lib/libcynara-client-commons.so.0.14.24
[0-187.8646] 42ed6000-42ee5000 ---p 00006000 b3:12 13472      /usr/lib/libcynara-client-commons.so.0.14.24
[0-187.8646] 42ee5000-42ee6000 r--p 00005000 b3:12 13472      /usr/lib/libcynara-client-commons.so.0.14.24
[0-187.8646] 42ee6000-42ee7000 rw-p 00006000 b3:12 13472      /usr/lib/libcynara-client-commons.so.0.14.24
[0-187.8646] 42ef0000-42ef8000 r-xp 00000000 b3:12 16785      /usr/lib/libcynara-client.so.0.14.24
[0-187.8646] 42ef8000-42f07000 ---p 00008000 b3:12 16785      /usr/lib/libcynara-client.so.0.14.24
[0-187.8646] 42f07000-42f08000 r--p 00007000 b3:12 16785      /usr/lib/libcynara-client.so.0.14.24
[0-187.8647] 42f08000-42f09000 rw-p 00008000 b3:12 16785      /usr/lib/libcynara-client.so.0.14.24
[0-187.8647] 42f10000-42f12000 r-xp 00000000 b3:12 15437      /usr/lib/libcynara-session.so.0.14.24
[0-187.8647] 42f12000-42f21000 ---p 00002000 b3:12 15437      /usr/lib/libcynara-session.so.0.14.24
[0-187.8647] 42f21000-42f22000 r--p 00001000 b3:12 15437      /usr/lib/libcynara-session.so.0.14.24
[0-187.8647] 42f22000-42f23000 rw-p 00002000 b3:12 15437      /usr/lib/libcynara-session.so.0.14.24
[0-187.8647] 42f30000-42f36000 r-xp 00000000 b3:12 11480      /usr/lib/librt-2.24.so
[0-187.8647] 42f36000-42f45000 ---p 00006000 b3:12 11480      /usr/lib/librt-2.24.so
[0-187.8647] 42f45000-42f46000 r--p 00005000 b3:12 11480      /usr/lib/librt-2.24.so
[0-187.8647] 42f46000-42f47000 rw-p 00006000 b3:12 11480      /usr/lib/librt-2.24.so
[0-187.8647] 42f50000-430a0000 r-xp 00000000 b3:12 11138      /usr/lib/libgio-2.0.so.0.5200.2
[0-187.8647] 430a0000-430b0000 ---p 00150000 b3:12 11138      /usr/lib/libgio-2.0.so.0.5200.2
[0-187.8647] 430b0000-430b2000 r--p 00150000 b3:12 11138      /usr/lib/libgio-2.0.so.0.5200.2
[0-187.8647] 430b2000-430b4000 rw-p 00152000 b3:12 11138      /usr/lib/libgio-2.0.so.0.5200.2
[0-187.8647] 430b4000-430b5000 rw-p 00000000 00:00 0
[0-187.8647] 430c0000-431b7000 r-xp 00000000 b3:12 15321      /usr/lib/libglib-2.0.so.0.5200.2
[0-187.8647] 431b7000-431c6000 ---p 000f7000 b3:12 15321      /usr/lib/libglib-2.0.so.0.5200.2
[0-187.8647] 431c6000-431c7000 r--p 000f6000 b3:12 15321      /usr/lib/libglib-2.0.so.0.5200.2
[0-187.8648] 431c7000-431c8000 rw-p 000f7000 b3:12 15321      /usr/lib/libglib-2.0.so.0.5200.2
[0-187.8648] 431d0000-4321f000 r-xp 00000000 b3:12 13870      /usr/lib/libpcre.so.1.2.11
[0-187.8648] 4321f000-4322e000 ---p 0004f000 b3:12 13870      /usr/lib/libpcre.so.1.2.11
[0-187.8648] 4322e000-4322f000 r--p 0004e000 b3:12 13870      /usr/lib/libpcre.so.1.2.11
[0-187.8648] 4322f000-43230000 rw-p 0004f000 b3:12 13870      /usr/lib/libpcre.so.1.2.11
[0-187.8648] 43240000-43285000 r-xp 00000000 b3:12 11617      /usr/lib/libgobject-2.0.so.0.5200.2
[0-187.8648] 43285000-43294000 ---p 00045000 b3:12 11617      /usr/lib/libgobject-2.0.so.0.5200.2
[0-187.8648] 43294000-43295000 r--p 00044000 b3:12 11617      /usr/lib/libgobject-2.0.so.0.5200.2
[0-187.8648] 43295000-43296000 rw-p 00045000 b3:12 11617      /usr/lib/libgobject-2.0.so.0.5200.2
[0-187.8648] 432a0000-432b2000 r-xp 00000000 b3:12 16583      /usr/lib/libresolv-2.24.so
[0-187.8648] 432b2000-432c1000 ---p 00012000 b3:12 16583      /usr/lib/libresolv-2.24.so
[0-187.8648] 432c1000-432c2000 r--p 00011000 b3:12 16583      /usr/lib/libresolv-2.24.so
[0-187.8648] 432c2000-432c3000 rw-p 00012000 b3:12 16583      /usr/lib/libresolv-2.24.so
[0-187.8648] 432c3000-432c5000 rw-p 00000000 00:00 0
[0-187.8648] 432d0000-432df000 r-xp 00000000 b3:12 16219      /usr/lib/libz.so.1.2.11
[0-187.8648] 432df000-432ef000 ---p 0000f000 b3:12 16219      /usr/lib/libz.so.1.2.11
[0-187.8648] 432ef000-432f0000 r--p 0000f000 b3:12 16219      /usr/lib/libz.so.1.2.11
[0-187.8649] 432f0000-432f1000 rw-p 00010000 b3:12 16219      /usr/lib/libz.so.1.2.11
[0-187.8649] 43300000-4330c000 r-xp 00000000 b3:12 12033      /usr/lib/libbuxton2.so.1.1
[0-187.8649] 4330c000-4331b000 ---p 0000c000 b3:12 12033      /usr/lib/libbuxton2.so.1.1
[0-187.8649] 4331b000-4331c000 r--p 0000b000 b3:12 12033      /usr/lib/libbuxton2.so.1.1
[0-187.8649] 4331c000-4331d000 rw-p 0000c000 b3:12 12033      /usr/lib/libbuxton2.so.1.1
[0-187.8649] 43320000-43325000 r-xp 00000000 b3:12 15155      /usr/lib/libffi.so.6.0.2
[0-187.8649] 43325000-43334000 ---p 00005000 b3:12 15155      /usr/lib/libffi.so.6.0.2
[0-187.8649] 43334000-43335000 r--p 00004000 b3:12 15155      /usr/lib/libffi.so.6.0.2
[0-187.8649] 43335000-43336000 rw-p 00005000 b3:12 15155      /usr/lib/libffi.so.6.0.2
[0-187.8649] 43340000-43342000 r-xp 00000000 b3:12 16916      /usr/lib/libgmodule-2.0.so.0.5200.2
[0-187.8649] 43342000-43352000 ---p 00002000 b3:12 16916      /usr/lib/libgmodule-2.0.so.0.5200.2
[0-187.8649] 43352000-43353000 r--p 00002000 b3:12 16916      /usr/lib/libgmodule-2.0.so.0.5200.2
[0-187.8649] 43353000-43354000 rw-p 00003000 b3:12 16916      /usr/lib/libgmodule-2.0.so.0.5200.2
[0-187.8649] 43360000-43365000 r-xp 00000000 b3:12 12010      /usr/lib/libtzplatform-config-2.0.so.2.0.0
[0-187.8649] 43365000-43374000 ---p 00005000 b3:12 12010      /usr/lib/libtzplatform-config-2.0.so.2.0.0
[0-187.8649] 43374000-43375000 r--p 00004000 b3:12 12010      /usr/lib/libtzplatform-config-2.0.so.2.0.0
[0-187.8649] 43375000-43376000 rw-p 00005000 b3:12 12010      /usr/lib/libtzplatform-config-2.0.so.2.0.0
[0-187.8650] 43376000-4337b000 rw-p 00000000 00:00 0
[0-187.8650] 43380000-43386000 r-xp 00000000 b3:12 11608      /usr/lib/libvconf.so.0.3.1
[0-187.8650] 43386000-43395000 ---p 00006000 b3:12 11608      /usr/lib/libvconf.so.0.3.1
[0-187.8650] 43395000-43396000 r--p 00005000 b3:1o
[0-187.8684] 4683d000-4683e000 rw-p 00000000 00:00 0
[0-187.8684] 468a0000-468e6000 r-xp 00000000 b3:12 16766      /usr/lib/libsso_api.so
[0-187.8684] 468e6000-468f5000 ---p 00046000 b3:12 16766      /usr/lib/libsso_api.so
[0-187.8684] 468f5000-468f6000 r--p 00045000 b3:12 16766      /usr/lib/libsso_api.so
[0-187.8684] 468f6000-468f7000 rw-p 00046000 b3:12 16766      /usr/lib/libsso_api.so
[0-187.8684] 46980000-4699a000 r-xp 00000000 b3:12 16146      /usr/lib/libVDCurl.so.0.9
[0-187.8684] 4699a000-469a9000 ---p 0001a000 b3:12 16146      /usr/lib/libVDCurl.so.0.9
[0-187.8684] 469a9000-469aa000 r--p 00019000 b3:12 16146      /usr/lib/libVDCurl.so.0.9
[0-187.8684] 469aa000-469ab000 rw-p 0001a000 b3:12 16146      /usr/lib/libVDCurl.so.0.9
[0-187.8684] 46a00000-46a06000 r-xp 00000000 b3:12 16924      /usr/lib/libcomss-api.so
[0-187.8684] 46a06000-46a15000 ---p 00006000 b3:12 16924      /usr/lib/libcomss-api.so
[0-187.8684] 46a15000-46a16000 r--p 00005000 b3:12 16924      /usr/lib/libcomss-api.so
[0-187.8684] 46a16000-46a17000 rw-p 00006000 b3:12 16924      /usr/lib/libcomss-api.so
[0-187.8684] 46a60000-46bc1000 r-xp 00000000 b3:12 16213      /usr/lib/libtvs-parser.so
[0-187.8685] 46bc1000-46bd0000 ---p 00161000 b3:12 16213      /usr/lib/libtvs-parser.so
[0-187.8685] 46bd0000-46bd7000 r--p 00160000 b3:12 16213      /usr/lib/libtvs-parser.so
[0-187.8685] 46bd7000-46bdb000 rw-p 00167000 b3:12 16213      /usr/lib/libtvs-parser.so
[0-187.8685] 46be0000-46c28000 r-xp 00000000 b3:12 10913      /usr/lib/libpvr-service-api.so
[0-187.8685] 46c28000-46c37000 ---p 00048000 b3:12 10913      /usr/lib/libpvr-service-api.so
[0-187.8685] 46c37000-46c3b000 r--p 00047000 b3:12 10913      /usr/lib/libpvr-service-api.so
[0-187.8685] 46c3b000-46c3c000 rw-p 0004b000 b3:12 10913      /usr/lib/libpvr-service-api.so
[0-187.8685] 46c40000-46c59000 r-xp 00000000 b3:12 16748      /usr/lib/libca-api.so
[0-187.8685] 46c59000-46c68000 ---p 00019000 b3:12 16748      /usr/lib/libca-api.so
[0-187.8685] 46c68000-46c69000 r--p 00018000 b3:12 16748      /usr/lib/libca-api.so
[0-187.8685] 46c69000-46c6a000 rw-p 00019000 b3:12 16748      /usr/lib/libca-api.so
[0-187.8685] 46c70000-46c8a000 r-xp 00000000 b3:12 15149      /usr/lib/libnagsam-api.so
[0-187.8685] 46c8a000-46c9a000 ---p 0001a000 b3:12 15149      /usr/lib/libnagsam-api.so
[0-187.8685] 46c9a000-46c9b000 r--p 0001a000 b3:12 15149      /usr/lib/libnagsam-api.so
[0-187.8685] 46c9b000-46c9c000 rw-p 0001b000 b3:12 15149      /usr/lib/libnagsam-api.so
[0-187.8685] 46d40000-46d4a000 r-xp 00000000 b3:12 16332      /usr/lib/libpvr-security.so
[0-187.8685] 46d4a000-46d59000 ---p 0000a000 b3:12 16332      /usr/lib/libpvr-security.so
[0-187.8686] 46d59000-46d5a000 r--p 00009000 b3:12 16332      /usr/lib/libpvr-security.so
[0-187.8686] 46d5a000-46d5b000 rw-p 0000a000 b3:12 16332      /usr/lib/libpvr-security.so
[0-187.8686] 46d5b000-46d5d000 rw-p 00000000 00:00 0
[0-187.8686] 46d60000-46d6d000 r-xp 00000000 b3:12 14839      /usr/lib/libres-lookup.so.0.1
[0-187.8686] 46d6d000-46d7c000 ---p 0000d000 b3:12 14839      /usr/lib/libres-lookup.so.0.1
[0-187.8686] 46d7c000-46d7d000 r--p 0000c000 b3:12 14839      /usr/lib/libres-lookup.so.0.1
[0-187.8686] 46d7d000-46d7e000 rw-p 0000d000 b3:12 14839      /usr/lib/libres-lookup.so.0.1
[0-187.8686] 46e90000-46ea4000 r-xp 00000000 b3:12 13871      /usr/lib/libtv-resource-information.so.1.24
[0-187.8686] 46ea4000-46eb3000 ---p 00014000 b3:12 13871      /usr/lib/libtv-resource-information.so.1.24
[0-187.8686] 46eb3000-46eb4000 r--p 00013000 b3:12 13871      /usr/lib/libtv-resource-information.so.1.24
[0-187.8686] 46eb4000-46eb5000 rw-p 00014000 b3:12 13871      /usr/lib/libtv-resource-information.so.1.24
[0-187.8686] 46fb0000-46fb2000 r-xp 00000000 b3:12 16089      /usr/lib/libcapi-screensaver.so
[0-187.8686] 46fb2000-46fc1000 ---p 00002000 b3:12 16089      /usr/lib/libcapi-screensaver.so
[0-187.8686] 46fc1000-46fc2000 r--p 00001000 b3:12 16089      /usr/lib/libcapi-screensaver.so
[0-187.8686] 46fc2000-46fc3000 rw-p 00002000 b3:12 16089      /usr/lib/libcapi-screensaver.so
[0-187.8686] 47030000-47103000 r-xp 00000000 b3:12 12102      /usr/lib/libgstreamer-1.0.so.0.1202.0
[0-187.8686] 47103000-47113000 ---p 000d3000 b3:12 12102      /usr/lib/libgstreamer-1.0.so.0.1202.0
[0-187.8687] 47113000-47116000 r--p 000d3000 b3:12 12102      /usr/lib/libgstreamer-1.0.so.0.1202.0
[0-187.8687] 47116000-47118000 rw-p 000d6000 b3:12 12102      /usr/lib/libgstreamer-1.0.so.0.1202.0
[0-187.8687] 47118000-47119000 rw-p 00000000 00:00 0
[0-187.8687] 471e0000-47232000 r-xp 00000000 b3:12 11879      /usr/lib/libgstvideo-1.0.so.0.1202.0
[0-187.8687] 47232000-47242000 ---p 00052000 b3:12 11879      /usr/lib/libgstvideo-1.0.so.0.1202.0
[0-187.8687] 47242000-4724a000 r--p 00052000 b3:12 11879      /usr/lib/libgstvideo-1.0.so.0.1202.0
[0-187.8687] 4724a000-4724b000 rw-p 0005a000 b3:12 11879      /usr/lib/libgstvideo-1.0.so.0.1202.0
[0-187.8687] 47370000-473ba000 r-xp 00000000 b3:12 13490      /usr/lib/libgstbase-1.0.so.0.1202.0
[0-187.8687] 473ba000-473c9000 ---p 0004a000 b3:12 13490      /usr/lib/libgstbase-1.0.so.0.1202.0
[0-187.8687] 473c9000-473ca000 r--p 00049000 b3:12 13490      /usr/lib/libgstbase-1.0.so.0.1202.0
[0-187.8687] 473ca000-473cb000 rw-p 0004a000 b3:12 13490      /usr/lib/libgstbase-1.0.so.0.1202.0
[0-187.8687] 47700000-47706000 r-xp 00000000 b3:12 11987      /usr/lib/libtv-resource-manager.so.1.43
[0-187.8687] 47706000-47715000 ---p 00006000 b3:12 11987      /usr/lib/libtv-resource-manager.so.1.43
[0-187.8687] 47715000-47716000 r--p 00005000 b3:12 11987      /usr/lib/libtv-resource-manager.so.1.43
[0-187.8687] 47716000-47717000 rw-p 00006000 b3:12 11987      /usr/lib/libtv-resource-manager.so.1.43
[0-187.8687] 47717000-47718000 rw-p 00000000 00:00 0
[0-187.8687] b17ff000-b1800000 ---p 00000000 00:00 0
[0-187.8688] b1800000-b19ff000 rw-p 00000000 00:00 0          [tstack: TCAlarm:tvs-dae: 3593]
[0-187.8688] b19ff000-b1a00000 ---p 00000000 00:00 0
[0-187.8688] b1a00000-b1bff000 rw-p 00000000 00:00 0
[0-187.8688] b1bff000-b2f00000 rw-p 00000000 00:00 0
[0-187.8688] b2f00000-b2f42000 rw-p 00000000 00:00 0
[0-187.8688] b2f42000-b3000000 ---p 00000000 00:00 0
[0-187.8688] b3000000-b3021000 rw-p 00000000 00:00 0
[0-187.8688] b3021000-b3100000 ---p 00000000 00:00 0
[0-187.8688] b3100000-b3101000 ---p 00000000 00:00 0
[0-187.8688] b3101000-b3300000 rw-p 00000000 00:00 0
[0-187.8688] b3300000-b4300000 r--s 00000000 00:05 60965      /kdbus-conn:libdbus-kdbus (deleted)
[0-187.8688] b4300000-b43fa000 rw-p 00000000 00:00 0
[0-187.8688] b43fa000-b4400000 ---p 00000000 00:00 0
[0-187.8688] b4500000-b4521000 rw-p 00000000 00:00 0
[0-187.8688] b4521000-b4600000 ---p 00000000 00:00 0
[0-187.8688] b4600000-b46f1000 rw-p 00000000 00:00 0
[0-187.8688] b46f1000-b4700000 ---p 00000000 00:00 0
[0-187.8688] b4700000-b4701000 ---p 00000000 00:00 0
[0-187.8688] b4701000-b4900000 rw-p 00000000 00:00 0          [tstack: tvs-daemon: 3587]
[0-187.8688] b4900000-b4901000 ---p 00000000 00:00 0
[0-187.8689] b4901000-b4b00000 rw-p 00000000 00:00 0          [tstack: TCSystemTimeMan: 3592]
[0-187.8689] b4b00000-b4b01000 ---p 00000000 00:00 0
[0-187.8689] b4b01000-b4d00000 rw-p 00000000 00:00 0          [tstack: TCScanManager: 3591]
[0-187.8689] b4d00000-b5d00000 r--s 00000000 00:05 60961      /kdbus-conn:gdbus-kdbus (deleted)
[0-187.8689] b5d00000-b5d01000 ---p 00000000 00:00 0
[0-187.8689] b5d01000-b5f00000 rw-p 00000000 00:00 0          [tstack: gkdbus: 3582]
[0-187.8689] b5f00000-b5f21000 rw-p 00000000 00:00 0
[0-187.8689] b5f21000-b6000000 ---p 00000000 00:00 0
[0-187.8689] b6022000-b6024000 r-xp 00000000 b3:12 11313      /usr/lib/libnvram-impl-sec.so.0.1
[0-187.8689] b6024000-b6033000 ---p 00002000 b3:12 11313      /usr/lib/libnvram-impl-sec.so.0.1
[0-187.8689] b6033000-b6034000 r--p705] 41060000-42a4d000 r--p 00000000 b3:12 11120      /usr/lib/libicudata.so.63.2
[0-198.8705] 42a4d000-42a5c000 ---p 019ed000 b3:12 11120      /usr/lib/libicudata.so.63.2
[0-198.8705] 42a5c000-42a5d000 r--p 019ec000 b3:12 11120      /usr/lib/libicudata.so.63.2
[0-198.8705] 42a5d000-42a5e000 rw-p 019ed000 b3:12 11120      /usr/lib/libicudata.so.63.2
[0-198.8705] 42a60000-42a62000 r-xp 00000000 b3:12 15500      /usr/lib/libproc-stat.so.5.5.0
[0-198.8705] 42a62000-42a71000 ---p 00002000 b3:12 15500      /usr/lib/libproc-stat.so.5.5.0
[0-198.8705] 42a71000-42a72000 r--p 00001000 b3:12 15500      /usr/lib/libproc-stat.so.5.5.0
[0-198.8705] 42a72000-42a73000 rw-p 00002000 b3:12 15500      /usr/lib/libproc-stat.so.5.5.0
[0-198.8705] 42a80000-42ba5000 r-xp 00000000 b3:12 12215      /usr/lib/libc-2.24.so
[0-198.8705] 42ba5000-42bb4000 ---p 00125000 b3:12 12215      /usr/lib/libc-2.24.so
[0-198.8705] 42bb4000-42bb6000 r--p 00124000 b3:12 12215      /usr/lib/libc-2.24.so
[0-198.8706] 42bb6000-42bb8000 rw-p 00126000 b3:12 12215      /usr/lib/libc-2.24.so
[0-198.8706] 42bb8000-42bba000 rw-p 00000000 00:00 0
[0-198.8706] 42bc0000-42bd9000 r-xp 00000000 b3:12 10911      /usr/lib/libgcc_s.so.1
[0-198.8706] 42bd9000-42be8000 ---p 00019000 b3:12 10911      /usr/lib/libgcc_s.so.1
[0-198.8706] 42be8000-42be9000 r--p 00018000 b3:12 10911      /usr/lib/libgcc_s.so.1
[0-198.8706] 42be9000-42bea000 rw-p 00019000 b3:12 10911      /usr/lib/libgcc_s.so.1
[0-198.8706] 42bf0000-42c05000 r-xp 00000000 b3:12 12269      /usr/lib/libpthread-2.24.so
[0-198.8706] 42c05000-42c14000 ---p 00015000 b3:12 12269      /usr/lib/libpthread-2.24.so
[0-198.8706] 42c14000-42c15000 r--p 00014000 b3:12 12269      /usr/lib/libpthread-2.24.so
[0-198.8706] 42c15000-42c16000 rw-p 00015000 b3:12 12269      /usr/lib/libpthread-2.24.so
[0-198.8706] 42c16000-42c18000 rw-p 00000000 00:00 0
[0-198.8706] 42c20000-42c23000 r-xp 00000000 b3:12 15184      /usr/lib/libdl-2.24.so
[0-198.8706] 42c23000-42c32000 ---p 00003000 b3:12 15184      /usr/lib/libdl-2.24.so
[0-198.8706] 42c32000-42c33000 r--p 00002000 b3:12 15184      /usr/lib/libdl-2.24.so
[0-198.8706] 42c33000-42c34000 rw-p 00003000 b3:12 15184      /usr/lib/libdl-2.24.so
[0-198.8706] 42c40000-42d34000 r-xp 00000000 b3:12 16580      /usr/lib/libstdc++.so.6.0.22
[0-198.8706] 42d34000-42d44000 ---p 000f4000 b3:12 16580      /usr/lib/libstdc++.so.6.0.22
[0-198.8706] 42d44000-42d48000 r--p 000f4000 b3:12 16580      /usr/lib/libstdc++.so.6.0.22
[0-198.8707] 42d48000-42d4b000 rw-p 000f8000 b3:12 16580      /usr/lib/libstdc++.so.6.0.22
[0-198.8707] 42d4b000-42d4d000 rw-p 00000000 00:00 0
[0-198.8707] 42d50000-42dc2000 r-xp 00000000 b3:12 10909      /usr/lib/libm-2.24.so
[0-198.8707] 42dc2000-42dd1000 ---p 00072000 b3:12 10909      /usr/lib/libm-2.24.so
[0-198.8707] 42dd1000-42dd2000 r--p 00071000 b3:12 10909      /usr/lib/libm-2.24.so
[0-198.8707] 42dd2000-42dd3000 rw-p 00072000 b3:12 10909      /usr/lib/libm-2.24.so
[0-198.8707] 42de0000-42ded000 r-xp 00000000 b3:12 16172      /usr/lib/libcapi-base-common.so.0.4.54
[0-198.8707] 42ded000-42dfd000 ---p 0000d000 b3:12 16172      /usr/lib/libcapi-base-common.so.0.4.54
[0-198.8707] 42dfd000-42dff000 r--p 0000d000 b3:12 16172      /usr/lib/libcapi-base-common.so.0.4.54
[0-198.8707] 42dff000-42e00000 rw-p 0000f000 b3:12 16172      /usr/lib/libcapi-base-common.so.0.4.54
[0-198.8707] 42e10000-42e13000 r-xp 00000000 b3:12 11408      /usr/lib/libdlog.so.0.0.0
[0-198.8707] 42e13000-42e22000 ---p 00003000 b3:12 11408      /usr/lib/libdlog.so.0.0.0
[0-198.8707] 42e22000-42e23000 r--p 00002000 b3:12 11408      /usr/lib/libdlog.so.0.0.0
[0-198.8707] 42e23000-42e24000 rw-p 00003000 b3:12 11408      /usr/lib/libdlog.so.0.0.0
[0-198.8707] 42e30000-42e5b000 r-xp 00000000 b3:12 13572      /usr/lib/libcynara-commons.so.0.14.24
[0-198.8707] 42e5b000-42e6a000 ---p 0002b000 b3:12 13572      /usr/lib/libcynara-commons.so.0.14.24
[0-198.8708] 42e6a000-42e6c000 r--p 0002a000 b3:12 13572      /usr/lib/libcynara-commons.so.0.14.24
[0-198.8708] 42e6c000-42e6d000 rw-p 0002c000 b3:12 13572      /usr/lib/libcynara-commons.so.0.14.24
[0-198.8708] 42e70000-42e85000 r-xp 00000000 b3:12 16133      /usr/lib/libdbuspolicy1.so.1.1.0
[0-198.8708] 42e85000-42e94000 ---p 00015000 b3:12 16133      /usr/lib/libdbuspolicy1.so.1.1.0
[0-198.8708] 42e94000-42e95000 r--p 00014000 b3:12 16133      /usr/lib/libdbuspolicy1.so.1.1.0
[0-198.8708] 42e95000-42e96000 rw-p 00015000 b3:12 16133      /usr/lib/libdbuspolicy1.so.1.1.0
[0-198.8708] 42ea0000-42eb6000 r-xp 00000000 b3:12 16277      /usr/lib/libexpat.so.1.6.9
[0-198.8708] 42eb6000-42ec5000 ---p 00016000 b3:12 16277      /usr/lib/libexpat.so.1.6.9
[0-198.8708] 42ec5000-42ec7000 r--p 00015000 b3:12 16277      /usr/lib/libexpat.so.1.6.9
[0-198.8708] 42ec7000-42ec8000 rw-p 00017000 b3:12 16277      /usr/lib/libexpat.so.1.6.9
[0-198.8708] 42ed0000-42ed6000 r-xp 00000000 b3:12 13472      /usr/lib/libcynara-client-commons.so.0.14.24
[0-198.8708] 42ed6000-42ee5000 ---p 00006000 b3:12 13472      /usr/lib/libcynara-client-commons.so.0.14.24
[0-198.8708] 42ee5000-42ee6000 r--p 00005000 b3:12 13472      /usr/lib/libcynara-client-commons.so.0.14.24
[0-198.8708] 42ee6000-42ee7000 rw-p 00006000 b3:12 13472      /usr/lib/libcynara-client-commons.so.0.14.24
[0-198.8708] 42ef0000-42ef8000 r-xp 00000000 b3:12 16785      /usr/lib/libcynara-client.so.0.14.24
[0-198.8708] 42ef8000-42f07000 ---p 00008000 b3:12 16785      /usr/lib/libcynara-client.so.0.14.24
[0-198.8708] 42f07000-42f08000 r--p 00007000 b3:12 16785      /usr/lib/libcynara-client.so.0.14.24
[0-198.8709] 42f08000-42f09000 rw-p 00008000 b3:12 16785      /usr/lib/libcynara-client.so.0.14.24
[0-198.8709] 42f10000-42f12000 r-xp 00000000 b3:12 15437      /usr/lib/libcynara-session.so.0.14.24
[0-198.8709] 42f12000-42f21000 ---p 00002000 b3:12 15437      /usr/lib/libcynara-session.so.0.14.24
[0-198.8709] 42f21000-42f22000 r--p 00001000 b3:12 15437      /usr/lib/libcynara-session.so.0.14.24
[0-198.8709] 42f22000-42f23000 rw-p 00002000 b3:12 15437      /usr/lib/libcynara-session.so.0.14.24
[0-198.8709] 42f30000-42f36000 r-xp 00000000 b3:12 11480      /usr/lib/librt-2.24.so
[0-198.8709] 42f36000-42f45000 ---p 00006000 b3:12 11480      /usr/lib/librt-2.24.so
[0-198.8709] 42f45000-42f46000 r--p 00005000 b3:12 11480      /usr/lib/librt-2.24.so
[0-198.8709] 42f46000-42f47000 rw-p 00006000 b3:12 11480      /usr/lib/librt-2.24.so
[0-198.8709] 42f50000-430a0000 r-xp 00000000 b3:12 11138      /usr/lib/libgio-2.0.so.0.5200.2
[0-198.8709] 430a0000-430b0000 ---p 00150000 b3:12 11138      /usr/lib/libgio-2.0.so.0.5200.2
[0-198.8709] 430b0000-430b2000 r--p 00150000 b3:12 11138      /usr/lib/libgio-2.0.so.0.5200.2
[0-198.8709] 430b2000-430b4000 rw-p 00152000 b3:12 11138      /usr/lib/libgio-2.0.so.0.5200.2
[0-198.8709] 430b4000-430b5000 rw-p 00000000 00:00 0
[0-198.8709] 430c0000-431b7000 r-xp 00000000 b3:12 15321      /usr/lib/libglib-2.0.so.0.5200.2
[0-198.8709] 431b7000-431c6000 ---p 000f7000 b3:12 15321      /usr/lib/libglib-2.0.so.0.5200.2
[0-198.8710] 431c6000-431c7000 r--p 000f6000 b3:12 15321      /usr/lib/libglib-2.0.so.0.5200.2
[0-198.8710] 431c7000-431c8000 rw-p 000f7000 b3:12 15321      /usr/lib/libglib-2.0.so.0.5200.2
[0-198.8710] 431d0000-4321f000 r-xp 00000000 b3:12 13870      /usr/lib/libpcre.so.1.2.11
[0-198.8710] 4321f000-4322e000 ---p 0004f000 b3:12 13870      /usr/lib/libpcre.so.1.2.11
[0-198.8710] 4322e000-4322f000 r--p 0004e000 b3:12 13870      /usr/lib/libpcre.so.1.2.11
[0-198.8710] 4322f000-43230000 rw-p 0004f000 b3:12 13870      /usr/lib/libpcre.so.1.2.11
[0-198.8710] 43240000-43285000 r-xp 00000000 b3:12 11617      /usr/lib/libgobject-2.0.so.0.5200.2
[0-198.8710] 43285000-43294000 ---p 00045000 b3:12 11617      /usr/lib/libgobject-2.0.so.0.5200.2
[0-198.8710] 43294000-43295000 r--p 00044000 b3:12 11617      /usr/lib/libgobject-2.0.so.0.5200.2
[0-198.8710] 43295000-43296000 rw-p 00045000 b3:12 11617      /usr/lib/libgobject-2.0.so.0.5200.2
[0-198.8710] 432a0000-432b2000 r-xp 00000000 b3:12 16583      /usr/lib/libresolv-2.24.so
[0-198.85000 r--p 00004000 b3:12 15191      /usr/lib/libnode-manager.so.0.1
[0-198.8746] 46795000-46796000 rw-p 00005000 b3:12 15191      /usr/lib/libnode-manager.so.0.1
[0-198.8746] 46796000-46799000 rw-p 00000000 00:00 0
[0-198.8746] 467e0000-4682b000 r-xp 00000000 b3:12 16703      /usr/lib/libci-api.so
[0-198.8746] 4682b000-4683a000 ---p 0004b000 b3:12 16703      /usr/lib/libci-api.so
[0-198.8746] 4683a000-4683c000 r--p 0004a000 b3:12 16703      /usr/lib/libci-api.so
[0-198.8746] 4683c000-4683d000 rw-p 0004c000 b3:12 16703      /usr/lib/libci-api.so
[0-198.8746] 4683d000-4683e000 rw-p 00000000 00:00 0
[0-198.8746] 468a0000-468e6000 r-xp 00000000 b3:12 16766      /usr/lib/libsso_api.so
[0-198.8746] 468e6000-468f5000 ---p 00046000 b3:12 16766      /usr/lib/libsso_api.so
[0-198.8746] 468f5000-468f6000 r--p 00045000 b3:12 16766      /usr/lib/libsso_api.so
[0-198.8746] 468f6000-468f7000 rw-p 00046000 b3:12 16766      /usr/lib/libsso_api.so
[0-198.8746] 46980000-4699a000 r-xp 00000000 b3:12 16146      /usr/lib/libVDCurl.so.0.9
[0-198.8746] 4699a000-469a9000 ---p 0001a000 b3:12 16146      /usr/lib/libVDCurl.so.0.9
[0-198.8746] 469a9000-469aa000 r--p 00019000 b3:12 16146      /usr/lib/libVDCurl.so.0.9
[0-198.8746] 469aa000-469ab000 rw-p 0001a000 b3:12 16146      /usr/lib/libVDCurl.so.0.9
[0-198.8746] 46a00000-46a06000 r-xp 00000000 b3:12 16924      /usr/lib/libcomss-api.so
[0-198.8747] 46a06000-46a15000 ---p 00006000 b3:12 16924      /usr/lib/libcomss-api.so
[0-198.8747] 46a15000-46a16000 r--p 00005000 b3:12 16924      /usr/lib/libcomss-api.so
[0-198.8747] 46a16000-46a17000 rw-p 00006000 b3:12 16924      /usr/lib/libcomss-api.so
[0-198.8747] 46a60000-46bc1000 r-xp 00000000 b3:12 16213      /usr/lib/libtvs-parser.so
[0-198.8747] 46bc1000-46bd0000 ---p 00161000 b3:12 16213      /usr/lib/libtvs-parser.so
[0-198.8747] 46bd0000-46bd7000 r--p 00160000 b3:12 16213      /usr/lib/libtvs-parser.so
[0-198.8747] 46bd7000-46bdb000 rw-p 00167000 b3:12 16213      /usr/lib/libtvs-parser.so
[0-198.8747] 46be0000-46c28000 r-xp 00000000 b3:12 10913      /usr/lib/libpvr-service-api.so
[0-198.8747] 46c28000-46c37000 ---p 00048000 b3:12 10913      /usr/lib/libpvr-service-api.so
[0-198.8747] 46c37000-46c3b000 r--p 00047000 b3:12 10913      /usr/lib/libpvr-service-api.so
[0-198.8747] 46c3b000-46c3c000 rw-p 0004b000 b3:12 10913      /usr/lib/libpvr-service-api.so
[0-198.8747] 46c40000-46c59000 r-xp 00000000 b3:12 16748      /usr/lib/libca-api.so
[0-198.8747] 46c59000-46c68000 ---p 00019000 b3:12 16748      /usr/lib/libca-api.so
[0-198.8747] 46c68000-46c69000 r--p 00018000 b3:12 16748      /usr/lib/libca-api.so
[0-198.8747] 46c69000-46c6a000 rw-p 00019000 b3:12 16748      /usr/lib/libca-api.so
[0-198.8747] 46c70000-46c8a000 r-xp 00000000 b3:12 15149      /usr/lib/libnagsam-api.so
[0-198.8747] 46c8a000-46c9a000 ---p 0001a000 b3:12 15149      /usr/lib/libnagsam-api.so
[0-198.8748] 46c9a000-46c9b000 r--p 0001a000 b3:12 15149      /usr/lib/libnagsam-api.so
[0-198.8748] 46c9b000-46c9c000 rw-p 0001b000 b3:12 15149      /usr/lib/libnagsam-api.so
[0-198.8748] 46d40000-46d4a000 r-xp 00000000 b3:12 16332      /usr/lib/libpvr-security.so
[0-198.8748] 46d4a000-46d59000 ---p 0000a000 b3:12 16332      /usr/lib/libpvr-security.so
[0-198.8748] 46d59000-46d5a000 r--p 00009000 b3:12 16332      /usr/lib/libpvr-security.so
[0-198.8748] 46d5a000-46d5b000 rw-p 0000a000 b3:12 16332      /usr/lib/libpvr-security.so
[0-198.8748] 46d5b000-46d5d000 rw-p 00000000 00:00 0
[0-198.8748] 46d60000-46d6d000 r-xp 00000000 b3:12 14839      /usr/lib/libres-lookup.so.0.1
[0-198.8748] 46d6d000-46d7c000 ---p 0000d000 b3:12 14839      /usr/lib/libres-lookup.so.0.1
[0-198.8748] 46d7c000-46d7d000 r--p 0000c000 b3:12 14839      /usr/lib/libres-lookup.so.0.1
[0-198.8748] 46d7d000-46d7e000 rw-p 0000d000 b3:12 14839      /usr/lib/libres-lookup.so.0.1
[0-198.8748] 46e90000-46ea4000 r-xp 00000000 b3:12 13871      /usr/lib/libtv-resource-information.so.1.24
[0-198.8748] 46ea4000-46eb3000 ---p 00014000 b3:12 13871      /usr/lib/libtv-resource-information.so.1.24
[0-198.8748] 46eb3000-46eb4000 r--p 00013000 b3:12 13871      /usr/lib/libtv-resource-information.so.1.24
[0-198.8748] 46eb4000-46eb5000 rw-p 00014000 b3:12 13871      /usr/lib/libtv-resource-information.so.1.24
[0-198.8748] 46fb0000-46fb2000 r-xp 00000000 b3:12 16089      /usr/lib/libcapi-screensaver.so
[0-198.8748] 46fb2000-46fc1000 ---p 00002000 b3:12 16089      /usr/lib/libcapi-screensaver.so
[0-198.8749] 46fc1000-46fc2000 r--p 00001000 b3:12 16089      /usr/lib/libcapi-screensaver.so
[0-198.8749] 46fc2000-46fc3000 rw-p 00002000 b3:12 16089      /usr/lib/libcapi-screensaver.so
[0-198.8749] 47030000-47103000 r-xp 00000000 b3:12 12102      /usr/lib/libgstreamer-1.0.so.0.1202.0
[0-198.8749] 47103000-47113000 ---p 000d3000 b3:12 12102      /usr/lib/libgstreamer-1.0.so.0.1202.0
[0-198.8749] 47113000-47116000 r--p 000d3000 b3:12 12102      /usr/lib/libgstreamer-1.0.so.0.1202.0
[0-198.8749] 47116000-47118000 rw-p 000d6000 b3:12 12102      /usr/lib/libgstreamer-1.0.so.0.1202.0
[0-198.8749] 47118000-47119000 rw-p 00000000 00:00 0
[0-198.8749] 471e0000-47232000 r-xp 00000000 b3:12 11879      /usr/lib/libgstvideo-1.0.so.0.1202.0
[0-198.8749] 47232000-47242000 ---p 00052000 b3:12 11879      /usr/lib/libgstvideo-1.0.so.0.1202.0
[0-198.8749] 47242000-4724a000 r--p 00052000 b3:12 11879      /usr/lib/libgstvideo-1.0.so.0.1202.0
[0-198.8749] 4724a000-4724b000 rw-p 0005a000 b3:12 11879      /usr/lib/libgstvideo-1.0.so.0.1202.0
[0-198.8749] 47370000-473ba000 r-xp 00000000 b3:12 13490      /usr/lib/libgstbase-1.0.so.0.1202.0
[0-198.8749] 473ba000-473c9000 ---p 0004a000 b3:12 13490      /usr/lib/libgstbase-1.0.so.0.1202.0
[0-198.8749] 473c9000-473ca000 r--p 00049000 b3:12 13490      /usr/lib/libgstbase-1.0.so.0.1202.0
[0-198.8749] 473ca000-473cb000 rw-p 0004a000 b3:12 13490      /usr/lib/libgstbase-1.0.so.0.1202.0
[0-198.8749] 47700000-47706000 r-xp 00000000 b3:12 11987      /usr/lib/libtv-resource-manager.so.1.43
[0-198.8749] 47706000-47715000 ---p 00006000 b3:12 11987      /usr/lib/libtv-resource-manager.so.1.43
[0-198.8750] 47715000-47716000 r--p 00005000 b3:12 11987      /usr/lib/libtv-resource-manager.so.1.43
[0-198.8750] 47716000-47717000 rw-p 00006000 b3:12 11987      /usr/lib/libtv-resource-manager.so.1.43
[0-198.8750] 47717000-47718000 rw-p 00000000 00:00 0
[0-198.8750] b17ff000-b1800000 ---p 00000000 00:00 0
[0-198.8750] b1800000-b19ff000 rw-p 00000000 00:00 0          [tstack: TCAlarm:tvs-dae: 3750]
[0-198.8750] b19ff000-b1a00000 ---p 00000000 00:00 0
[0-198.8750] b1a00000-b1bff000 rw-p 00000000 00:00 0
[0-198.8750] b1bff000-b2f00000 rw-p 00000000 00:00 0
[0-198.8750] b2f00000-b3f00000 r--s 00000000 00:05 61752      /kdbus-conn:libdbus-kdbus (deleted)
[0-198.8750] b3f00000-b3f01000 ---p 00000000 00:00 0
[0-198.8750] b3f01000-b4100000 rw-p 00000000 00:00 0
[0-198.8750] b4100000-b41b1000 rw-p 00000000 00:00 0
[0-198.8750] b41b1000-b4200000 ---p 00000000 00:00 0
[0-198.8750] b4200000-b4221000 rw-p 00000000 00:00 0
[0-198.8750] b4221000-b4300000 ---p 00000000 00:00 0
[0-198.8750] b4300000-b43b2000 rw-p 00000000 00:00 0
[0-198.8750] b43b2000-b4400000 ---p 00000000 00:00 0
[0-198.8750] b4400000-b44d4000 rw-p 00000000 00:00 0
[0-198.8750] b44d4000-b4500000 ---p 00000000 00:00 0
[0-198.8750] b4500000-b4501000 ---p 00000000 00:00 0
[0-198.8751] b4501000-b4700000 rw-p 00000000 00:00 0          [tstack: tvs-daemon: 3741]
[0-198.8751] b4700000-b4701000 ---p 00000000 00:00 0
[0-198.8751] b4701000-b4900000 rw-p 00000000 00:00 0          [tstack: TCScanManager: 3745]
[0-198.8751] b4900000-b4901000 ---p 00000000 00:00 0
[0-198.8751] b4901000-b4b00000 rw-p 00000000 00:00 0          [tstack: TCSystemTimeMan: 3747]
[0-198.8751] b4b00000-b5b00000 r--s 00000000 00:05 61745      /kdbus-conn:gdbus-kdbus (deleted)
[0-198.8751] b5b00000-b5b21000 rw-p 00000000 00:00 0
[0-143b60000-43bbf000 r-xp 00000000 b3:12 16184      /usr/lib/libeina.so.1.23.99
[1-207.8640] 43bbf000-43bce000 ---p 0005f000 b3:12 16184      /usr/lib/libeina.so.1.23.99
[1-207.8640] 43bce000-43bcf000 r--p 0005e000 b3:12 16184      /usr/lib/libeina.so.1.23.99
[1-207.8640] 43bcf000-43bd0000 rw-p 0005f000 b3:12 16184      /usr/lib/libeina.so.1.23.99
[1-207.8640] 43bd0000-43bd1000 rw-p 00000000 00:00 0
[1-207.8640] 43be0000-43c1c000 r-xp 00000000 b3:12 16910      /usr/lib/libssl.so.1.0.0
[1-207.8640] 43c1c000-43c2c000 ---p 0003c000 b3:12 16910      /usr/lib/libssl.so.1.0.0
[1-207.8640] 43c2c000-43c2e000 r--p 0003c000 b3:12 16910      /usr/lib/libssl.so.1.0.0
[1-207.8640] 43c2e000-43c32000 rw-p 0003e000 b3:12 16910      /usr/lib/libssl.so.1.0.0
[1-207.8640] 43c40000-43c52000 r-xp 00000000 b3:12 16498      /usr/lib/libdeviced.so.1.0.3
[1-207.8640] 43c52000-43c61000 ---p 00012000 b3:12 16498      /usr/lib/libdeviced.so.1.0.3
[1-207.8640] 43c61000-43c62000 r--p 00011000 b3:12 16498      /usr/lib/libdeviced.so.1.0.3
[1-207.8640] 43c62000-43c63000 rw-p 00012000 b3:12 16498      /usr/lib/libdeviced.so.1.0.3
[1-207.8640] 43c70000-43c8c000 r-xp 00000000 b3:12 16443      /usr/lib/libjsoncpp.so.0.10.4
[1-207.8640] 43c8c000-43c9b000 ---p 0001c000 b3:12 16443      /usr/lib/libjsoncpp.so.0.10.4
[1-207.8640] 43c9b000-43c9c000 r--p 0001b000 b3:12 16443      /usr/lib/libjsoncpp.so.0.10.4
[1-207.8640] 43c9c000-43c9d000 rw-p 0001c000 b3:12 16443      /usr/lib/libjsoncpp.so.0.10.4
[1-207.8641] 43ca0000-43ca1000 r-xp 00000000 b3:12 16800      /usr/lib/libdisplay-panel-c-glue.so.0.1
[1-207.8641] 43ca1000-43cb0000 ---p 00001000 b3:12 16800      /usr/lib/libdisplay-panel-c-glue.so.0.1
[1-207.8641] 43cb0000-43cb1000 rw-p 00000000 b3:12 16800      /usr/lib/libdisplay-panel-c-glue.so.0.1
[1-207.8641] 43cc0000-43cc1000 r-xp 00000000 b3:12 12189      /usr/lib/libdisplay-panel.so.0.1
[1-207.8641] 43cc1000-43cd1000 ---p 00001000 b3:12 12189      /usr/lib/libdisplay-panel.so.0.1
[1-207.8641] 43cd1000-43cd2000 r--p 00001000 b3:12 12189      /usr/lib/libdisplay-panel.so.0.1
[1-207.8641] 43cd2000-43cd3000 rw-p 00002000 b3:12 12189      /usr/lib/libdisplay-panel.so.0.1
[1-207.8641] 43ce0000-43cea000 r-xp 00000000 b3:12 16696      /usr/lib/libdrm.so.2.4.0
[1-207.8641] 43cea000-43cf9000 ---p 0000a000 b3:12 16696      /usr/lib/libdrm.so.2.4.0
[1-207.8641] 43cf9000-43cfa000 r--p 00009000 b3:12 16696      /usr/lib/libdrm.so.2.4.0
[1-207.8641] 43cfa000-43cfb000 rw-p 0000a000 b3:12 16696      /usr/lib/libdrm.so.2.4.0
[1-207.8641] 43d00000-43d08000 r-xp 00000000 b3:12 16151      /usr/lib/libmmfcommon.so.0.0.0
[1-207.8641] 43d08000-43d17000 ---p 00008000 b3:12 16151      /usr/lib/libmmfcommon.so.0.0.0
[1-207.8641] 43d17000-43d18000 r--p 00007000 b3:12 16151      /usr/lib/libmmfcommon.so.0.0.0
[1-207.8641] 43d18000-43d19000 rw-p 00008000 b3:12 16151      /usr/lib/libmmfcommon.so.0.0.0
[1-207.8641] 43d20000-43d21000 r-xp 00000000 b3:12 13540      /usr/lib/libpower-control-c-glue.so.0.1
[1-207.8642] 43d21000-43d30000 ---p 00001000 b3:12 13540      /usr/lib/libpower-control-c-glue.so.0.1
[1-207.8642] 43d30000-43d31000 rw-p 00000000 b3:12 13540      /usr/lib/libpower-control-c-glue.so.0.1
[1-207.8642] 43d40000-43d41000 r-xp 00000000 b3:12 12451      /usr/lib/libpower-control.so.0.1
[1-207.8642] 43d41000-43d50000 ---p 00001000 b3:12 12451      /usr/lib/libpower-control.so.0.1
[1-207.8642] 43d50000-43d51000 r--p 00000000 b3:12 12451      /usr/lib/libpower-control.so.0.1
[1-207.8642] 43d51000-43d52000 rw-p 00001000 b3:12 12451      /usr/lib/libpower-control.so.0.1
[1-207.8642] 43d60000-43d63000 r-xp 00000000 b3:12 15171      /usr/lib/libsec-video-tuner-check.so.0.1.0
[1-207.8642] 43d63000-43d72000 ---p 00003000 b3:12 15171      /usr/lib/libsec-video-tuner-check.so.0.1.0
[1-207.8642] 43d72000-43d73000 r--p 00002000 b3:12 15171      /usr/lib/libsec-video-tuner-check.so.0.1.0
[1-207.8642] 43d73000-43d74000 rw-p 00003000 b3:12 15171      /usr/lib/libsec-video-tuner-check.so.0.1.0
[1-207.8642] 43d80000-43e15000 r-xp 00000000 b3:12 11717      /usr/lib/libtvs-chms.so
[1-207.8642] 43e15000-43e24000 ---p 00095000 b3:12 11717      /usr/lib/libtvs-chms.so
[1-207.8642] 43e24000-43e27000 r--p 00094000 b3:12 11717      /usr/lib/libtvs-chms.so
[1-207.8642] 43e27000-43e29000 rw-p 00097000 b3:12 11717      /usr/lib/libtvs-chms.so
[1-207.8642] 43e29000-43e2a000 rw-p 00000000 00:00 0
[1-207.8643] 43e40000-43e54000 r-xp 00000000 b3:12 15393      /usr/lib/libboost_filesystem.so.1.58.0
[1-207.8643] 43e54000-43e63000 ---p 00014000 b3:12 15393      /usr/lib/libboost_filesystem.so.1.58.0
[1-207.8643] 43e63000-43e64000 r--p 00013000 b3:12 15393      /usr/lib/libboost_filesystem.so.1.58.0
[1-207.8643] 43e64000-43e65000 rw-p 00014000 b3:12 15393      /usr/lib/libboost_filesystem.so.1.58.0
[1-207.8643] 43e70000-43e8d000 r-xp 00000000 b3:12 16466      /usr/lib/liblibtv-plpmanager.so
[1-207.8643] 43e8d000-43e9c000 ---p 0001d000 b3:12 16466      /usr/lib/liblibtv-plpmanager.so
[1-207.8643] 43e9c000-43e9d000 r--p 0001c000 b3:12 16466      /usr/lib/liblibtv-plpmanager.so
[1-207.8643] 43e9d000-43e9e000 rw-p 0001d000 b3:12 16466      /usr/lib/liblibtv-plpmanager.so
[1-207.8643] 43ea0000-43ebc000 r-xp 00000000 b3:12 17035      /usr/lib/libsensor-genuine.so.4.0.4
[1-207.8643] 43ebc000-43ecb000 ---p 0001c000 b3:12 17035      /usr/lib/libsensor-genuine.so.4.0.4
[1-207.8643] 43ecb000-43ecc000 rw-p 0001b000 b3:12 17035      /usr/lib/libsensor-genuine.so.4.0.4
[1-207.8643] 43ed0000-43ee1000 r-xp 00000000 b3:12 15268      /usr/lib/libsensord-shared.so
[1-207.8643] 43ee1000-43ef0000 ---p 00011000 b3:12 15268      /usr/lib/libsensord-shared.so
[1-207.8643] 43ef0000-43ef1000 r--p 00010000 b3:12 15268      /usr/lib/libsensord-shared.so
[1-207.8643] 43ef1000-43ef2000 rw-p 00011000 b3:12 15268      /usr/lib/libsensord-shared.so
[1-207.8643] 43f00000-43f08000 r-xp 00000000 b3:12 12157      /usr/lib/libappcore-common.so.1.14.1
[1-207.8643] 43f08000-43f17000 ---p 00008000 b3:12 12157      /usr/lib/libappcore-common.so.1.14.1
[1-207.8644] 43f17000-43f18000 r--p 00007000 b3:12 12157      /usr/lib/libappcore-common.so.1.14.1
[1-207.8644] 43f18000-43f19000 rw-p 00008000 b3:12 12157      /usr/lib/libappcore-common.so.1.14.1
[1-207.8644] 43f20000-43f22000 r-xp 00000000 b3:12 17099      /usr/lib/libboost_system.so.1.58.0
[1-207.8644] 43f22000-43f31000 ---p 00002000 b3:12 17099      /usr/lib/libboost_system.so.1.58.0
[1-207.8644] 43f31000-43f32000 r--p 00001000 b3:12 17099      /usr/lib/libboost_system.so.1.58.0
[1-207.8644] 43f32000-43f33000 rw-p 00002000 b3:12 17099      /usr/lib/libboost_system.so.1.58.0
[1-207.8644] 43f40000-43f44000 r-xp 00000000 b3:12 17021      /usr/lib/libcapi-appfw-app-control-uri.so.0.11.11
[1-207.8644] 43f44000-43f53000 ---p 00004000 b3:12 17021      /usr/lib/libcapi-appfw-app-control-uri.so.0.11.11
[1-207.8644] 43f53000-43f54000 r--p 00003000 b3:12 17021      /usr/lib/libcapi-appfw-app-control-uri.so.0.11.11
[1-207.8644] 43f54000-43f55000 rw-p 00004000 b3:12 17021      /usr/lib/libcapi-appfw-app-control-uri.so.0.11.11
[1-207.8644] 43f60000-43f67000 r-xp 00000000 b3:12 11187      /usr/lib/libcapi-appfw-app-control.so.0.11.11
[1-207.8644] 43f67000-43f76000 ---p 00007000 b3:12 11187      /usr/lib/libcapi-appfw-app-control.so.0.11.11
[1-207.8644] 43f76000-43f77000 r--p 00006000 b3:12 11187      /usr/lib/libcapi-appfw-app-control.so.0.11.11
[1-207.8644] 43f77000-43f78000 rw-p 00007000 b3:12 11187      /usr/lib/libcapi-appfw-app-control.so.0.11.11
[1-207.8644] 43f80000-43fe4000 r-xp 00000000 b3:12 11221      /usr/lib/libtvs-pvr.so
[1-207.8644] 43fe4000-43ff4000 ---p 00064000 b3:12 11221      /usr/lib/libtvs-pvr.so
[1-207.8645] 43ff4000-43ff5000 r--p 00064000 b3:12 11221      /usr/lib/libtvs-pvr.so
[1-207.8645] 43ff5000-43ff7000 rw-p 00065000 b3:12 11221      /usr/lib/libtvs-pvr.so
[1-207.8645] 44000000-44061000 r-xp 00000000 b3:12 12282      /usr/lib/libsecurity-manager-commons.so.1.0.2
[1-207.8645] 44061000-44071000 ---p 00061000 b3:12 12282      /usr/lib/libsecurity-manager-commons.so.1.0.2
[1-207.8645] 44071000-44073000 rw-p 0006100000000
[1-207.8680] eba0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[1-207.8680] ebc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[1-207.8680] ebe0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[1-207.8680] ec00: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[1-207.8680] ec20: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[1-207.8680] ec40: 00000000 00000000 00000000 00000000 00000000 00000078 be2db19c
[1-207.8680] -----------------------------------------------------------
[1-207.8680]
[2-211.0797] cas_cc_open
[2-211.0798] [cas_cc_read] waiting for event notification
[2-214.9264] [MC:S][214.9263][AVEMonDIM]Inv-0
[2-214.9310] [MC:A][214.9310]Inv(0)
[0-216.2785] [kpi_fault_info] [k] 10 -> write function call
[0-216.2786] [kpi_fault_info] [k] 10 -> p:0x43db2e8a l:0x43db2e8b th:tvs-daemon pro:tvs-daemon ty:SIGSEGV pgid:3773
[0-216.2786] [kpi_fault_info] [k] PC Start: 0x43d80000 Offset: 0x00032e8a
[issue_report_ag[0-216.2786] [kpi_fault_info] [k] d_path : [/usr/lib/libtvs-chms.so]
ent][isCoreDumpE[0-216.2786] [kpi_fault_info] [k] exe d_path : [/usr/bin/tvs-daemon]
xpected:411]erro[0-216.2786] [kpi_fault_info] [k] LR Start: 0x43d80000 Offset: 0x00032e8b
r_kind = SIGSEGV[0-216.2786] [kpi_fault_info] [K] start time:207615606283, end time:216270360369
[issue_report_[0-216.2786] [Pid:3786][VDLP COREDUMP] SIGNR:11
[0-216.2786]
agent][read_faul[0-216.2787] [Extended-Mincore] do_minimal_core called for signal 11 and comm tvs-daemon and group_leader_comm tvs-daemon
t_info_in_proc:1[0-216.2787] [Extended-Mincore] [tvs-daemon | 3786] Waiting for get_coredump_config to return..
154]error_count is max(10)
[0-216.4802] [Extended-Mincore] [tvs-daemon | 3786] get_coredump_config returned with core_type = 0
[1-216.7690] Before Recovery:
[1-216.7690] Code: f000 80c6 f7fb e8ee (6803) 695b
[1-216.7690] After Recovery:
[1-216.7690] send signal from KERNEL, SIG : 11, tvs-daemon(3854), handler:0x0 force_sig_info
[1-216.7690] tvs-daemon: unhandled page fault (11) at 0x00000000, code 0x017
[1-216.8067]  Ver : 6340677, release
[1-216.8067]  TV, Kant.SU2-Tizen, release, Trunk_2020_MP
[1-216.8067]  Linux version 4.1.10 (abuild@A1312DKG) (gcc version 6.2.1 20161213 (Tizen/Linaro GCC 6.2.1 2016.12/VDCosmos-20190704 7.8) ) #1 SMP PREEMPT Fri Jan 8 11:04:50 UTC 2021
[1-216.8067]  dtsversion=6290398_kantsu2-1.5G-cma console=ttyS0,115200 rs232=0 earlyprintk maxcpus=4 no_console_suspend only_entry_model root=/dev/mmcblk0p18 KDUMP=16 SELP_ENABLE=20208724 _nvtca9-16m rootfstype=vdfs ro init=/sbin/init mem=808M@32M mem=56M@968M mem=256M@2048M vmalloc=300M rootwait quiet bdinfo=00000091 model=4kbtin   pba_none
[1-216.8067]
[1-216.8067] Last Exception point
[1-216.8067] --------------------------------------------------------------------------------------
[1-216.8067] PC, LR MEMINFO
[1-216.8068] PC:43db2e8a, LR:43db2e8b
[1-216.8068] --------------------------------------------------------------------------------------
[1-216.8068] PC meminfo (0x43db328a to 0x43db328a)
[1-216.8068] 3280:
[issue_report_ag[1-216.8068] LR meminfo (0x43db268b to 0x43db328b)
ent][isCoreDumpE[1-216.8068] 2680:                            2010f8cb 3f18f84a e8def7fb 4a374603 20014931
xpected:411]erro[1-216.8068] 26a0: 6058447a 60983248 f8c31d18 601ab00c 603b5864 a000f8c4 e8506063 33013f00
[1-216.8068] 26c0: 3fe2e8c0 d1f82a00 8f5bf3bf f7fb6878 4a2aed2a 4620492a 4479447a e92cf7fb
r_kind = SIGSEGV[1-216.8068] 26e0: 4618683b fdbcf039 f7fce779 f7fbe96c f8dbeb0a 46583000 4798685b ec62f7fc
[1-216.8068] 2700: 211c4604 f7fb4658 6878ed5c ece6f7fb 46304b1c f103447b f103011c 62390234
[issue_report_[1-216.8068] 2720: 637a3354 f03863bb 4640ff73 ff70f038 f7fc4620 4604ef18 eda0f7fc 4604e7e5
agent][read_faul[1-216.8068] 2740: 4604e7e3 f0384630 e7eeff63 00074e60 00000b90 0007441a 0005622c 00000bb8
t_info_in_proc:1[1-216.8068] 2760: 000573a6 00000e20 00074390 00072c9c 00074342 00074324 0007299c 00075b28
154]error_count [1-216.8068] 2780: 0003889f 0007427c e59f3014 e59f2014 e08f3003 e7932002 e3520000 012fff1e
is max(10)
[1-216.8068] 27a0: eafff3f3 00074c30 00000df8 48084b07 4a08447b 33034478 447a1a1b d9032b06
[1-216.8068] 27c0: 58d34b05 4718b103 bf004770 00075b04 00075b00 00074c0a 00000dc0 48094908
[1-216.8069] 27e0: 4b094479 1a094478 1089447b 71d1eb01 d0031049 589b4a05 4718b103 bf004770
[1-216.8069] 2800: 00075ad4 00075ad0 00074bdc 00000e04 4b0ab508 447b4a0a 781b447a 4b09b96b
[1-216.8069] 2820: b12358d3 447b4b08 f7fc6818 f7ffefec 4b06ffbd 447b2201 bd08701a 00075a9e
[1-216.8069] 2840: 00074bac 00000e10 000759da 00075a7e b5084807 68024478 447b4b06 e8bdb912
[1-216.8069] 2860: e7bb4008 589b4a04 d0f82b00 e7f64798 00072560 00074b6a 00000cf4 00000000
[1-216.8069] 2880: 1d03b480 af006840 fab01ac0 0940f080 f85d46bd 47707b04 41f0e92d f8d04606
[1-216.8069] 28a0: af008004 45a86885 4644bf18 6823d006 34304620 4798681b d1f842a5 8008f8c6
[1-216.8069] 28c0: 81f0e8bd 6842b480 6880af00 fab01a10 0940f080 f85d46bd 47707b04 6843b480
[1-216.8069] 28e0: 6083af00 f85d46bd 47707b04 6842b480 6880af00 fab01a10 0940f080 f85d46bd
[1-216.8069] 2900: 47707b04 2301b480 7303af00 f85d46bd 47707b04 4604b598 af006843 46186882
[1-216.8069] 2920: 689b681b b1084798 73232300 bf00bd98 4605b5f8 af004606 0f04f855 d00542a8
[1-216.8069] 2940: f7fb6804 4620eecc d1f942ac 60752300 60f360b5 bf00bdf8 4605b5f8 46064b08
[1-216.8069] 2960: 447baf00 60033308 0f04f855 d00542a8 f7fb6804 4620eeb4 d1f942ac bdf84630
[1-216.8069] 2980: 00072456 43f8e92d af004681 4f04f859 d012454c 4688460e f7fa200c 68a3ef5c
[1-216.8070] 29a0: 60834641 f7fa4605 68b3ef62 60b33301 8000f8d5 45a16824 e8bdd1ee bf0083f8
[1-216.8070] 29c0: 2104b598 af004604 ebfaf7fb bd984620 4605b5f8 46064b0a 447baf00 60033308
[1-216.8070] 29e0: 0f04f855 d00542a8 f7fb6804 4620ee78 d1f942ac 21144630 ebe2f7fb bdf84630
[1-216.8070] 2a00: 000723de 4604b598 4a0b4b0a 0120f100 6980447b 4288af00 f103589b 60230308
[1-216.8070] 2a20: f7fbd001 4620ee5c f7fb2130 4620ebca bf00bd98 000749b4 00000b50 4604b598
[1-216.8070] 2a40: 4a0f4b0e 013cf100 6b40447b 4288af00 f103589b 60230308 f7fbd001 6a61ee40
[1-216.8070] 2a60: 001cf104 f836f04b 1d2068e1 f848f04b 214c4620 eba4f7fb bd984620 0007497c
[1-216.8070] 2a80: 00000c00 4604b598 4a0f4b0e 013cf100 6b40447b 4288af00 f103589b 60230308
[1-216.8070] 2aa0: f7fbd001 6a61ee1c 001cf104 f812f04b 1d2068e1 f824f04b 214c4620 eb80f7fb
[1-216.8070] 2ac0: bd984620 00074934 00000c00 4604b598 4a0f4b0e 013cf100 6b40447b 4288af00
[1-216.8070] 2ae0: f103589b 60230308 f7fbd001 6a61edf8 001cf104 ffeef04a 1d2068e1 f800f04b
[1-216.8070] 2b00: 214c4620 eb5cf7fb bd984620 000748ec 00000c00 4604b598 4a0f4b0e 013cf100
[1-216.8071] 2b20: 6b40447b 4288af00 f103589b 60230308 f7fbd001 6a61edd4 001cf104 ffcaf04a
[1-216.8071] 2b40: 1d2068e1 ffdcf04a 214c4620 eb38f7fb bd984620 000748a4 00000c00 b083b590
[1-216.8071] 2b60: 693caf02 f7fa9400 3704efc6 bd9046bd f44fb580 4b047222 af004904 447b4804
[1-216.8071] 2b80: 44784479 edc8f7fb 0004dde2 0004e058 0004e082 47f0e92d 4b214606 4c21b084
[1-216.8071] 2ba0: af00447b f04f6900 4a1f0900 8004f853 9004f8c7 6803447a 4000f8d8 689c60fc
[1-216.8071] 2bc0: d1284294 0510f107 4608468a 9d08f845 f7fc4629 4604e896 46504629 0401f084
[1-216.8071] 2be0: 9008f8c7 eae0f7fb b2e06078 200cb150 ee30f7fa 6083687b f7fa1d31 68f3ee38
[1-216.8071] 2c00: 60f33301 f8d868fa 429a3000 3710d106 e8bd46bd 1d3a87f0 e7e747a0 eed2f7fb
[1-216.8071] 2c20: 00074824 00000b90 0003ed39 3458f8df 2458f8df e92d447b b0b943f0 af04589e
[1-216.8071] 2c40: f8c76833 f7fb30cc 2300ecea f7fb607b 4601e92c f1072200 f7fc0008 f7fbe84c
[1-216.8071] 2c60: 4604ec96 280068b8 81d3f000 ec74f7fc 1d3b4601 22004620 eab2f7fc f0002800
[1-216.8071] 2c80: efc08186 68b80010 0410f107 edc4613c 617cplayer.so.0.0.0
[1-216.8105] 44e8d000-44e8e000 r--p 0011d000 b3:12 15445      /usr/lib/libtv_player.so.0.0.0
[1-216.8105] 44e8e000-44e92000 rw-p 0011e000 b3:12 15445      /usr/lib/libtv_player.so.0.0.0
[1-216.8105] 44e92000-44e94000 rw-p 00000000 00:00 0
[1-216.8105] 44eb0000-44edb000 r-xp 00000000 b3:12 15462      /usr/lib/libnotification.so.0.5.45
[1-216.8105] 44edb000-44eea000 ---p 0002b000 b3:12 15462      /usr/lib/libnotification.so.0.5.45
[1-216.8105] 44eea000-44eeb000 r--p 0002a000 b3:12 15462      /usr/lib/libnotification.so.0.5.45
[1-216.8105] 44eeb000-44eec000 rw-p 0002b000 b3:12 15462      /usr/lib/libnotification.so.0.5.45
[1-216.8105] 44ef0000-44f6f000 r-xp 00000000 b3:12 13866      /usr/lib/libtvs-guide.so
[1-216.8105] 44f6f000-44f7f000 ---p 0007f000 b3:12 13866      /usr/lib/libtvs-guide.so
[1-216.8105] 44f7f000-44f81000 r--p 0007f000 b3:12 13866      /usr/lib/libtvs-guide.so
[1-216.8105] 44f81000-44f83000 rw-p 00081000 b3:12 13866      /usr/lib/libtvs-guide.so
[1-216.8105] 44f90000-44fac000 r-xp 00000000 b3:12 13546      /usr/lib/libtvs-ewbs.so
[1-216.8105] 44fac000-44fbb000 ---p 0001c000 b3:12 13546      /usr/lib/libtvs-ewbs.so
[1-216.8105] 44fbb000-44fbc000 r--p 0001b000 b3:12 13546      /usr/lib/libtvs-ewbs.so
[1-216.8105] 44fbc000-44fbd000 rw-p 0001c000 b3:12 13546      /usr/lib/libtvs-ewbs.so
[1-216.8105] 44fc0000-44fca000 r-xp 00000000 b3:12 11814      /usr/lib/libalarm.so.0.10.2
[1-216.8105] 44fca000-44fd9000 ---p 0000a000 b3:12 11814      /usr/lib/libalarm.so.0.10.2
[1-216.8106] 44fd9000-44fda000 r--p 00009000 b3:12 11814      /usr/lib/libalarm.so.0.10.2
[1-216.8106] 44fda000-44fdb000 rw-p 0000a000 b3:12 11814      /usr/lib/libalarm.so.0.10.2
[1-216.8106] 44fe0000-44fe2000 r-xp 00000000 b3:12 14789      /usr/lib/libappsvc.so.0.1.0
[1-216.8106] 44fe2000-44ff1000 ---p 00002000 b3:12 14789      /usr/lib/libappsvc.so.0.1.0
[1-216.8106] 44ff1000-44ff2000 r--p 00001000 b3:12 14789      /usr/lib/libappsvc.so.0.1.0
[1-216.8106] 44ff2000-44ff3000 rw-p 00002000 b3:12 14789      /usr/lib/libappsvc.so.0.1.0
[1-216.8106] 45000000-45049000 r-xp 00000000 b3:12 16420      /usr/lib/libtvs-udm.so
[1-216.8106] 45049000-45058000 ---p 00049000 b3:12 16420      /usr/lib/libtvs-udm.so
[1-216.8106] 45058000-45059000 r--p 00048000 b3:12 16420      /usr/lib/libtvs-udm.so
[1-216.8106] 45059000-4505b000 rw-p 00049000 b3:12 16420      /usr/lib/libtvs-udm.so
[1-216.8106] 45060000-45063000 r-xp 00000000 b3:12 15426      /usr/lib/libcapi-hbbtv-tv.so.0.1
[1-216.8106] 45063000-45072000 ---p 00003000 b3:12 15426      /usr/lib/libcapi-hbbtv-tv.so.0.1
[1-216.8106] 45072000-45073000 r--p 00002000 b3:12 15426      /usr/lib/libcapi-hbbtv-tv.so.0.1
[1-216.8106] 45073000-45074000 rw-p 00003000 b3:12 15426      /usr/lib/libcapi-hbbtv-tv.so.0.1
[1-216.8106] 45074000-45075000 rw-p 00000000 00:00 0
[1-216.8106] 45080000-45248000 r-xp 00000000 b3:12 16404      /usr/lib/libicui18n.so.63.2
[1-216.8107] 45248000-45257000 ---p 001c8000 b3:12 16404      /usr/lib/libicui18n.so.63.2
[1-216.8107] 45257000-4525f000 r--p 001c7000 b3:12 16404      /usr/lib/libicui18n.so.63.2
[1-216.8107] 4525f000-45261000 rw-p 001cf000 b3:12 16404      /usr/lib/libicui18n.so.63.2
[1-216.8107] 45270000-4539b000 r-xp 00000000 b3:12 11529      /usr/lib/libicuuc.so.63.2
[1-216.8107] 4539b000-453aa000 ---p 0012b000 b3:12 11529      /usr/lib/libicuuc.so.63.2
[1-216.8107] 453aa000-453b4000 r--p 0012a000 b3:12 11529      /usr/lib/libicuuc.so.63.2
[1-216.8107] 453b4000-453b5000 rw-p 00134000 b3:12 11529      /usr/lib/libicuuc.so.63.2
[1-216.8107] 453b5000-453b9000 rw-p 00000000 00:00 0
[1-216.8107] 453c0000-453d3000 r-xp 00000000 b3:12 13530      /usr/lib/libsec-video-drm-helper.so.0.1.0
[1-216.8107] 453d3000-453e2000 ---p 00013000 b3:12 13530      /usr/lib/libsec-video-drm-helper.so.0.1.0
[1-216.8107] 453e2000-453e3000 r--p 00012000 b3:12 13530      /usr/lib/libsec-video-drm-helper.so.0.1.0
[1-216.8107] 453e3000-453e4000 rw-p 00013000 b3:12 13530      /usr/lib/libsec-video-drm-helper.so.0.1.0
[1-216.8107] 453f0000-453f8000 r-xp 00000000 b3:12 15919      /usr/lib/libsec-audio.so.0.1
[1-216.8107] 453f8000-45407000 ---p 00008000 b3:12 15919      /usr/lib/libsec-audio.so.0.1
[1-216.8107] 45407000-45408000 r--p 00007000 b3:12 15919      /usr/lib/libsec-audio.so.0.1
[1-216.8107] 45408000-45409000 rw-p 00008000 b3:12 15919      /usr/lib/libsec-audio.so.0.1
[1-216.8107] 45410000-45429000 r-xp 00000000 b3:12 16948      /usr/lib/libv4lconvert.so.0.0.0
[1-216.8108] 45429000-45438000 ---p 00019000 b3:12 16948      /usr/lib/libv4lconvert.so.0.0.0
[1-216.8108] 45438000-4543a000 r--p 00018000 b3:12 16948      /usr/lib/libv4lconvert.so.0.0.0
[1-216.8108] 4543a000-4543b000 rw-p 0001a000 b3:12 16948      /usr/lib/libv4lconvert.so.0.0.0
[1-216.8108] 4543b000-4548d000 rw-p 00000000 00:00 0
[1-216.8108] 45490000-45492000 r-xp 00000000 b3:12 15315      /usr/lib/libeeprom-map.so.0.1
[1-216.8108] 45492000-454a1000 ---p 00002000 b3:12 15315      /usr/lib/libeeprom-map.so.0.1
[1-216.8108] 454a1000-454a2000 r--p 00001000 b3:12 15315      /usr/lib/libeeprom-map.so.0.1
[1-216.8108] 454a2000-454a3000 rw-p 00002000 b3:12 15315      /usr/lib/libeeprom-map.so.0.1
[1-216.8108] 454b0000-454ec000 r-xp 00000000 b3:12 16376      /usr/lib/libtvs-av.so
[1-216.8108] 454ec000-454fc000 ---p 0003c000 b3:12 16376      /usr/lib/libtvs-av.so
[1-216.8108] 454fc000-454fd000 rw-p 0003c000 b3:12 16376      /usr/lib/libtvs-av.so
[1-216.8108] 454fd000-454fe000 rw-p 00000000 00:00 0
[1-216.8108] 45500000-45509000 r-xp 00000000 b3:12 11708      /usr/lib/libfbproxyserver.so.0.1.2
[1-216.8108] 45509000-45519000 ---p 00009000 b3:12 11708      /usr/lib/libfbproxyserver.so.0.1.2
[1-216.8108] 45519000-4551a000 r--p 00009000 b3:12 11708      /usr/lib/libfbproxyserver.so.0.1.2
[1-216.8108] 4551a000-4551b000 rw-p 0000a000 b3:12 11708      /usr/lib/libfbproxyserver.so.0.1.2
[1-216.8109] 4551b000-4551c000 rw-p 00000000 00:00 0
[1-216.8109] 45520000-45535000 r-xp 00000000 b3:12 15196      /usr/lib/libcapi-system-system-settings.so.0.0.6
[1-216.8109] 45535000-45544000 ---p 00015000 b3:12 15196      /usr/lib/libcapi-system-system-settings.so.0.0.6
[1-216.8109] 45544000-45545000 r--p 00014000 b3:12 15196      /usr/lib/libcapi-system-system-settings.so.0.0.6
[1-216.8109] 45545000-45549000 rw-p 00015000 b3:12 15196      /usr/lib/libcapi-system-system-settings.so.0.0.6
[1-216.8109] 45550000-4556d000 r-xp 00000000 b3:12 12050      /usr/lib/libtvsystem.so.0.1
[1-216.8109] 4556d000-4557c000 ---p 0001d000 b3:12 12050      /usr/lib/libtvsystem.so.0.1
[1-216.8109] 4557c000-4557d000 r--p 0001c000 b3:12 12050      /usr/lib/libtvsystem.so.0.1
[1-216.8109] 4557d000-4557e000 rw-p 0001d000 b3:12 12050      /usr/lib/libtvsystem.so.0.1
[1-216.8109] 45580000-45587000 r-xp 00000000 b3:12 16092      /usr/lib/libv4l2.so.0.0.0
[1-216.8109] 45587000-45596000 ---p 00007000 b3:12 16092      /usr/lib/libv4l2.so.0.0.0
[1-216.8109] 45596000-45597000 r--p 00006000 b3:12 16092      /usr/lib/libv4l2.so.0.0.0
[1-216.8109] 45597000-4559b000 rw-p 00007000 b3:12 16092      /usr/lib/libv4l2.so.0.0.0
[1-216.8109] 455b0000-455c4000 r-xp 00000000 b3:12 16380      /usr/lib/libmmfile_utils.so.0.0.0
[1-216.8109] 455c4000-455d3000 ---p 00014000 b3:12 16380      /usr/lib/libmmfile_utils.so.0.0.0
[1-216.8109] 455d3000-455d4000 r--p 00013000 b3:12 16380      /usr/lib/libmmfile_utils.so.0.0.0
[1-216.8110] 455d4000-455d5000 rw-p 00014000 b3:12 16380      /usr/lib/libmmfile_utils.so.0.0.0
[1-216.8110] 455e0000-45613000 r-xp 00000000 b3:12 11784      /usr/lib/libtvs-nrt.so
[1-216.8110] 45613000-45622000 ---p 00033000 b3:12 11784      /usr/lib/libtvs-nrt.so
[1-216.8110] 45622000-45623000 r--p 00032000 b3:12 11784      /usr/lib/libtvs-nrt.so
[1-216.8110] 45623000-45625000 rw-p 00033000 b3:12 11784      /usr/lib/libtvs-nrt.so
[1-216.8110] 45630000-45655000 r-xp 00000000 b3:12 16399      /usr/lib/libtvs-core.so.0.1
[1-216.8110] 45655000-45665000 ---p 00025000 b3:12 16399      /usr/lib/libtvs-core.so.0.1
[1-216.8110] 45665000-45666000 r--p 00025000 b3:12 16399      /usr    /usr/lib/libglib-2.0.so.0.5200.2
[0-225.3607] 431b7000-431c6000 ---p 000f7000 b3:12 15321      /usr/lib/libglib-2.0.so.0.5200.2
[0-225.3607] 431c6000-431c7000 r--p 000f6000 b3:12 15321      /usr/lib/libglib-2.0.so.0.5200.2
[0-225.3607] 431c7000-431c8000 rw-p 000f7000 b3:12 15321      /usr/lib/libglib-2.0.so.0.5200.2
[0-225.3607] 431d0000-4321f000 r-xp 00000000 b3:12 13870      /usr/lib/libpcre.so.1.2.11
[0-225.3607] 4321f000-4322e000 ---p 0004f000 b3:12 13870      /usr/lib/libpcre.so.1.2.11
[0-225.3607] 4322e000-4322f000 r--p 0004e000 b3:12 13870      /usr/lib/libpcre.so.1.2.11
[0-225.3607] 4322f000-43230000 rw-p 0004f000 b3:12 13870      /usr/lib/libpcre.so.1.2.11
[0-225.3607] 43240000-43285000 r-xp 00000000 b3:12 11617      /usr/lib/libgobject-2.0.so.0.5200.2
[0-225.3607] 43285000-43294000 ---p 00045000 b3:12 11617      /usr/lib/libgobject-2.0.so.0.5200.2
[0-225.3607] 43294000-43295000 r--p 00044000 b3:12 11617      /usr/lib/libgobject-2.0.so.0.5200.2
[0-225.3608] 43295000-43296000 rw-p 00045000 b3:12 11617      /usr/lib/libgobject-2.0.so.0.5200.2
[0-225.3608] 432a0000-432b2000 r-xp 00000000 b3:12 16583      /usr/lib/libresolv-2.24.so
[0-225.3608] 432b2000-432c1000 ---p 00012000 b3:12 16583      /usr/lib/libresolv-2.24.so
[0-225.3608] 432c1000-432c2000 r--p 00011000 b3:12 16583      /usr/lib/libresolv-2.24.so
[0-225.3608] 432c2000-432c3000 rw-p 00012000 b3:12 16583      /usr/lib/libresolv-2.24.so
[0-225.3608] 432c3000-432c5000 rw-p 00000000 00:00 0
[0-225.3608] 432d0000-432df000 r-xp 00000000 b3:12 16219      /usr/lib/libz.so.1.2.11
[0-225.3608] 432df000-432ef000 ---p 0000f000 b3:12 16219      /usr/lib/libz.so.1.2.11
[0-225.3608] 432ef000-432f0000 r--p 0000f000 b3:12 16219      /usr/lib/libz.so.1.2.11
[0-225.3608] 432f0000-432f1000 rw-p 00010000 b3:12 16219      /usr/lib/libz.so.1.2.11
[0-225.3608] 43300000-4330c000 r-xp 00000000 b3:12 12033      /usr/lib/libbuxton2.so.1.1
[0-225.3608] 4330c000-4331b000 ---p 0000c000 b3:12 12033      /usr/lib/libbuxton2.so.1.1
[0-225.3608] 4331b000-4331c000 r--p 0000b000 b3:12 12033      /usr/lib/libbuxton2.so.1.1
[0-225.3608] 4331c000-4331d000 rw-p 0000c000 b3:12 12033      /usr/lib/libbuxton2.so.1.1
[0-225.3608] 43320000-43325000 r-xp 00000000 b3:12 15155      /usr/lib/libffi.so.6.0.2
[0-225.3608] 43325000-43334000 ---p 00005000 b3:12 15155      /usr/lib/libffi.so.6.0.2
[0-225.3608] 43334000-43335000 r--p 00004000 b3:12 15155      /usr/lib/libffi.so.6.0.2
[0-225.3609] 43335000-43336000 rw-p 00005000 b3:12 15155      /usr/lib/libffi.so.6.0.2
[0-225.3609] 43340000-43342000 r-xp 00000000 b3:12 16916      /usr/lib/libgmodule-2.0.so.0.5200.2
[0-225.3609] 43342000-43352000 ---p 00002000 b3:12 16916      /usr/lib/libgmodule-2.0.so.0.5200.2
[0-225.3609] 43352000-43353000 r--p 00002000 b3:12 16916      /usr/lib/libgmodule-2.0.so.0.5200.2
[0-225.3609] 43353000-43354000 rw-p 00003000 b3:12 16916      /usr/lib/libgmodule-2.0.so.0.5200.2
[0-225.3609] 43360000-43365000 r-xp 00000000 b3:12 12010      /usr/lib/libtzplatform-config-2.0.so.2.0.0
[0-225.3609] 43365000-43374000 ---p 00005000 b3:12 12010      /usr/lib/libtzplatform-config-2.0.so.2.0.0
[0-225.3609] 43374000-43375000 r--p 00004000 b3:12 12010      /usr/lib/libtzplatform-config-2.0.so.2.0.0
[0-225.3609] 43375000-43376000 rw-p 00005000 b3:12 12010      /usr/lib/libtzplatform-config-2.0.so.2.0.0
[0-225.3609] 43376000-4337b000 rw-p 00000000 00:00 0
[0-225.3609] 43380000-43386000 r-xp 00000000 b3:12 11608      /usr/lib/libvconf.so.0.3.1
[0-225.3609] 43386000-43395000 ---p 00006000 b3:12 11608      /usr/lib/libvconf.so.0.3.1
[0-225.3609] 43395000-43396000 r--p 00005000 b3:12 11608      /usr/lib/libvconf.so.0.3.1
[0-225.3609] 43396000-43397000 rw-p 00006000 b3:12 11608      /usr/lib/libvconf.so.0.3.1
[0-225.3609] 433a0000-433df000 r-xp 00000000 b3:12 11604      /usr/lib/libfactory-interface-DVB.so
[0-225.3609] 433df000-433ef000 ---p 0003f000 b3:12 11604      /usr/lib/libfactory-interface-DVB.so
[0-225.3609] 433ef000-433f1000 r--p 0003f000 b3:12 11604      /usr/lib/libfactory-interface-DVB.so
[0-225.3610] 433f1000-433f3000 rw-p 00041000 b3:12 11604      /usr/lib/libfactory-interface-DVB.so
[0-225.3610] 43400000-43401000 r-xp 00000000 b3:12 11304      /usr/lib/liblwipc.so
[0-225.3610] 43401000-43410000 ---p 00001000 b3:12 11304      /usr/lib/liblwipc.so
[0-225.3610] 43410000-43411000 r--p 00000000 b3:12 11304      /usr/lib/liblwipc.so
[0-225.3610] 43411000-43412000 rw-p 00001000 b3:12 11304      /usr/lib/liblwipc.so
[0-225.3610] 43420000-43425000 r-xp 00000000 b3:12 14730      /usr/lib/libopen-debugmenu_rel.so
[0-225.3610] 43425000-43434000 ---p 00005000 b3:12 14730      /usr/lib/libopen-debugmenu_rel.so
[0-225.3610] 43434000-43435000 r--p 00004000 b3:12 14730      /usr/lib/libopen-debugmenu_rel.so
[0-225.3610] 43435000-43436000 rw-p 00005000 b3:12 14730      /usr/lib/libopen-debugmenu_rel.so
[0-225.3610] 43440000-43459000 r-xp 00000000 b3:12 11655      /usr/lib/liblzma.so.5.2.4
[0-225.3610] 43459000-43468000 ---p 00019000 b3:12 11655      /usr/lib/liblzma.so.5.2.4
[0-225.3610] 43468000-43469000 r--p 00018000 b3:12 11655      /usr/lib/liblzma.so.5.2.4
[0-225.3610] 43469000-4346a000 rw-p 00019000 b3:12 11655      /usr/lib/liblzma.so.5.2.4
[0-225.3610] 43470000-43475000 r-xp 00000000 b3:12 15161      /usr/lib/libcapi-system-info.so.0.2.1
[0-225.3610] 43475000-43484000 ---p 00005000 b3:12 15161      /usr/lib/libcapi-system-info.so.0.2.1
[0-225.3610] 43484000-43485000 r--p 00004000 b3:12 15161      /usr/lib/libcapi-system-info.so.0.2.1
[0-225.3610] 43485000-43486000 rw-p 00005000 b3:12 15161      /usr/lib/libcapi-system-info.so.0.2.1
[0-225.3611] 43490000-43493000 r-xp 00000000 b3:12 11867      /usr/lib/libfconfig.so
[0-225.3611] 43493000-434a2000 ---p 00003000 b3:12 11867      /usr/lib/libfconfig.so
[0-225.3611] 434a2000-434a3000 r--p 00002000 b3:12 11867      /usr/lib/libfconfig.so
[0-225.3611] 434a3000-434a4000 rw-p 00003000 b3:12 11867      /usr/lib/libfconfig.so
[0-225.3611] 434b0000-43506000 r-xp 00000000 b3:12 11119      /usr/lib/libsystemd.so.0.16.0
[0-225.3611] 43506000-43515000 ---p 00056000 b3:12 11119      /usr/lib/libsystemd.so.0.16.0
[0-225.3611] 43515000-43517000 r--p 00055000 b3:12 11119      /usr/lib/libsystemd.so.0.16.0
[0-225.3611] 43517000-43518000 rw-p 00057000 b3:12 11119      /usr/lib/libsystemd.so.0.16.0
[0-225.3611] 43520000-4356d000 r-xp 00000000 b3:12 16685      /usr/lib/libdbus-1.so.3.14.6
[0-225.3611] 4356d000-4357c000 ---p 0004d000 b3:12 16685      /usr/lib/libdbus-1.so.3.14.6
[0-225.3611] 4357c000-4357d000 r--p 0004c000 b3:12 16685      /usr/lib/libdbus-1.so.3.14.6
[0-225.3611] 4357d000-4357e000 rw-p 0004d000 b3:12 16685      /usr/lib/libdbus-1.so.3.14.6
[0-225.3611] 43580000-435ba000 r-xp 00000000 b3:12 12421      /usr/lib/libmount.so.1.1.0
[0-225.3611] 435ba000-435ca000 ---p 0003a000 b3:12 12421      /usr/lib/libmount.so.1.1.0
[0-225.3611] 435ca000-435cb000 r--p 0003a000 b3:12 12421      /usr/lib/libmount.so.1.1.0
[0-225.3611] 435cb000-435cc000 rw-p 0003b000 b3:12 12421      /usr/lib/libmount.so.1.1.0
[0-225.3611] 435cc000-435cf000 rw-p 00000000 00:00 0
[0-225.3612] 435e0000-4360c000 r-xp 00000000 b3:12 15306      /usr/lib/libblkid.so.1.1.0
[0-225.3612] 4360c000-4361b000 ---p 0002c000 b3:12 15306      /usr/lib/libblkid.so.1.1.0
[0-225.3612] 4361b000-4361e000 r--p 0002b000 b3:12 15306      /usr/lib/libblkid.so.1.1.0
[0-225.3612] 4361e000-4361f000 rw-p 0002e000 b3:12 15306      /usr/lib/libblkid.so.1.1.0
[0-225.3612] 4361f000-43620000 rw-p 00000000 00:00 0
[0-225.3612] 43630000-43633000 r-xp 00000000 b3:12 12251      /usr/lib/libiniparser.so.0
[0-225.3612] 43633000-43642000 ---p 00003000 b3:12 12251      /usr/lib/libiniparser.so.0
[0-225.3612] 43642000-43643000 r--p 00002000 b3:12 12251      /usr/lib/libiniparser.so.0
[0-225.3612] 43643000-43644000 rw-p 00003000 b3:12 12251      /usr/lib/libiniparser.so.0
[0-225.3612] 43650000-43655000 r-xp 00000000 b3:12 16131      /usr/lib/libsmack.so.1.3.1
[0-225.3612] 43655000-43664000 ---p 00005000 b3:12 16131      /usr/lib/libsmack.so.1.3.1
[0-225.3612] 43664000-43665[0-225.3647] 473ba000-473c9000 ---p 0004a000 b3:12 13490      /usr/lib/libgstbase-1.0.so.0.1202.0
[0-225.3647] 473c9000-473ca000 r--p 00049000 b3:12 13490      /usr/lib/libgstbase-1.0.so.0.1202.0
[0-225.3647] 473ca000-473cb000 rw-p 0004a000 b3:12 13490      /usr/lib/libgstbase-1.0.so.0.1202.0
[0-225.3647] 47700000-47706000 r-xp 00000000 b3:12 11987      /usr/lib/libtv-resource-manager.so.1.43
[0-225.3647] 47706000-47715000 ---p 00006000 b3:12 11987      /usr/lib/libtv-resource-manager.so.1.43
[0-225.3647] 47715000-47716000 r--p 00005000 b3:12 11987      /usr/lib/libtv-resource-manager.so.1.43
[0-225.3647] 47716000-47717000 rw-p 00006000 b3:12 11987      /usr/lib/libtv-resource-manager.so.1.43
[0-225.3647] 47717000-47718000 rw-p 00000000 00:00 0
[0-225.3647] b19ff000-b1a00000 ---p 00000000 00:00 0
[0-225.3647] b1a00000-b1bff000 rw-p 00000000 00:00 0          [tstack: TCAlarm:tvs-dae: 3882]
[0-225.3647] b1bff000-b1c00000 ---p 00000000 00:00 0
[0-225.3647] b1c00000-b1dff000 rw-p 00000000 00:00 0
[0-225.3647] b1dff000-b3100000 rw-p 00000000 00:00 0
[0-225.3647] b3100000-b4100000 r--s 00000000 00:05 65653      /kdbus-conn:libdbus-kdbus (deleted)
[0-225.3647] b4100000-b4101000 ---p 00000000 00:00 0
[0-225.3647] b4101000-b4300000 rw-p 00000000 00:00 0
[0-225.3647] b4300000-b43d6000 rw-p 00000000 00:00 0
[0-225.3647] b43d6000-b4400000 ---p 00000000 00:00 0
[0-225.3648] b4400000-b4460000 rw-p 00000000 00:00 0
[0-225.3648] b4460000-b4500000 ---p 00000000 00:00 0
[0-225.3648] b4500000-b4521000 rw-p 00000000 00:00 0
[0-225.3648] b4521000-b4600000 ---p 00000000 00:00 0
[0-225.3648] b4600000-b46fb000 rw-p 00000000 00:00 0
[0-225.3648] b46fb000-b4700000 ---p 00000000 00:00 0
[0-225.3648] b4700000-b4701000 ---p 00000000 00:00 0
[0-225.3648] b4701000-b4900000 rw-p 00000000 00:00 0          [tstack: tvs-daemon: 3876]
[0-225.3648] b4900000-b4901000 ---p 00000000 00:00 0
[0-225.3648] b4901000-b4b00000 rw-p 00000000 00:00 0          [tstack: TCSystemTimeMan: 3881]
[0-225.3648] b4b00000-b4b01000 ---p 00000000 00:00 0
[0-225.3648] b4b01000-b4d00000 rw-p 00000000 00:00 0          [tstack: TCScanManager: 3880]
[0-225.3648] b4d00000-b5d00000 r--s 00000000 00:05 65649      /kdbus-conn:gdbus-kdbus (deleted)
[0-225.3648] b5d00000-b5d21000 rw-p 00000000 00:00 0
[0-225.3648] b5d21000-b5e00000 ---p 00000000 00:00 0
[0-225.3648] b5e41000-b5e46000 r-xp 00000000 b3:12 16939      /usr/lib/libpower-control-impl-sec.so.0.1
[0-225.3648] b5e46000-b5e56000 ---p 00005000 b3:12 16939      /usr/lib/libpower-control-impl-sec.so.0.1
[0-225.3648] b5e56000-b5e57000 r--p 00005000 b3:12 16939      /usr/lib/libpower-control-impl-sec.so.0.1
[0-225.3648] b5e57000-b5e58000 rw-p 00006000 b3:12 16939      /usr/lib/libpower-control-impl-sec.so.0.1
[0-225.3649] b5e58000-b5e65000 r-xp 00000000 b3:12 16769      /usr/lib/libnss_securitymanager.so.2.0.0
[0-225.3649] b5e65000-b5e74000 ---p 0000d000 b3:12 16769      /usr/lib/libnss_securitymanager.so.2.0.0
[0-225.3649] b5e74000-b5e75000 r--p 0000c000 b3:12 16769      /usr/lib/libnss_securitymanager.so.2.0.0
[0-225.3649] b5e75000-b5e76000 rw-p 0000d000 b3:12 16769      /usr/lib/libnss_securitymanager.so.2.0.0
[0-225.3649] b5e88000-b5e8a000 r-xp 00000000 b3:12 11313      /usr/lib/libnvram-impl-sec.so.0.1
[0-225.3649] b5e8a000-b5e99000 ---p 00002000 b3:12 11313      /usr/lib/libnvram-impl-sec.so.0.1
[0-225.3649] b5e99000-b5e9a000 r--p 00001000 b3:12 11313      /usr/lib/libnvram-impl-sec.so.0.1
[0-225.3649] b5e9a000-b5e9b000 rw-p 00002000 b3:12 11313      /usr/lib/libnvram-impl-sec.so.0.1
[0-225.3649] b5e9b000-b5e9c000 ---p 00000000 00:00 0
[0-225.3649] b5e9c000-b609b000 rw-p 00000000 00:00 0          [tstack: gkdbus: 3871]
[0-225.3649] b609b000-b609c000 ---p 00000000 00:00 0
[0-225.3649] b609c000-b629b000 rw-p 00000000 00:00 0          [tstack: gmain: 3870]
[0-225.3649] b629b000-b629c000 ---p 00000000 00:00 0
[0-225.3649] b629c000-b649b000 rw-p 00000000 00:00 0          [tstack: WatchdogNotifie: 3869]
[0-225.3649] b649b000-b649c000 ---p 00000000 00:00 0
[0-225.3649] b649c000-b669b000 rw-p 00000000 00:00 0          [tstack: tvs-daemon: 3868]
[0-225.3649] b669b000-b66ac000 r-xp 00000000 b3:12 16098      /usr/lib/libsystem-info-external-plugin.so
[0-225.3650] b66ac000-b66bc000 ---p 00011000 b3:12 16098      /usr/lib/libsystem-info-external-plugin.so
[0-225.3650] b66bc000-b66bd000 r--p 00011000 b3:12 16098      /usr/lib/libsystem-info-external-plugin.so
[0-225.3650] b66bd000-b66c1000 rw-p 00012000 b3:12 16098      /usr/lib/libsystem-info-external-plugin.so
[0-225.3650] b66c1000-b66cb000 r-xp 00000000 b3:12 11418      /usr/lib/libnss_files-2.24.so
[0-225.3650] b66cb000-b66da000 ---p 0000a000 b3:12 11418      /usr/lib/libnss_files-2.24.so
[0-225.3650] b66da000-b66db000 r--p 00009000 b3:12 11418      /usr/lib/libnss_files-2.24.so
[0-225.3650] b66db000-b66dc000 rw-p 0000a000 b3:12 11418      /usr/lib/libnss_files-2.24.so
[0-225.3650] b66dc000-b66e7000 r-xp 00000000 b3:12 11165      /usr/lib/libnss_nis-2.24.so
[0-225.3650] b66e7000-b66f6000 ---p 0000b000 b3:12 11165      /usr/lib/libnss_nis-2.24.so
[0-225.3650] b66f6000-b66f7000 r--p 0000a000 b3:12 11165      /usr/lib/libnss_nis-2.24.so
[0-225.3650] b66f7000-b66f8000 rw-p 0000b000 b3:12 11165      /usr/lib/libnss_nis-2.24.so
[0-225.3650] b66f8000-b670a000 r-xp 00000000 b3:12 11930      /usr/lib/libnsl-2.24.so
[0-225.3650] b670a000-b6719000 ---p 00012000 b3:12 11930      /usr/lib/libnsl-2.24.so
[0-225.3650] b6719000-b671a000 r--p 00011000 b3:12 11930      /usr/lib/libnsl-2.24.so
[0-225.3650] b671a000-b671b000 rw-p 00012000 b3:12 11930      /usr/lib/libnsl-2.24.so
[0-225.3650] b671b000-b671d000 rw-p 00000000 00:00 0
[0-225.3650] b6725000-b6742000 r--p 00000000 b3:12 3340       /usr/share/dbus-1/system.conf.serialized
[0-225.3651] b6742000-b6744000 rw-p 00000000 00:00 0
[0-225.3651] b6744000-b6746000 rw-p 00000000 00:00 0
[0-225.3651] b6746000-b6748000 rw-p 00000000 00:00 0
[0-225.3651] b6748000-b674a000 rw-p 00000000 00:00 0
[0-225.3651] b674a000-b674c000 rw-p 00000000 00:00 0
[0-225.3651] b674c000-b674e000 rw-p 00000000 00:00 0
[0-225.3651] b674e000-b6750000 rw-p 00000000 00:00 0
[0-225.3651] b6750000-b6752000 rw-p 00000000 00:00 0
[0-225.3651] b6752000-b6754000 rw-p 00000000 00:00 0
[0-225.3651] b6754000-b6756000 rw-p 00000000 00:00 0
[0-225.3651] b6756000-b6758000 rw-p 00000000 00:00 0
[0-225.3651] b6758000-b675a000 rw-p 00000000 00:00 0
[0-225.3651] b675a000-b675c000 rw-p 00000000 00:00 0
[0-225.3651] b675c000-b675e000 rw-p 00000000 00:00 0
[0-225.3651] b675e000-b6760000 rw-p 00000000 00:00 0
[0-225.3651] b6760000-b6762000 rw-p 00000000 00:00 0
[0-225.3651] b6762000-b6764000 rw-p 00000000 00:00 0
[0-225.3651] b6764000-b6766000 rw-p 00000000 00:00 0
[0-225.3651] b6766000-b6768000 rw-p 00000000 00:00 0
[0-225.3651] b6768000-b676a000 rw-p 00000000 00:00 0
[0-225.3651] b676a000-b676c000 rw-p 00000000 00:00 0
[0-225.3651] b676c000-b676e000 rw-p 00000000 00:00 0
[0-225.3652] b676e000-b6770000 rw-p 00000000 00:00 0
[0-225.3652] b6774000-b677a000 r--s 00000000 b3:16 1100       /factory_peq/factory-data/FactoryIndexFile_Part1.dat
[0-225.3652] b677a000-b6781000 r-xp 00000000 b3:12 16544      /usr/lib/libnss_compat-2.24.so
[0-225.3652] b6781000-b6790000 ---p 00007000 b3:12 16544      /usr/lib/libnss_compat-2.24.so
[0-225.3652] b6790000-b6791000 r--p 00006000 b3:12 16544      /usr/lib/libnss_compat-2.24.so
[0-225.3652] b6791000-b6792000 rw-p 00007000 b3:12 16544      /usr/lib/libnss_compat-2.24.so
[0-225.3652] b6792000-b6793000 r--p 00000000 00:00 0
[0-225.3652] b6795000-b6797000 rw-p 00000000 00:00 0
[0-225.3652] be649000b3:12 11221      /usr/lib/libtvs-pvr.so
[1-234.3609] 43fe4000-43ff4000 ---p 00064000 b3:12 11221      /usr/lib/libtvs-pvr.so
[1-234.3609] 43ff4000-43ff5000 r--p 00064000 b3:12 11221      /usr/lib/libtvs-pvr.so
[1-234.3609] 43ff5000-43ff7000 rw-p 00065000 b3:12 11221      /usr/lib/libtvs-pvr.so
[1-234.3609] 44000000-44061000 r-xp 00000000 b3:12 12282      /usr/lib/libsecurity-manager-commons.so.1.0.2
[1-234.3609] 44061000-44071000 ---p 00061000 b3:12 12282      /usr/lib/libsecurity-manager-commons.so.1.0.2
[1-234.3609] 44071000-44073000 rw-p 00061000 b3:12 12282      /usr/lib/libsecurity-manager-commons.so.1.0.2
[1-234.3609] 44080000-440d3000 r-xp 00000000 b3:12 16185      /usr/lib/libboost_serialization.so.1.58.0
[1-234.3609] 440d3000-440e3000 ---p 00053000 b3:12 16185      /usr/lib/libboost_serialization.so.1.58.0
[1-234.3610] 440e3000-440e4000 r--p 00053000 b3:12 16185      /usr/lib/libboost_serialization.so.1.58.0
[1-234.3610] 440e4000-440e6000 rw-p 00054000 b3:12 16185      /usr/lib/libboost_serialization.so.1.58.0
[1-234.3610] 440f0000-44130000 r-xp 00000000 b3:12 11420      /usr/lib/libtvs-dbms.so
[1-234.3610] 44130000-4413f000 ---p 00040000 b3:12 11420      /usr/lib/libtvs-dbms.so
[1-234.3610] 4413f000-44140000 r--p 0003f000 b3:12 11420      /usr/lib/libtvs-dbms.so
[1-234.3610] 44140000-44142000 rw-p 00040000 b3:12 11420      /usr/lib/libtvs-dbms.so
[1-234.3610] 44150000-44158000 r-xp 00000000 b3:12 11258      /usr/lib/libcrypt-2.24.so
[1-234.3610] 44158000-44167000 ---p 00008000 b3:12 11258      /usr/lib/libcrypt-2.24.so
[1-234.3610] 44167000-44168000 r--p 00007000 b3:12 11258      /usr/lib/libcrypt-2.24.so
[1-234.3610] 44168000-44169000 rw-p 00008000 b3:12 11258      /usr/lib/libcrypt-2.24.so
[1-234.3610] 44169000-44190000 rw-p 00000000 00:00 0
[1-234.3610] 441a0000-441bf000 r-xp 00000000 b3:12 11836      /usr/lib/libboost_thread.so.1.58.0
[1-234.3610] 441bf000-441ce000 ---p 0001f000 b3:12 11836      /usr/lib/libboost_thread.so.1.58.0
[1-234.3610] 441ce000-441cf000 r--p 0001e000 b3:12 11836      /usr/lib/libboost_thread.so.1.58.0
[1-234.3610] 441cf000-441d0000 rw-p 0001f000 b3:12 11836      /usr/lib/libboost_thread.so.1.58.0
[1-234.3610] 441e0000-44238000 r-xp 00000000 b3:12 11766      /usr/lib/libtvs-tpms.so
[1-234.3610] 44238000-44248000 ---p 00058000 b3:12 11766      /usr/lib/libtvs-tpms.so
[1-234.3611] 44248000-44249000 r--p 00058000 b3:12 11766      /usr/lib/libtvs-tpms.so
[1-234.3611] 44249000-4424b000 rw-p 00059000 b3:12 11766      /usr/lib/libtvs-tpms.so
[1-234.3611] 44260000-4426b000 r-xp 00000000 b3:12 11802      /usr/lib/libprocps.so.7.1.0
[1-234.3611] 4426b000-4427b000 ---p 0000b000 b3:12 11802      /usr/lib/libprocps.so.7.1.0
[1-234.3611] 4427b000-4427c000 r--p 0000b000 b3:12 11802      /usr/lib/libprocps.so.7.1.0
[1-234.3611] 4427c000-4427d000 rw-p 0000c000 b3:12 11802      /usr/lib/libprocps.so.7.1.0
[1-234.3611] 4427d000-4428f000 rw-p 00000000 00:00 0
[1-234.3611] 442a0000-442b6000 r-xp 00000000 b3:12 16922      /usr/lib/libcapi-system-usbdevice.so
[1-234.3611] 442b6000-442c6000 ---p 00016000 b3:12 16922      /usr/lib/libcapi-system-usbdevice.so
[1-234.3611] 442c6000-442c9000 r--p 00016000 b3:12 16922      /usr/lib/libcapi-system-usbdevice.so
[1-234.3611] 442c9000-442ca000 rw-p 00019000 b3:12 16922      /usr/lib/libcapi-system-usbdevice.so
[1-234.3611] 442d0000-442e1000 r-xp 00000000 b3:12 16741      /usr/lib/libcynara-admin.so.0.14.24
[1-234.3611] 442e1000-442f0000 ---p 00011000 b3:12 16741      /usr/lib/libcynara-admin.so.0.14.24
[1-234.3611] 442f0000-442f1000 r--p 00010000 b3:12 16741      /usr/lib/libcynara-admin.so.0.14.24
[1-234.3611] 442f1000-442f2000 rw-p 00011000 b3:12 16741      /usr/lib/libcynara-admin.so.0.14.24
[1-234.3611] 44300000-44317000 r-xp 00000000 b3:12 11039      /usr/lib/libcynara-storage.so.0.14.24
[1-234.3611] 44317000-44326000 ---p 00017000 b3:12 11039      /usr/lib/libcynara-storage.so.0.14.24
[1-234.3612] 44326000-44327000 r--p 00016000 b3:12 11039      /usr/lib/libcynara-storage.so.0.14.24
[1-234.3612] 44327000-44328000 rw-p 00017000 b3:12 11039      /usr/lib/libcynara-storage.so.0.14.24
[1-234.3612] 44330000-4434c000 r-xp 00000000 b3:12 11921      /usr/lib/libtv_recorder.so.0.0.0
[1-234.3612] 4434c000-4435b000 ---p 0001c000 b3:12 11921      /usr/lib/libtv_recorder.so.0.0.0
[1-234.3612] 4435b000-4435c000 r--p 0001b000 b3:12 11921      /usr/lib/libtv_recorder.so.0.0.0
[1-234.3612] 4435c000-4435d000 rw-p 0001c000 b3:12 11921      /usr/lib/libtv_recorder.so.0.0.0
[1-234.3612] 44360000-44379000 r-xp 00000000 b3:12 11871      /usr/lib/libsecurity-manager-client.so.3.0.0
[1-234.3612] 44379000-44388000 ---p 00019000 b3:12 11871      /usr/lib/libsecurity-manager-client.so.3.0.0
[1-234.3612] 44388000-44389000 r--p 00018000 b3:12 11871      /usr/lib/libsecurity-manager-client.so.3.0.0
[1-234.3612] 44389000-4438a000 rw-p 00019000 b3:12 11871      /usr/lib/libsecurity-manager-client.so.3.0.0
[1-234.3612] 44390000-4439e000 r-xp 00000000 b3:12 16454      /usr/lib/libsecurity-privilege-manager.so.1.1.6
[1-234.3612] 4439e000-443ad000 ---p 0000e000 b3:12 16454      /usr/lib/libsecurity-privilege-manager.so.1.1.6
[1-234.3612] 443ad000-443ae000 r--p 0000d000 b3:12 16454      /usr/lib/libsecurity-privilege-manager.so.1.1.6
[1-234.3612] 443ae000-443af000 rw-p 0000e000 b3:12 16454      /usr/lib/libsecurity-privilege-manager.so.1.1.6
[1-234.3612] 443c0000-443cb000 r-xp 00000000 b3:12 16579      /usr/lib/libcynara-client-async.so.0.14.24
[1-234.3612] 443cb000-443da000 ---p 0000b000 b3:12 16579      /usr/lib/libcynara-client-async.so.0.14.24
[1-234.3613] 443da000-443db000 r--p 0000a000 b3:12 16579      /usr/lib/libcynara-client-async.so.0.14.24
[1-234.3613] 443db000-443dc000 rw-p 0000b000 b3:12 16579      /usr/lib/libcynara-client-async.so.0.14.24
[1-234.3613] 443e0000-443e9000 r-xp 00000000 b3:12 16143      /usr/lib/libwayland-client.so.0.3.0
[1-234.3613] 443e9000-443f9000 ---p 00009000 b3:12 16143      /usr/lib/libwayland-client.so.0.3.0
[1-234.3613] 443f9000-443fa000 r--p 00009000 b3:12 16143      /usr/lib/libwayland-client.so.0.3.0
[1-234.3613] 443fa000-443fb000 rw-p 0000a000 b3:12 16143      /usr/lib/libwayland-client.so.0.3.0
[1-234.3613] 44400000-44471000 r-xp 00000000 b3:12 15185      /usr/lib/libtvs-util.so
[1-234.3613] 44471000-44480000 ---p 00071000 b3:12 15185      /usr/lib/libtvs-util.so
[1-234.3613] 44480000-44481000 r--p 00070000 b3:12 15185      /usr/lib/libtvs-util.so
[1-234.3613] 44481000-44484000 rw-p 00071000 b3:12 15185      /usr/lib/libtvs-util.so
[1-234.3613] 44490000-444cf000 r-xp 00000000 b3:12 16091      /usr/lib/libtvs-ht-api.so
[1-234.3613] 444cf000-444de000 ---p 0003f000 b3:12 16091      /usr/lib/libtvs-ht-api.so
[1-234.3613] 444de000-444df000 r--p 0003e000 b3:12 16091      /usr/lib/libtvs-ht-api.so
[1-234.3613] 444df000-444e1000 rw-p 0003f000 b3:12 16091      /usr/lib/libtvs-ht-api.so
[1-234.3613] 444f0000-44537000 r-xp 00000000 b3:12 15519      /usr/lib/libtvs-ht.so
[1-234.3613] 44537000-44546000 ---p 00047000 b3:12 15519      /usr/lib/libtvs-ht.so
[1-234.3613] 44546000-44548000 r--p 00046000 b3:12 15519      /usr/lib/libtvs-ht.so
[1-234.3614] 44548000-44549000 rw-p 00048000 b3:12 15519      /usr/lib/libtvs-ht.so
[1-234.3614] 44550000-44607000 r-xp 00000000 b3:12 12447      /usr/lib/libtvs-iss.so
[1-234.3614] 44607000-44616000 ---p 000b7000 b3:12 12447      /usr/lib/libtvs-iss.so
[1-234.3614] 44616000-44619000 r--p 000b6000 b3:12 12447      /usr/lib/libtvs-iss.so
[1-234.3614] 44619000-4461b000 rw-p 000b9000 b3:12 12447      /usr/lib/libtvs-iss.so
[1-234.3614] 44620000-44633000 r-xp 00000000 b3:12 17097      /usr/lib/libboost_iostreams.so.1.58.0
[1-234.3614] 44633000-44642000 ---p 00013000 b3:12 17097      /usr/lib/libboost_iostreams.so.1.58.0
[1-234.3614] 44642000-44643000 r--p 00012000 b3:12 17097      /usr/lib/libboost_iostreams.so.1.58.0
[1-234.3614] 44643000-44644000 rw-p 00013000 b3:12 17097      /usr/lib/libboost_iostreams.so.1.58.0
[1-234.3614] 44650000-44693000 r-xp 00000000 b3:12 11040      /usr/lib/libtvs-ics.so
[1-234.3614] 44693000-446a2000 ---p 00043000 b3:12 1kantsu2-1.5G-cma console=ttyS0,115200 rs232=0 earlyprintk maxcpus=4 no_console_suspend only_entry_model root=/dev/mmcblk0p18 KDUMP=16 SELP_ENABLE=20208724 _nvtca9-16m rootfstype=vdfs ro init=/sbin/init mem=808M@32M mem=56M@968M mem=256M@2048M vmalloc=300M rootwait quiet bdinfo=00000091 model=4kbtin   pba_none [1-243.2818]
[1-243.2818] Last Exception point
[1-243.2818] --------------------------------------------------------------------------------------
[1-243.2818] PC, LR MEMINFO
[1-243.2818] PC:43db2e8a, LR:43db2e8b
[1-243.2818] PC meminfo (0x43db328a to 0x43db328a)
[1-243.2818] 3280:
[1-243.2818] LR meminfo (0x43db268b to 0x43db328b)
[1-243.2818] 2680:                            2010f8cb 3f18f84a e8def7fb 4a374603 20014931
[1-243.2819] 26a0: 6058447a 60983248 f8c31d18 601ab00c 603b5864 a000f8c4 e8506063 33013f00
[1-243.2819] 26c0: 3fe2e8c0 d1f82a00 8f5bf3bf f7fb6878 4a2aed2a 4620492a 4479447a e92cf7fb
[1-243.2819] 26e0: 4618683b fdbcf039 f7fce779 f7fbe96c f8dbeb0a 46583000 4798685b ec62f7fc
[1-243.2819] 2700: 211c4604 f7fb4658 6878ed5c ece6f7fb 46304b1c f103447b f103011c 62390234
[1-243.2819] 2720: 637a3354 f03863bb 4640ff73 ff70f038 f7fc4620 4604ef18 eda0f7fc 4604e7e5
[1-243.2819] 2740: 4604e7e3 f0384630 e7eeff63 00074e60 00000b90 0007441a 0005622c 00000bb8
[1-243.2819] 2760: 000573a6 00000e20 00074390 00072c9c 00074342 00074324 0007299c 00075b28
[1-243.2819] 2780: 0003889f 0007427c e59f3014 e59f2014 e08f3003 e7932002 e3520000 012fff1e
[1-243.2819] 27a0: eafff3f3 00074c30 00000df8 48084b07 4a08447b 33034478 447a1a1b d9032b06
[1-243.2819] 27c0: 58d34b05 4718b103 bf004770 00075b04 00075b00 00074c0a 00000dc0 48094908
[1-243.2819] 27e0: 4b094479 1a094478 1089447b 71d1eb01 d0031049 589b4a05 4718b103 bf004770
[1-243.2819] 2800: 00075ad4 00075ad0 00074bdc 00000e04 4b0ab508 447b4a0a 781b447a 4b09b96b
[1-243.2820] 2820: b12358d3 447b4b08 f7fc6818 f7ffefec 4b06ffbd 447b2201 bd08701a 00075a9e
[1-243.2820] 2840: 00074bac 00000e10 000759da 00075a7e b5084807 68024478 447b4b06 e8bdb912
[1-243.2820] 2860: e7bb4008 589b4a04 d0f82b00 e7f64798 00072560 00074b6a 00000cf4 00000000
[1-243.2820] 2880: 1d03b480 af006840 fab01ac0 0940f080 f85d46bd 47707b04 41f0e92d f8d04606
[1-243.2820] 28a0: af008004 45a86885 4644bf18 6823d006 34304620 4798681b d1f842a5 8008f8c6
[1-243.2820] 28c0: 81f0e8bd 6842b480 6880af00 fab01a10 0940f080 f85d46bd 47707b04 6843b480
[1-243.2820] 28e0: 6083af00 f85d46bd 47707b04 6842b480 6880af00 fab01a10 0940f080 f85d46bd
[1-243.2820] 2900: 47707b04 2301b480 7303af00 f85d46bd 47707b04 4604b598 af006843 46186882
[1-243.2820] 2920: 689b681b b1084798 73232300 bf00bd98 4605b5f8 af004606 0f04f855 d00542a8
[1-243.2820] 2940: f7fb6804 4620eecc d1f942ac 60752300 60f360b5 bf00bdf8 4605b5f8 46064b08
[1-243.2820] 2960: 447baf00 60033308 0f04f855 d00542a8 f7fb6804 4620eeb4 d1f942ac bdf84630
[1-243.2820] 2980: 00072456 43f8e92d af004681 4f04f859 d012454c 4688460e f7fa200c 68a3ef5c
[1-243.2820] 29a0: 60834641 f7fa4605 68b3ef62 60b33301 8000f8d5 45a16824 e8bdd1ee bf0083f8
[1-243.2820] 29c0: 2104b598 af004604 ebfaf7fb bd984620 4605b5f8 46064b0a 447baf00 60033308
[1-243.2820] 29e0: 0f04f855 d00542a8 f7fb6804 4620ee78 d1f942ac 21144630 ebe2f7fb bdf84630
[1-243.2821] 2a00: 000723de 4604b598 4a0b4b0a 0120f100 6980447b 4288af00 f103589b 60230308
[1-243.2821] 2a20: f7fbd001 4620ee5c f7fb2130 4620ebca bf00bd98 000749b4 00000b50 4604b598
[1-243.2821] 2a40: 4a0f4b0e 013cf100 6b40447b 4288af00 f103589b 60230308 f7fbd001 6a61ee40
[1-243.2821] 2a60: 001cf104 f836f04b 1d2068e1 f848f04b 214c4620 eba4f7fb bd984620 0007497c
[1-243.2821] 2a80: 00000c00 4604b598 4a0f4b0e 013cf100 6b40447b 4288af00 f103589b 60230308
[1-243.2821] 2aa0: f7fbd001 6a61ee1c 001cf104 f812f04b 1d2068e1 f824f04b 214c4620 eb80f7fb
[1-243.2821] 2ac0: bd984620 00074934 00000c00 4604b598 4a0f4b0e 013cf100 6b40447b 4288af00
[1-243.2821] 2ae0: f103589b 60230308 f7fbd001 6a61edf8 001cf104 ffeef04a 1d2068e1 f800f04b
[1-243.2821] 2b00: 214c4620 eb5cf7fb bd984620 000748ec 00000c00 4604b598 4a0f4b0e 013cf100
[1-243.2821] 2b20: 6b40447b 4288af00 f103589b 60230308 f7fbd001 6a61edd4 001cf104 ffcaf04a
[1-243.2821] 2b40: 1d2068e1 ffdcf04a 214c4620 eb38f7fb bd984620 000748a4 00000c00 b083b590
[1-243.2821] 2b60: 693caf02 f7fa9400 3704efc6 bd9046bd f44fb580 4b047222 af004904 447b4804
[1-243.2821] 2b80: 44784479 edc8f7fb 0004dde2 0004e058 0004e082 47f0e92d 4b214606 4c21b084
[1-243.2821] 2ba0: af00447b f04f6900 4a1f0900 8004f853 9004f8c7 6803447a 4000f8d8 689c60fc
[1-243.2821] 2bc0: d1284294 0510f107 4608468a 9d08f845 f7fc4629 4604e896 46504629 0401f084
[1-243.2821] 2be0: 9008f8c7 eae0f7fb b2e06078 200cb150 ee30f7fa 6083687b f7fa1d31 68f3ee38
[1-243.2822] 2c00: 60f33301 f8d868fa 429a3000 3710d106 e8bd46bd 1d3a87f0 e7e747a0 eed2f7fb
[1-243.2822] 2c20: 00074824 00000b90 0003ed39 3458f8df 2458f8df e92d447b b0b943f0 af04589e
[1-243.2822] 2c40: f8c76833 f7fb30cc 2300ecea f7fb607b 4601e92c f1072200 f7fc0008 f7fbe84c
[1-243.2822] 2c60: 4604ec96 280068b8 81d3f000 ec74f7fc 1d3b4601 22004620 eab2f7fc f0002800
[1-243.2822] 2c80: efc08186 68b80010 0410f107 edc4613c 617c0b01 f0002800 214781bc ec9ef7fc
[1-243.2822] 2ca0: 695b6803 46034798 0824f107 801cf8c7 001cf107 0006e893 f047440a 2024f80f
[1-243.2822] 2cc0: 637b2300 edc6f7fa f10069fb 46050c10 c008f8c0 f0004543 6a7a818c 61026083
[1-243.2822] 2ce0: 46286a3b 46216b7a 230060eb 623b622a 3024f887 801cf8c7 edb8f7fa 69f869bb
[1-243.2822] 2d00: 61bb3301 d0014540 ece8f7fb 280068b8 817ff000 f7fc214d 6803ec62 4798695b
[1-243.2822] 2d20: f1074603 f8c70840 f1078038 e8930038 440a0006 ffd2f046 23002024 f7fa653b
[1-243.2822] 2d40: 6bbbed8a 0c10f100 f8c04605 4543c008 8157f000 60836c3a 6bfb6102 6d3a4628
[1-243.2822] 2d60: 60eb4621 622a2300 f88763fb f8c73040 f7fa8038 69bbed7c 33016bb8 454061bb
[1-243.2822] 2d80: f7fbd001 68b8ecac f0002800 214f8142 ec24f7fc 695b6803 46034798 085cf107
[1-243.2822] 2da0: 8054f8c7 0054f107 0006e893 f046440a 2024ff95 66fb2300 ed4cf7fa f1006d7b
[1-243.2823] 2dc0: 46050c10 c008f8c0 f0004543 6dfa80fa 61026083 46286dbb 46216efa 230060eb
[1-243.2823] 2de0: 65bb622a 305cf887 8054f8c7 ed3ef7fa 6d7869bb 61bb3301 d0014540 ec6ef7fb
[1-243.2823] 2e00: 280068b8 8105f000 f7fc214c 6803ebe8 4798695b f1074603 f8c70878 f1078070
[1-243.2823] 2e20: e8930070 440a0006 ff58f046 23002024 3088f8c7 ed0ef7fa f1006f3b 46050c10
[1-243.2823] 2e40: c008f8c0 f0004543 6fba80cc 61026083 46286f7b 2088f8d7 60eb4621 622a2300
[1-243.2823] 2e60: f887677b f8c73078 f7fa8070 69bbed00 33016f38 454061bb f7fbd001 68b8ec30
[1-243.2823] 2e80: f0002800 f7fb80c6 6803e8ee 4798695b f1074603 f8c70894 f107808c e893008c
[1-243.2823] 2ea0: 440a0006 ff1af046 23002024 30a4f8c7 ecd0f7fa 308cf8d7 0c10f100 f8c04605
[1-243.2823] 2ec0: 4543c008 8085f000 2094f8d7 61026083 3090f8d7 f8d74628 462120a4 230060eb
[1-243.2823] 2ee0: f8c7622a f8873090 f8c73094 f7fa808c 69bbecbe 008cf8d7 61bb3301 d0014540
[1-243.2823] 2f00: ebecf7fb 280068b8 8083f000 f7fc210d 6803e88a 4798691b 05a8f107 23004601
[1-243.2823] 2f20: 46224628 ec74f7fc 68784629 ecdcf7fc f7fab9a8 4a56ee76 0c01f04f 4b564955
[1-243.2823] 2f40: 4479447a 447b32c8 93029203 23033134 c004f8cd f44f9300 f7fb73a6 4628ec3e
[1-243.2823] 2f60: e9a6f7fb f04a4620 68f8fd03 f039b108 6878f977 6803b110 4798685b 20ccf8d7
[1-243.2823] 2f80: 429a6833 37d4d147 e8bd46bd f7fa83f0 4a42ee48 49422501 4b422403 4479447a
[1-243.2823] 2fa0: 447b32c8 93029203 95013134 133ff240 f7fb9400 68f8ec12 d0da2800 f950f039
[1-243.2824] 2fc0: 46c1e7d7 000fe8b9 61696128 61eb61aa 46c1e700 000fe8b9 61696128 61eb61aa
[1-243.2824] 2fe0: 46c1e776 000fe8b9 61696128 61eb61aa 46c1e72e 000fe8b9 61696128 61eb61aa
[1-243.2824] 3000: 46c1e66e 000fe8b9 61696128 61eb61aa f7ffe6a3 f7fbfdad 6d7becd6 45434605
[1-243.2824] 3020: 4618d002 eb5af7fb f04a4620 68f8fca1 f039b108 6878f915 6lib/libmmfile_utils.so.0.0.0
[1-243.2858] 455d3000-455d4000 r--p 00013000 b3:12 16380      /usr/lib/libmmfile_utils.so.0.0.0
[1-243.2858] 455d4000-455d5000 rw-p 00014000 b3:12 16380      /usr/lib/libmmfile_utils.so.0.0.0
[1-243.2858] 455e0000-45613000 r-xp 00000000 b3:12 11784      /usr/lib/libtvs-nrt.so
[1-243.2858] 45613000-45622000 ---p 00033000 b3:12 11784      /usr/lib/libtvs-nrt.so
[1-243.2858] 45622000-45623000 r--p 00032000 b3:12 11784      /usr/lib/libtvs-nrt.so
[1-243.2858] 45623000-45625000 rw-p 00033000 b3:12 11784      /usr/lib/libtvs-nrt.so
[1-243.2858] 45630000-45655000 r-xp 00000000 b3:12 16399      /usr/lib/libtvs-core.so.0.1
[1-243.2858] 45655000-45665000 ---p 00025000 b3:12 16399      /usr/lib/libtvs-core.so.0.1
[1-243.2858] 45665000-45666000 r--p 00025000 b3:12 16399      /usr/lib/libtvs-core.so.0.1
[1-243.2859] 45666000-45667000 rw-p 00026000 b3:12 16399      /usr/lib/libtvs-core.so.0.1
[1-243.2859] 45670000-45675000 r-xp 00000000 b3:12 15188      /usr/lib/libcapi-media-metadata-extractor.so
[1-243.2859] 45675000-45684000 ---p 00005000 b3:12 15188      /usr/lib/libcapi-media-metadata-extractor.so
[1-243.2859] 45684000-45685000 r--p 00004000 b3:12 15188      /usr/lib/libcapi-media-metadata-extractor.so
[1-243.2859] 45685000-45686000 rw-p 00005000 b3:12 15188      /usr/lib/libcapi-media-metadata-extractor.so
[1-243.2859] 45690000-4569d000 r-xp 00000000 b3:12 11915      /usr/lib/libpvr-parser.so
[1-243.2859] 4569d000-456ac000 ---p 0000d000 b3:12 11915      /usr/lib/libpvr-parser.so
[1-243.2859] 456ac000-456ad000 r--p 0000c000 b3:12 11915      /usr/lib/libpvr-parser.so
[1-243.2859] 456ad000-456ae000 rw-p 0000d000 b3:12 11915      /usr/lib/libpvr-parser.so
[1-243.2859] 456b0000-456b9000 r-xp 00000000 b3:12 15517      /usr/lib/libcapi-system-runtime-info.so.0.0.199+tvprd
[1-243.2859] 456b9000-456c8000 ---p 00009000 b3:12 15517      /usr/lib/libcapi-system-runtime-info.so.0.0.199+tvprd
[1-243.2859] 456c8000-456c9000 r--p 00008000 b3:12 15517      /usr/lib/libcapi-system-runtime-info.so.0.0.199+tvprd
[1-243.2859] 456c9000-456ca000 rw-p 00009000 b3:12 15517      /usr/lib/libcapi-system-runtime-info.so.0.0.199+tvprd
[1-243.2859] 456d0000-456e7000 r-xp 00000000 b3:12 16736      /usr/lib/libtvs-sospec.so
[1-243.2859] 456e7000-456f6000 ---p 00017000 b3:12 16736      /usr/lib/libtvs-sospec.so
[1-243.2859] 456f6000-456f7000 r--p 00016000 b3:12 16736      /usr/lib/libtvs-sospec.so
[1-243.2860] 456f7000-456f8000 rw-p 00017000 b3:12 16736      /usr/lib/libtvs-sospec.so
[1-243.2860] 456f8000-456f9000 rw-p 00000000 00:00 0
[1-243.2860] 45700000-45713000 r-xp 00000000 b3:12 15322      /usr/lib/libtvs-time.so
[1-243.2860] 45713000-45722000 ---p 00013000 b3:12 15322      /usr/lib/libtvs-time.so
[1-243.2860] 45722000-45723000 r--p 00012000 b3:12 15322      /usr/lib/libtvs-time.so
[1-243.2860] 45723000-45724000 rw-p 00013000 b3:12 15322      /usr/lib/libtvs-time.so
[1-243.2860] 45730000-45744000 r-xp 00000000 b3:12 15156      /usr/lib/libtvs-tvplus.so
[1-243.2860] 45744000-45753000 ---p 00014000 b3:12 15156      /usr/lib/libtvs-tvplus.so
[1-243.2860] 45753000-45754000 r--p 00013000 b3:12 15156      /usr/lib/libtvs-tvplus.so
[1-243.2860] 45754000-45755000 rw-p 00014000 b3:12 15156      /usr/lib/libtvs-tvplus.so
[1-243.2860] 45760000-4576b000 r-xp 00000000 b3:12 11637      /usr/lib/libtvs-config.so
[1-243.2860] 4576b000-4577a000 ---p 0000b000 b3:12 11637      /usr/lib/libtvs-config.so
[1-243.2860] 4577a000-4577b000 r--p 0000a000 b3:12 11637      /usr/lib/libtvs-config.so
[1-243.2860] 4577b000-4577c000 rw-p 0000b000 b3:12 11637      /usr/lib/libtvs-config.so
[1-243.2860] 45790000-45795000 r-xp 00000000 b3:12 16231      /usr/lib/libmmffile.so.0.0.0
[1-243.2860] 45795000-457a4000 ---p 00005000 b3:12 16231      /usr/lib/libmmffile.so.0.0.0
[1-243.2860] 457a4000-457a5000 r--p 00004000 b3:12 16231      /usr/lib/libmmffile.so.0.0.0
[1-243.2860] 457a5000-457a6000 rw-p 00005000 b3:12 16231      /usr/lib/libmmffile.so.0.0.0
[1-243.2861] 457b0000-457bc000 r-xp 00000000 b3:12 11527      /usr/lib/libtvs-ems.so
[1-243.2861] 457bc000-457cc000 ---p 0000c000 b3:12 11527      /usr/lib/libtvs-ems.so
[1-243.2861] 457cc000-457cd000 rw-p 0000c000 b3:12 11527      /usr/lib/libtvs-ems.so
[1-243.2861] 457d0000-457d3000 r-xp 00000000 b3:12 11677      /usr/lib/libtizen-extension-tv-client.so.0.0.0
[1-243.2861] 457d3000-457e2000 ---p 00003000 b3:12 11677      /usr/lib/libtizen-extension-tv-client.so.0.0.0
[1-243.2861] 457e2000-457e3000 r--p 00002000 b3:12 11677      /usr/lib/libtizen-extension-tv-client.so.0.0.0
[1-243.2861] 457e3000-457e4000 rw-p 00003000 b3:12 11677      /usr/lib/libtizen-extension-tv-client.so.0.0.0
[1-243.2861] 457f0000-45975000 r-xp 00000000 b3:12 16125      /usr/lib/libtvs-live.so
[1-243.2861] 45975000-45985000 ---p 00185000 b3:12 16125      /usr/lib/libtvs-live.so
[1-243.2861] 45985000-45989000 r--p 00185000 b3:12 16125      /usr/lib/libtvs-live.so
[1-243.2861] 45989000-4598d000 rw-p 00189000 b3:12 16125      /usr/lib/libtvs-live.so
[1-243.2861] 4598d000-4598e000 rw-p 00000000 00:00 0
[1-243.2861] 45990000-45a80000 r-xp 00000000 b3:12 11992      /usr/lib/libtvs-dsm.so
[1-243.2861] 45a80000-45a8f000 ---p 000f0000 b3:12 11992      /usr/lib/libtvs-dsm.so
[1-243.2861] 45a8f000-45a92000 r--p 000ef000 b3:12 11992      /usr/lib/libtvs-dsm.so
[1-243.2861] 45a92000-45a94000 rw-p 000f2000 b3:12 11992      /usr/lib/libtvs-dsm.so
[1-243.2861] 45a94000-45aa5000 rw-p 00000000 00:00 0
[1-243.2862] 45ab0000-45ab2000 r-xp 00000000 b3:12 11988      /usr/lib/libug_duck.so
[1-243.2862] 45ab2000-45ac1000 ---p 00002000 b3:12 11988      /usr/lib/libug_duck.so
[1-243.2862] 45ac1000-45ac2000 r--p 00001000 b3:12 11988      /usr/lib/libug_duck.so
[1-243.2862] 45ac2000-45ac3000 rw-p 00002000 b3:12 11988      /usr/lib/libug_duck.so
[1-243.2862] 45b50000-45c43000 r-xp 00000000 b3:12 14413      /usr/lib/libtvs-api.so
[1-243.2862] 45c43000-45c53000 ---p 000f3000 b3:12 14413      /usr/lib/libtvs-api.so
[1-243.2862] 45c53000-45c56000 r--p 000f3000 b3:12 14413      /usr/lib/libtvs-api.so
[1-243.2862] 45c56000-45c58000 rw-p 000f6000 b3:12 14413      /usr/lib/libtvs-api.so
[1-243.2862] 45c58000-45c5f000 rw-p 00000000 00:00 0
[1-243.2862] 45c70000-45cc0000 r-xp 00000000 b3:12 11714      /usr/lib/libtvs-api-ipc.so
[1-243.2862] 45cc0000-45ccf000 ---p 00050000 b3:12 11714      /usr/lib/libtvs-api-ipc.so
[1-243.2862] 45ccf000-45cd1000 r--p 0004f000 b3:12 11714      /usr/lib/libtvs-api-ipc.so
[1-243.2862] 45cd1000-45cd3000 rw-p 00051000 b3:12 11714      /usr/lib/libtvs-api-ipc.so
[1-243.2862] 45d20000-45d39000 r-xp 00000000 b3:12 12070      /usr/lib/libdbus-glib-1.so.2.2.2
[1-243.2862] 45d39000-45d48000 ---p 00019000 b3:12 12070      /usr/lib/libdbus-glib-1.so.2.2.2
[1-243.2862] 45d48000-45d49000 r--p 00018000 b3:12 12070      /usr/lib/libdbus-glib-1.so.2.2.2
[1-243.2862] 45d49000-45d4a000 rw-p 00019000 b3:12 12070      /usr/lib/libdbus-glib-1.so.2.2.2
[1-243.2862] 45de0000-45df9000 r-xp 00000000 b3:12 12267      /usr/lib/libep-iptv-service-api.so
[1-243.2863] 45df9000-45e08000 ---p 00019000 b3:12 12267      /usr/lib/libep-iptv-service-api.so
[1-243.2863] 45e08000-45e09000 r--p 00018000 b3:12 12267      /usr/lib/libep-iptv-service-api.so
[1-243.2863] 45e09000-45e0a000 rw-p 00019000 b3:12 12267      /usr/lib/libep-iptv-service-api.so
[1-243.2863] 45e90000-45f40000 r-xp 00000000 b3:12 15922      /usr/lib/libavoc.so
[1-243.2863] 45f40000-45f4f000 ---p 000b0000 b3:12 15922      /usr/lib/libavoc.so
[1-243.2863] 45f4f000-45f5f000 r--p 000af000 b3:12 15922      /usr/lib/libavoc.so
[1-243.2863] 45f5f000-45f60000 rw-p 000bf000 b3:12 15922      /usr/lib/libavoc.so
[1-243.2863] 45ff0000-46005000 r-xp 00000000 b3:12 12097      /usr/lib/libmicom.so.0.1
[1-243.2863] 46005000-46014000 ---p 00015000 b3:12 12097      /usr/lib/libmicom.so.0.1
[1-243.2863] 46014000-46015000 r--p 00014000 b3:12 12097      /usr/lib/libmicom.so.0.1
[1-243.2863] 46015000-46016000 rw-p 00015000 b3:12 12097      /usr/lib/libmicom.so.0.1
[1-243.2863] 46020000-4602c000 r-xp 00000000 b3:12 11641      /usr/lib00.2
[0-252.3221] 431d0000-4321f000 r-xp 00000000 b3:12 13870      /usr/lib/libpcre.so.1.2.11
[0-252.3221] 4321f000-4322e000 ---p 0004f000 b3:12 13870      /usr/lib/libpcre.so.1.2.11
[0-252.3221] 4322e000-4322f000 r--p 0004e000 b3:12 13870      /usr/lib/libpcre.so.1.2.11
[0-252.3221] 4322f000-43230000 rw-p 0004f000 b3:12 13870      /usr/lib/libpcre.so.1.2.11
[0-252.3221] 43240000-43285000 r-xp 00000000 b3:12 11617      /usr/lib/libgobject-2.0.so.0.5200.2
[0-252.3221] 43285000-43294000 ---p 00045000 b3:12 11617      /usr/lib/libgobject-2.0.so.0.5200.2
[0-252.3221] 43294000-43295000 r--p 00044000 b3:12 11617      /usr/lib/libgobject-2.0.so.0.5200.2
[0-252.3221] 43295000-43296000 rw-p 00045000 b3:12 11617      /usr/lib/libgobject-2.0.so.0.5200.2
[0-252.3221] 432a0000-432b2000 r-xp 00000000 b3:12 16583      /usr/lib/libresolv-2.24.so
[0-252.3221] 432b2000-432c1000 ---p 00012000 b3:12 16583      /usr/lib/libresolv-2.24.so
[0-252.3221] 432c1000-432c2000 r--p 00011000 b3:12 16583      /usr/lib/libresolv-2.24.so
[0-252.3222] 432c2000-432c3000 rw-p 00012000 b3:12 16583      /usr/lib/libresolv-2.24.so
[0-252.3222] 432c3000-432c5000 rw-p 00000000 00:00 0
[0-252.3222] 432d0000-432df000 r-xp 00000000 b3:12 16219      /usr/lib/libz.so.1.2.11
[0-252.3222] 432df000-432ef000 ---p 0000f000 b3:12 16219      /usr/lib/libz.so.1.2.11
[0-252.3222] 432ef000-432f0000 r--p 0000f000 b3:12 16219      /usr/lib/libz.so.1.2.11
[0-252.3222] 432f0000-432f1000 rw-p 00010000 b3:12 16219      /usr/lib/libz.so.1.2.11
[0-252.3222] 43300000-4330c000 r-xp 00000000 b3:12 12033      /usr/lib/libbuxton2.so.1.1
[0-252.3222] 4330c000-4331b000 ---p 0000c000 b3:12 12033      /usr/lib/libbuxton2.so.1.1
[0-252.3222] 4331b000-4331c000 r--p 0000b000 b3:12 12033      /usr/lib/libbuxton2.so.1.1
[0-252.3222] 4331c000-4331d000 rw-p 0000c000 b3:12 12033      /usr/lib/libbuxton2.so.1.1
[0-252.3222] 43320000-43325000 r-xp 00000000 b3:12 15155      /usr/lib/libffi.so.6.0.2
[0-252.3222] 43325000-43334000 ---p 00005000 b3:12 15155      /usr/lib/libffi.so.6.0.2
[0-252.3222] 43334000-43335000 r--p 00004000 b3:12 15155      /usr/lib/libffi.so.6.0.2
[0-252.3222] 43335000-43336000 rw-p 00005000 b3:12 15155      /usr/lib/libffi.so.6.0.2
[0-252.3223] 43340000-43342000 r-xp 00000000 b3:12 16916      /usr/lib/libgmodule-2.0.so.0.5200.2
[0-252.3223] 43342000-43352000 ---p 00002000 b3:12 16916      /usr/lib/libgmodule-2.0.so.0.5200.2
[0-252.3223] 43352000-43353000 r--p 00002000 b3:12 16916      /usr/lib/libgmodule-2.0.so.0.5200.2
[0-252.3223] 43353000-43354000 rw-p 00003000 b3:12 16916      /usr/lib/libgmodule-2.0.so.0.5200.2
[0-252.3223] 43360000-43365000 r-xp 00000000 b3:12 12010      /usr/lib/libtzplatform-config-2.0.so.2.0.0
[0-252.3223] 43365000-43374000 ---p 00005000 b3:12 12010      /usr/lib/libtzplatform-config-2.0.so.2.0.0
[0-252.3223] 43374000-43375000 r--p 00004000 b3:12 12010      /usr/lib/libtzplatform-config-2.0.so.2.0.0
[0-252.3223] 43375000-43376000 rw-p 00005000 b3:12 12010      /usr/lib/libtzplatform-config-2.0.so.2.0.0
[0-252.3223] 43376000-4337b000 rw-p 00000000 00:00 0
[0-252.3223] 43380000-43386000 r-xp 00000000 b3:12 11608      /usr/lib/libvconf.so.0.3.1
[0-252.3223] 43386000-43395000 ---p 00006000 b3:12 11608      /usr/lib/libvconf.so.0.3.1
[0-252.3223] 43395000-43396000 r--p 00005000 b3:12 11608      /usr/lib/libvconf.so.0.3.1
[0-252.3223] 43396000-43397000 rw-p 00006000 b3:12 11608      /usr/lib/libvconf.so.0.3.1
[0-252.3223] 433a0000-433df000 r-xp 00000000 b3:12 11604      /usr/lib/libfactory-interface-DVB.so
[0-252.3223] 433df000-433ef000 ---p 0003f000 b3:12 11604      /usr/lib/libfactory-interface-DVB.so
[0-252.3224] 433ef000-433f1000 r--p 0003f000 b3:12 11604      /usr/lib/libfactory-interface-DVB.so
[0-252.3224] 433f1000-433f3000 rw-p 00041000 b3:12 11604      /usr/lib/libfactory-interface-DVB.so
[0-252.3224] 43400000-43401000 r-xp 00000000 b3:12 11304      /usr/lib/liblwipc.so
[0-252.3224] 43401000-43410000 ---p 00001000 b3:12 11304      /usr/lib/liblwipc.so
[0-252.3224] 43410000-43411000 r--p 00000000 b3:12 11304      /usr/lib/liblwipc.so
[0-252.3224] 43411000-43412000 rw-p 00001000 b3:12 11304      /usr/lib/liblwipc.so
[0-252.3224] 43420000-43425000 r-xp 00000000 b3:12 14730      /usr/lib/libopen-debugmenu_rel.so
[0-252.3224] 43425000-43434000 ---p 00005000 b3:12 14730      /usr/lib/libopen-debugmenu_rel.so
[0-252.3224] 43434000-43435000 r--p 00004000 b3:12 14730      /usr/lib/libopen-debugmenu_rel.so
[0-252.3224] 43435000-43436000 rw-p 00005000 b3:12 14730      /usr/lib/libopen-debugmenu_rel.so
[0-252.3224] 43440000-43459000 r-xp 00000000 b3:12 11655      /usr/lib/liblzma.so.5.2.4
[0-252.3224] 43459000-43468000 ---p 00019000 b3:12 11655      /usr/lib/liblzma.so.5.2.4
[0-252.3224] 43468000-43469000 r--p 00018000 b3:12 11655      /usr/lib/liblzma.so.5.2.4
[0-252.3224] 43469000-4346a000 rw-p 00019000 b3:12 11655      /usr/lib/liblzma.so.5.2.4
[0-252.3224] 43470000-43475000 r-xp 00000000 b3:12 15161      /usr/lib/libcapi-system-info.so.0.2.1
[0-252.3224] 43475000-43484000 ---p 00005000 b3:12 15161      /usr/lib/libcapi-system-info.so.0.2.1
[0-252.3225] 43484000-43485000 r--p 00004000 b3:12 15161      /usr/lib/libcapi-system-info.so.0.2.1
[0-252.3225] 43485000-43486000 rw-p 00005000 b3:12 15161      /usr/lib/libcapi-system-info.so.0.2.1
[0-252.3225] 43490000-43493000 r-xp 00000000 b3:12 11867      /usr/lib/libfconfig.so
[0-252.3225] 43493000-434a2000 ---p 00003000 b3:12 11867      /usr/lib/libfconfig.so
[0-252.3225] 434a2000-434a3000 r--p 00002000 b3:12 11867      /usr/lib/libfconfig.so
[0-252.3225] 434a3000-434a4000 rw-p 00003000 b3:12 11867      /usr/lib/libfconfig.so
[0-252.3225] 434b0000-43506000 r-xp 00000000 b3:12 11119      /usr/lib/libsystemd.so.0.16.0
[0-252.3225] 43506000-43515000 ---p 00056000 b3:12 11119      /usr/lib/libsystemd.so.0.16.0
[0-252.3225] 43515000-43517000 r--p 00055000 b3:12 11119      /usr/lib/libsystemd.so.0.16.0
[0-252.3225] 43517000-43518000 rw-p 00057000 b3:12 11119      /usr/lib/libsystemd.so.0.16.0
[0-252.3225] 43520000-4356d000 r-xp 00000000 b3:12 16685      /usr/lib/libdbus-1.so.3.14.6
[0-252.3225] 4356d000-4357c000 ---p 0004d000 b3:12 16685      /usr/lib/libdbus-1.so.3.14.6
[0-252.3225] 4357c000-4357d000 r--p 0004c000 b3:12 16685      /usr/lib/libdbus-1.so.3.14.6
[0-252.3225] 4357d000-4357e000 rw-p 0004d000 b3:12 16685      /usr/lib/libdbus-1.so.3.14.6
[0-252.3225] 43580000-435ba000 r-xp 00000000 b3:12 12421      /usr/lib/libmount.so.1.1.0
[0-252.3225] 435ba000-435ca000 ---p 0003a000 b3:12 12421      /usr/lib/libmount.so.1.1.0
[0-252.3226] 435ca000-435cb000 r--p 0003a000 b3:12 12421      /usr/lib/libmount.so.1.1.0
[0-252.3226] 435cb000-435cc000 rw-p 0003b000 b3:12 12421      /usr/lib/libmount.so.1.1.0
[0-252.3226] 435cc000-435cf000 rw-p 00000000 00:00 0
[0-252.3226] 435e0000-4360c000 r-xp 00000000 b3:12 15306      /usr/lib/libblkid.so.1.1.0
[0-252.3226] 4360c000-4361b000 ---p 0002c000 b3:12 15306      /usr/lib/libblkid.so.1.1.0
[0-252.3226] 4361b000-4361e000 r--p 0002b000 b3:12 15306      /usr/lib/libblkid.so.1.1.0
[0-252.3226] 4361e000-4361f000 rw-p 0002e000 b3:12 15306      /usr/lib/libblkid.so.1.1.0
[0-252.3226] 4361f000-43620000 rw-p 00000000 00:00 0
[0-252.3226] 43630000-43633000 r-xp 00000000 b3:12 12251      /usr/lib/libiniparser.so.0
[0-252.3226] 43633000-43642000 ---p 00003000 b3:12 12251      /usr/lib/libiniparser.so.0
[0-252.3226] 43642000-43643000 r--p 00002000 b3:12 12251      /usr/lib/libiniparser.so.0
[0-252.3226] 43643000-43644000 rw-p 00003000 b3:12 12251      /usr/lib/libiniparser.so.0
[0-252.3226] 43650000-43655000 r-xp 00000000 b3:12 16131      /usr/lib/libsmack.so.1.3.1
[0-252.3226] 43655000-43664000 ---p 00005000 b3:12 16131      /usr/lib/libsmack.so.1.3.1
[0-252.3226] 43664000-43665000 r--p 00004000 b3:12 16131      /usr/lib/libsmack.so.1.3.1
[0-252.3226] 43665000-43666000 rw-p 00005000 b3:12 16131      /usr/lib/libsmack.so.1.3.1
[0-252.3227] 43670000-43673000 r-xp 00000000 b3:12 14693      /usr/lib/libuuid.so.1.3.0
[0-252.3227] 43673000-43682000 ---p 00003000 b3:12 14693      /usr/lib/libuuid<0>
@Alex1101 , нужно указать свои действия  и подписать логи
Изменил UART на Debug и логи пошли
Лог идет бесконечно
(сначала часть= лог1, затем сбрасывает и идет лог2)
Поэтому так и подписал
Снимаю RT809F с доустановленым терминалом
Пока разбираюсь с логами, мало что понятно
@Alex1101 , "сторожевой таймер" watchdog on поставь в off
такие логи нужно:
Лог нажатия кнопки включения;
Лог со вставленным обновлением;
Лог со входом в консоль, через Ентер
Как вижу что проц новатек так обычно виновник всего ясен , Самсунг уже лет семь ставит новатеки в удешевленное говно и всегда они глючат
Kant.SU2-Tizen
Платформа.
Пробуй по USB обнову накатить, на сайте оф. описано как.
1 час назад, san-vai сказал:
Не идет никак
При этом лог такой
При этом :
Надо к eMMC подключаться .Или снимать ее и заливать user чужой.
<0>ь<0>яzAC
V2
0084(Jan  8 2021 10:55:46)
load tcon fail
load tcon (40000) fail
444mA
d
boot-up
(Jan  8 2021 - 10:55:47)
0084(6250644)
r
J001
S11
E11
0 p
GPT
D
DTB 0
xdt1.5G
SECDRV 0
or003.0
SECOS 0
kr003.0
KERNEL 0
z[1-0.0575] cma: [swapper/0(1)] cma_alloc(): returned ec507000 range 81000 - 81040
[1-0.0601] I2C IRQ init_timer start(0517_Tizen4.0)
[0-0.0669] [DEBUG]register base fd6f0000
[0-0.0670] [DEBUG] interregister base d
[0-0.0670] gzip support fifo mode
[0-0.0672] (NULL device *): ~get gpio base-val: 0xed096000, 0x0
[0-0.0673] nvt,auth fd770000.auth: hw auth support fifo mode, 1090309
[1-0.0904] type=2000 audit(0.079:1): initialized
[1-0.0960] Novatek UART Direct I/O Driver Init.
[1-0.0961] nvt-udio fd092000.uart: io_base ed0a8000
[1-0.0961] nvt-udio fd092000.uart: clock rate 100000000
[1-0.0961] nvt-udio fd092000.uart: baud rate 115200
[1-0.0961] nvt-udio fd092000.uart: irq 11
[1-0.0962] nvt-udio fd092000.uart: probing completed
[1-0.1442] [NTKETHMAC]: synopGMAC_probe.
[1-0.1443] [NTKETHMAC]: Now Registering the netdevice
[0-0.1713] mmcblk0: mmc0:0001 4FTE4R 3.64 GiB
[1-0.1771]  Ver : 6340677, release
[1-0.1771]  TV, Kant.SU2-Tizen, release, Trunk_2020_MP
[1-0.1771]  Linux version 4.1.10 (abuild@A1312DKG) (gcc version 6.2.1 20161213 (Tizen/Linaro GCC 6.2.1 2016.12/VDCosmos-20190704 7.8) ) #1 SMP PREEMPT Fri Jan 8 11:04:50 UTC 2021
[1-0.1844]  dtsversion=6290398_kantsu2-1.5G-cma console=ttyS0,115200 rs232=0 earlyprintk maxcpus=4 no_console_suspend only_entry_model root=/dev/mmcblk0p18 KDUMP=16 SELP_ENABLE=20208724 _nvtca9-16m rootfstype=vdfs ro init=/sbin/init mem=808M@32M mem=56M@968M mem=256M@2048M vmalloc=300M rootwait quiet bdinfo=00000091 model=4kbtin   pba_none
[/sbin/init] Start init process!!!!!!!!!!!!!!!!
[1-0.3581] vdfs4-WARN: SB: bad signature - , expected - VDFSmount: /mnt/systemrw: wrong fs type, bad option, bad superblock on /dev/mmcblk0p20, missing codepage or helper program, or other error.
[1-2.1482] [NTKETHMAC]: Trim RTER_RX = 0x3, 0368[70]
[1-2.1482] [NTKETHMAC]: Trim RTER_TX = 0x3, 0368[6c]
[1-2.1482] [NTKETHMAC]: Trim TX_ROUT = 0x4, 0374[25]
[1-2.1483] [NTKETHMAC]: Trim TX_SWING = 0x1, 0378[21]
systemrw_backup.xz isn't exist
[0-3.3775] vdfs4-WARN: SB: bad signature - , expected - VDFSmount: /mnt/systemrw: wrong fs type, bad option, bad superblock on /dev
data_backup.xz isn't exist
/sbin/init: line 46: /sys/kernel/debug/tracing/trace_marker: No such file or directory
[Info] Initailize T-trace
error opening /sys/kernel/debug/tracing/options/[0-3.5045] init: lwipc
overwrite: No su[1-3.5047] init: logger
ch file or direc[0-3.5048] lwipc mod ld(0xbe800000)
tory (2)
Tags: [1-3.5053] logger mod ld(0xbe805000)
0x1, excludedTags: 0x0
error opening /sys/kernel/debug/tracing/tracing_on: No such file or directory (2)
unable to start tracing
[cynara-launcher] launch cynara( 119 )
[cynara-launcher] wait socket files:300
[3-3.5524] init: tztv_bootmode
[3-3.5527] tztv_bootmode mod ld(0xbe81d000)
Booting from tztv mode
boot mode: normal
[eeprom open wait]
Set Buxton env
[0-3.6416] [FB:INIT] fast init start
[0-3.6453] [FB:INIT] insmod file : index.json
[prdv_attr: /dev/null]
[2-3.6547] DynBoost3.1.8
[eeprom open wai[0-3.6576] [FB:INIT] [prebasic Start]
t]
[0-3.6576] [FB:INIT] cmd[prebasic:insmod]
[prdv_attr: /dev/tty]
[prdv_attr: /dev/bptime]
[0-3.6577] [FB:INIT] prebasic 0 start
[prdv_attr: /dev/snd/timer]
[p[1-3.6690] init: PreInit
rdv_attr: /dev/uinput]
[prdv_at[1-3.6701] ================================================================================
tr: /dev/zero]
cat: /run/user/5001/.launchpad.p[1-3.6701]  Pre Initiation
id: No such file[1-3.6701]  Version : Kantsu2_Onemain_2020_KantSU2_Trunk2020_MP_v0.201016.0_r93d41424e63.
 or directory
C[1-3.6701] ================================================================================
ynara db update success
[eeprom open wait]
[eeprom open wait]
[eeprom open wait]
[3.72 13.35][BXT] buxton2d start[1-3.7357] [TEMP_MSGBOX] #################
ed
[1-3.7357] [TEMP_MSGBOX] MessageBox Drive_init
build: 20210108_144709
keymap: 20210108_144709
We have a keyma[1-3.7519] genirq: Flags mismatch irq 11. 00000080 (ntk_serial) vs. 00000000 (fd092000.uart)
p cache version file
[eeprom open wait]
[prdv_attr: /dev/eeprom]
[1-3.7519] PreInit mod ld(0xbe821000)
[1-3.7520] [FB:INIT] prebasic 0 end
[1-3.7520] [FB:INIT] prebasic 1 start
[1-3.7549] init: tztv_eeprom
[1-3.7553] client = 0xebdfe200
[1-3.7602] tztv_eeprom mod ld(0xbe88d000)
[prdv_attr: /dev[1-3.7603] [FB:INIT] prebasic 1 end
/micom-cec]
FP_NVRAM_FASTBOOT_I[1-3.7603] [FB:INIT] prebasic 2 start
N_PRODUCTION [0]
non-factory production mode
[1-3.7713] init: tztv_micom
[3-3.7974] [MC:S][3.7974][kthread_watchdo]Rollback
[security-manage[3-3.8029] [MC:A][3.8028]TV ver 1010_R(1)
r-launcher(242)][3-3.8092] [MC:A][3.8064][PwrOnMode:1][PrePOM:0][Res: 0][T-TV-1010_R(1)]
  > Starting Sec[1-3.8211] tztv_micom mod ld(0xbe893000)
urity Manager La[1-3.8212] [FB:INIT] prebasic 2 end
uncher...
[secu[1-3.8212] [FB:INIT] prebasic 3 start
rity-manager-lau[2-3.8297] [MC:A][3.8297](PrsK)(Panel)(Pre:0x0000FF, Cur:0x2D)
ncher(242)]  > s[3-3.8394] [SBH] get_boot_reason is (0)
ecurity-manager([3-3.8395] [MC:A][3.8393]boot_reason(0) [TV ver 1010_R(1)]
pid : 260) is la[1-3.8421] init: videobuf2_core
unched successfu[1-3.8424] videobuf2_core mod ld(0xbe8a5000)
lly...
[1-3.8425] [FB:INIT] prebasic 3 end
[1-3.8426] [FB:INIT] prebasic 4 start
[prdv_attr: /dev/dmabuf_kds]
[prdv_attr: /dev/mali0]
[1-3.8452] init: videobuf2_memops
[1-3.8453] videobuf2_memops mod ld(0xbe8ad000)
[1-3.8453] [FB:INIT] prebasic 4 end
[1-3.8453] [FB:INIT] prebasic 5 start
[3-3.8580] init: videobuf2_vmalloc
[3-3.8585] videobuf2_vmalloc mod ld(0xbe8af000)
[3-3.8586] [FB:INIT] prebasic 5 end
[3-3.8587] [FB:INIT] [prebasic End time:201]
[3-3.8587] [FB:INIT] fi_util_mq_send_cmd: cmd(122)
[3-3.8588] [FB:INIT] [fi_depList_init:763] index_path [/tmp/FACTORY_PRODCU[FB:INIT] no flag file:/tmp/FACTORY_PRODCUTION
[3-3.8588] [FB:INIT] [fi_depList_init:763] index_path [/opt/usr/apps/MCS_m[FB:INIT] no flag file:/opt/usr/apps/MCS_mode
[3-3.8588] [FB:INIT] [fi_depList_init:763] index_path [/opt/usr/apps/org.t[FB:INIT] no flag file:/opt/usr/apps/org.tizen.btapp/data/tv_so[FB:INIT] [fi_depList_init:763] index_path []
[3-3.8589] [FB:INIT] no flag file:
[3-3.8589] [FB:INIT] Index path Null
[3-3.8589] [FB:INIT] INIT index_path[index]
[3-3.8591] [FB:INIT] [fw Start]
[3-3.8592] [FB:INIT] cmd[fw:insmod]
[3-3.8592] [FB:INIT] fw 0 start
[3-3.8594] [FB:INIT] [tzdev Start]
[3-3.8594] [FB:INIT] cmd[tzdev:insmod]
[3-3.8594] [FB:INIT] tzdev 0 start
[1-3.8606] [FB:LOGO] panel_enable(1)
[3-3.8770] init: mali
[2-3.8773] init: tzdev
[3-3.8835] mali mod ld(0xbe8b1000)
[3-3.8836] [FB:INIT] fw 0 end
[3-3.8836] [FB:INIT] fw 1 start
[3-3.8941] [MC:A][3.8941](PrsK)(Panel)(Pre:0x00002D, Cur:0x2D)
[1-3.9175] [FB:LOGO] logo mode(0)
[2-3.9576] [MC:A][3.9575](PrsK)(Panel)(Pre:0x00002D, Cur:0x2D)
[3-3.9849] tzdev mod ld(0xbe8fd000)
[3-3.9850] [FB:INIT] tzdev 0 end
[3-3.9851] [FB:INIT] cmd[tzdev:chmod]
[3-3.9851] [FB:INIT] [tzdev End time:125]
[3-3.9852] [FB:INIT] create path(/tmp/tzdev_insmod_done)
[2-4.0218] [MC:A][4.0218](PrsK)(Panel)(Pre:0x00002D, Cur:0x2D)
[2-4.0857] [MC:A][4.0856](PrsK)(Panel)(Pre:0x00002D, Cur:0x2D)
/usr/bin/firstscreen.sh: line 20: /sys/kernel/debug/tracing/trace_marker: No such file or directory
[security-manager-launcher(242)]  > inotify event is received for /run/security-manager.socket
[2-4.1499] [MC:A][4.1498](PrsK)(Panel)(Pre:0x00002D, Cur:0x2D)
cat: /opt/data/DeviceTracker/htPolicyState: No such file or directory
[3-4.2142] [MC:A][4.2142](PrsK)(Panel)(Pre:0x00002D, Cur:0x2D)
[PKGMGR] /opt/dbspace/.pkgmgr_parser.db file size 948
[PKGMGR] integrity : ok
Buffer main is set
argc = 10, optind = 9, Kb 1024, rotate 1
[PKGMGR] /opt/dbspace/.pkgmgr_cert.db file size 184
[PKGMGR] in[3-4.2780] [MC:A][4.2780](PrsK)(Panel)(Pre:0x00002D, Cur:0x2D)
tegrity : ok
[2-4.2837] init: ntkdriver
[0-4.3067] ================================================================================
netlink recv: No buffer space available
[PKGMGR] /opt/dbspace/user/5001/.pkgmgr_parser.db file size 148
[prdv_attr: /dev/sdp_mem]
[3-4.3106] [SBH] bw_get_boot_mode() : 0, BOOT_TYPE_ISP(1) BOOT_TYPE_RVU(2)
[0-4.3150]  NTK Driver
waiting firstscreen launch
[0-4.3150]  Version : Kantsu2_Onemain_2020_KantSU2_Trunk2020_MP_v0.201016.0_r93d41424e63.
[0-4.3150] ================================================================================
[PKGMGR] /var/lib/package-manage[0-4.3150] ntkdrvs: NOVATEK drivers loaded begin.
r/restriction.db[3-4.3159] [SBH] create boot mode file(/tmp/normal_mode)
 file size 16
[PKGMGR] integrit[2-4.3239] msg-wt61p807 msg-wt61p807: received unknown cmd ack
y : ok
[0-4.3242] nvt_dt cannot find video_es_tbl!
[0-4.3243] ksb cann't find video_es_tbl node
[2-4.3268] [FB] fastvideo start
[2-4.3271] [FB] fb_insmod_wait_lock: mode(12) sLtaero
n2 decoder s uilt t 14:2:9,My  5 2    ode reviion: d106ebb1, 2020-03-20
_CPU_Intialize... OK
_Reload_text(304) ... OK
_Reload_data(12288) ... OK
TC = c400a810
s[tart ....3411] [HDMI-CMD]:Trim.Valid=1
[0-4.3411] [HDMI-CMD]:EARCTrim.Valid=1
[PKGMGR] /opt/db[3-4.3415] [MC:A][4.3415](PrsK)(Panel)(Pre:0x00002D, Cur:0x2D)
space/.widget.db[2-4.3417] [FB] fb_insmod_wait_lock: mode(12) end
 file size 28
[[3-4.3585] [FB] Hotel mode : 0:0
PKGMGR] integrit[3-4.3585] [FB] Hotel mode disable
y : ok
RO and R[0-4.3640] Novatek FRE Driver loaded
W is same versio[3-4.3665] [FB] fb_insmod_wait_lock: mode(13) start
n
/home/owner/.[3-4.3665] [FB] fb_insmod_wait_lock: mode(13) end
dotnet/corefx/cr[0-4.3960] [FB] boot_mode,channel_lock:3,0
yptography/x509s[0-4.3960] [FB] invalied bootmode(3)!!
tores/ is alread[0-4.3961] [FB] video_show_done(skip/fail)
y created
mkdir[1-4.4023] [FB] fb_status_fail: fastvideo SKIP. ( reason : [ 8 ] )
: cannot create [2-4.4072] [MC:A][4.4056](PrsK)(Panel)(Pre:0x00002D, Cur:0x2D)
directory `/opt/[3-4.4515] [perfm]1.4.18
usr/home/owner/s[3-4.4698] [MC:A][4.4698](PrsK)(Panel)(Pre:0x00002D, Cur:0x2D)
hare/dotnet/': File exists
Recreate Seed
[1-4.5301] cma: [fastinit(272)] cma_alloc(): returned ec507800 range 81040 - 81048
[PKGMGR] /opt/us[3-4.5341] [MC:A][4.5341](PrsK)(Panel)(Pre:0x00002D, Cur:0x2D)
r/home/owner/.applications/dbspa[3-4.5534] ESTART(main) 4.54137
ce/.widget.db file size 28
[PKG[3-4.5536] ESTART: 0.00410 [0.00410] - Begin Startup
MGR] integrity : ok
[3-4.5650] ESTART: 0.01543 [0.01133] - Signal Trap
[3-4.5651] ESTART: 0.01563 [0.00021] - Signal Trap Done
/usr/bin/dotnet-[3-4.5652] ESTART: 0.01565 [0.00002] - Eina Init
developer-mode.s[1-4.5749] [hdmi leon2] hdmi_leon2 find pool node ERROR !!!
h found
[1-4.5749] [hdmi leon2] driver loaded > ERROR !!!
[1-4.5786] ntkdriver mod ld(0xbe920000)
[1-4.5787] [FB:INIT] fw 1 end
[1-4.5787] [FB:INIT] [fw End time:720]
[2-4.5788] [FB:INIT] [pq Start]
[2-4.5789] [FB:INIT] cmd[pq:insmod]
[2-4.5789] [FB:INIT] pq 0 start
[1-4.5823] [FB:INIT] [kfactory Start]
[1-4.5823] [FB:INIT] cmd[kfactory:insmod]
[PKGMGR] /opt/db[1-4.5823] [FB:INIT] kfactory 0 start
space/.appsvc.db[2-4.5845] init: ntkndp_pq
 file size 40
[[3-4.5851] ESTART: 0.03558 [0.01993] - Eina Init Done
PKGMGR] integrit[3-4.5851] ESTART: 0.03563 [0.00005] - E_Object Hash Init
y : ok
[1-4.5911] init: kfactory_drv
[1-4.5920] kfactory_drv mod ld(0xbf196000)
[3-4.5920] ESTART: 0.04250 [0.00687] - E_Object Hash Init Done
[3-4.5921] ESTART: 0.04256 [0.00005] - E_Log Init
[kfactoryd] rest[1-4.5921] [FB:INIT] kfactory 0 end
ore daemon!!
[1-4.5921] [FB:INIT] cmd[kfactory:execute]
[3-4.5922] ESTART: 0.04272 [0.00017] - E_Log Init Done
[3-4.5923] ESTART: 0.04275 [0.00002] - Determine Prefix
[2-4.5975] [MC:A][4.5974](PrsK)(Panel)(Pre:0x00002D, Cur:0x2D)
[1-4.5995] [FB:INIT] cmd[kfactory:insmod]
[1-4.5995] [FB:INIT] kfactory 0 start
[1-4.5996] [FB:INIT] kfactory 0 end
[1-4.5997] [FB:INIT] kfactory 1 start
[1-4.6056] init: system_drv_api
[3-4.6056] ESTART: 0.05608 [0.01333] - Determine Prefix Done
[3-4.6056] ESTART: 0.05613 [0.00005] - Parse Arguments
[3-4.6057] ESTART: 0.05615 [0.00002] - Parse Arguments Done
[3-4.6057] ESTART: 0.05617 [0.00002] - Eet Init
[PKGMGR] /opt/db[1-4.6058] system_drv_api mod ld(0xbe803000)
space/user/5001/[3-4.6059] ESTART: 0.05636 [0.00019] - Eet Init Done
[3-4.6059] ESTART: 0.05639 [0.00003] - Ecore Init
.appsvc.db file [1-4.6060] [FB:INIT] kfactory 1 end
size 40
[PKGMGR[1-4.6060] [FB:INIT] kfactory 2 start
[1-4.6107] init: system_drv
[3-4.6152] ESTART: 0.06566 [0.00927] - Ecore Init Done
] integrity : ok[3-4.6152] ESTART: 0.06571 [0.00005] - EIO Init
[3-4.6155] ESTART: 0.06598 [0.00026] - EIO Init Done
Develope mode is[3-4.6155] ESTART: 0.06600 [0.00002] - Ecore Event Handlers
 off
[3-4.6155] ESTART: 0.06602 [0.00003] - Ecore Event Handlers Done
[3-4.6156] ESTART: 0.06604 [0.00002] - Ecore_File Init
[1-4.6195] system_drv mod ld(0xbf19f000)
[1-4.6211] [FB:INIT] kfactory 2 end
[1-4.6211] [FB:INIT] kfactory 3 start
[2-4.6212] ntkndp_pq mod ld(0xbf17b000)
[prdv_attr: /dev/video28]
[1-4.6212] [FB:INIT] kfactory 3 end
[1-4.6212] [FB:INIT] [kfactory End time:39]
[2-4.6213] [FB:INIT] pq 0 end
[2-4.6213] [FB:INIT] pq 1 start
[3-4.6214] [FB:INIT] [extin Start]
[3-4.6214] [FB:INIT] cmd[extin:insmod]
[3-4.6214] [FB:INIT] extin 0 start
[1-4.6214] [FB:INIT] [logo Start]
[1-4.6215] [FB:INIT] cmd[logo:insmod]
[1-4.6215] [FB:INIT] logo 0 start
[2-4.6616] [MC:A][4.6616](PrsK)(Panel)(Pre:0x00002D, Cur:0x2D)
[1-4.6646] init: ntkndptcon
[3-4.6686] ESTART: 0.11910 [0.05306] - Ecore_File Init Done
[3-4.6687] ESTART: 0.11916 [0.00005] - E_Util_File_Monitor Init
[3-4.6687] ESTART: 0.11920 [0.00005] - E_Util_File_Monitor Init Done
[3-4.6688] ESTART: 0.11933 [0.00013] - XDG_DATA_DIRS Init
[3-4.6689] ESTART: 0.11943 [0.00010] - XDG_DATA_DIRS Init Done
[3-4.6690] ESTART: 0.11945 [0.00002] - Ecore_Evas Init
[2-4.6696] ntkndptcon mod ld(0xbf1a7000)
[2-4.6696] KER_TCON_DrvInit: _tcon_mbxisr_ready
[3-4.6785] cma: [KTCON_INIT(413)] cma_alloc(): returned ec507a00 range 81050 - 81060
[2-4.6815] [FB:INIT] pq 1 end
[2-4.6816] [FB:INIT] [pq End time:103]
[2-4.6855] init: ntkndpextin
[1-4.6872] init: ntkndplogo
[2-4.7297] [MC:A][4.7296](PrsK)(Panel)(Pre:0x00002D, Cur:0x2D)
[1-4.7518] ntkndplogo mod ld(0xbf1c8000)
[1-4.7519] [FB:INIT] logo 0 end
[1-4.7520] [FB:INIT] [logo End time:130]
[3-4.7521] [FB:INIT] [frc Start]
[3-4.7522] [FB:INIT] cmd[frc:insmod]
[3-4.7522] [FB:INIT] frc 0 start
[1-4.7522] [FB:INIT] fi_util_mq_send_cmd: cmd(108)
[1-4.7523] [FB:INIT] [hdmi1 Start]
[1-4.7523] [FB:INIT] cmd[hdmi1:insmod]
[1-4.7523] [FB:INIT] hdmi1 0 start
[3-4.7524] [FB:INIT] [audio Start]
[1-4.7524] [FB:INIT] [alsa Start]
[1-4.7525] [FB:INIT] cmd[alsa:insmod]
[1-4.7525] [FB:INIT] alsa 0 start
[3-4.7525] [FB:INIT] cmd[audio:insmod]
[3-4.7525] [FB:INIT] audio 0 start
[3-4.7537] cma: [KTCON_INIT(413)] cma_alloc(): returned ec507a00 range 81050 - 81060
[2-4.7570] [FB:INIT] [tuner Start]
[PKGMGR] /opt/db[2-4.7570] [FB:INIT] cmd[tuner:insmod]
[2-4.7570] [FB:INIT] tuner 0 start
space/.app-conte[1-4.7596] init: ntkndphdmi
[1-4.7608] set g_ndp_hdmi_port_max  = 3
xt.db file size [1-4.7609] Can not find hdmi_hpd -> HDMI_HPD_PORTB in dtb file
48
[PKGMGR] int[1-4.7610] Can not find hdmi_hpd -> HDMI_HPD_PORTD in dtb file
egrity : ok
[1-4.7610] brdType = 1
[1-4.7610] eHDMI_HOT_PLUG[0] = 160
[1-4.7610] eHDMI_HOT_PLUG[2] = 163
[2-4.7629] [MC:S][4.7629][fastlogo]Inv-1
[2-4.7675] [MC:A][4.7675]Inv(0)
[3-4.7675] ntkndphdmi mod ld(0xbf14a000)
[3-4.7677] [FB:INIT] hdmi1 0 end
[3-4.7677] [FB:INIT] hdmi1 1 start
[1-4.7679] [FB:LOGO] panel unmute
[1-4.7696] [FB:LOGO] BootLogo start
[3-4.7729] init: tztv_frc_tcon_api
[3-4.7742] tztv_frc_tcon_api mod ld(0xbf15f000)
[2-4.7746] [FB:INIT] frc 0 end
[2-4.7746] [FB:INIT] frc 1 star49345 [0.00004] - Evas_GL New
[1-6.0472] ESTART: 1.49772 [0.00427] - Evas_GL New Done
[1-6.0558] ESTART: 1.50628 [0.00856] - E_Output Hwc Setup Done
[1-6.0558] ESTART: 1.50633 [0.00005] - E_Comp_Screen Outputs Init Done
[1-6.0559] ESTART: 1.50638 [0.00005] - E_Comp_Screen_Engine Init Done
[1-6.0559] ESTART: 1.50639 [0.00001] - E_Input Init
[1-6.0686] ESTART: 1.51903 [0.01264] - E_Input Init Done
[1-6.0686] ESTART: 1.51906 [0.00003] - E_Comp_Wl Init
[1-6.0693] ESTART: 1.51977 [0.00070] - E_Comp_Wl_GL Init
[2-6.0699] [MC:A][6.0699](PrsK)(Panel)(Pre:0x00002D, Cur:0x2D)
[1-6.0729] ESTART: 1.52341 [0.00364] - E_Comp_Wl_GL Init Done
[1-6.0743] ESTART: 1.52477 [0.00136] - E_Comp_Wl Init Done
[1-6.0743] ESTART: 1.52480 [0.00002] - E_Comp_Canvas Init
[1-6.0753] ESTART: 1.52578 [0.00099] - E_Comp_Canvas Init Done
[1-6.0753] ESTART: 1.52583 [0.00005] - E_Pointer New
[1-6.0754] ESTART: 1.52585 [0.00001] - E_Pointer New Done
[1-6.0754] ESTART: 1.52586 [0.00001] - E_Comp_WL Keymap Init
[1-6.0807] ESTART: 1.53120 [0.00535] - E_Comp_WL Keymap Init Done
[1-6.0807] ESTART: 1.53123 [0.00003] - DBUS Init
[1-6.0810] ESTART: 1.53150 [0.00026] - DBUS Init Done
[1-6.0810] ESTART: 1.53152 [0.00002] - E_Comp_Screen Init Done
[1-6.0813] ESTART: 1.53176 [0.00024] - Compositor Init Done
[1-6.0813] ESTART: 1.53178 [0.00002] - Screens Init Done
[1-6.0813] ESTART: 1.53179 [0.00001] - E_Devicemgr Init
[1-6.0827] ESTART: 1.53319 [0.00140] - E_Devicemgr Init Done
[1-6.0827] ESTART: 1.53321 [0.00002] - E_Keyrouter Init
[1-6.0877] ESTART: 1.53820 [0.00499] - E_Keyrouter Init Done
[1-6.0877] ESTART: 1.53823 [0.00003] - E_Screensaver Init
[1-6.0877] ESTART: 1.53824 [0.00001] - E_Screensaver Init Done
[1-6.0878] ESTART: 1.53825 [0.00001] - E_Comp Freeze
[1-6.0878] ESTART: 1.53828 [0.00002] - E_Comp Freeze Done
[1-6.0878] ESTART: 1.53828 [0.00001] - E_Grabinput Init
[1-6.0878] ESTART: 1.53829 [0.00001] - E_Grabinput Init Done
[1-6.0878] ESTART: 1.53830 [0.00001] - E_Gesture Init
[1-6.0878] ESTART: 1.53831 [0.00001] - E_Module Init
[1-6.0884] ESTART: 1.53890 [0.00059] - E_Module Init Done
[1-6.0884] ESTART: 1.53892 [0.00002] - E_Mouse Init
[1-6.0884] ESTART: 1.53893 [0.00001] - E_Mouse Init Done
[1-6.0884] ESTART: 1.53894 [0.00001] - E_Icon Init
[1-6.0885] ESTART: 1.53895 [0.00001] - E_Icon Init Done
[1-6.0885] ESTART: 1.53895 [0.00001] - E_Policy Init
[1-6.0886] ESTART: 1.53914 [0.00018] - E_Policy Init Done
[1-6.0887] ESTART: 1.53915 [0.00001] - E_Process Init
[1-6.0887] ESTART: 1.53916 [0.00002] - E_Process Init Done
[1-6.0887] ESTART: 1.53917 [0.00001] - E_Security Init
[1-6.0889] ESTART: 1.53939 [0.00022] - E_Security Init Done
[1-6.0889] ESTART: 1.53940 [0.00001] - Load Modules
[1-6.0889] ESTART: 1.53941 [0.00001] - Load Modules Done
[1-6.0889] ESTART: 1.53942 [0.00001] - E_Comp Thaw
[1-6.0890] ESTART: 1.53945 [0.00003] - E_Comp Thaw Done
[1-6.0890] ESTART: 1.53947 [0.00002] - MAIN LOOP AT LAST
[1-6.0890] ESTART: 1.53948 [0.00001] - [WM] Send start-up completion
[1-6.0892] ESTART: 1.53973 [0.00025] - SLEEP
[1-6.0932] ESTART: 1.54369 [0.00396] - e-mod-tizen-wm-policy Module Open
[2-6.1337] [MC:A][6.1336](PrsK)(Panel)(Pre:0x00002D, Cur:0x2D)
[2-6.1352] usb usb1-port1: status 0101, change 0001, 12 Mb/s
[2-6.1849] [FB:LOGO] BootLogo end
[2-6.1933] [FB] fb_insmod_wait_lock: mode(2) start
[2-6.1933] [FB] fb_insmod_wait_lock: mode(2) end
[2-6.1933] [FB] fb mute enter
[2-6.1935] [MC:S][6.1935][fb_do_inmute_pr]Inv-0
[1-6.1958] ESTART: 1.64631 [0.10262] - e-mod-tizen-wm-policy Module Open Done m:0x218528
[1-6.1959] ESTART: 1.64635 [0.00004] - e-mod-tizen-wm-policy Module Enable
[2-6.1978] [MC:A][6.1978]Inv(0)
[1-6.2003] [FB] fb_insmod_wait_lock: mode(15) start
[1-6.2003] [FB] fb_insmod_wait_lock: mode(15) end
[1-6.2003] [frc-tcon][ft_set_inverter][off][dpms:-1][pid:557,fb_do_inmute_pr]
[2-6.2011] [MC:A][6.2010](PrsK)(Panel)(Pre:0x00002D, Cur:0x2D)
[1-6.2114] KER_TCON_get_need_chk_tcon_ready: need_chk_tcon_ready(1)
[1-6.2186] ESTART: 1.66906 [0.02271] - e-mod-tizen-wm-policy Module Enable Done 1
[1-6.2186] ESTART: 1.66911 [0.00005] - e-mod-tizen-monitor-helper Module Open
[1-6.2296] ESTART: 1.68002 [0.01091] - e-mod-tizen-monitor-helper Module Open Done m:0x4c76c8
[1-6.2296] ESTART: 1.68008 [0.00006] - e-mod-tizen-monitor-helper Module Enable
[1-6.2302] Enlightenment set as VIP process - start
[1-6.2303] Enlightenment set as VIP process - done
[1-6.2304] ESTART: 1.68086 [0.00078] - e-mod-tizen-monitor-helper Module Enable Done 1
[1-6.2304] ESTART: 1.68089 [0.00003] - e-mod-tizen-video-tv Module Open
[0-6.2388] [FB] fb_insmod_wait_lock: mode(10) start
[0-6.2388] [FB] fb_insmod_wait_lock: mode(10) end
[1-6.2608] ave_ppi_init start
[1-6.2609] ESTART: 1.71139 [0.03050] - e-mod-tizen-video-tv Module Open Done m:0x4c9890
[1-6.2609] ESTART: 1.71141 [0.00002] - e-mod-tizen-video-tv Module Enable
[2-6.2619] [MC:A][6.2619](PrsK)(Panel)(Pre:0x00002D, Cur:0x2D)
[1-6.2623] ESTART: 1.71279 [0.00138] - e-mod-tizen-video-tv Module Enable Done 1
[1-6.2623] ESTART: 1.71283 [0.00004] - e-mod-tizen-keyrouter-tv Module Open
[2-6.3117] msg-wt61p807 msg-wt61p807: received unknown cmd ack
[2-6.3119] [FB] AVOC ready start
[2-6.3264] [MC:A][6.3260](PrsK)(Panel)(Pre:0x00002D, Cur:0x2D)
[2-6.3802] usb 1-1: new high-speed USB device number 2 using NT72668-ehci
[3-6.3896] [MC:A][6.3895](PrsK)(Panel)(Pre:0x00002D, Cur:0x2D)
[3-6.4538] [MC:A][6.4538](PrsK)(Panel)(Pre:0x00002D, Cur:0x2D)
[1-6.4592] init: cfg80211
[1-6.4686] cfg80211 mod ld(0xbf504000)
[3-6.5092] init: mt7668_prealloc
[3-6.5105] mt7668_prealloc mod ld(0xbe81f000)
[1-6.5139] [FB:INIT] [preusb End time:831]
[3-6.5180] [MC:A][6.5180](PrsK)(Panel)(Pre:0x00002D, Cur:0x2D)
[2-6.5194] [FB:INIT] [usb Start]
[2-6.5195] [FB:INIT] cmd[usb:insmod]
[2-6.5195] [FB:INIT] usb 0 start
[1-6.5511] ESTART: 2.00158 [0.28876] - e-mod-tizen-keyrouter-tv Module Open Done m:0x4cee30
[1-6.5511] ESTART: 2.00164 [0.00006] - e-mod-tizen-keyrouter-tv Module Enable
[2-6.5610] init: usb_enable
[2-6.5673] [send_micom_msg] send msg success for on
[2-6.5674] [set_3G_port] set 3g on success
[2-6.5676] usb_enable mod ld(0xbf15d000)
[2-6.5677] [FB:INIT] usb 0 end
[2-6.5678] [FB:INIT] [usb End time:48]
[2-6.5681] [FB:INIT] fi_util_mq_send_cmd: cmd(107)
[2-6.5752] [FB:INIT] [wifi Start]
[2-6.5752] [FB:INIT] cmd[wifi:execute]
[3-6.5841] [MC:A][6.5816](PrsK)(Panel)(Pre:0x00002D, Cur:0x2D)
[3-6.5843] [FB:INIT] [postusb Start]
[3-6.5843] [FB:INIT] cmd[postusb:insmod]
[3-6.5844] [FB:INIT] postusb 0 start
[3-6.5879] [FB:INIT] [bt Start]
[0-6.5884] ESTART: 2.03885 [0.03721] - e-mod-tizen-keyrouter-tv Module Enable Done 1
[0-6.5884] ESTART: 2.03890 [0.00006] - e-mod-tizen-devicemgr Module Open
[3-6.5886] [FB:INIT] cmd[bt:insmod]
[3-6.5886] [FB:INIT] bt 0 start
[0-6.5920] ESTART: 2.04248 [0.00358] - e-mod-tizen-devicemgr Module Open Done m:0x4aec38
[0-6.5920] ESTART: 2.04252 [0.00004] - e-mod-tizen-devicemgr Module Enable
[0-6.5921] ESTART: 2.04257 [0.00005] - e-mod-tizen-devicemgr Module Enable Done 1
[0-6.5921] ESTART: 2.04262 [0.00005] - e-mod-tizen-launchscreen Module Open
[3-6.5952] init: usb_storage
[3-6.5972] usb_storage mod ld(0xbf533000)
[3-6.5973] [FB:INIT] postusb 0 end
[3-6.5973] [FB:INIT] postusb 1 start
[0-6.6004] ESTART: 2.05088 [0.00826] - e-mod-tizen-launchscreen Module Open Done m:0x4ae828
[0-6.6004] ESTART: 2.05093 [0.00004] - e-mod-tizen-launchscreen Module Enable
[0-6.6055] ESTART: 2,05599 [0,00507] - e-mod-tizen-launchscreen Module Enable Done 1
[0-6.6056] ESTART: 2,05606 [0,00007] - e-mod-tizen-hwc-tv Module Open
[3-6.6058] init: btsbc
[3-6.6062] btsbc mod ld(0xbf53d000)
[3-6.6063] [FB:INIT] bt 0 end
[3-6.6064] [FB:INIT] bt 1 start
[3-6.6118] init: hcas_usb_core
[3-6.6190] hcas_usb_core mod ld(0xbf3e2000)
[3-6.6192] [FB:INIT] postusb 1 end
[3-6.6192] [FB:INIT] postusb 2 start
[3-6.6196] init: btpcm
[3-6.6203] btpcm mod ld(0xbf545000)
[3-6.6204] [FB:INIT] bt 1 end
[3-6.6204] [FB:INIT] bt 2 start
[3-6.6262] init: usbserial
[3-6.6371] usbserial mod ld(0xbf54d000)
[3-6.6373] [FB:INIT] postusb 2 en<0>
1) При подсоединении флешки к включенному тв:
-601.3333] 43a10000-43b35000 r-xp 00000000 b3:12 14712      /usr/lib/libcrypto.so.1.0.0
[3-601.3333] 43b35000-43b44000 ---p 00125000 b3:12 14712      /usr/lib/libcrypto.so.1.0.0
[3-601.3334] 43b44000-43b52000 r--p 00124000 b3:12 14712      /usr/lib/libcrypto.so.1.0.0
[3-601.3334] 43b52000-43b59000 rw-p 00132000 b3:12 14712      /usr/lib/libcrypto.so.1.0.0
[3-601.3334] 43b59000-43b5c000 rw-p 00000000 00:00 0
[3-601.3334] 43b60000-43bbf000 r-xp 00000000 b3:12 16184      /usr/lib/libeina.so.1.23.99
[3-601.3334] 43bbf000-43bce000 ---p 0005f000 b3:12 16184      /usr/lib/libeina.so.1.23.99
[3-601.3334] 43bce000-43bcf000 r--p 0005e000 b3:12 16184      /usr/lib/libeina.so.1.23.99
[3-601.3334] 43bcf000-43bd0000 rw-p 0005f000 b3:12 16184      /usr/lib/libeina.so.1.23.99
[3-601.3334] 43bd0000-43bd1000 rw-p 00000000 00:00 0
[3-601.3334] 43be0000-43c1c000 r-xp 00000000 b3:12 16910      /usr/lib/libssl.so.1.0.0
[3-601.3334] 43c1c000-43c2c000 ---p 0003c000 b3:12 16910      /usr/lib/libssl.so.1.0.0
[3-601.3335] 43c2c000-43c2e000 r--p 0003c000 b3:12 16910      /usr/lib/libssl.so.1.0.0
[3-601.3335] 43c2e000-43c32000 rw-p 0003e000 b3:12 16910      /usr/lib/libssl.so.1.0.0
[3-601.3335] 43c40000-43c52000 r-xp 00000000 b3:12 16498      /usr/lib/libdeviced.so.1.0.3
[3-601.3335] 43c52000-43c61000 ---p 00012000 b3:12 16498      /usr/lib/libdeviced.so.1.0.3
[3-601.3335] 43c61000-43c62000 r--p 00011000 b3:12 16498      /usr/lib/libdeviced.so.1.0.3
[3-601.3335] 43c62000-43c63000 rw-p 00012000 b3:12 16498      /usr/lib/libdeviced.so.1.0.3
[3-601.3335] 43c70000-43c8c000 r-xp 00000000 b3:12 16443      /usr/lib/libjsoncpp.so.0.10.4
[3-601.3335] 43c8c000-43c9b000 ---p 0001c000 b3:12 16443      /usr/lib/libjsoncpp.so.0.10.4
[3-601.3335] 43c9b000-43c9c000 r--p 0001b000 b3:12 16443      /usr/lib/libjsoncpp.so.0.10.4
[3-601.3335] 43c9c000-43c9d000 rw-p 0001c000 b3:12 16443      /usr/lib/libjsoncpp.so.0.10.4
[3-601.3336] 43ca0000-43ca1000 r-xp 00000000 b3:12 16800      /usr/lib/libdisplay-panel-c-glue.so.0.1
[3-601.3336] 43ca1000-43cb0000 ---p 00001000 b3:12 16800      /usr/lib/libdisplay-panel-c-glue.so.0.1
[3-601.3336] 43cb0000-43cb1000 rw-p 00000000 b3:12 16800      /usr/lib/libdisplay-panel-c-glue.so.0.1
[3-601.3336] 43cc0000-43cc1000 r-xp 00000000 b3:12 12189      /usr/lib/libdisplay-panel.so.0.1
[3-601.3336] 43cc1000-43cd1000 ---p 00001000 b3:12 12189      /usr/lib/libdisplay-panel.so.0.1
[3-601.3336] 43cd1000-43cd2000 r--p 00001000 b3:12 12189      /usr/lib/libdisplay-panel.so.0.1
[3-601.3336] 43cd2000-43cd3000 rw-p 00002000 b3:12 12189      /usr/lib/libdisplay-panel.so.0.1
[3-601.3336] 43ce0000-43cea000 r-xp 00000000 b3:12 16696      /usr/lib/libdrm.so.2.4.0
[3-601.3336] 43cea000-43cf9000 ---p 0000a000 b3:12 16696      /usr/lib/libdrm.so.2.4.0
[3-601.3337] 43cf9000-43cfa000 r--p 00009000 b3:12 16696      /usr/lib/libdrm.so.2.4.0
[3-601.3337] 43cfa000-43cfb000 rw-p 0000a000 b3:12 16696      /usr/lib/libdrm.so.2.4.0
[3-601.3337] 43d00000-43d08000 r-xp 00000000 b3:12 16151      /usr/lib/libmmfcommon.so.0.0.0
[3-601.3337] 43d08000-43d17000 ---p 00008000 b3:12 16151      /usr/lib/libmmfcommon.so.0.0.0
[3-601.3337] 43d17000-43d18000 r--p 00007000 b3:12 16151      /usr/lib/libmmfcommon.so.0.0.0
[3-601.3337] 43d18000-43d19000 rw-p 00008000 b3:12 16151      /usr/lib/libmmfcommon.so.0.0.0
[3-601.3337] 43d20000-43d21000 r-xp 00000000 b3:12 13540      /usr/lib/libpower-control-c-glue.so.0.1
[3-601.3337] 43d21000-43d30000 ---p 00001000 b3:12 13540      /usr/lib/libpower-control-c-glue.so.0.1
[3-601.3337] 43d30000-43d31000 rw-p 00000000 b3:12 13540      /usr/lib/libpower-control-c-glue.so.0.1
[3-601.3337] 43d40000-43d41000 r-xp 00000000 b3:12 12451      /usr/lib/libpower-control.so.0.1
[3-601.3338] 43d41000-43d50000 ---p 00001000 b3:12 12451      /usr/lib/libpower-control.so.0.1
[3-601.3338] 43d50000-43d51000 r--p 00000000 b3:12 12451      /usr/lib/libpower-control.so.0.1
[3-601.3338] 43d51000-43d52000 rw-p 00001000 b3:12 12451      /usr/lib/libpower-control.so.0.1
[3-601.3338] 43d60000-43d63000 r-xp 00000000 b3:12 15171      /usr/lib/libsec-video-tuner-check.so.0.1.0
[3-601.3338] 43d63000-43d72000 ---p 00003000 b3:12 15171      /usr/lib/libsec-video-tuner-check.so.0.1.0
[3-601.3338] 43d72000-43d73000 r--p 00002000 b3:12 15171      /usr/lib/libsec-video-tuner-check.so.0.1.0
[3-601.3338] 43d73000-43d74000 rw-p 00003000 b3:12 15171      /usr/lib/libsec-video-tuner-check.so.0.1.0
[3-601.3338] 43d80000-43e15000 r-xp 00000000 b3:12 11717      /usr/lib/libtvs-chms.so
[3-601.3338] 43e15000-43e24000 ---p 00095000 b3:12 11717      /usr/lib/libtvs-chms.so
[3-601.3339] 43e24000-43e27000 r--p 00094000 b3:12 11717      /usr/lib/libtvs-chms.so
[3-601.3339] 43e27000-43e29000 rw-p 00097000 b3:12 11717      /usr/lib/libtvs-chms.so
[3-601.3339] 43e29000-43e2a000 rw-p 00000000 00:00 0
[3-601.3339] 43e40000-43e54000 r-xp 00000000 b3:12 15393      /usr/lib/libboost_filesystem.so.1.58.0
[3-601.3339] 43e54000-43e63000 ---p 00014000 b3:12 15393      /usr/lib/libboost_filesystem.so.1.58.0
[3-601.3339] 43e63000-43e64000 r--p 00013000 b3:12 15393      /usr/lib/libboost_filesystem.so.1.58.0
[3-601.3339] 43e64000-43e65000 rw-p 00014000 b3:12 15393      /usr/lib/libboost_filesystem.so.1.58.0
[3-601.3339] 43e70000-43e8d000 r-xp 00000000 b3:12 16466      /usr/lib/liblibtv-plpmanager.so
[3-601.3339] 43e8d000-43e9c000 ---p 0001d000 b3:12 16466      /usr/lib/liblibtv-plpmanager.so
[3-601.3339] 43e9c000-43e9d000 r--p 0001c000 b3:12 16466      /usr/lib/liblibtv-plpmanager.so
[3-601.3340] 43e9d000-43e9e000 rw-p 0001d000 b3:12 16466      /usr/lib/liblibtv-plpmanager.so
[3-601.3340] 43ea0000-43ebc000 r-xp 00000000 b3:12 17035      /usr/lib/libsensor-genuine.so.4.0.4
[3-601.3340] 43ebc000-43ecb000 ---p 0001c000 b3:12 17035      /usr/lib/libsensor-genuine.so.4.0.4
[3-601.3340] 43ecb000-43ecc000 rw-p 0001b000 b3:12 17035      /usr/lib/libsensor-genuine.so.4.0.4
[3-601.3340] 43ed0000-43ee1000 r-xp 00000000 b3:12 15268      /usr/lib/libsensord-shared.so
[3-601.3340] 43ee1000-43ef0000 ---p 00011000 b3:12 15268      /usr/lib/libsensord-shared.so
[3-601.3340] 43ef0000-43ef1000 r--p 00010000 b3:12 15268      /usr/lib/libsensord-shared.so
[3-601.3340] 43ef1000-43ef2000 rw-p 00011000 b3:12 15268      /usr/lib/libsensord-shared.so
[3-601.3340] 43f00000-43f08000 r-xp 00000000 b3:12 12157      /usr/lib/libappcore-common.so.1.14.1
[3-601.3341] 43f08000-43f17000 ---p 00008000 b3:12 12157      /usr/lib/libappcore-common.so.1.14.1
[3-601.3341] 43f17000-43f18000 r--p 00007000 b3:12 12157      /usr/lib/libappcore-common.so.1.14.1
[3-601.3341] 43f18000-43f19000 rw-p 00008000 b3:12 12157      /usr/lib/libappcore-common.so.1.14.1
[3-601.3341] 43f20000-43f22000 r-xp 00000000 b3:12 17099      /usr/lib/libboost_system.so.1.58.0
[3-601.3341] 43f22000-43f31000 ---p 00002000 b3:12 17099      /usr/lib/libboost_system.so.1.58.0
[3-601.3341] 43f31000-43f32000 r--p 00001000 b3:12 17099      /usr/lib/libboost_system.so.1.58.0
[3-601.3341] 43f32000-43f33000 rw-p 00002000 b3:12 17099      /usr/lib/libboost_system.so.1.58.0
[3-601.3341] 43f40000-43f44000 r-xp 00000000 b3:12 17021      /usr/lib/libcapi-appfw-app-control-uri.so.0.11.11
[3-601.3341] 43f44000-43f53000 ---p 00004000 b3:12 17021      /usr/lib/libcapi-appfw-app-control-uri.so.0.11.11
[3-601.3342] 43f53000-43f54000 r--p 00003000 b3:12 17021      /usr/lib/libcapi-appfw-app-control-uri.so.0.11.11
[3-601.3342] 43f54000-43f55000 rw-p 00004000 b3:12 17021      /usr/lib/libcapi-appfw-app-control-uri.so.0.11.11
[3-601.3342] 43f60000-43f67000 r-xp 00000000 b3:12 11187      /usr/lib/libcapi-appfw-app-control.so.0.11.11
[3-601.3342] 43f67000-43f76000 ---p 00007000 b3:12 11187      /usr/lib/libcapi-appfw-app-control.so.0.11.11
[3-601.3342] 43f76000-43f77000 r--p 00006000 b3:12 11187      /usr/lib/libcapi-appfw-app-control.so.0.11.11
[3-601.3342] 43f77000-43f78000 rw-p 00007000 b3:12 11187      /usr/lib/libcapi-appfw-app-control.so.0.11.11
[3-601.3342] 43f80000-43fe4000 r-xp 00000000 b3:12 11221      /usr/lib/libtvs-pvr.so
[3-601.3342] 43fe4000-43ff4000 ---p 00064000 b3:12 11221      /usr/lib/libtvs-pvr.so
[3-601.3342] 43ff4000-43ff5000 r--p 00064000 b3:12 11221      /usr/lib/libtvs-pvr.so
[3-601.3342] 43ff5000-43ff7000 rw-p 00065000 b3:12 11221      /usr/lib/libtvs-pvr.so
[3-601.3343] 44000000-44061000 r-xp 00000000 b3:12 12282      /usr/lib/libsecurity-manager-commons.so.1.0.2
[3-601.3343] 44061000-44071000 ---p 00061000 b3:12 12282      /usr/lib/libsecurity-manager-commons.so.1.0.2
[3-601.3343] 44071000-44073000 rw-p 00061000 b3:12 12282      /usr/lib/libsecurity-manager-commons.so.1.0.2
[3-601.3343] 44080000-440d3000 r-xp 00000000 b3:12 16185      /usr/lib/libboost_serialization.so.1.58.0
[3-601.3343] 440d3000-440e3000 ---p 00053000 b3:12 16185      /usr/lib/libboost_serialization.so.1.58.0
[3-601.3343] 440e3000-440e4000 r--p 00053000 b3:12 16185      /usr/lib/libboost_serialization.so.1.58.0
[3-601.3343] 440e4000-440e6000 rw-p 00054000 b3:12 16185      /usr/lib/libboost_serialization.so.1.58.0
[3-601.3343] 440f0000-44130000 r-xp 00000000 b3:12 11420      /usr/lib/libtvs-dbms.so
[3-601.3343] 44130000-4413f000 ---p 00040000 b3:12 11420      /usr/lib/libtvs-dbms.so
[3-601.3344] 4413f000-44140000 r--p 0003f000 b3:12 11420      /usr/lib/libtvs-dbms.so
[3-601.3344] 44140000-44142000 rw-p 00040000 b3:12 11420      /usr/lib/libtvs-dbms.so
[3-601.3344] 44150000-44158000 r-xp 00000000 b3:12 11258      /usr/lib/libcrypt-2.24.so
[3-601.3344] 44158000-44167000 ---p 00008000 b3:12 11258      /usr/lib/libcrypt-2.24.so
[3-601.3344] 44167000-44168000 r--p 00007000 b3:12 11258      /usr/lib/libcrypt-2.24.so
[3-601.3344] 44168000-44169000 rw-p 00008000 b3:12 11258      /usr/lib/libcrypt-2.24.so
[3-601.3344] 44169000-44190000 rw-p 00000000 00:00 0
[3-601.3344] 441a0000-441bf000 r-xp 00000000 b3:12 11836      /usr/lib/libboost_thread.so.1.58.0
[3-601.3344] 441bf000-441ce000 ---p 0001f000 b3:12 11836      /usr/lib/libboost_thread.so.1.58.0
[3-601.3344] 441ce000-441cf000 r--p 0001e000 b3:12 11836      /usr/lib/libboost_thread.so.1.58.0
[3-601.3345] 441cf000-441d0000 rw-p 0001f000 b3:12 11836      /usr/lib/libboost_thread.so.1.58.0
[3-601.3345] 441e0000-44238000 r-xp 00000000 b3:12 11766      /usr/lib/libtvs-tpms.so
[3-601.3345] 44238000-44248000 ---p 00058000 b3:12 11766      /usr/lib/libtvs-tpms.so
[3-601.3345] 44248000-44249000 r--p 00058000 b3:12 11766      /usr/lib/libtvs-tpms.so
[3-601.3345] 44249000-4424b000 rw-p 00059000 b3:12 11766      /usr/lib/libtvs-tpms.so
[3-601.3345] 44260000-4426b000 r-xp 00000000 b3:12 11802      /usr/lib/libprocps.so.7.1.0
[3-601.3345] 4426b000-4427b000 ---p 0000b000 b3:12 11802      /usr/lib/libprocps.so.7.1.0
[3-601.3345] 4427b000-4427c000 r--p 0000b000 b3:12 11802      /usr/lib/libprocps.so.7.1.0
[3-601.3345] 4427c000-4427d000 rw-p 0000c000 b3:12 11802      /usr/lib/libprocps.so.7.1.0
[3-601.3345] 4427d000-4428f000 rw-p 00000000 00:00 0
[3-601.3346] 442a0000-442b6000 r-xp 00000000 b3:12 16922      /usr/lib/libcapi-system-usbdevice.so
[3-601.3346] 442b6000-442c6000 ---p 00016000 b3:12 16922      /usr/lib/libcapi-system-usbdevice.so
[3-601.3346] 442c6000-442c9000 r--p 00016000 b3:12 16922      /usr/lib/libcapi-system-usbdevice.so
[3-601.3346] 442c9000-442ca000 rw-p 00019000 b3:12 16922      /usr/lib/libcapi-system-usbdevice.so
[3-601.3346] 442d0000-442e1000 r-xp 00000000 b3:12 16741      /usr/lib/libcynara-admin.so.0.14.24
[3-601.3346] 442e1000-442f0000 ---p 00011000 b3:12 16741      /usr/lib/libcynara-admin.so.0.14.24
[3-601.3346] 442f0000-442f1000 r--p 00010000 b3:12 16741      /usr/lib/libcynara-admin.so.0.14.24
[3-601.3346] 442f1000-442f2000 rw-p 00011000 b3:12 16741      /usr/lib/libcynara-admin.so.0.14.24
[3-601.3346] 44300000-44317000 r-xp 00000000 b3:12 11039      /usr/lib/libcynara-storage.so.0.14.24
[3-601.3347] 44317000-44326000 ---p 00017000 b3:12 11039      /usr/lib/libcynara-storage.so.0.14.24
[3-601.3347] 44326000-44327000 r--p 00016000 b3:12 11039      /usr/lib/libcynara-storage.so.0.14.24
[3-601.3347] 44327000-44328000 rw-p 00017000 b3:12 11039      /usr/lib/libcynara-storage.so.0.14.24
[3-601.3347] 44330000-4434c000 r-xp 00000000 b3:12 11921      /usr/lib/libtv_recorder.so.0.0.0
[3-601.3347] 4434c000-4435b000 ---p 0001c000 b3:12 11921      /usr/lib/libtv_recorder.so.0.0.0
[3-601.3347] 4435b000-4435c000 r--p 0001b000 b3:12 11921      /usr/lib/libtv_recorder.so.0.0.0
[3-601.3347] 4435c000-4435d000 rw-p 0001c000 b3:12 11921      /usr/lib/libtv_recorder.so.0.0.0
[3-601.3347] 44360000-44379000 r-xp 00000000 b3:12 11871      /usr/lib/libsecurity-manager-client.so.3.0.0
[3-601.3347] 44379000-44388000 ---p 00019000 b3:12 11871      /usr/lib/libsecurity-manager-client.so.3.0.0
[3-601.3348] 44388000-44389000 r--p 00018000 b3:12 11871      /usr/lib/libsecurity-manager-client.so.3.0.0
[3-601.3348] 44383:12 11677      /usr/lib/libtizen-extension-tv-client.so.0.0.0
[3-601.3371] 457e3000-457e4000 rw-p 00003000 b3:12 11677      /usr/lib/libtizen-extension-tv-client.so.0.0.0
[3-601.3371] 457f0000-45975000 r-xp 00000000 b3:12 16125      /usr/lib/libtvs-live.so
[3-601.3371] 45975000-45985000 ---p 00185000 b3:12 16125      /usr/lib/libtvs-live.so
[3-601.3371] 45985000-45989000 r--p 00185000 b3:12 16125      /usr/lib/libtvs-live.so
[3-601.3371] 45989000-4598d000 rw-p 00189000 b3:12 16125      /usr/lib/libtvs-live.so
[3-601.3372] 4598d000-4598e000 rw-p 00000000 00:00 0
[3-601.3372] 45990000-45a80000 r-xp 00000000 b3:12 11992      /usr/lib/libtvs-dsm.so
[3-601.3372] 45a80000-45a8f000 ---p 000f0000 b3:12 11992      /usr/lib/libtvs-dsm.so
[3-601.3372] 45a8f000-45a92000 r--p 000ef000 b3:12 11992      /usr/lib/libtvs-dsm.so
[3-601.3372] 45a92000-45a94000 rw-p 000f2000 b3:12 11992      /usr/lib/libtvs-dsm.so
[3-601.3372] 45a94000-45aa5000 rw-p 00000000 00:00 0
[3-601.3372] 45ab0000-45ab2000 r-xp 00000000 b3:12 11988      /usr/lib/libug_duck.so
[3-601.3372] 45ab2000-45ac1000 ---p 00002000 b3:12 11988      /usr/lib/libug_duck.so
[3-601.3372] 45ac1000-45ac2000 r--p 00001000 b3:12 11988      /usr/lib/libug_duck.so
[3-601.3372] 45ac2000-45ac3000 rw-p 00002000 b3:12 11988      /usr/lib/libug_duck.so
[3-601.3373] 45b50000-45c43000 r-xp 00000000 b3:12 14413      /usr/lib/libtvs-api.so
[3-601.3373] 45c43000-45c53000 ---p 000f3000 b3:12 14413      /usr/lib/libtvs-api.so
[3-601.3373] 45c53000-45c56000 r--p 000f3000 b3:12 14413      /usr/lib/libtvs-api.so
[3-601.3373] 45c56000-45c58000 rw-p 000f6000 b3:12 14413      /usr/lib/libtvs-api.so
[3-601.3373] 45c58000-45c5f000 rw-p 00000000 00:00 0
[3-601.3373] 45c70000-45cc0000 r-xp 00000000 b3:12 11714      /usr/lib/libtvs-api-ipc.so
[3-601.3373] 45cc0000-45ccf000 ---p 00050000 b3:12 11714      /usr/lib/libtvs-api-ipc.so
[3-601.3373] 45ccf000-45cd1000 r--p 0004f000 b3:12 11714      /usr/lib/libtvs-api-ipc.so
[3-601.3373] 45cd1000-45cd3000 rw-p 00051000 b3:12 11714      /usr/lib/libtvs-api-ipc.so
[3-601.3373] 45d20000-45d39000 r-xp 00000000 b3:12 12070      /usr/lib/libdbus-glib-1.so.2.2.2
[3-601.3374] 45d39000-45d48000 ---p 00019000 b3:12 12070      /usr/lib/libdbus-glib-1.so.2.2.2
[3-601.3374] 45d48000-45d49000 r--p 00018000 b3:12 12070      /usr/lib/libdbus-glib-1.so.2.2.2
[3-601.3374] 45d49000-45d4a000 rw-p 00019000 b3:12 12070      /usr/lib/libdbus-glib-1.so.2.2.2
[3-601.3374] 45de0000-45df9000 r-xp 00000000 b3:12 12267      /usr/lib/libep-iptv-service-api.so
[3-601.3374] 45df9000-45e08000 ---p 00019000 b3:12 12267      /usr/lib/libep-iptv-service-api.so
[3-601.3374] 45e08000-45e09000 r--p 00018000 b3:12 12267      /usr/lib/libep-iptv-service-api.so
[3-601.3374] 45e09000-45e0a000 rw-p 00019000 b3:12 12267      /usr/lib/libep-iptv-service-api.so
[3-601.3374] 45e90000-45f40000 r-xp 00000000 b3:12 15922      /usr/lib/libavoc.so
[3-601.3374] 45f40000-45f4f000 ---p 000b0000 b3:12 15922      /usr/lib/libavoc.so
[3-601.3374] 45f4f000-45f5f000 r--p 000af000 b3:12 15922      /usr/lib/libavoc.so
[3-601.3375] 45f5f000-45f60000 rw-p 000bf000 b3:12 15922      /usr/lib/libavoc.so
[3-601.3375] 45ff0000-46005000 r-xp 00000000 b3:12 12097      /usr/lib/libmicom.so.0.1
[3-601.3375] 46005000-46014000 ---p 00015000 b3:12 12097      /usr/lib/libmicom.so.0.1
[3-601.3375] 46014000-46015000 r--p 00014000 b3:12 12097      /usr/lib/libmicom.so.0.1
[3-601.3375] 46015000-46016000 rw-p 00015000 b3:12 12097      /usr/lib/libmicom.so.0.1
[3-601.3375] 46020000-4602c000 r-xp 00000000 b3:12 11641      /usr/lib/libapputil.so.0.1.0
[3-601.3375] 4602c000-4603b000 ---p 0000c000 b3:12 11641      /usr/lib/libapputil.so.0.1.0
[3-601.3375] 4603b000-4603c000 r--p 0000b000 b3:12 11641      /usr/lib/libapputil.so.0.1.0
[3-601.3375] 4603c000-4603d000 rw-p 0000c000 b3:12 11641      /usr/lib/libapputil.so.0.1.0
[3-601.3376] 46060000-46062000 r-xp 00000000 b3:12 15331      /usr/lib/libbptime.so
[3-601.3376] 46062000-46071000 ---p 00002000 b3:12 15331      /usr/lib/libbptime.so
[3-601.3376] 46071000-46072000 r--p 00001000 b3:12 15331      /usr/lib/libbptime.so
[3-601.3376] 46072000-46073000 rw-p 00002000 b3:12 15331      /usr/lib/libbptime.so
[3-601.3376] 46080000-4608b000 r-xp 00000000 b3:12 10910      /usr/lib/libfbclient.so.0.1.2
[3-601.3376] 4608b000-4609a000 ---p 0000b000 b3:12 10910      /usr/lib/libfbclient.so.0.1.2
[3-601.3376] 4609a000-4609b000 r--p 0000a000 b3:12 10910      /usr/lib/libfbclient.so.0.1.2
[3-601.3376] 4609b000-4609c000 rw-p 0000b000 b3:12 10910      /usr/lib/libfbclient.so.0.1.2
[3-601.3376] 4609c000-4609d000 rw-p 00000000 00:00 0
[3-601.3376] 460a0000-460a1000 r-xp 00000000 b3:12 16333      /usr/lib/libnvram-c-glue.so.0.1
[3-601.3377] 460a1000-460b0000 ---p 00001000 b3:12 16333      /usr/lib/libnvram-c-glue.so.0.1
[3-601.3377] 460b0000-460b1000 rw-p 00000000 b3:12 16333      /usr/lib/libnvram-c-glue.so.0.1
[3-601.3377] 460c0000-460ca000 r-xp 00000000 b3:12 13588      /usr/lib/libIrbCtrlApi.so
[3-601.3377] 460ca000-460d9000 ---p 0000a000 b3:12 13588      /usr/lib/libIrbCtrlApi.so
[3-601.3377] 460d9000-460da000 r--p 00009000 b3:12 13588      /usr/lib/libIrbCtrlApi.so
[3-601.3377] 460da000-460db000 rw-p 0000a000 b3:12 13588      /usr/lib/libIrbCtrlApi.so
[3-601.3377] 460e0000-461d4000 r-xp 00000000 b3:12 13496      /usr/lib/libtvs-scan.so
[3-601.3377] 461d4000-461e3000 ---p 000f4000 b3:12 13496      /usr/lib/libtvs-scan.so
[3-601.3377] 461e3000-461e8000 r--p 000f3000 b3:12 13496      /usr/lib/libtvs-scan.so
[3-601.3377] 461e8000-461ec000 rw-p 000f8000 b3:12 13496      /usr/lib/libtvs-scan.so
[3-601.3378] 46360000-4639f000 r-xp 00000000 b3:12 11808      /usr/lib/libteec.so
[3-601.3378] 4639f000-463af000 ---p 0003f000 b3:12 11808      /usr/lib/libteec.so
[3-601.3378] 463af000-463b0000 rw-p 0003f000 b3:12 11808      /usr/lib/libteec.so
[3-601.3378] 463c0000-463fc000 r-xp 00000000 b3:12 11502      /usr/lib/libcryptocore.so.0.1.0
[3-601.3378] 463fc000-4640b000 ---p 0003c000 b3:12 11502      /usr/lib/libcryptocore.so.0.1.0
[3-601.3378] 4640b000-4640c000 r--p 0003b000 b3:12 11502      /usr/lib/libcryptocore.so.0.1.0
[3-601.3378] 4640c000-4640e000 rw-p 0003c000 b3:12 11502      /usr/lib/libcryptocore.so.0.1.0
[3-601.3378] 464a0000-464a2000 r-xp 00000000 b3:12 16938      /usr/lib/libaul-ex.so.0.1.0
[3-601.3378] 464a2000-464b1000 ---p 00002000 b3:12 16938      /usr/lib/libaul-ex.so.0.1.0
[3-601.3378] 464b1000-464b2000 r--p 00001000 b3:12 16938      /usr/lib/libaul-ex.so.0.1.0
[3-601.3379] 464b2000-464b3000 rw-p 00002000 b3:12 16938      /usr/lib/libaul-ex.so.0.1.0
[3-601.3379] 46500000-46501000 r-xp 00000000 b3:12 11793      /usr/lib/libnvram.so.0.1
[3-601.3379] 46501000-46510000 ---p 00001000 b3:12 11793      /usr/lib/libnvram.so.0.1
[3-601.3379] 46510000-46511000 r--p 00000000 b3:12 11793      /usr/lib/libnvram.so.0.1
[3-601.3379] 46511000-46512000 rw-p 00001000 b3:12 11793      /usr/lib/libnvram.so.0.1
[3-601.3379] 46540000-46591000 r-xp 00000000 b3:12 11783      /usr/lib/libcurl.so.4.5.0
[3-601.3379] 46591000-465a1000 ---p 00051000 b3:12 11783      /usr/lib/libcurl.so.4.5.0
[3-601.3379] 465a1000-465a2000 r--p 00051000 b3:12 11783      /usr/lib/libcurl.so.4.5.0
[3-601.3380] 465a2000-465a3000 rw-p 00052000 b3:12 11783      /usr/lib/libcurl.so.4.5.0
[3-601.3380] 466a0000-466c8000 r-xp 00000000 b3:12 16112      /usr/lib/libsecurestorage-client.so.1.0.0
[3-601.3380] 466c8000-466d7000 ---p 00028000 b3:12 16112      /usr/lib/libsecurestorage-client.so.1.0.0
[3-601.3380] 466d7000-466d8000 r--p 00027000 b3:12 16112      /usr/lib/libsecurestorage-client.so.1.0.0
[3-601.3380] 466d8000-466d9000 rw-p 00028000 b3:12 16112      /usr/lib/libsecurestorage-client.so.1.0.0
[3-601.3380] 46710000-46727000 r-xp 00000000 b3:12 16823      /usr/lib/libnghttp2.so.14.17.1
[3-601.3380] 46727000-46736000 ---p 00017000 b3:12 16823      /usr/lib/libnghttp2.so.14.17.1
[3-601.3380] 46736000-46738000 r--p 00016000 b3:12 16823      /usr/lib/libnghttp2.so.14.17.1
[3-601.3380] 46738000-46739000 rw-p 00018000 b3:12 16823      /usr/lib/libnghttrw-p 00034000 b3:12 16328      /usr/lib/libaul.so.0.20.4
[2-626.0883] 43990000-43999000 r-xp 00000000 b3:12 16762      /usr/lib/libstorage.so.0.1
[2-626.0883] 43999000-439a8000 ---p 00009000 b3:12 16762      /usr/lib/libstorage.so.0.1
[2-626.0884] 439a8000-439a9000 r--p 00008000 b3:12 16762      /usr/lib/libstorage.so.0.1
[2-626.0884] 439a9000-439aa000 rw-p 00009000 b3:12 16762      /usr/lib/libstorage.so.0.1
[2-626.0884] 439b0000-439b4000 r-xp 00000000 b3:12 11135      /usr/lib/libxdgmime.so.1.1.0
[2-626.0884] 439b4000-439c4000 ---p 00004000 b3:12 11135      /usr/lib/libxdgmime.so.1.1.0
[2-626.0884] 439c4000-439c5000 r--p 00004000 b3:12 11135      /usr/lib/libxdgmime.so.1.1.0
[2-626.0884] 439c5000-439c6000 rw-p 00005000 b3:12 11135      /usr/lib/libxdgmime.so.1.1.0
[2-626.0884] 439d0000-439d3000 r-xp 00000000 b3:12 11552      /usr/lib/libcap.so.2.24
[2-626.0884] 439d3000-439e2000 ---p 00003000 b3:12 11552      /usr/lib/libcap.so.2.24
[2-626.0884] 439e2000-439e3000 r--p 00002000 b3:12 11552      /usr/lib/libcap.so.2.24
[2-626.0885] 439e3000-439e4000 rw-p 00003000 b3:12 11552      /usr/lib/libcap.so.2.24
[2-626.0885] 439f0000-439f2000 r-xp 00000000 b3:12 16393      /usr/lib/libsmart-deadlock.so
[2-626.0885] 439f2000-43a01000 ---p 00002000 b3:12 16393      /usr/lib/libsmart-deadlock.so
[2-626.0885] 43a01000-43a02000 r--p 00001000 b3:12 16393      /usr/lib/libsmart-deadlock.so
[2-626.0885] 43a02000-43a03000 rw-p 00002000 b3:12 16393      /usr/lib/libsmart-deadlock.so
[2-626.0885] 43a10000-43b35000 r-xp 00000000 b3:12 14712      /usr/lib/libcrypto.so.1.0.0
[2-626.0885] 43b35000-43b44000 ---p 00125000 b3:12 14712      /usr/lib/libcrypto.so.1.0.0
[2-626.0885] 43b44000-43b52000 r--p 00124000 b3:12 14712      /usr/lib/libcrypto.so.1.0.0
[2-626.0885] 43b52000-43b59000 rw-p 00132000 b3:12 14712      /usr/lib/libcrypto.so.1.0.0
[2-626.0885] 43b59000-43b5c000 rw-p 00000000 00:00 0
[2-626.0886] 43b60000-43bbf000 r-xp 00000000 b3:12 16184      /usr/lib/libeina.so.1.23.99
[2-626.0886] 43bbf000-43bce000 ---p 0005f000 b3:12 16184      /usr/lib/libeina.so.1.23.99
[2-626.0886] 43bce000-43bcf000 r--p 0005e000 b3:12 16184      /usr/lib/libeina.so.1.23.99
[2-626.0886] 43bcf000-43bd0000 rw-p 0005f000 b3:12 16184      /usr/lib/libeina.so.1.23.99
[2-626.0886] 43bd0000-43bd1000 rw-p 00000000 00:00 0
[2-626.0886] 43be0000-43c1c000 r-xp 00000000 b3:12 16910      /usr/lib/libssl.so.1.0.0
[2-626.0886] 43c1c000-43c2c000 ---p 0003c000 b3:12 16910      /usr/lib/libssl.so.1.0.0
[2-626.0886] 43c2c000-43c2e000 r--p 0003c000 b3:12 16910      /usr/lib/libssl.so.1.0.0
[2-626.0886] 43c2e000-43c32000 rw-p 0003e000 b3:12 16910      /usr/lib/libssl.so.1.0.0
[2-626.0886] 43c40000-43c52000 r-xp 00000000 b3:12 16498      /usr/lib/libdeviced.so.1.0.3
[2-626.0887] 43c52000-43c61000 ---p 00012000 b3:12 16498      /usr/lib/libdeviced.so.1.0.3
[2-626.0887] 43c61000-43c62000 r--p 00011000 b3:12 16498      /usr/lib/libdeviced.so.1.0.3
[2-626.0887] 43c62000-43c63000 rw-p 00012000 b3:12 16498      /usr/lib/libdeviced.so.1.0.3
[2-626.0887] 43c70000-43c8c000 r-xp 00000000 b3:12 16443      /usr/lib/libjsoncpp.so.0.10.4
[2-626.0887] 43c8c000-43c9b000 ---p 0001c000 b3:12 16443      /usr/lib/libjsoncpp.so.0.10.4
[2-626.0887] 43c9b000-43c9c000 r--p 0001b000 b3:12 16443      /usr/lib/libjsoncpp.so.0.10.4
[2-626.0887] 43c9c000-43c9d000 rw-p 0001c000 b3:12 16443      /usr/lib/libjsoncpp.so.0.10.4
[2-626.0887] 43ca0000-43ca1000 r-xp 00000000 b3:12 16800      /usr/lib/libdisplay-panel-c-glue.so.0.1
[2-626.0887] 43ca1000-43cb0000 ---p 00001000 b3:12 16800      /usr/lib/libdisplay-panel-c-glue.so.0.1
[2-626.0888] 43cb0000-43cb1000 rw-p 00000000 b3:12 16800      /usr/lib/libdisplay-panel-c-glue.so.0.1
[2-626.0888] 43cc0000-43cc1000 r-xp 00000000 b3:12 12189      /usr/lib/libdisplay-panel.so.0.1
[2-626.0888] 43cc1000-43cd1000 ---p 00001000 b3:12 12189      /usr/lib/libdisplay-panel.so.0.1
[2-626.0888] 43cd1000-43cd2000 r--p 00001000 b3:12 12189      /usr/lib/libdisplay-panel.so.0.1
[2-626.0888] 43cd2000-43cd3000 rw-p 00002000 b3:12 12189      /usr/lib/libdisplay-panel.so.0.1
[2-626.0888] 43ce0000-43cea000 r-xp 00000000 b3:12 16696      /usr/lib/libdrm.so.2.4.0
[2-626.0888] 43cea000-43cf9000 ---p 0000a000 b3:12 16696      /usr/lib/libdrm.so.2.4.0
[2-626.0888] 43cf9000-43cfa000 r--p 00009000 b3:12 16696      /usr/lib/libdrm.so.2.4.0
[2-626.0888] 43cfa000-43cfb000 rw-p 0000a000 b3:12 16696      /usr/lib/libdrm.so.2.4.0
[2-626.0889] 43d00000-43d08000 r-xp 00000000 b3:12 16151      /usr/lib/libmmfcommon.so.0.0.0
[2-626.0889] 43d08000-43d17000 ---p 00008000 b3:12 16151      /usr/lib/libmmfcommon.so.0.0.0
[2-626.0889] 43d17000-43d18000 r--p 00007000 b3:12 16151      /usr/lib/libmmfcommon.so.0.0.0
[2-626.0889] 43d18000-43d19000 rw-p 00008000 b3:12 16151      /usr/lib/libmmfcommon.so.0.0.0
[2-626.0889] 43d20000-43d21000 r-xp 00000000 b3:12 13540      /usr/lib/libpower-control-c-glue.so.0.1
[2-626.0889] 43d21000-43d30000 ---p 00001000 b3:12 13540      /usr/lib/libpower-control-c-glue.so.0.1
[2-626.0889] 43d30000-43d31000 rw-p 00000000 b3:12 13540      /usr/lib/libpower-control-c-glue.so.0.1
[2-626.0889] 43d40000-43d41000 r-xp 00000000 b3:12 12451      /usr/lib/libpower-control.so.0.1
[2-626.0889] 43d41000-43d50000 ---p 00001000 b3:12 12451      /usr/lib/libpower-control.so.0.1
[2-626.0889] 43d50000-43d51000 r--p 00000000 b3:12 12451      /usr/lib/libpower-control.so.0.1
[2-626.0890] 43d51000-43d52000 rw-p 00001000 b3:12 12451      /usr/lib/libpower-control.so.0.1
[2-626.0890] 43d60000-43d63000 r-xp 00000000 b3:12 15171      /usr/lib/libsec-video-tuner-check.so.0.1.0
[2-626.0890] 43d63000-43d72000 ---p 00003000 b3:12 15171      /usr/lib/libsec-video-tuner-check.so.0.1.0
[2-626.0890] 43d72000-43d73000 r--p 00002000 b3:12 15171      /usr/lib/libsec-video-tuner-check.so.0.1.0
[2-626.0890] 43d73000-43d74000 rw-p 00003000 b3:12 15171      /usr/lib/libsec-video-tuner-check.so.0.1.0
[2-626.0890] 43d80000-43e15000 r-xp 00000000 b3:12 11717      /usr/lib/libtvs-chms.so
[2-626.0890] 43e15000-43e24000 ---p 00095000 b3:12 11717      /usr/lib/libtvs-chms.so
[2-626.0890] 43e24000-43e27000 r--p 00094000 b3:12 11717      /usr/lib/libtvs-chms.so
[2-626.0890] 43e27000-43e29000 rw-p 00097000 b3:12 11717      /usr/lib/libtvs-chms.so
[2-626.0891] 43e29000-43e2a000 rw-p 00000000 00:00 0
[2-626.0891] 43e40000-43e54000 r-xp 00000000 b3:12 15393      /usr/lib/libboost_filesystem.so.1.58.0
[2-626.0891] 43e54000-43e63000 ---p 00014000 b3:12 15393      /usr/lib/libboost_filesystem.so.1.58.0
[2-626.0891] 43e63000-43e64000 r--p 00013000 b3:12 15393      /usr/lib/libboost_filesystem.so.1.58.0
[2-626.0891] 43e64000-43e65000 rw-p 00014000 b3:12 15393      /usr/lib/libboost_filesystem.so.1.58.0
[2-626.0891] 43e70000-43e8d000 r-xp 00000000 b3:12 16466      /usr/lib/liblibtv-plpmanager.so
[2-626.0891] 43e8d000-43e9c000 ---p 0001d000 b3:12 16466      /usr/lib/liblibtv-plpmanager.so
[2-626.0891] 43e9c000-43e9d000 r--p 0001c000 b3:12 16466      /usr/lib/liblibtv-plpmanager.so
[2-626.0891] 43e9d000-43e9e000 rw-p 0001d000 b3:12 16466      /usr/lib/liblibtv-plpmanager.so
[1-626.0891] [Extended-Mincore] do_minimal_core called for signal 6 and comm tv-viewer and group_leader_comm tv-viewer
[2-626.0892] 43ea0000-43ebc000 r-xp 00000000 b3:12 17035      /usr/lib/libsensor-genuine.so.4.0.4
[1-626.0892] [Extended-Mincore] [tv-viewer | 977] Waiting for get_coredump_config to return..
[2-626.0892] 43ebc000-43ecb000 ---p 0001c000 b3:12 17035      /usr/lib/libsensor-genuine.so.4.0.4
[2-626.0892] 43ecb000-43ecc000 rw-p 0001b000 b3:12 17035      /usr/lib/libsensor-genuine.so.4.0.4
[2-626.0892] 43ed0000-43ee1000 r-xp 00000000 b3:12 15268      /usr/lib/libsensord-shared.so
[2-626.0892] 43ee1000-43ef0000 ---p 00011000 b3:12 15268      /usr/lib/libsensord-shared.so
[2-626.0892] 43ef0000-43ef1000 r--p 00010000 b3:12 15268      /usr/lib/libsensord-shared.so
[2-626.0892] 43ef1000-43ef2000 rw-p 00011000 b3:12 15268      /usr/lib/libsensord-shared.so
[2-626.0892] 43f00000-43f08000 r-xp 00000000 b3:12 12157      /usr/lib/libappcore-common.so.1.14.1
[2-626.0892] 43f08000-43f170[2-626.0954] f4e0: 00000003 00000003 00000003 00000003 00000003 00000003 00000003 00000003
[2-626.0954] f500: 00000003 00000000 000f6c60 00000014 42bb6620 0000001e 000000e8 000707e0
[2-626.0954] f520: 0005b419 0000001c 00000001 000fd018 00000003 00000003 00000003 00000003
[2-626.0954] f540: 00000003 00000003 00000003 00000003 00000003 00000003 00000003 00000003
[2-626.0954] f560: 00000003 00000003 00000003 00000003 00000003 00000003 00000003 00000003
[2-626.0954] f580: 00000000 b648c5e0 b648c188 41030000 ffffffff b648c120 00000000 00200000
[2-626.0954] f5a0: ffffffff b648c120 00000001 00000000 ffffffff 00071ec8 00070870 45650190
[2-626.0954] f5c0: be4cf5d8 456667b0 00000000 4102ffb4 00000000 0003f54b 000ff160 000ff164
[2-626.0955] f5e0: 00000000 4564eb15 01002001 00000002 00000000 00000000 00000000 00000000
[2-626.0955] f600: 00000000 00000001 00000000 00000003 00000003 00000003 00000003 00000003
[2-626.0955] f620: 00000003 00000003 00000003 00000003 00000003 00000003 00000003 00000003
[2-626.0955] f640: 00000003 00000003 00000003 00000003 00000003 00000003 00000003 00000000
[2-626.0955] f660: 00070870 0003e3f1 00000003 00000003 00000003 00000003 00000003 00000003
[2-626.0955] f680: 00000003 00000003 00000003 00000003 00000003 00000003 00000003 00000003
[2-626.0955] f6a0: 00000003 00000003 00000003 00000003 00000003 00000003 00000000 00000000
[2-626.0955] f6c0: 45666f3c 4565018c 45650190 be4cf6e8 456667b0 4563ebdb 45650190 45650b40
[2-626.0955] f6e0: 00000044 45650b80 00053350 00000000 0002d218 00000000 00000000 42a979f8
[2-626.0956] f700: 42bb63f0 be4cf854 00000001 0002b6f0 00000002 00000010 3c672c2d c082a299
[2-626.0956] f720: 00053350 00000000 0002d218 00000000 00000000 00000000 4102ffb4 00000000
[2-626.0956] f740: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2-626.0956] f760: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2-626.0956] f780: 00000001 000fcc08 00000073 000fcdc8 000fcc98 0000000a 000fcc98 00000039
[2-626.0956] f7a0: 000fcc98 000fcdd0 00000000 449314a8 44930cfd 449314d4 00000008 00000039
[2-626.0956] f7c0: 00000b91 be4cf9f4 42bb7008 44942070 00000027 44942000 44930b4d 42bb7008
[2-626.0956] f7e0: 44930b4d 44941ecc 00000001 be4cf854 44930b7b 4493168c 00000b91 be4cf9f4
[2-626.0956] f800: 00000001 44941ecc 44930b4d 410106cc 00000000 fffffffc 00000000 00000001
[2-626.0957] f820: 00000000 00000000 4102ffb4 41010828 00000000 00000000 0002d218 00000000
[2-626.0957] f840: 00000000 0002d244 000533b0 41010b30 be4cf854
[2-626.0957] -----------------------------------------------------------
[2-626.0957]
[1-626.2922] [Extended-Mincore] [tv-viewer | 977] get_coredump_config returned with core_type = 0
[3-627.5929] logger: settings-servic (p:1092) exceeds the log limit:800
[2-629.5392] usb usb2-port1: status 0101, change 0001, 12 Mb/s
[2-629.8002] usb 2-1: new high-speed USB device number 4 using NT72668-ehci
[2-634.4300] [kpi_fault_info] [k] 3 -> write function call
[2-634.4301] [kpi_fault_info] [k] 3 -> p:0x42bf7390 l:0x00000000 th:tvs-daemon pro:tvs-daemon ty:SIGABRT pgid:2961
[2-634.4301] [kpi_fault_info] [k] PC Start: 0x42bf0000 Offset: 0x00007390
[2-634.4301] [kpi_fault_info] [k] d_path : [/usr/lib/libpthread-2.24.so]
[2-634.4301] [kpi_fault_info] [k] exe d_path : [/usr/bin/tvs-daemon]
[2-634.4301] [kpi_fault_info] [K] start time:592161297857, end time:634429792497
[2-634.4301] [Pid:2961][VDLP COREDUMP] SIGNR:6
[2-634.4301]
[2-634.4302] [Pid:2961][COREDUMP_FAIL|COREDUMP_WAIT FAIL] Process termination is in progress
[1-634.4302] [Extended-Mincore] do_minimal_core called for signal 11 and comm tvs-daemon and group_leader_comm tvs-daemon
[1-634.4302] [Extended-Mincore] [tvs-daemon | 3004] Waiting for get_coredump_config to return..
[issue_report_agent][isCoreDumpExpected:411]error_kind = SIGABRT
[issue_report_agent][read_fault_info_in_proc:1154]error_count is max(10)
[1-634.6322] [Extended-Mincore] [tvs-daemon | 3004] get_coredump_config returned with core_type = 0
[1-635.0934] Before Recovery:
[1-635.0935] Code: f000 80c6 f7fb e8ee (6803) 695b
[1-635.0935] After Recovery:
[1-635.0935] send signal from KERNEL, SIG : 11, tvs-daemon(3643), handler:0x0 force_sig_info
[1-635.0935] tvs-daemon: unhandled page fault (11) at 0x00000000, code 0x017
[1-635.1255]  Ver : 6340677, release
[1-635.1255]  TV, Kant.SU2-Tizen, release, Trunk_2020_MP
[1-635.1255]  Linux version 4.1.10 (abuild@A1312DKG) (gcc version 6.2.1 20161213 (Tizen/Linaro GCC 6.2.1 2016.12/VDCosmos-20190704 7.8) ) #1 SMP PREEMPT Fri Jan 8 11:04:50 UTC 2021
[1-635.1255]  dtsversion=6290398_kantsu2-1.5G-cma console=ttyS0,115200 rs232=0 earlyprintk maxcpus=4 no_console_suspend only_entry_model root=/dev/mmcblk0p18 KDUMP=16 SELP_ENABLE=20208724 _nvtca9-16m rootfstype=vdfs ro init=/sbin/init mem=808M@32M mem=56M@968M mem=256M@2048M vmalloc=300M rootwait quiet bdinfo=00000091 model=4kbtin   pba_none
[1-635.1255]
[1-635.1255] Last Exception point
[1-635.1255] --------------------------------------------------------------------------------------
[1-635.1255] PC, LR MEMINFO
[1-635.1255] PC:43db2e8a, LR:43db2e8b
[1-635.1255] PC meminfo (0x43db328a to 0x43db328a)
[1-635.1255] 3280:
[1-635.1255] LR meminfo (0x43db268b to 0x43db328b)
[1-635.1256] 2680:                            2010f8cb 3f18f84a e8def7fb 4a374603 20014931
[1-635.1256] 26a0: 6058447a 60983248 f8c31d18 601ab00c 603b5864 a000f8c4 e8506063 33013f00
[1-635.1256] 26c0: 3fe2e8c0 d1f82a00 8f5bf3bf f7fb6878 4a2aed2a 4620492a 4479447a e92cf7fb
[1-635.1256] 26e0: 4618683b fdbcf039 f7fce779 f7fbe96c f8dbeb0a 46583000 4798685b ec62f7fc
[1-635.1256] 2700: 211c4604 f7fb4658 6878ed5c ece6f7fb 46304b1c f103447b f103011c 62390234
[1-635.1256] 2720: 637a3354 f03863bb 4640ff73 ff70f038 f7fc4620 4604ef18 eda0f7fc 4604e7e5
[1-635.1256] 2740: 4604e7e3 f0384630 e7eeff63 00074e60 00000b90 0007441a 0005622c 00000bb8
[1-635.1256] 2760: 000573a6 00000e20 00074390 00072c9c 00074342 00074324 0007299c 00075b28
[1-635.1256] 2780: 0003889f 0007427c e59f3014 e59f2014 e08f3003 e7932002 e3520000 012fff1e
[1-635.1256] 27a0: eafff3f3 00074c30 00000df8 48084b07 4a08447b 33034478 447a1a1b d9032b06
[1-635.1256] 27c0: 58d34b05 4718b103 bf004770 00075b04 00075b00 00074c0a 00000dc0 48094908
[1-635.1256] 27e0: 4b094479 1a094478 1089447b 71d1eb01 d0031049 589b4a05 4718b103 bf004770
[1-635.1256] 2800: 00075ad4 00075ad0 00074bdc 00000e04 4b0ab508 447b4a0a 781b447a 4b09b96b
[1-635.1256] 2820: b12358d3 447b4b08 f7fc6818 f7ffefec 4b06ffbd 447b2201 bd08701a 00075a9e
[1-635.1256] 2840: 00074bac 00000e10 000759da 00075a7e b5084807 68024478 447b4b06 e8bdb912
[1-635.1257] 2860: e7bb4008 589b4a04 d0f82b00 e7f64798 00072560 00074b6a 00000cf4 00000000
[1-635.1257] 2880: 1d03b480 af006840 fab01ac0 0940f080 f85d46bd 47707b04 41f0e92d f8d04606
[1-635.1257] 28a0: af008004 45a86885 4644bf18 6823d006 34304620 4798681b d1f842a5 8008f8c6
[1-635.1257] 28c0: 81f0e8bd 6842b480 6880af00 fab01a10 0940f080 f85d46bd 47707b04 6843b480
[1-635.1257] 28e0: 6083af00 f85d46bd 47707b04 6842b480 6880af00 fab01a10 0940f080 f85d46bd
[1-635.1257] 2900: 47707b04 2301b480 7303af00 f85d46bd 47707b04 4604b598 af006843 46186882
[1-635.1257] 2920: 689b681b b1084798 73232300 bf00bd98 4605b5f8 af004606 0f04f855 d00542a8
[1-635.1257] 2940: f7fb6804 4620eecc d1f942ac 60752300 60f360b5 bf00bdf8 4605b5f8 46064b08
[1-635.1257] 2960: 447baf00 60033308 0f04f855 d00542a8
2) При следующем сообщении
[0-230.8024] 2780: 0003889f 0007427c e59f3014 e59f2014 e08f3003 e7932002 e3520000 012fff1e
[0-230.8024] 27a0: eafff3f3 00074c30 00000df8 48084b07 4a08447b 33034478 447a1a1b d9032b06
[0-230.8024] 27c0: 58d34b05 4718b103 bf004770 00075b04 00075b00 00074c0a 00000dc0 48094908
[0-230.8024] 27e0: 4b094479 1a094478 1089447b 71d1eb01 d0031049 589b4a05 4718b103 bf004770
[0-230.8024] 2800: 00075ad4 00075ad0 00074bdc 00000e04 4b0ab508 447b4a0a 781b447a 4b09b96b
[0-230.8024] 2820: b12358d3 447b4b08 f7fc6818 f7ffefec 4b06ffbd 447b2201 bd08701a 00075a9e
[0-230.8024] 2840: 00074bac 00000e10 000759da 00075a7e b5084807 68024478 447b4b06 e8bdb912
[0-230.8024] 2860: e7bb4008 589b4a04 d0f82b00 e7f64798 00072560 00074b6a 00000cf4 00000000
[0-230.8024] 2880: 1d03b480 af006840 fab01ac0 0940f080 f85d46bd 47707b04 41f0e92d f8d04606
[0-230.8024] 28a0: af008004 45a86885 4644bf18 6823d006 34304620 4798681b d1f842a5 8008f8c6
[0-230.8024] 28c0: 81f0e8bd 6842b480 6880af00 fab01a10 0940f080 f85d46bd 47707b04 6843b480
[0-230.8024] 28e0: 6083af00 f85d46bd 47707b04 6842b480 6880af00 fab01a10 0940f080 f85d46bd
[0-230.8024] 2900: 47707b04 2301b480 7303af00 f85d46bd 47707b04 4604b598 af006843 46186882
[0-230.8024] 2920: 689b681b b1084798 73232300 bf00bd98 4605b5f8 af004606 0f04f855 d00542a8
[0-230.8025] 2940: f7fb6804 4620eecc d1f942ac 60752300 60f360b5 bf00bdf8 4605b5f8 46064b08
[0-230.8025] 2960: 447baf00 60033308 0f04f855 d00542a8 f7fb6804 4620eeb4 d1f942ac bdf84630
[0-230.8025] 2980: 00072456 43f8e92d af004681 4f04f859 d012454c 4688460e f7fa200c 68a3ef5c
[0-230.8025] 29a0: 60834641 f7fa4605 68b3ef62 60b33301 8000f8d5 45a16824 e8bdd1ee bf0083f8
[0-230.8025] 29c0: 2104b598 af004604 ebfaf7fb bd984620 4605b5f8 46064b0a 447baf00 60033308
[0-230.8025] 29e0: 0f04f855 d00542a8 f7fb6804 4620ee78 d1f942ac 21144630 ebe2f7fb bdf84630
[0-230.8025] 2a00: 000723de 4604b598 4a0b4b0a 0120f100 6980447b 4288af00 f103589b 60230308
[0-230.8025] 2a20: f7fbd001 4620ee5c f7fb2130 4620ebca bf00bd98 000749b4 00000b50 4604b598
[0-230.8025] 2a40: 4a0f4b0e 013cf100 6b40447b 4288af00 f103589b 60230308 f7fbd001 6a61ee40
[0-230.8025] 2a60: 001cf104 f836f04b 1d2068e1 f848f04b 214c4620 eba4f7fb bd984620 0007497c
[0-230.8025] 2a80: 00000c00 4604b598 4a0f4b0e 013cf100 6b40447b 4288af00 f103589b 60230308
[0-230.8025] 2aa0: f7fbd001 6a61ee1c 001cf104 f812f04b 1d2068e1 f824f04b 214c4620 eb80f7fb
[0-230.8025] 2ac0: bd984620 00074934 00000c00 4604b598 4a0f4b0e 013cf100 6b40447b 4288af00
[0-230.8025] 2ae0: f103589b 60230308 f7fbd001 6a61edf8 001cf104 ffeef04a 1d2068e1 f800f04b
[0-230.8025] 2b00: 214c4620 eb5cf7fb bd984620 000748ec 00000c00 4604b598 4a0f4b0e 013cf100
[0-230.8025] 2b20: 6b40447b 4288af00 f103589b 60230308 f7fbd001 6a61edd4 001cf104 ffcaf04a
[0-230.8026] 2b40: 1d2068e1 ffdcf04a 214c4620 eb38f7fb bd984620 000748a4 00000c00 b083b590
[0-230.8026] 2b60: 693caf02 f7fa9400 3704efc6 bd9046bd f44fb580 4b047222 af004904 447b4804
[0-230.8026] 2b80: 44784479 edc8f7fb 0004dde2 0004e058 0004e082 47f0e92d 4b214606 4c21b084
[0-230.8026] 2ba0: af00447b f04f6900 4a1f0900 8004f853 9004f8c7 6803447a 4000f8d8 689c60fc
[0-230.8026] 2bc0: d1284294 0510f107 4608468a 9d08f845 f7fc4629 4604e896 46504629 0401f084
[0-230.8026] 2be0: 9008f8c7 eae0f7fb b2e06078 200cb150 ee30f7fa 6083687b f7fa1d31 68f3ee38
[0-230.8026] 2c00: 60f33301 f8d868fa 429a3000 3710d106 e8bd46bd 1d3a87f0 e7e747a0 eed2f7fb
[0-230.8026] 2c20: 00074824 00000b90 0003ed39 3458f8df 2458f8df e92d447b b0b943f0 af04589e
[0-230.8026] 2c40: f8c76833 f7fb30cc 2300ecea f7fb607b 4601e92c f1072200 f7fc0008 f7fbe84c
[0-230.8026] 2c60: 4604ec96 280068b8 81d3f000 ec74f7fc 1d3b4601 22004620 eab2f7fc f0002800
[0-230.8026] 2c80: efc08186 68b80010 0410f107 edc4613c 617c0b01 f0002800 214781bc ec9ef7fc
[0-230.8026] 2ca0: 695b6803 46034798 0824f107 801cf8c7 001cf107 0006e893 f047440a 2024f80f
[0-230.8026] 2cc0: 637b2300 edc6f7fa f10069fb 46050c10 c008f8c0 f0004543 6a7a818c 61026083
[0-230.8026] 2ce0: 46286a3b 46216b7a 230060eb 623b622a 3024f887 801cf8c7 edb8f7fa 69f869bb
[0-230.8026] 2d00: 61bb3301 d0014540 ece8f7fb 280068b8 817ff000 f7fc214d 6803ec62 4798695b
[0-230.8026] 2d20: f1074603 f8c70840 f1078038 e8930038 440a0006 ffd2f046 23002024 f7fa653b
[0-230.8027] 2d40: 6bbbed8a 0c10f100 f8c04605 4543c008 8157f000 60836c3a 6bfb6102 6d3a4628
[0-230.8027] 2d60: 60eb4621 622a2300 f88763fb f8c73040 f7fa8038 69bbed7c 33016bb8 454061bb
[0-230.8027] 2d80: f7fbd001 68b8ecac f0002800 214f8142 ec24f7fc 695b6803 46034798 085cf107
[0-230.8027] 2da0: 8054f8c7 0054f107 0006e893 f046440a 2024ff95 66fb2300 ed4cf7fa f1006d7b
[0-230.8027] 2dc0: 46050c10 c008f8c0 f0004543 6dfa80fa 61026083 46286dbb 46216efa 230060eb
[0-230.8027] 2de0: 65bb622a 305cf887 8054f8c7 ed3ef7fa 6d7869bb 61bb3301 d0014540 ec6ef7fb
[0-230.8027] 2e00: 280068b8 8105f000 f7fc214c 6803ebe8 4798695b f1074603 f8c70878 f1078070
[0-230.8027] 2e20: e8930070 440a0006 ff58f046 23002024 3088f8c7 ed0ef7fa f1006f3b 46050c10
[0-230.8027] 2e40: c008f8c0 f0004543 6fba80cc 61026083 46286f7b 2088f8d7 60eb4621 622a2300
[0-230.8027] 2e60: f887677b f8c73078 f7fa8070 69bbed00 33016f38 454061bb f7fbd001 68b8ec30
[0-230.8027] 2e80: f0002800 f7fb80c6 6803e8ee 4798695b f1074603 f8c70894 f107808c e893008c
[0-230.8027] 2ea0: 440a0006 ff1af046 23002024 30a4f8c7 ecd0f7fa 308cf8d7 0c10f100 f8c04605
[0-230.8027] 2ec0: 4543c008 8085f000 2094f8d7 61026083 3090f8d7 f8d74628 462120a4 230060eb
[0-230.8027] 2ee0: f8c7622a f8873090 f8c73094 f7fa808c 69bbecbe 008cf8d7 61bb3301 d0014540
[0-230.8027] 2f00: ebecf7fb 280068b8 8083f000 f7fc210d 6803e88a 4798691b 05a8f107 23004601
[0-230.8028] 2f20: 46224628 ec74f7fc 68784629 ecdcf7fc f7fab9a8 4a56ee76 0c01f04f 4b564955
[0-230.8028] 2f40: 4479447a 447b32c8 93029203 23033134 c004f8cd f44f9300 f7fb73a6 4628ec3e
[0-230.8028] 2f60: e9a6f7fb f04a4620 68f8fd03 f039b108 6878f977 6803b110 4798685b 20ccf8d7
[0-230.8028] 2f80: 429a6833 37d4d147 e8bd46bd f7fa83f0 4a42ee48 49422501 4b422403 4479447a
[0-230.8028] 2fa0: 447b32c8 93029203 95013134 133ff240 f7fb9400 68f8ec12 d0da2800 f950f039
[0-230.8028] 2fc0: 46c1e7d7 000fe8b9 61696128 61eb61aa 46c1e700 000fe8b9 61696128 61eb61aa
[0-230.8028] 2fe0: 46c1e776 000fe8b9 61696128 61eb61aa 46c1e72e 000fe8b9 61696128 61eb61aa
[0-230.8028] 3000: 46c1e66e 000fe8b9 61696128 61eb61aa f7ffe6a3 f7fbfdad 6d7becd6 45434605
[0-230.8028] 3020: 4618d002 eb5af7fb f04a4620 68f8fca1 f039b108 6878f915 6803b110 4798685b
[0-230.8028] 3040: f7fc4628 69fbea90 45434605 e7ebd1e9 e7e94605 e7ea4605 e7ec4605 46056bbb
[0-230.8028] 3060: d1de4543 f8d7e7e0 4605308c d1d84543 6f3be7da 45434605 e7d5d1d3 46284603
[0-230.8028] 3080: f7fb461d e7cfe916 00074790 00000b90 0004da20 0004dcca 0004dd56 0004d9c4
[0-230.8028] 30a0: 0004dc6e 0004dcb2 4c2cb5f0 af02b087 f7fc447c f200e9d4 46285564 ed78f7fb
[0-230.8028] 30c0: 0010efc0 603b2316 0b02edc7 e9c6f7fc 0310f107 e9134606 e88d0003 e8970003
[0-230.8028] 30e0: 4630000c efa4f7fb 4a1db198 491d2300 586158a2 ec8af7fb 6803b158 308cf8d3
[0-230.8029] 3100: 46044798 f7fb4628 4620e96a 46bd3714 4915bdf0 48152248 44784479 e95cf7fc
[0-230.8029] 3120: 20014a13 447a4913 32d84479 ebe2f7fc 46282400 e952f7fb 37144620 bdf046bd
[0-230.8029] 3140: 46284604 e94af7fb f7fc4620 4604ea0c f7fb4628 4620e944 ea04f7fc 00074314
[0-230.8029] 3160: 00000bd8 00000cc0 0004daf4 0004dbc2 0004d83a 0004dbc4 200db580 af004903
[0-230.8029] 3180: f7fa4479 f7fbef58 bd80e858 0004db80 b5b04b1d 4a1d4604 6885447b 589baf00
[0-230.8029] 31a0: 60033308 1d2bb15d 2f00e853 e8c31e51 28001fe0 f3bfd1f8 2a018f5b 4620d005
[0-230.8029] 31c0: f7fa210c 4620effe 682bbdb0 689b4628 f1054798 e8530308 1e512f00 1fe0e8c3
[0-230.8029] 31e0: d1f82800 8f5bf3bf d1e82a01 4b08682a 68d1447b d1034299 46286853 e7de4798
[0-230.8029] 3200: 47884628 bf00e7db 0007422c 00000c6c 00037801 b5b04b1d 4a1d4604 6885447b
[0-230.8029] 3220: 589baf00 60033308 1d2bb15d 2f00e853 e8c31e51 28001fe0 f3bfd1f8 2a018f5b
[0-230.8029] 3240: 4620d005 f7fa210c 4620efbc 682bbdb0 689b4628 f1054798 e8530308 1e512f00
[0-230.8029] 3260: 1fe0e8c3 d1f82800 8f5bf3bf d1e82a01 4b08682a 68d1447b d1034299 46286853
[0-230.8029] 3280: e7de4798 47884628 bf00e7db
[0-230.8029] --------------------------------------------------------------------------------------
[0-230.8029]
[0-230.8029] CPU: 0 PID: 3942 Comm: tvs-daemon Tainted: PO 4.1.10 #1 PPID: 1 PComm: systemd
[0-230.8029] Hardware name: Novatek-Cortex CA53
[0-230.8030] task: cc3a0980 ti: d841a000 task.ti: d841a000
[0-230.8030] pc : [<43db2e8a>]    lr : [<43db2e8b>]    psr: a0000030
[0-230.8030] sp : b46fe3e8  ip : 43e276b0  fp : b46fe6b4
[0-230.8030] r10: b46fe620  r9 : b46fe480  r8 : b46fe470
[0-230.8030] r7 : b46fe3f8  r6 : 00071ec8  r5 : b4377810  r4 : b46fe408
[0-230.8030] r3 : 00000004  r2 : 00000000  r1 : b46fe408  r0 : 00000000
[0-230.8030] Flags: NzCv  IRQs on  FIQs on  Mode USER_32  ISA Thumb  Segment user
[0-230.8030] Control: 10c5383d  Table: 1afd806a  DAC: 00000015
[0-230.8030] -----------------------------------------------------------
[0-230.8030] * dump maps on pid (3942 - tvs-daemon)
[0-230.8030] 00010000-00060000 r-xp 00000000 b3:12 10680      /usr/bin/tvs-daemon
[0-230.8030] 0006f000-00070000 r--p 0004f000 b3:12 10680      /usr/bin/tvs-daemon
[0-230.8030] 00070000-00073000 rw-p 00050000 b3:12 10680      /usr/bin/tvs-daemon
[0-230.8030] 00082000-000c9000 rw-p 00052000 b3:12 10680      /usr/bin/tvs-daemon
[0-230.8030] 000c9000-0010f000 rw-p 00000000 00:00 0          [heap]
[0-230.8030] 41000000-41020000 r-xp 00000000 b3:12 16495      /usr/lib/ld-2.24.so
[0-230.8030] 4102f000-41030000 r--p 0001f000 b3:12 16495      /usr/lib/ld-2.24.so
[0-230.8030] 41030000-41031000 rw-p 00020000 b3:12 16495      /usr/lib/ld-2.24.so
[0-230.8030] 41040000-41041000 r-xp 00000000 b3:12 14788      /usr/lib/libpower-defs.so.0.1.1
[0-230.8031] 41041000-41050000 ---p 00001000 b3:12 14788      /usr/lib/libpower-defs.so.0.1.1
[0-230.8031] 41050000-41051000 r--p 00000000 b3:12 14788      /usr/lib/libpower-defs.so.0.1.1
[0-230.8031] 41051000-41052000 rw-p 00001000 b3:12 14788      /usr/lib/libpower-defs.so.0.1.1
[0-230.8031] 41060000-42a4d000 r--p 00000000 b3:12 11120      /usr/lib/libicudata.so.63.2
[0-230.8031] 42a4d000-42a5c000 ---p 019ed000 b3:12 11120      /usr/lib/libicudata.so.63.2
[0-230.8031] 42a5c000-42a5d000 r--p 019ec000 b3:12 11120      /usr/lib/libicudata.so.63.2
[0-230.8031] 42a5d000-42a5e000 rw-p 019ed000 b3:12 11120      /usr/lib/libicudata.so.63.2
[0-230.8031] 42a60000-42a62000 r-xp 00000000 b3:12 15500      /usr/lib/libproc-stat.so.5.5.0
[0-230.8031] 42a62000-42a71000 ---p 00002000 b3:12 15500      /usr/lib/libproc-stat.so.5.5.0
[0-230.8031] 42a71000-42a72000 r--p 00001000 b3:12 15500      /usr/lib/libproc-stat.so.5.5.0
[0-230.8031] 42a72000-42a73000 rw-p 00002000 b3:12 15500      /usr/lib/libproc-stat.so.5.5.0
[0-230.8031] 42a80000-42ba5000 r-xp 00000000 b3:12 12215      /usr/lib/libc-2.24.so
[0-230.8031] 42ba5000-42bb4000 ---p 00125000 b3:12 12215      /usr/lib/libc-2.24.so
[0-230.8031] 42bb4000-42bb6000 r--p 00124000 b3:12 12215      /usr/lib/libc-2.24.so
[0-230.8031] 42bb6000-42bb8000 rw-p 00126000 b3:12 12215      /usr/lib/libc-2.24.so
[0-230.8031] 42bb8000-42bba000 rw-p 00000000 00:00 0
[0-230.8032] 42bc0000-42bd9000 r-xp 00000000 b3:12 10911      /usr/lib/libgcc_s.so.1
[0-230.8032] 42bd9000-42be8000 ---p 00019000 b3:12 10911      /usr/lib/libgcc_s.so.1
[0-230.8032] 42be8000-42be9000 r--p 00018000 b3:12 10911      /usr/lib/libgcc_s.so.1
[0-230.8032] 42be9000-42bea000 rw-p 00019000 b3:12 10911      /usr/lib/libgcc_s.so.1
[0-230.8032] 42bf0000-42c05000 r-xp 00000000 b3:12 12269      /usr/lib/libpthread-2.24.so
[0-230.8032] 42c05000-42c14000 ---p 00015000 b3:12 12269      /usr/lib/libpthread-2.24.so
[0-230.8032] 42c14000-42c15000 r--p 00014000 b3:12 12269      /usr/lib/libpthread-2.24.so
[0-230.8032] 42c15000-42c16000 rw-p 00015000 b3:12 12269      /usr/lib/libpthread-2.24.so
[0-230.8032] 42c16000-42c18000 rw-p 00000000 00:00 0
[0-230.8032] 42c20000-42c23000 r-xp 00000000 b3:12 15184      /usr/lib/libdl-2.24.so
[0-230.8032] 42c23000-42c32000 ---p 00003000 b3:12 15184      /usr/lib/libdl-2.24.so
[0-230.8032] 42c32000-42c33000 r--p 00002000 b3:12 15184      /usr/lib/libdl-2.24.so
[0-230.8032] 42c33000-42c34000 rw-p 00003000 b3:12 15184      /usr/lib/libdl-2.24.so
[0-230.8032] 42c40000-42d34000 r-xp 00000000 b3:12 16580      /usr/lib/libstdc++.so.6.0.22
[0-230.8032] 42d34000-42d44000 ---p 000f4000 b3:12 16580      /usr/lib/libstdc++.so.6.0.22
[0-230.8032] 42d44000-42d48000 r--p 000f4000 b3:12 16580      /usr/lib/libstdc++.so.6.0.22
[0-230.8032] 42d48000-42d4b000 rw-p 000f8000 b3:12 16580      /usr/lib/libstdc++.so.6.0.22
[0-230.8033] 42d4b000-42d4d000 rw-p 00000000 00:00 0
[0-230.8033] 42d50000-42dc2000 r-xp 00000000 b3:12 10909      /usr/lib/libm-2.24.so
[0-230.8033] 42dc2000-42dd1000 ---p 00072000 b3:12 10909      /usr/lib/libm-2.24.so
[0-230.8033] 42dd1000-42dd2000 r--p 00071000 b3:12 10909      /usr/lib/libm-2.24.so
[0-230.8033] 42dd2000-42dd3000 rw-p 00072000 b3:12 10909      /usr/lib/libm-2.24.so
[0-230.8033] 42de0000-42ded000 r-xp 00000000 b3:12 16172      /usr/lib/libcapi-base-common.so.0.4.54
[0-230.8033] 42ded000-42dfd000 ---p 0000d000 b3:12 16172      /usr/lib/libcapi-base-common.so.0.4.54
[0-230.8033] 42dfd000-42dff000 r--p 0000d000 b3:12 16172      /usr/lib/libcapi-base-common.so.0.4.54
[0-230.8033] 42dff000-42e00000 rw-p 0000f000 b3:12 16172      /usr/lib/libcapi-base-common.so.0.4.54
[0-230.8033] 42e10000-42e13000 r-xp 00000000 b3:12 11408      /usr/lib/libdlog.so.0.0.0
[0-230.8033] 42e13000-42e22000 ---p 00003000 b3:12 11408      /usr/lib/libdlog.so.0.0.0
[0-230.8033] 42e22000-42e23000 r--p 00002000 b3:12 11408      /usr/lib/libdlog.so.0.0.0
[0-230.803--p 001ae000 b3:12 11306      /usr/lib/libtvs-api-native.so
[0-230.8058] 44d51000-44d56000 rw-p 001b1000 b3:12 11306      /usr/lib/libtvs-api-native.so
[0-230.8058] 44d56000-44d57000 rw-p 00000000 00:00 0
[0-230.8058] 44d60000-44e7d000 r-xp 00000000 b3:12 15445       f039b108 6878f915 6803b110 4798685b
[0-239.6192] 3040: f7fc4628 69fbea90 45434605 e7ebd1e9 e7e94605 e7ea4605 e7ec4605 46056bbb
[0-239.6192] 3060: d1de4543 f8d7e7e0 4605308c d1d84543 6f3be7da 45434605 e7d5d1d3 46284603
[0-239.6192] 3080: f7fb461d e7cfe916 00074790 00000b90 0004da20 0004dcca 0004dd56 0004d9c4
[0-239.6192] 30a0: 0004dc6e 0004dcb2 4c2cb5f0 af02b087 f7fc447c f200e9d4 46285564 ed78f7fb
[0-239.6193] 30c0: 0010efc0 603b2316 0b02edc7 e9c6f7fc 0310f107 e9134606 e88d0003 e8970003
[0-239.6193] 30e0: 4630000c efa4f7fb 4a1db198 491d2300 586158a2 ec8af7fb 6803b158 308cf8d3
[0-239.6193] 3100: 46044798 f7fb4628 4620e96a 46bd3714 4915bdf0 48152248 44784479 e95cf7fc
[0-239.6193] 3120: 20014a13 447a4913 32d84479 ebe2f7fc 46282400 e952f7fb 37144620 bdf046bd
[0-239.6193] 3140: 46284604 e94af7fb f7fc4620 4604ea0c f7fb4628 4620e944 ea04f7fc 00074314
[0-239.6193] 3160: 00000bd8 00000cc0 0004daf4 0004dbc2 0004d83a 0004dbc4 200db580 af004903
[0-239.6193] 3180: f7fa4479 f7fbef58 bd80e858 0004db80 b5b04b1d 4a1d4604 6885447b 589baf00
[0-239.6193] 31a0: 60033308 1d2bb15d 2f00e853 e8c31e51 28001fe0 f3bfd1f8 2a018f5b 4620d005
[0-239.6193] 31c0: f7fa210c 4620effe 682bbdb0 689b4628 f1054798 e8530308 1e512f00 1fe0e8c3
[0-239.6193] 31e0: d1f82800 8f5bf3bf d1e82a01 4b08682a 68d1447b d1034299 46286853 e7de4798
[0-239.6193] 3200: 47884628 bf00e7db 0007422c 00000c6c 00037801 b5b04b1d 4a1d4604 6885447b
[0-239.6193] 3220: 589baf00 60033308 1d2bb15d 2f00e853 e8c31e51 28001fe0 f3bfd1f8 2a018f5b
[0-239.6193] 3240: 4620d005 f7fa210c 4620efbc 682bbdb0 689b4628 f1054798 e8530308 1e512f00
[0-239.6193] 3260: 1fe0e8c3 d1f82800 8f5bf3bf d1e82a01 4b08682a 68d1447b d1034299 46286853
[0-239.6193] 3280: e7de4798 47884628 bf00e7db
[0-239.6193] --------------------------------------------------------------------------------------
[0-239.6193]
[0-239.6194] CPU: 0 PID: 3992 Comm: tvs-daemon Tainted: PO 4.1.10 #1 PPID: 1 PComm: systemd
[0-239.6194] Hardware name: Novatek-Cortex CA53
[0-239.6194] task: d8cdb440 ti: cf902000 task.ti: cf902000
[0-239.6194] pc : [<43db2e8a>]    lr : [<43db2e8b>]    psr: a0000030
[0-239.6194] sp : b46fe3e8  ip : 43e276b0  fp : b46fe6b4
[0-239.6194] r10: b46fe620  r9 : b46fe480  r8 : b46fe470
[0-239.6194] r7 : b46fe3f8  r6 : 00071ec8  r5 : b43910f0  r4 : b46fe408
[0-239.6194] r3 : 00000004  r2 : 00000000  r1 : b46fe408  r0 : 00000000
[0-239.6194] Flags: NzCv  IRQs on  FIQs on  Mode USER_32  ISA Thumb  Segment user
[0-239.6194] Control: 10c5383d  Table: 1afd806a  DAC: 00000015
[0-239.6194] -----------------------------------------------------------
[0-239.6194] * dump maps on pid (3992 - tvs-daemon)
[0-239.6194] 00010000-00060000 r-xp 00000000 b3:12 10680      /usr/bin/tvs-daemon
[0-239.6194] 0006f000-00070000 r--p 0004f000 b3:12 10680      /usr/bin/tvs-daemon
[0-239.6194] 00070000-00073000 rw-p 00050000 b3:12 10680      /usr/bin/tvs-daemon
[0-239.6194] 00082000-000c9000 rw-p 00052000 b3:12 10680      /usr/bin/tvs-daemon
[0-239.6194] 000c9000-0010f000 rw-p 00000000 00:00 0          [heap]
[0-239.6195] 41000000-41020000 r-xp 00000000 b3:12 16495      /usr/lib/ld-2.24.so
[0-239.6195] 4102f000-41030000 r--p 0001f000 b3:12 16495      /usr/lib/ld-2.24.so
[0-239.6195] 41030000-41031000 rw-p 00020000 b3:12 16495      /usr/lib/ld-2.24.so
[0-239.6195] 41040000-41041000 r-xp 00000000 b3:12 14788      /usr/lib/libpower-defs.so.0.1.1
[0-239.6195] 41041000-41050000 ---p 00001000 b3:12 14788      /usr/lib/libpower-defs.so.0.1.1
[0-239.6195] 41050000-41051000 r--p 00000000 b3:12 14788      /usr/lib/libpower-defs.so.0.1.1
[0-239.6195] 41051000-41052000 rw-p 00001000 b3:12 14788      /usr/lib/libpower-defs.so.0.1.1
[0-239.6195] 41060000-42a4d000 r--p 00000000 b3:12 11120      /usr/lib/libicudata.so.63.2
[0-239.6195] 42a4d000-42a5c000 ---p 019ed000 b3:12 11120      /usr/lib/libicudata.so.63.2
[0-239.6195] 42a5c000-42a5d000 r--p 019ec000 b3:12 11120      /usr/lib/libicudata.so.63.2
[0-239.6195] 42a5d000-42a5e000 rw-p 019ed000 b3:12 11120      /usr/lib/libicudata.so.63.2
[0-239.6195] 42a60000-42a62000 r-xp 00000000 b3:12 15500      /usr/lib/libproc-stat.so.5.5.0
[0-239.6195] 42a62000-42a71000 ---p 00002000 b3:12 15500      /usr/lib/libproc-stat.so.5.5.0
[0-239.6195] 42a71000-42a72000 r--p 00001000 b3:12 15500      /usr/lib/libproc-stat.so.5.5.0
[0-239.6195] 42a72000-42a73000 rw-p 00002000 b3:12 15500      /usr/lib/libproc-stat.so.5.5.0
[0-239.6195] 42a80000-42ba5000 r-xp 00000000 b3:12 12215      /usr/lib/libc-2.24.so
[0-239.6196] 42ba5000-42bb4000 ---p 00125000 b3:12 12215      /usr/lib/libc-2.24.so
[0-239.6196] 42bb4000-42bb6000 r--p 00124000 b3:12 12215      /usr/lib/libc-2.24.so
[0-239.6196] 42bb6000-42bb8000 rw-p 00126000 b3:12 12215      /usr/lib/libc-2.24.so
[0-239.6196] 42bb8000-42bba000 rw-p 00000000 00:00 0
[0-239.6196] 42bc0000-42bd9000 r-xp 00000000 b3:12 10911      /usr/lib/libgcc_s.so.1
[0-239.6196] 42bd9000-42be8000 ---p 00019000 b3:12 10911      /usr/lib/libgcc_s.so.1
[0-239.6196] 42be8000-42be9000 r--p 00018000 b3:12 10911      /usr/lib/libgcc_s.so.1
[0-239.6196] 42be9000-42bea000 rw-p 00019000 b3:12 10911      /usr/lib/libgcc_s.so.1
[0-239.6196] 42bf0000-42c05000 r-xp 00000000 b3:12 12269      /usr/lib/libpthread-2.24.so
[0-239.6196] 42c05000-42c14000 ---p 00015000 b3:12 12269      /usr/lib/libpthread-2.24.so
[0-239.6196] 42c14000-42c15000 r--p 00014000 b3:12 12269      /usr/lib/libpthread-2.24.so
[0-239.6196] 42c15000-42c16000 rw-p 00015000 b3:12 12269      /usr/lib/libpthread-2.24.so
[0-239.6196] 42c16000-42c18000 rw-p 00000000 00:00 0
[0-239.6196] 42c20000-42c23000 r-xp 00000000 b3:12 15184      /usr/lib/libdl-2.24.so
[0-239.6196] 42c23000-42c32000 ---p 00003000 b3:12 15184      /usr/lib/libdl-2.24.so
[0-239.6196] 42c32000-42c33000 r--p 00002000 b3:12 15184      /usr/lib/libdl-2.24.so
[0-239.6197] 42c33000-42c34000 rw-p 00003000 b3:12 15184      /usr/lib/libdl-2.24.so
[0-239.6197] 42c40000-42d34000 r-xp 00000000 b3:12 16580      /usr/lib/libstdc++.so.6.0.22
[0-239.6197] 42d34000-42d44000 ---p 000f4000 b3:12 16580      /usr/lib/libstdc++.so.6.0.22
[0-239.6197] 42d44000-42d48000 r--p 000f4000 b3:12 16580      /usr/lib/libstdc++.so.6.0.22
[0-239.6197] 42d48000-42d4b000 rw-p 000f8000 b3:12 16580      /usr/lib/libstdc++.so.6.0.22
[0-239.6197] 42d4b000-42d4d000 rw-p 00000000 00:00 0
[0-239.6197] 42d50000-42dc2000 r-xp 00000000 b3:12 10909      /usr/lib/libm-2.24.so
[0-239.6197] 42dc2000-42dd1000 ---p 00072000 b3:12 10909      /usr/lib/libm-2.24.so
[0-239.6197] 42dd1000-42dd2000 r--p 00071000 b3:12 10909      /usr/lib/libm-2.24.so
[0-239.6197] 42dd2000-42dd3000 rw-p 00072000 b3:12 10909      /usr/lib/libm-2.24.so
[0-239.6197] 42de0000-42ded000 r-xp 00000000 b3:12 16172      /usr/lib/libcapi-base-common.so.0.4.54
[0-239.6197] 42ded000-42dfd000 ---p 0000d000 b3:12 16172      /usr/lib/libcapi-base-common.so.0.4.54
[0-239.6197] 42dfd000-42dff000 r--p 0000d000 b3:12 16172      /usr/lib/libcapi-base-common.so.0.4.54
[0-239.6197] 42dff000-42e00000 rw-p 0000f000 b3:12 16172      /usr/lib/libcapi-base-common.so.0.4.54
[0-239.6197] 42e10000-42e13000 r-xp 00000000 b3:12 11408      /usr/lib/libdlog.so.0.0.0
[0-239.6197] 42e13000-42e22000 ---p 00003000 b3:12 11408      /usr/lib/libdlog.so.0.0.0
[0-239.6198] 42e22000-42e23000 r--p 00002000 b3:12 11408      /usr/lib/libdlog.so.0.0.0
[0-239.6198] 42e23000-42e24000 rw-p 00003000 b3:12 11408      /usr/lib/libdlog.so.0.0.0
[0-239.6198] 42e30000-42e5b000 r-xp 00000000 b3:12 13572      /usr/lib/libcynara-commons.so.0.14.24
[0-239.6198] 42e5b000-42e6a000 ---p 0002b000 b3:12 13572      /usr/lib/libcynara-commons.so.0.14.24
[0-239.6198] 42e6a000-42e6c000 r--p 0002a000 b3:12 13572      /usr/lib/libcynara-commons.so.0.14.24
[0-239.6198] 42e6c000-42e6d000 rw-p 0002c000 b3:12 13572      /usr/lib/libcynara-commons.so.0.14.24
[0-239.6198] 42e70000-42e85000 r-xp 00000000 b3:12 16133      /usr/lib/libdbuspolicy1.so.1.1.0
[0-239.6198] 42e85000-42e94000 ---p 00015000 b3:12 16133      /usr/lib/libdbuspolicy1.so.1.1.0
[0-239.6198] 42e94000-42e95000 r--p 00014000 b3:12 16133      /usr/lib/libdbuspolicy1.so.1.1.0
[0-239.6198] 42e95000-42e96000 rw-p 00015000 b3:12 16133      /usr/lib/libdbuspolicy1.so.1.1.0
[0-239.6198] 42ea0000-42eb6000 r-xp 00000000 b3:12 16277      /usr/lib/libexpat.so.1.6.9
[0-239.6198] 42eb6000-42ec5000 ---p 00016000 b3:12 16277      /usr/lib/libexpat.so.1.6.9
[0-239.6198] 42ec5000-42ec7000 r--p 00015000 b3:12 16277      /usr/lib/libexpat.so.1.6.9
[0-239.6198] 42ec7000-42ec8000 rw-p 00017000 b3:12 16277      /usr/lib/libexpat.so.1.6.9
[0-239.6198] 42ed0000-42ed6000 r-xp 00000000 b3:12 13472      /usr/lib/libcynara-client-commons.so.0.14.24
[0-239.6198] 42ed6000-42ee5000 ---p 00006000 b3:12 13472      /usr/lib/libcynara-client-commons.so.0.14.24
[0-239.6199] 42ee5000-42ee6000 r--p 00005000 b3:12 13472      /usr/lib/libcynara-client-commons.so.0.14.24
[0-239.6199] 42ee6000-42ee7000 rw-p 00006000 b3:12 13472      /usr/lib/libcynara-client-commons.so.0.14.24
[0-239.6199] 42ef0000-42ef8000 r-xp 00000000 b3:12 16785      /usr/lib/libcynara-client.so.0.14.24
[0-239.6199] 42ef8000-42f07000 ---p 00008000 b3:12 16785      /usr/lib/libcynara-client.so.0.14.24
[0-239.6199] 42f07000-42f08000 r--p 00007000 b3:12 16785      /usr/lib/libcynara-client.so.0.14.24
[0-239.6199] 42f08000-42f09000 rw-p 00008000 b3:12 16785      /usr/lib/libcynara-client.so.0.14.24
[0-239.6199] 42f10000-42f12000 r-xp 00000000 b3:12 15437      /usr/lib/libcynara-session.so.0.14.24
[0-239.6199] 42f12000-42f21000 ---p 00002000 b3:12 15437      /usr/lib/libcynara-session.so.0.14.24
[0-239.6199] 42f21000-42f22000 r--p 00001000 b3:12 15437      /usr/lib/libcynara-session.so.0.14.24
[0-239.6199] 42f22000-42f23000 rw-p 00002000 b3:12 15437      /usr/lib/libcynara-session.so.0.14.24
[0-239.6199] 42f30000-42f36000 r-xp 00000000 b3:12 11480      /usr/lib/librt-2.24.so
[0-239.6199] 42f36000-42f45000 ---p 00006000 b3:12 11480      /usr/lib/librt-2.24.so
[0-239.6199] 42f45000-42f46000 r--p 00005000 b3:12 11480      /usr/lib/librt-2.24.so
[0-239.6199] 42f46000-42f47000 rw-p 00006000 b3:12 11480      /usr/lib/librt-2.24.so
[0-239.6199] 42f50000-430a0000 r-xp 00000000 b3:12 11138      /usr/lib/libgio-2.0.so.0.5200.2
[0-239.6199] 430a0000-430b0000 ---p 00150000 b3:12 11138      /usr/lib/libgio-2.0.so.0.5200.2
[0-239.6200] 430b0000-430b2000 r--p 00150000 b3:12 11138      /usr/lib/libgio-2.0.so.0.5200.2
[0-239.6200] 430b2000-430b4000 rw-p 00152000 b3:12 11138      /usr/lib/libgio-2.0.so.0.5200.2
[0-239.6200] 430b4000-430b5000 rw-p 00000000 00:00 0
[0-239.6200] 430c0000-431b7000 r-xp 00000000 b3:12 15321      /usr/lib/libglib-2.0.so.0.5200.2
[0-239.6200] 431b7000-431c6000 ---p 000f7000 b3:12 15321      /usr/lib/libglib-2.0.so.0.5200.2
[0-239.6200] 431c6000-431c7000 r--p 000f6000 b3:12 15321      /usr/lib/libglib-2.0.so.0.5200.2
[0-239.6200] 431c7000-431c8000 rw-p 000f7000 b3:12 15321      /usr/lib/libglib-2.0.so.0.5200.2
[0-239.6200] 431d0000-4321f000 r-xp 00000000 b3:12 13870      /usr/lib/libpcre.so.1.2.11
[0-239.6200] 4321f000-4322e000 ---p 0004f000 b3:12 13870      /usr/lib/libpcre.so.1.2.11
[0-239.6200] 4322e000-4322f000 r--p 0004e000 b3:12 13870      /usr/lib/libpcre.so.1.2.11
[0-239.6200] 4322f000-43230000 rw-p 0004f000 b3:12 13870      /usr/lib/libpcre.so.1.2.11
[0-239.6200] 43240000-43285000 r-xp 00000000 b3:12 11617      /usr/lib/libgobject-2.0.so.0.5200.2
[0-239.6200] 43285000-43294000 ---p 00045000 b3:12 11617      /usr/lib/libgobject-2.0.so.0.5200.2
[0-239.6200] 43294000-43295000 r--p 00044000 b3:12 11617      /usr/lib/libgobject-2.0.so.0.5200.2
[0-239.6200] 43295000-43296000 rw-p 00045000 b3:12 11617      /usr/lib/libgobject-2.0.so.0.5200.295] 41051000-41052000 rw-p 00001000 b3:12 14788      /usr/lib/libpower-defs.so.0.1.1
3) При вкл. в сеть со вставленной флешкой
<0>яzAC
V2
0084(Jan  8 2021 10:55:46)
load tcon fail
load tcon (40000) fail
444mA
d
boot-up
(Jan  8 2021 - 10:55:47)
0084(6250644)
r
J001
S11
E11
0 p
GPT
D
DTB 0
xdt1.5G
SECDRV 0
or003.0
SECOS 0
kr003.0
KERNEL 0
z[1-0.0575] cma: [swapper/0(1)] cma_alloc(): returned ec507000 range 81000 - 81040
[1-0.0601] I2C IRQ init_timer start(0517_Tizen4.0)
[0-0.0669] [DEBUG]register base fd6f0000
[0-0.0670] [DEBUG] interregister base d
[0-0.0670] gzip support fifo mode
[0-0.0672] (NULL device *): ~get gpio base-val: 0xed096000, 0x0
[0-0.0673] nvt,auth fd770000.auth: hw auth support fifo mode, 1090309
[1-0.0904] type=2000 audit(0.079:1): initialized
[1-0.0960] Novatek UART Direct I/O Driver Init.
[1-0.0961] nvt-udio fd092000.uart: io_base ed0a8000
[1-0.0961] nvt-udio fd092000.uart: clock rate 100000000
[1-0.0961] nvt-udio fd092000.uart: baud rate 115200
[1-0.0961] nvt-udio fd092000.uart: irq 11
[1-0.0962] nvt-udio fd092000.uart: probing completed
[0-0.1362] [NTKETHMAC]: synopGMAC_probe.
[0-0.1363] [NTKETHMAC]: Now Registering the netdevice
[1-0.1740]  Ver : 6340677, release
[1-0.1740]  TV, Kant.SU2-Tizen, release, Trunk_2020_MP
[1-0.1740]  Linux version 4.1.10 (abuild@A1312DKG) (gcc version 6.2.1 20161213 (Tizen/Linaro GCC 6.2.1 2016.12/VDCosmos-20190704 7.8) ) #1 SMP PREEMPT Fri Jan 8 11:04:50 UTC 2021
[1-0.1741]  dtsversion=6290398_kantsu2-1.5G-cma console=ttyS0,115200 rs232=0 earlyprintk maxcpus=4 no_console_suspend only_entry_model root=/dev/mmcblk0p18 KDUMP=16 SELP_ENABLE=20208724 _nvtca9-16m rootfstype=vdfs ro init=/sbin/init mem=808M@32M mem=56M@968M mem=256M@2048M vmalloc=300M rootwait quiet bdinfo=00000091 model=4kbtin   pba_none
[1-0.1841] mmcblk0: mmc0:0001 4FTE4R 3.64 GiB
[/sbin/init] Start init process!!!!!!!!!!!!!!!!
[0-0.3248] vdfs4-WARN: SB: bad signature - , expected - VDFSmount: /mnt/systemrw: wrong fs type, bad option, bad superblock on /dev/mmcblk0p20, missing codepage or helper program, or other error.
[0-2.1402] [NTKETHMAC]: Trim RTER_RX = 0x3, 0368[70]
[0-2.1402] [NTKETHMAC]: Trim RTER_TX = 0x3, 0368[6c]
[0-2.1402] [NTKETHMAC]: Trim TX_ROUT = 0x4, 0374[25]
[0-2.1403] [NTKETHMAC]: Trim TX_SWING = 0x1, 0378[21]
systemrw_backup.xz isn't exist
[0-3.3442] vdfs4-WARN: SB: bad signature - , expected - VDFSmount: /mnt/systemrw: wrong fs type, bad option, bad superblock on /dev
data_backup.xz isn't exist
/sbin/init: line 46: /sys/kernel/debug/tracing/trace_marker: No such file or directory
[Info] Initailize T-trace
error opening /sys/kernel/debug/tracing/options/overwrite: No such file or direc[0-3.4744] init: logger
tory (2)
Tags: [1-3.4745] init: lwipc
0x1, excludedTag[0-3.4752] lwipc mod ld(0xbe818000)
s: 0x0
error opening /sys/kernel/debug/tracing/[0-3.4756] logger mod ld(0xbe800000)
tracing_on: No such file or directory (2)
unable to start tracing
[cynara-launcher] launch cynara( 120 )
[cynara-launcher] wait socket files:300
[3-3.5206] init: tztv_bootmode
[0-3.5219] tztv_bootmode mod ld(0xbe81d000)
Booting from tztv mode
boot mode: normal
Cynara db update success
[eeprom open wait]
[0-3.6046] [FB:INIT] fast init start
[0-3.6081] [FB:INIT] insmod file : index.json
[eeprom open wait]
Set Buxton env
[0-3.6270] [FB:INIT] [prebasic Start]
cat: /run/user/5001/.[0-3.6270] [FB:INIT] cmd[prebasic:insmod]
launchpad.pid: No such file or directory
[0-3.6270] [FB:INIT] prebasic 0 start
[1-3.6440] DynBoost3.1.8
[eeprom open wait]
[0-3.6534] init: PreInit
[0-3.6544] ================================================================================
[security-manage[0-3.6544]  Pre Initiation
r-launcher(192)][0-3.6544]  Version : Kantsu2_Onemain_2020_KantSU2_Trunk2020_MP_v0.201016.0_r93d41424e63.
  > Starting Sec[0-3.6544] ================================================================================
urity Manager Launcher...
[security-manager-launcher(192)]  > security-manager([1-3.6994] [TEMP_MSGBOX] #################
pid : 195) is la[1-3.6994] [TEMP_MSGBOX] MessageBox Drive_init
unched successfu[1-3.6994] [TEMP_MSGBOX] MessageBox Drive_init
lly...
[eeprom [1-3.6999] genirq: Flags mismatch irq 11. 00000080 (ntk_serial) vs. 00000000 (fd092000.uart)
open wait]
[eep[1-3.6999] PreInit mod ld(0xbe821000)
rom open wait]
build: 20210108_144709
keymap: [1-3.7000] [FB:INIT] prebasic 0 end
20210108_144709
We have a keymap cache version file
FP_NVRAM_FASTBOOT_IN_PRODUCTION [0]
non-factory production mode
[prdv_attr: /dev/null]
[prdv_attr: /dev/tty]
[prdv_att[1-3.7000] [FB:INIT] prebasic 1 start
r: /dev/bptime]
[prdv_attr: /dev/snd/timer]
[prdv_attr: /dev/u[1-3.7214] init: tztv_eeprom
input]
[prdv_at[1-3.7217] client = 0xebdfe200
tr: /dev/eeprom][1-3.7242] tztv_eeprom mod ld(0xbe88d000)
[prdv_attr: /dev/zero]
[3.73 13.22][BXT] buxt[1-3.7243] [FB:INIT] prebasic 1 end
on2d started
[p[1-3.7243] [FB:INIT] prebasic 2 start
rdv_attr: /dev/micom-cec]
[1-3.7272] init: tztv_micom
[2-3.7365] [MC:S][3.7362][kthread_watchdo]Rollback
[2-3.7420] [MC:A][3.7420]TV ver 1010_R(1)
[2-3.7460] [MC:A][3.7459][PwrOnMode:1][PrePOM:0][Res: 0][T-TV-1010_R(1)]
[2-3.7612] tztv_micom mod ld(0xbe893000)
[2-3.7613] [FB:INIT] prebasic 2 end
[2-3.7614] [FB:INIT] prebasic 3 start
[2-3.7718] init: videobuf2_core
[2-3.7725] videobuf2_core mod ld(0xbe8a5000)
[2-3.7726] [FB:INIT] prebasic 3 end
[2-3.7727] [FB:INIT] prebasic 4 start
[2-3.7759] init: videobuf2_memops
[2-3.7764] videobuf2_memops mod ld(0xbe8ad000)
[2-3.7765] [FB:INIT] prebasic 4 end
[2-3.7766] [FB:INIT] prebasic 5 start
[2-3.7768] [MC:A][3.7768]boot_reason(0) [TV ver 1010_R(1)]
[0-3.7808] [SBH] get_boot_reason is (0)
[prdv_attr: /dev[2-3.7957] init: videobuf2_vmalloc
/dmabuf_kds]
[2-3.7959] videobuf2_vmalloc mod ld(0xbe8af000)
[prdv_attr: /dev[2-3.7962] [FB:INIT] prebasic 5 end
/mali0]
[2-3.7962] [FB:INIT] [prebasic End time:170]
[2-3.7963] [FB:INIT] fi_util_mq_send_cmd: cmd(122)
[2-3.7963] [FB:INIT] [fi_depList_init:763] index_path [/tmp/FACTORY_PRODCU[FB:INIT] no flag file:/tmp/FACTORY_PRODCUTION
[2-3.7964] [FB:INIT] [fi_depList_init:763] index_path [/opt/usr/apps/MCS_m[FB:INIT] no flag file:/opt/usr/apps/MCS_mode
[2-3.7964] [FB:INIT] [fi_depList_init:763] index_path [/opt/usr/apps/org.t[FB:INIT] no flag file:/opt/usr/apps/org.tizen.btapp/data/tv_so[FB:INIT] [fi_depList_init:763] index_path []
[2-3.7964] [FB:INIT] no flag file:
[2-3.7964] [FB:INIT] Index path Null
[2-3.7965] [FB:INIT] INIT index_path[index]
[2-3.7988] [FB:INIT] [tzdev Start]
[2-3.7989] [FB:INIT] cmd[tzdev:insmod]
[2-3.7989] [FB:INIT] tzdev 0 start
[3-3.7996] [FB:LOGO] panel_enable(1)
[1-3.8044] [FB:INIT] [fw Start]
[1-3.8045] [FB:INIT] cmd[fw:insmod]
[1-3.8045] [FB:INIT] fw 0 start
[3-3.8076] init: tzdev
[3-3.8597] [FB:LOGO] logo mode(0)
[3-3.8672] tzdev mod ld(0xbe8b1000)
[3-3.8674] [FB:INIT] tzdev 0 end
[3-3.8674] [FB:INIT] cmd[tzdev:chmod]
[3-3.8674] [FB:INIT] [tzdev End time:69]
[3-3.8675] [FB:INIT] create path(/tmp/tzdev_insmod_done)
[PKGMGR] /opt/db[1-3.8697] init: mali
space/.pkgmgr_pa[0-3.8778] mali mod ld(0xbe8d6000)
rser.db file siz[0-3.8779] [FB:INIT] fw 0 end
e 948
[PKGMGR] integrity : ok
[0-3.8779] [FB:INIT] fw 1 start
/usr/bin/firstscreen.sh: line 20: /sys/kernel/debug/tracing/trace_marker: No such file or directory
[PKGMGR] /opt/dbspace/.pkgmgr_cert.db file size 184
[0-4.1158] [SBH] bw_get_boot_mode() : 0, BOOT_TYPE_ISP(1) BOOT_TYPE_RVU(2)
[0-4.1229] [SBH] create boot mode file(/tmp/normal_mode)
netlink recv: No buffer space available
[security-manager-launcher(192)]  > inotify event is received for /run/security-manager.socket
[PKGMGR] /opt/dbspace/user/5001/.pkgmgr_parser.db file size 148
[PKGMGR] /var/lib/package-manager/restriction.db file size 16
cat: /opt/data/DeviceTracker/htPolicyState: No such file or directory
Buffer main is set
argc = 10, optind = 9, Kb 1024, rotate 1
[PKGMGR] /opt/dbspace/.widget.db file size 28
[1-4.2708] init: ntkdriver
[1-4.2870] ================================================================================
[1-4.2870]  NTK Driver
[1-4.2870]  Version : Kantsu2_Onemain_2020_KantSU2_Trunk2020_MP_v0.201016.0_r93d41424e63.
[prdv_attr: /dev[1-4.2871] ntkdrvs: NOVATEK drivers loaded begin.
/sdp_mem]
[1-4.2935] nvt_dt cannot find video_es_tbl!
[1-4.2936] ksb cann't find video_es_tbl node
[1-4.3065] [HDMI-CMD]:Trim.Valid=1
[1-4.3065] [HDMI-CMD]:EARCTrim.Valid=1
[1-4.3235] [FB] fastvideo start
[1-4.3236] [FB] fb_insmod_wait_lock: mode(12) start
[1-4.3237] [FB] fb_insmod_wait_lock: mode(12) end
[2-4.3301] Novatek FRE Driver loaded
[0-4.3348] [FB] Hotel mode : 0:0
[0-4.3348] [FB] Hotel mode disable
[1-4.3361] [FB] fb_insmod_wait_lock: mode(13) start
[0-4.3391] msg-wt61p807 msg-wt61p807: received unknown cmd ack
[PKGMGR] /opt/us[1-4.3417] [FB] fb_insmod_wait_lock: mode(13) end
r/home/owner/.ap[0-4.3543] [FB] boot_mode,channel_lock:3,0
plications/dbspa[0-4.3543] [FB] invalied bootmode(3)!!
ce/.widget.db fi[1-4.3562] [FB] video_show_done(skip/fail)
le size 28
[PKG[0-4.3640] [FB] fb_status_fail: fastvideo SKIP. ( reason : [ 8 ] )
MGR] integrity : ok
Leon2 decoder is built at 14:25:19, May  5 2
code revision: bd10666ebb1, 2020-03-20
_CPU_Initialize ... OK
_Reload_text(304) ... OK
_Reload[1_data(.122888) .]. [NDP_OH
STC = cR40T]0 aL8:10
s0txa0r0t 0..0.
0007, U: 0x00000005.
[PKGMGR] /opt/db[3-4.4384] cma: [fastinit(257)] cma_alloc(): returned ec507800 range 81040 - 81048
space/.appsvc.db file size 40
waiting firstscreen launch
[3-4.4900] [hdmi leon2] hdmi_leon2 find pool node ERROR !!!
[3-4.4900] [hdmi leon2] driver loaded > ERROR !!!
[PKGMGR] /opt/dbspace/user/5001/.appsvc.db file size 40
[3-4.4908] ntkdriver mod ld(0xbe922000)
[3-4.4909] [FB:INIT] fw 1 end
[3-4.4910] [FB:INIT] [fw End time:686]
[1-4.4911] [FB:INIT] [kfactory Start]
[1-4.4911] [FB:INIT] cmd[kfactory:insmod]
[1-4.4912] [FB:INIT] kfactory 0 start
[2-4.4912] [FB:INIT] [pq Start]
[kfactoryd] restore daemon!!
[2-4.4912] [FB:INIT] cmd[pq:insmod]
[2-4.4912] [FB:INIT] pq 0 start
[1-4.4944] init: kfactory_drv
[1-4.4954] kfactory_drv mod ld(0xbf17d000)
[1-4.4955] [FB:INIT] kfactory 0 end
[1-4.4955] [FB:INIT] cmd[kfactory:execute]
[1-4.4996] [FB:INIT] cmd[kfactory:insmod]
[1-4.4996] [FB:INIT] kfactory 0 start
[1-4.4997] [FB:INIT] kfactory 0 end
[1-4.4997] [FB:INIT] kfactory 1 start
[3-4.5045] init: ntkndp_pq
[1-4.5110] init: system_drv_api
[1-4.5112] system_drv_api mod ld(0xbe816000)
[1-4.5113] [FB:INIT] kfactory 1 end
RO and RW is same version[1-4.5113] [FB:INIT] kfactory 2 start
[1-4.5143] init: system_drv
/home/owner/.dot[1-4.5174] system_drv mod ld(0xbf1a1000)
net/corefx/crypt[1-4.5176] [FB:INIT] kfactory 2 end
ography/x509stores/ is already created
[prdv_at[1-4.5176] [FB:INIT] kfactory 3 start
tr: /dev/video28[1-4.5176] [FB:INIT] kfactory 3 end
[1-4.5176] [FB:INIT] [kfactory End time:27]
[0-4.5178] [FB:INIT] [logo Start]
mkdir: [2-4.5178] [FB:INIT] [extin Start]
cannot create di[0-4.5179] [FB:INIT] cmd[logo:insmod]
rectory `/opt/us[0-4.5179] [FB:INIT] logo 0 start
r/home/owner/share/dotnet/': Fil[1-4.5179] [FB:INIT] cmd[extin:insmod]
e exists
Recreate Seed
/usr/bin/dotnet-developer-mode.sh found
[PKGMGR] /opt/dbspace/.app-context.db file size 48
[1-4.5179] [FB:INIT] extin 0 start
[2-4.5241] [perfm]1.4.18
Develope mode is off
[1-4.5242] init: ntkndplogo
[0-4.5253] init: ntkndpextin
[2-4.5450] ESTART(main) 4.53357
[2-4.5453] ESTART: 0.00353 [0.00353] - Begin Startup
[2-4.5573] ESTART: 0.01557 [0.01204] - Signal Trap
[2-4.5575] ESTART: 0.01583 [0.00026] - Signal Trap Done
[2-4.5576] ESTART: 0.01585 [0.00002] - Eina Init
[3-4.5696] ESTART: 0.02785 [0.01200] - Eina Init Done
[3-4.5696] ESTART: 0.02792 [0.00007] - E_Object Hash Init
[3-4.5778] ESTART: 0.03609 [0.00818] - E_Object Hash Init Done
[3-4.5779] ESTART: 0.03615 [0.00006] - E_Log Init
[3-4.5780] ESTART: 0.03627 [0.00012] - E_Log Init Done
[3-4.5780] ESTART: 0.03629 [0.00002] - Determine Prefix
[0-4.5861] ntkndplogo mod ld(0xbf1a9000)
[0-4.5862] [FB:INIT] logo 0 end
[0-4.5862] [FB:INIT] [logo End time:69]
[1-4.5863] [FB:INIT] [tuner Start]
[1-4.5864] [FB:INIT] cmd[tuner:insmod]
[1-4.5864] [FB:INIT] tuner 0 start
[2-4.5864] [FB:INIT] [frc Start]
[0-4.5865] [FB:INIT] [hdmi1 Start]
[2-4.5866] [FB:INIT] [audio Start]
[0-4.5866] [FB:INIT] cmd[frc:insmod]
[0-4.5866] [FB:INIT] frc 0 start
[2-4.5866] [FB:INIT] cmd[audio:insmod]
[1-4.5867] [FB:INIT] [alsa Start]
[0-4.5867] [FB:INIT] cmd[hdmi1:insmod]
[0-4.5867] [FB:INIT] hdmi1 0 start
[1-4.5867] [FB:INIT] fi_util_mq_send_cmd: cmd(108)
[2-4.5867] [FB:INIT] audio 0 start
[0-4.5868] [FB:I-N-I---T]- --c-m--- dTh[rlead Saa:cik nsageo d]-
thread[idle]
-- stack base = c400a8b8, upper = c400b010
-- lowerest sp = c40aef0
thread[]
-- stack base = 4090b8, upper = c400a810
-- lowerest s0p 45 8006000008]0
[FtB:rIead[]T
]-a-l stack b asset a= 34bfa0rta
8, pper = 34bfb800
-- lwrest sp = 00000000
[1-4.5884] [MC:S][4.5884][fastlogo]Inv-1
[3-4.5908] ntkndp_pq mod ld(0xbf186000)
[3-4.5921] ESTART: 0.05033 [0.01405] - Determine Prefix Done
[3-4.5921] ESTART: 0.05038 [0.00005] - Parse Arguments
[3-4.5921] ESTART: 0.05040 [0.00002] - Parse Arguments Done
[3-4.5921] ESTART: 0.05041 [0.00001] - Eet Init
[1-4.5930] [MC:A][4.5928]Inv(0)
[1-4.5931] [FB:LOGO] panel unmute
[3-4.5934] ESTART: 0.05161 [0.00120] - Eet Init Done
[3-4.5934] ESTART: 0.05167 [0.00006] - Ecore Init
[3-4.5948] [FB:LOGO] BootLogo start
[1-4.5974] init: ntkndphdmi
[2-4.5987] [FB:INIT] pq 0 end
[2-4.5987] [FB:INIT] pq 1 start
[1-4.5989] set g_ndp_hdmi_port_max  = 3
[1-4.5990] Can not find hdmi_hpd -> HDMI_HPD_PORTB in dtb file
[1-4.5991] Can not find hdmi_hpd -> HDMI_HPD_PORTD in dtb file
[1-4.5991] brdType = 1
[1-4.5991] eHDMI_HOT_PLUG[0] = 160
[1-4.5991] eHDMI_HOT_PLUG[2] = 163
[1-4.6068] ntkndphdmi mod ld(0xbf1bc000)
[1-4.6125] [FB:INIT] hdmi1 0 end
[1-4.6125] [FB:INIT] hdmi1 1 start
[3-4.6209] init: tztv_frc_tcon_api
[3-4.6223] tztv_frc_tcon_api mod ld(0xbf1cf000)
[3-4.6224] [FB:INIT] frc 0 end
[3-4.6224] [FB:INIT] frc 1 start
[2-4.6276] init: ntkndptcon
[0-4.6276] [HDMI-CMD]:[AUD]_hdmi_Initialize:En(0)
[0-4.6276] [HDMI-CMD]:[AUD]HDMI_Ctrl_Set_AudIPU-Mux(2)En(0)
[1-4.6288] init: tztv_audio_amp_api
[1-4.6296] tztv_audio_amp_api mod ld(0xbf1f8000)
[0-4.6334] [HDMI-CMD]:_4HDMI Initial Done
[1-4.6348] init: tztv_hdmi_switch_api
[1-4.6358] tztv_hdmi_switch_api mod ld(0xbf25a000)
[3-4.6362] ESTART: 0.09440 [0.04273] - Ecore Init Done
[3-4.6362] ESTART: 0.09452 [0.00012] - EIO Init
[3-4.6365] ESTART: 0.09478 [0.00026] - EIO Init Done
[3-4.6365] ESTART: 0.09480 [0.00002] - Ecore Event Handlers
[3-4.6366] ESTART: 0.09482 [0.00003] - Ecore Event Handlers Done
[3-4.6366] ESTART: 0.09489 [0.00006] - Ecore_File Init
[0-4.6439] KER_TCON_DrvInit: _tcon_mbxisr_ready
[3-4.6466] ntkndptcon mod ld(0xbf1e5000)
[3-4.6467] [FB:INIT] pq 1 end
[3-4.6467] [FB:INIT] [pq End time:155]
[1-4.6469] cma: [KTCON_INIT(419)] cma_alloc(): returned ec507a00 range 81050 - 81060
[1-4.6492] [FB:INIT] audio 0 end
[1-4.6493] [FB:INIT] audio 1 start
[0-4.6584] [FB:INIT] hdmi1 1 end
[0-4.6584] [FB:INIT] [hdmi1 End time:72]
[3-4.6593] [FB:INIT] [hdmi2 Start]
[3-4.6593] [FB:INIT] cmd[hdmi2:insmod]
[3-4.6593] [FB:INIT] hdmi2 0 start
[2-4.6627] init: ntkndpalsa
[0-4.6631] init: tztv_frc_tcon
[1-4.6633] init: tztv_audio_amp
[1-4.6743] init: tztv_tuner_drv_eu
[1-4.6759] tztv_tuner_drv_eu mod ld(0xbf2bf000)
[1-4.6760] [FB:INIT] tuner 0 end
[1-4.6760] [FB:INIT] tuner 1 start
[3-4.6803] init: tztv_hdmi_switch
[1-4.6803] init: tztv_tuner_eu
[0-4.6850] ESTART: 0.14324 [0.04835] - Ecore_File Init Done
[0-4.6850] ESTART: 0.14328 [0.00004] - E_Util_File_Monitor Init
[0-4.6850] ESTART: 0.14331 [0.00003] - E_Util_File_Monitor Init Done
[0-4.6851] ESTART: 0.14338 [0.00007] - XDG_DATA_DIRS Init
[0-[1-7.4096] ESTART: 2,86793 [0,00004] -            e-mod-tizen-virtualscreen-tv Module Enable
[1-7.4849] logger: enlightenment (p:220) exceeds the log limit:800
[1-7.4906] ESTART: 2,94891 [0,08098] - e-mod-tizen-virtualscreen-tv Module Enable Done 1
[1-7.5025] ESTART: 2,96074 [0,01183] - e-mod-tizen-wintok-tv Module Open
[1-7.5128] ESTART: 2,97104 [0,01030] - e-mod-tizen-wintok-tv Module Open Done m:0x59a2d8
[1-7.5128] ESTART: 2,97109 [0,00005] - e-mod-tizen-wintok-tv Module Enable
[1-7.5129] ESTART: 2,97116 [0,00007] - e-mod-tizen-wintok-tv Module Enable Done 1
[2-7.5468] ESTART: 3,00509 [0,03393] - e-mod-tizen-screensaver Module Open
[2-7.5581] ESTART: 3,01640 [0,01131] - e-mod-tizen-screensaver Module Open Done m:0x5bece8
[2-7.5582] ESTART: 3,01647 [0,00006] - e-mod-tizen-screensaver Module Enable
[2-7.5584] ESTART: 3,01669 [0,00022] - e-mod-tizen-screensaver Module Enable Done 1
[2-7.5597] ESTART: 3,01793 [0,00125] - e-mod-tizen-cursormgr-tv Module Open
[2-7.5820] ESTART: 3,04028 [0,02235] - e-mod-tizen-cursormgr-tv Module Open Done m:0x5ae4e8
[2-7.5821] ESTART: 3,04035 [0,00007] - e-mod-tizen-cursormgr-tv Module Enable
[1-7.5964] ESTART: 3,05465 [0,01430] - e-mod-tizen-cursormgr-tv Module Enable Done 1
[1-7.5967] ESTART: 3,05495 [0,00030] - e-mod-tizen-screencontroller-tv Module Open
[1-7.6179] ESTART: 3,07621 [0,02127] - e-mod-tizen-screencontroller-tv Module Open Done m:0x5a8158
[1-7.6180] ESTART: 3,07626 [0,00005] - e-mod-tizen-screencontroller-tv Module Enable
[1-7.6188] ESTART: 3,07704 [0,00078] - e-mod-tizen-screencontroller-tv Module Enable Done 1
[1-7.6191] ESTART: 3,07743 [0,00039] - [DEFERRED] DPMS Init
[1-7.6192] ESTART: 3,07745 [0,00002] - [DEFERRED] DPMS Init Done
[1-7.6192] ESTART: 3,07746 [0,00001] - [DEFERRED] Screens Init: win
[1-7.6192] ESTART: 3,07747 [0,00001] - [DEFERRED] Screens Init: win Done
[1-7.6192] ESTART: 3,07749 [0,00001] - [DEFERRED] E_Dnd Init
[1-7.6192] ESTART: 3,07750 [0,00002] - [DEFERRED] E_Dnd Init Done
[1-7.6192] ESTART: 3,07751 [0,00001] - [DEFERRED] E_Scale Init
[1-7.6194] ESTART: 3,07770 [0,00019] - [DEFERRED] E_Scale Init Done
[1-7.6194] ESTART: 3,07771 [0,00001] - [DEFERRED] E_Test_Helper Init
[1-7.6194] ESTART: 3,07773 [0,00002] - [DEFERRED] E_Test_Helper Done
[1-7.6195] ESTART: 3,07774 [0,00001] - [DEFERRED] E_INFO_SERVER Init
[1-7.6195] ESTART: 3,07775 [0,00001] - [DEFERRED] E_INFO_SERVER Done
[1-7.6195] ESTART: 3,07776 [0,00001] - [DEFERRED] Compositor's deferred job
[1-7.6195] ESTART: 3,07777 [0,00001] - E_BG_Zone Update
[0-7.6464] Bluetooth: [BTUSB] btmtk_usb_send_get_flash_type_cmd: Flash type:0B
[0-7.6464] Bluetooth: [BTUSB] btmtk_usb_get_flash_type_cmd: Get flash type result: OK
[0-7.6487] Bluetooth: [BTUSB] btmtk_usb_read_flash: lpm version:value:0E-08-01-D1-FC-00-23-03-08-20
[0-7.6559] Bluetooth: [BTUSB] btmtk_usb_read_flash: lpm version:value:0E-08-01-D1-FC-00-23-03-08-20
[0-7.6575] Bluetooth: [BTUSB] btmtk_usb_read_flash: lpm version:value:0E-08-01-D1-FC-00-23-03-08-20
[2-7.7814] init: smart_deadlock
[2-7.8723] [system_drv_ioctl] invalid ioctl param.
[1-7.8772] ESTART: 3,33547 [0,25770] - E_BG_Zone Update Done
[1-7.8772] ESTART: 3,33551 [0,00004] - E_Comp_Wl_Deferred
[1-7.8772] ESTART: 3,33553 [0,00002] - E_Comp_Wl_Deferred Done
[1-7.8773] ESTART: 3,33554 [0,00001] - [DEFERRED] Compositor's deferred job Done
[1-7.8773] ESTART: 3,33555 [0,00001] - [DEFERRED] E_Policy's deferred job
[1-7.8773] ESTART: 3,33557 [0,00002] - [DEFERRED] E_Policy's deferred job Done
[1-7.8773] ESTART: 3,33558 [0,00001] - [DEFERRED] E_Module's deferred job
[1-7.8773] ESTART: 3,33559 [0,00001] - [DEFERRED] E_Module's deferred job Done
[2-7.9673] [MC:A][7.9673][PwrOnMode:1][PrePOM:0][Res: 0][T-TV-1010_R(1)]
[2-7.9925] smart_deadlock mod ld(0xbf17a000)
[2-8.0653] [MC:S][8.0653][deviced]Scr on-0x33
[1-8.0937] dboohdmi handle_hdmi_port_changed :[0]:2
[1-8.0961] dboohdmi handle_hdmi_port_changed :[1]:2
[1-8.1107] dboohdmi handle_hdmi_port_changed :[2]:2
[1-8.1248] dboohdmi handle_hdmi_port_changed :[3]:2
[0-8.2372] Bluetooth: [BTUSB] btmtk_usb_read_flash: lpm version:value:0E-08-01-D1-FC-00-68-76-54-24
[0-8.2373] Bluetooth: [BTUSB] btmtk_usb_get_fw_version_in_flash: fw ver:20, 8, 3, 20
[0-8.2424] [system_drv_ioctl] invalid ioctl param.
[1-8.2424] [system_drv_ioctl] invalid ioctl param.
[1-8.2425] [system_drv_ioctl] invalid ioctl param.
[1-8.2860] [ALSA-CTRL] dnse auto volume level mode: put OFF [583:avocd]
[1-8.2872] [ALSA-CTRL] dnse balance: put 10 [583:avocd]
[0-8.3336] btusb_create:initiating spin_locks for btusb-endpoint buffers
[0-8.3336] btusb_create:all endpoint-buffers lock init done
[0-8.3380] Bluetooth: [BTUSB] btusb_probe: device_enable_async_suspend btusb0 1
[0-8.3383] [BTPCM] btpcm_ibiza_init: ibiza_pcm_buf_left_phy_addr=0x0
[0-8.3383] [BTPCM] btpcm_ibiza_init: ibiza_pcm_buf_size=0
[0-8.3383] [BTPCM] btpcm_ibiza_init: ibiza_pcm_left_write_phy_addr=0x0
[0-8.3383] [BTPCM] btpcm_ibiza_init: ibiza_enable_mark_addr(Default)=0x0
[0-8.3384] [BTPCM] btpcm_ibiza_init: ibiza_pcm_buf_left_phy_addr=0x0
[0-8.3384] [BTPCM] btpcm_ibiza_init: ibiza_pcm_buf_size=0
[0-8.3384] [BTPCM] btpcm_ibiza_init: ibiza_pcm_left_write_phy_addr=0x0
[0-8.3384] [BTPCM] btpcm_ibiza_init: ibiza_enable_mark_addr(Default)=0x0
[2-8.3385] [wlan][565](HAL EVENT) mtk_usb_probe()
[2-8.3385] [wlan][565](HAL EVENT) wlan_probe(0x20b1)(0)
[0-8.3386] btusb mod ld(0xbf569000)
[0-8.3387] [FB:INIT] bt 2 end
[0-8.3387] [FB:INIT] bt 3 start
[1-8.3425] [FB] AVOC ready end
[1-8.3426] [frc-tcon][ft_set_inverter][on][dpms:-1][pid:539,fb_do_inmute_pr]
[2-8.3445] [MC:S][8.3426][fb_do_inmute_pr]Inv-1
[2-8.3470] [FB] fb mute end
[2-8.3472] [MC:A][8.3469]Inv(0)
[0-8.3503] init: hid_samsung
[2-8.3582] [wlan][565](HAL STATE) USB Device speed: 3 [512]
[0-8.3589] [frc-tcon] panel dpms: on [pid:668,deviced]
[2-8.3593] [MC:S][8.3590][deviced]Inv-1
[0-8.3603] hid_samsung mod ld(0xbe81f000)
[0-8.3605] [FB:INIT] bt 3 end
[0-8.3605] [FB:INIT] [bt End time:1702]
[2-8.3642] [MC:A][8.3642]Inv(0)
[2-8.3652] [wlan][565](INIT EVENT) SS WCT734M type (PID: 0x20b1)
[2-8.3804] [wlan][565](INIT EVENT) Power on Wi-Fi....
[1-8.3881] [ALSA-CTRL] legacy ddplus out: put 1 [583:avocd]
[1-8.4190] [ALSA-CTRL] speaker out gain: put 15 [583:avocd]
[1-8.4201] [ALSA-CTRL] hp/line out gain: put 100 [583:avocd]
[1-8.4235] [ALSA-CTRL] speaker out mute: put 0 [583:avocd]
[1-8.4237] [ALSA-CTRL] spdif out mute: put 0 [583:avocd]
[1-8.4239] [ALSA-CTRL] main out bt/acm pcm mute: put 1 [583:avocd]
[1-8.4251] [ALSA-CTRL] hp/line out enable: put 0 [583:avocd]
[0-8.4305] [ALSA-CTRL] spdif out mute: put 1 [583:avocd]
[0-8.4307] [ALSA-CTRL] spdif out signal: put 1 [583:avocd]
[0-8.4307] [ALSA-CTRL] spdif out signal: [Error] put is not implemented yet
[0-8.4307] [ALSA-CTRL] spdif out mute: put 0 [583:avocd]
[0-8.4323] [ALSA-CTRL] spdif out delay: put 0 [583:avocd]
[0-8.4323] [ALSA-CTRL] pass through out delay: put 0 [583:avocd]
[0-8.4324] [ALSA-CTRL] main out delay: put 0 [583:avocd]
[0-8.4325] [ALSA-CTRL] hp/line out delay: put 0 [583:avocd]
[0-8.4325] [ALSA-CTRL] spdif out format: put PCM [583:avocd]
[0-8.4329] [ALSA-CTRL] pass through out: put 0 [583:avocd]
[0-8.4333] [ALSA-CTRL] output mix only: put 0 [583:avocd]
[2-8.4371] [wlan][565](INIT EVENT) Before HAL_WIFI_FUNC_READY_CHECK
[2-8.4381] [wlan][565](INIT EVENT) After HAL_WIFI_FUNC_READY_CHECK
[1-8.4944] [NTKETHMAC] synopGMAC_linux_open called
[2-8.5102] [wlan][565](INIT EVENT) Complete!!!
[2-8.5164] [wlan][565](INIT STATE) Request FW image: mtk/mt7668_patch_e2_hdr.bin done
[2-8.5483] [wlan][565](INIT STATE) Request FW image: mtk/WIFI_RAM_CODE_MT7668.bin done
[2-8.6204] [wlan][565](INIT STATE) Request FW image: mtk/WIFI_RAM_CODE2_USB_MT7668.bin done
[1-8.7323] Before Recovery:
[1-8.7323] Code: f000 80c6 f7fb e8ee (6803) 695b
[1-8.7323] After Recovery:
[1-8.7323] send signal from KERNEL, SIG : 11, tvs-daemon(760), handler:0x0 force_sig_info
[1-8.7323] tvs-daemon: unhandled page fault (11) at 0x00000000, code 0x017
[2-8.7620] [wlan][565](INIT WARN) Send a Dummy CMD as wor/libboost_filesystem.so.1.58.0
[1-9.6958] 43e70000-43e8d000 r-xp 00000000 b3:12 16466      /usr/lib/liblibtv-plpmanager.so
[1-9.6958] 43e8d000-43e9c000 ---p 0001d000 b3:12 16466      /usr/lib/liblibtv-plpmanager.so
[1-9.6958] 43e9c000-43e9d000 r--p 0001c000 b3:12 16466      /usr/lib/liblibtv-plpmanager.so
[1-9.6958] 43e9d000-43e9e000 rw-p 0001d000 b3:12 16466      /usr/lib/liblibtv-plpmanager.so
[1-9.6958] 43ea0000-43ebc000 r-xp 00000000 b3:12 17035      /usr/lib/libsensor-genuine.so.4.0.4
[1-9.6958] 43ebc000-43ecb000 ---p 0001c000 b3:12 17035      /usr/lib/libsensor-genuine.so.4.0.4
[1-9.6958] 43ecb000-43ecc000 rw-p 0001b000 b3:12 17035      /usr/lib/libsensor-genuine.so.4.0.4
[1-9.6958] 43ed0000-43ee1000 r-xp 00000000 b3:12 15268      /usr/lib/libsensord-shared.so
[1-9.6959] 43ee1000-43ef0000 ---p 00011000 b3:12 15268      /usr/lib/libsensord-shared.so
[1-9.6959] 43ef0000-43ef1000 r--p 00010000 b3:12 15268      /usr/lib/libsensord-shared.so
[1-9.6959] 43ef1000-43ef2000 rw-p 00011000 b3:12 15268      /usr/lib/libsensord-shared.so
[1-9.6959] 43f00000-43f08000 r-xp 00000000 b3:12 12157      /usr/lib/libappcore-common.so.1.14.1
[1-9.6959] 43f08000-43f17000 ---p 00008000 b3:12 12157      /usr/lib/libappcore-common.so.1.14.1
[1-9.6959] 43f17000-43f18000 r--p 00007000 b3:12 12157      /usr/lib/libappcore-common.so.1.14.1
[1-9.6959] 43f18000-43f19000 rw-p 00008000 b3:12 12157      /usr/lib/libappcore-common.so.1.14.1
[1-9.6959] 43f20000-43f22000 r-xp 00000000 b3:12 17099      /usr/lib/libboost_system.so.1.58.0
[1-9.6959] 43f22000-43f31000 ---p 00002000 b3:12 17099      /usr/lib/libboost_system.so.1.58.0
[1-9.6959] 43f31000-43f32000 r--p 00001000 b3:12 17099      /usr/lib/libboost_system.so.1.58.0
[1-9.6959] 43f32000-43f33000 rw-p 00002000 b3:12 17099      /usr/lib/libboost_system.so.1.58.0
[1-9.6959] 43f40000-43f44000 r-xp 00000000 b3:12 17021      /usr/lib/libcapi-appfw-app-control-uri.so.0.11.11
[1-9.6959] 43f44000-43f53000 ---p 00004000 b3:12 17021      /usr/lib/libcapi-appfw-app-control-uri.so.0.11.11
[1-9.6959] 43f53000-43f54000 r--p 00003000 b3:12 17021      /usr/lib/libcapi-appfw-app-control-uri.so.0.11.11
[1-9.6959] 43f54000-43f55000 rw-p 00004000 b3:12 17021      /usr/lib/libcapi-appfw-app-control-uri.so.0.11.11
[1-9.6959] 43f60000-43f67000 r-xp 00000000 b3:12 11187      /usr/lib/libcapi-appfw-app-control.so.0.11.11
[1-9.6959] 43f67000-43f76000 ---p 00007000 b3:12 11187      /usr/lib/libcapi-appfw-app-control.so.0.11.11
[1-9.6960] 43f76000-43f77000 r--p 00006000 b3:12 11187      /usr/lib/libcapi-appfw-app-control.so.0.11.11
[1-9.6960] 43f77000-43f78000 rw-p 00007000 b3:12 11187      /usr/lib/libcapi-appfw-app-control.so.0.11.11
[1-9.6960] 43f80000-43fe4000 r-xp 00000000 b3:12 11221      /usr/lib/libtvs-pvr.so
[1-9.6960] 43fe4000-43ff4000 ---p 00064000 b3:12 11221      /usr/lib/libtvs-pvr.so
[1-9.6960] 43ff4000-43ff5000 r--p 00064000 b3:12 11221      /usr/lib/libtvs-pvr.so
[1-9.6960] 43ff5000-43ff7000 rw-p 00065000 b3:12 11221      /usr/lib/libtvs-pvr.so
[1-9.6960] 44000000-44061000 r-xp 00000000 b3:12 12282      /usr/lib/libsecurity-manager-commons.so.1.0.2
[1-9.6960] 44061000-44071000 ---p 00061000 b3:12 12282      /usr/lib/libsecurity-manager-commons.so.1.0.2
[1-9.6960] 44071000-44073000 rw-p 00061000 b3:12 12282      /usr/lib/libsecurity-manager-commons.so.1.0.2
[1-9.6960] 44080000-440d3000 r-xp 00000000 b3:12 16185      /usr/lib/libboost_serialization.so.1.58.0
[1-9.6960] 440d3000-440e3000 ---p 00053000 b3:12 16185      /usr/lib/libboost_serialization.so.1.58.0
[1-9.6960] 440e3000-440e4000 r--p 00053000 b3:12 16185      /usr/lib/libboost_serialization.so.1.58.0
[1-9.6960] 440e4000-440e6000 rw-p 00054000 b3:12 16185      /usr/lib/libboost_serialization.so.1.58.0
[1-9.6960] 440f0000-44130000 r-xp 00000000 b3:12 11420      /usr/lib/libtvs-dbms.so
[1-9.6960] 44130000-4413f000 ---p 00040000 b3:12 11420      /usr/lib/libtvs-dbms.so
[1-9.6960] 4413f000-44140000 r--p 0003f000 b3:12 11420      /usr/lib/libtvs-dbms.so
[1-9.6960] 44140000-44142000 rw-p 00040000 b3:12 11420      /usr/lib/libtvs-dbms.so
[1-9.6961] 44150000-44158000 r-xp 00000000 b3:12 11258      /usr/lib/libcrypt-2.24.so
[1-9.6961] 44158000-44167000 ---p 00008000 b3:12 11258      /usr/lib/libcrypt-2.24.so
[1-9.6961] 44167000-44168000 r--p 00007000 b3:12 11258      /usr/lib/libcrypt-2.24.so
[1-9.6961] 44168000-44169000 rw-p 00008000 b3:12 11258      /usr/lib/libcrypt-2.24.so
[1-9.6961] 44169000-44190000 rw-p 00000000 00:00 0
[1-9.6961] 441a0000-441bf000 r-xp 00000000 b3:12 11836      /usr/lib/libboost_thread.so.1.58.0
[1-9.6961] 441bf000-441ce000 ---p 0001f000 b3:12 11836      /usr/lib/libboost_thread.so.1.58.0
[1-9.6961] 441ce000-441cf000 r--p 0001e000 b3:12 11836      /usr/lib/libboost_thread.so.1.58.0
[1-9.6961] 441cf000-441d0000 rw-p 0001f000 b3:12 11836      /usr/lib/libboost_thread.so.1.58.0
[1-9.6961] 441e0000-44238000 r-xp 00000000 b3:12 11766      /usr/lib/libtvs-tpms.so
[1-9.6961] 44238000-44248000 ---p 00058000 b3:12 11766      /usr/lib/libtvs-tpms.so
[1-9.6961] 44248000-44249000 r--p 00058000 b3:12 11766      /usr/lib/libtvs-tpms.so
[1-9.6961] 44249000-4424b000 rw-p 00059000 b3:12 11766      /usr/lib/libtvs-tpms.so
[1-9.6961] 44260000-4426b000 r-xp 00000000 b3:12 11802      /usr/lib/libprocps.so.7.1.0
[1-9.6961] 4426b000-4427b000 ---p 0000b000 b3:12 11802      /usr/lib/libprocps.so.7.1.0
[1-9.6962] 4427b000-4427c000 r--p 0000b000 b3:12 11802      /usr/lib/libprocps.so.7.1.0
[1-9.6962] 4427c000-4427d000 rw-p 0000c000 b3:12 11802      /usr/lib/libprocps.so.7.1.0
[1-9.6962] 4427d000-4428f000 rw-p 00000000 00:00 0
[1-9.6962] 442a0000-442b6000 r-xp 00000000 b3:12 16922      /usr/lib/libcapi-system-usbdevice.so
[1-9.6962] 442b6000-442c6000 ---p 00016000 b3:12 16922      /usr/lib/libcapi-system-usbdevice.so
[1-9.6962] 442c6000-442c9000 r--p 00016000 b3:12 16922      /usr/lib/libcapi-system-usbdevice.so
[1-9.6962] 442c9000-442ca000 rw-p 00019000 b3:12 16922      /usr/lib/libcapi-system-usbdevice.so
[1-9.6962] 442d0000-442e1000 r-xp 00000000 b3:12 16741      /usr/lib/libcynara-admin.so.0.14.24
[1-9.6962] 442e1000-442f0000 ---p 00011000 b3:12 16741      /usr/lib/libcynara-admin.so.0.14.24
[1-9.6962] 442f0000-442f1000 r--p 00010000 b3:12 16741      /usr/lib/libcynara-admin.so.0.14.24
[1-9.6962] 442f1000-442f2000 rw-p 00011000 b3:12 16741      /usr/lib/libcynara-admin.so.0.14.24
[1-9.6962] 44300000-44317000 r-xp 00000000 b3:12 11039      /usr/lib/libcynara-storage.so.0.14.24
[1-9.6962] 44317000-44326000 ---p 00017000 b3:12 11039      /usr/lib/libcynara-storage.so.0.14.24
[1-9.6962] 44326000-44327000 r--p 00016000 b3:12 11039      /usr/lib/libcynara-storage.so.0.14.24
[1-9.6962] 44327000-44328000 rw-p 00017000 b3:12 11039      /usr/lib/libcynara-storage.so.0.14.24
[1-9.6962] 44330000-4434c000 r-xp 00000000 b3:12 11921      /usr/lib/libtv_recorder.so.0.0.0
[1-9.6963] 4434c000-4435b000 ---p 0001c000 b3:12 11921      /usr/lib/libtv_recorder.so.0.0.0
[1-9.6963] 4435b000-4435c000 r--p 0001b000 b3:12 11921      /usr/lib/libtv_recorder.so.0.0.0
[1-9.6963] 4435c000-4435d000 rw-p 0001c000 b3:12 11921      /usr/lib/libtv_recorder.so.0.0.0
[1-9.6963] 44360000-44379000 r-xp 00000000 b3:12 11871      /usr/lib/libsecurity-manager-client.so.3.0.0
[1-9.6963] 44379000-44388000 ---p 00019000 b3:12 11871      /usr/lib/libsecurity-manager-client.so.3.0.0
[1-9.6963] 44388000-44389000 r--p 00018000 b3:12 11871      /usr/lib/libsecurity-manager-client.so.3.0.0
[1-9.6963] 44389000-4438a000 rw-p 00019000 b3:12 11871      /usr/lib/libsecurity-manager-client.so.3.0.0
[1-9.6963] 44390000-4439e000 r-xp 00000000 b3:12 16454      /usr/lib/libsecurity-privilege-manager.so.1.1.6
[1-9.6963] 4439e000-443ad000 ---p 0000e000 b3:12 16454      /usr/lib/libsecurity-privilege-manager.so.1.1.6
[1-9.6963] 443ad000-443ae000 r--p 0000d000 b3:12 16454      /usr/lib/libsecurity-privilege-manager.so.1.1.6
[1-9.6963] 443ae000-443af000 rw-p 0000e000 b3:12 16454      /usr/lib/libsecurity-privilege-manager.so.1.1.6
[1-9.6963] 443c0000-443cb000 r-xp 00000000 b3:12 16579      /usr/lib/libcynara-client-async.so.0.14.24
[1-9.c
load tcon fail
444mA
А если отключить шлейфа на матрас ?
Будет это в логе.
10 минут назад, san-vai сказал:
Будет это в логе.
Да, проверял раньше, это также есть
(то есть : без изменений)
(Т-сon здесь на майне)
Сейчас перепроверю и отпишусь
Лог со входом в консоль, через Ентер
А  это как снять?
Еще по поводу тэкона:
напряжения все совпадают кроме следующих
1) VAA=13,9 (подписано на плате как 17 В)
2) HVAA=6,7 (подписано на плате как 8,6 В)
Это так и с подключенным шлейфом на матрицу, и без него (с подачей напряжения на к.т. FB_TRDY_3)
И попробуй замкни вверхней части две жирные точки и включить с откинутым шлейфом и что будет в терминале по поводу ткона ?
13 минут назад, san-vai сказал:
На сколько помню, без изменений
Но сейчас перепроверю
14 минут назад, Alex1101 сказал:
В принципе с такими напряжениями должен аппарат работать
(тем более что картинка в норме)
Как считаете насчет этих напряжений?
В логе ругань идет видимо на этот шим, он может быть подбит чуть или керамика уплыла возле, надо досконально его проверить, в логе не должно быть этого. Он не греется ?
32 минуты назад, san-vai сказал:
Будет это в логе.
1) с подключенным шлейфом
ЂzAC
V2
load tcon fail
444mA
d
boot-up
0084(6250644)
r
J001
S11
E11
0 p
GPT
D
DTB 0
xdt1.5G
SECDRV 0
or003.0
SECOS 0
kr003.0
KERNEL 0
[1-0.0600] I2C IRQ init_timer start(0517_Tizen4.0)
[1-0.0669] [DEBUG]register base fd6f0000
[1-0.0669] [DEBUG] interregister base d
[1-0.0670] gzip support fifo mode
[1-0.0672] (NULL device *): ~get gpio base-val: 0xed096000, 0x0
[1-0.0672] nvt,auth fd770000.auth: hw auth support fifo mode, 1090309
[0-0.0939] type=2000 audit(0.091:1): initialized
[1-0.1012] Novatek UART Direct I/O Driver Init.
[1-0.1013] nvt-udio fd092000.uart: io_base ed0a8000
[1-0.1013] nvt-udio fd092000.uart: clock rate 100000000
[1-0.1013] nvt-udio fd092000.uart: baud rate 115200
[1-0.1013] nvt-udio fd092000.uart: irq 11
[1-0.1014] nvt-udio fd092000.uart: probing completed
[1-0.1451] [NTKETHMAC]: synopGMAC_probe.
[1-0.1452] [NTKETHMAC]: Now Registering the netdevice
[1-0.1592] mmcblk0: mmc0:0001 4FTE4R 3.64 GiB
[1-0.1832]  Ver : 6340677, release
[1-0.1832]  TV, Kant.SU2-Tizen, release, Trunk_2020_MP
[1-0.1832]  Linux version 4.1.10 (abuild@A1312DKG) (gcc version 6.2.1 20161213 (Tizen/Linaro GCC 6.2.1 2016.12/VDCosmos-20190704 7.8) ) #1 SMP PREEMPT Fri Jan 8 11:04:50 UTC 2021
[1-0.1861]  dtsversion=6290398_kantsu2-1.5G-cma console=ttyS0,115200 rs232=0 earlyprintk maxcpus=4 no_console_suspend only_entry_model root=/dev/mmcblk0p18 KDUMP=16 SELP_ENABLE=20208724 _nvtca9-16m rootfstype=vdfs ro init=/sbin/init mem=808M@32M mem=56M@968M mem=256M@2048M vmalloc=300M rootwait quiet bdinfo=00000091 model=4kbtin   pba_none
[0-0.3293] vdfs4-WARN: SB: bad signature - , expected - VDFSmount: /mnt/systemrw: wrong fs type, bad option, bad superblock on /dev/mmcblk0p20, missing codepage or helper program, or other error.
[1-2.1482] [NTKETHMAC]: Trim RTER_RX = 0x3, 0368[70]
[1-2.1482] [NTKETHMAC]: Trim RTER_TX = 0x3, 0368[6c]
[1-2.1482] [NTKETHMAC]: Trim TX_ROUT = 0x4, 0374[25]
[1-2.1483] [NTKETHMAC]: Trim TX_SWING = 0x1, 0378[21]
2) с отключенным
ЂzAC
V2
load tcon fail
444mA
d
boot-up
0084(6250644)
r
J001
S11
E11
0 p
GPT
D
DTB 0
xdt1.5G
SECDRV 0
or003.0
SECOS 0
kr003.0
KERNEL 0
[0-0.1282] [NTKETHMAC]: synopGMAC_probe.
[0-0.1283] [NTKETHMAC]: Now Registering the netdevice
[0-0.1743]  Ver : 6340677, release
[0-0.1743]  TV, Kant.SU2-Tizen, release, Trunk_2020_MP
[0-0.1743]  Linux version 4.1.10 (abuild@A1312DKG) (gcc version 6.2.1 20161213 (Tizen/Linaro GCC 6.2.1 2016.12/VDCosmos-20190704 7.8) ) #1 SMP PREEMPT Fri Jan 8 11:04:50 UTC 2021
[0-0.1744]  dtsversion=6290398_kantsu2-1.5G-cma console=ttyS0,115200 rs232=0 earlyprintk maxcpus=4 no_console_suspend only_entry_model root=/dev/mmcblk0p18 KDUMP=16 SELP_ENABLE=20208724 _nvtca9-16m rootfstype=vdfs ro init=/sbin/init mem=808M@32M mem=56M@968M mem=256M@2048M vmalloc=300M rootwait quiet bdinfo=00000091 model=4kbtin   pba_none
[1-0.2335] mmcblk0: mmc0:0001 4FTE4R 3.64 GiB
[0-0.3626] vdfs4-WARN: SB: bad signature - , expected - VDFSmount: /mnt/systemrw: wrong fs type, bad option, bad superblock on /dev/mmcblk0p20, missing codepage or helper program, or other error.
[1-2.1322] [NTKETHMAC]: Trim RTER_RX = 0x3, 0368[70]
[1-2.1322] [NTKETHMAC]: Trim RTER_TX = 0x3, 0368[6c]
[1-2.1322] [NTKETHMAC]: Trim TX_ROUT = 0x4, 0374[25]
[1-2.1323] [NTKETHMAC]: Trim TX_SWING = 0x1, 0378[21]
[0-3.3810] vdfs4-WARN: SB: bad signature - , expected - VDFSmount: /mnt/systemrw: wrong fs type, bad option, bad superblock on /dev
error opening /sys/kernel/debug/tracing/options/overwrite: No such file or directory (2)
Tags: 0x1, excludedTags: 0x0
error opening /sys/kernel/debug/tracing/tracing_on: No s[0-3.5147] init: lwipc
uch file or dire[0-3.5150] lwipc mod ld(0xbe800000)
ctory (2)
[cynara-launcher] launch cynara( 116 )
[cy[1-3.5150] init: logger
nara-launcher] w[1-3.5164] logger mod ld(0xbe805000)
[0-3.5703] init: tztv_bootmode
[0-3.5705] tztv_bootmode mod ld(0xbe81d000)
boot mode: normal
[0-3.6762] [FB:INIT] fast init start
[0-3.6764] [FB:INIT] insmod file : index.json
build: 20210108_[0-3.6844] [FB:INIT] [prebasic Start]
144709
keymap: [0-3.6844] [FB:INIT] cmd[prebasic:insmod]
20210108_144709
[0-3.6844] [FB:INIT] prebasic 0 start
We have a keyma[0-3.6954] init: PreInit
p cache version [0-3.6965] ================================================================================
file
[security-[0-3.6965]  Pre Initiation
manager-launcher[0-3.6965]  Version : Kantsu2_Onemain_2020_KantSU2_Trunk2020_MP_v0.201016.0_r93d41424e63.
(174)]  > Starting Security Mana[0-3.6965] ================================================================================
ger Launcher...
[security-manager-launcher(174)]  > security-manager(pid : 194) is launched successfully...
Set Buxton env
cat: [eeprom open wait]
/run/user/5001/.launchpad.pid: No such file or directory
[eeprom open wait]
[0-3.7681] [TEMP_MSGBOX] #################
[0-3.7681] [TEMP_MSGBOX] MessageBox Drive_init
[0-3.7690] genirq: Flags mismatch irq 11. 00000080 (ntk_serial) vs. 00000000 (fd092000.uart)
[eeprom open wai[0-3.7690] PreInit mod ld(0xbe821000)
t]
[0-3.7691] [FB:INIT] prebasic 0 end
[0-3.7691] [FB:INIT] prebasic 1 start
[3-3.8080] DynBoost3.1.8
[eeprom open wait]
[prdv_attr: [0-3.8131] init: tztv_eeprom
/dev/tty]
[prdv_attr: /dev/bptime]
[prdv_attr: /dev/snd/timer][0-3.8134] client = 0xebdfe200
[prdv_attr: /d[0-3.8141] tztv_eeprom mod ld(0xbe88d000)
ev/uinput]
[prd[0-3.8142] [FB:INIT] prebasic 1 end
v_attr: /dev/eep[0-3.8142] [FB:INIT] prebasic 2 start
rom]
[prdv_attr[0-3.8226] init: tztv_micom
: /dev/zero]
[prdv_attr: /dev/micom-cec]
FP_NVRAM_FASTBOOT_IN_[3-3.8502] [MC:S][3.8502][kthread_watchdo]Rollback
PRODUCTION [0]
[3-3.8670] [MC:A][3.8660]TV ver 1010_R(1)
[3-3.8705] [MC:A][3.8697][PwrOnMode:1][PrePOM:0][Res: 0][T-TV-1010_R(1)]
[3.86 13.43][BXT] buxton2d started
[0-3.8798] tztv_micom mod ld(0xbe893000)
[0-3.8799] [FB:INIT] prebasic 2 end
[0-3.8799] [FB:INIT] prebasic 3 start
[0-3.8908] init: videobuf2_core
[0-3.8911] videobuf2_core mod ld(0xbe8a5000)
[0-3.8912] [FB:INIT] prebasic 3 end
[0-3.8912] [FB:INIT] prebasic 4 start
[1-3.8925] [MC:A][3.8925]boot_reason(0) [TV ver 1010_R(1)]
[prdv_attr: /dev/dmabuf_kds]
[2-3.8926] [SBH] get_boot_reason is (0)
[3-3.8965] init: videobuf2_memops
[prdv_attr: /dev/mali0]
[3-3.8968] videobuf2_memops mod ld(0xbe8ad000)
[3-3.8970] [FB:INIT] prebasic 4 end
[3-3.8970] [FB:INIT] prebasic 5 start
[3-3.9090] init: videobuf2_vmalloc
[3-3.9092] videobuf2_vmalloc mod ld(0xbe8af000)
[3-3.9094] [FB:INIT] prebasic 5 end
[3-3.9094] [FB:INIT] [prebasic End time:225]
[3-3.9094] [FB:INIT] fi_util_mq_send_cmd: cmd(122)
cat: [3-3.9095] [FB:INIT] [fi_depList_init:763] index_path [/tmp/FACTORY_PRODCU[FB:INIT] no flag file:/tmp/FACTORY_PRODCUTION
/opt/data/Device[3-3.9095] [FB:INIT] [fi_depList_init:763] index_path [/opt/usr/apps/MCS_m[FB:INIT] no flag file:/opt/usr/apps/MCS_mode
Tracker/htPolicy[3-3.9096] [FB:INIT] [fi_depList_init:763] index_path [/opt/usr/apps/org.t[FB:INIT] no flag file:/opt/usr/apps/org.tizen.btapp/data/tv_so[FB:INIT] [fi_depList_init:763] index_path []
State: No such f[3-3.9096] [FB:INIT] no flag file:
ile or directory[3-3.9096] [FB:INIT] Index path Null
[3-3.9096] [FB:INIT] INIT index_path[index]
[1-3.9096] [FB:LOGO] panel_enable(1)
[1-3.9098] [FB:INIT] [fw Start]
[1-3.9099] [FB:INIT] cmd[fw:insmod]
[1-3.9099] [FB:INIT] fw 0 start
[1-3.9117] [FB:INIT] [tzdev Start]
[1-3.9118] [FB:INIT] cmd[tzdev:insmod]
[1-3.9118] [FB:INIT] tzdev 0 start
[1-3.9210] init: mali
[0-3.9381] mali mod ld(0xbe8b1000)
[0-3.9382] [FB:INIT] fw 0 end
[0-3.9382] [FB:INIT] fw 1 start
[1-3.9432] init: tzdev
[1-3.9743] tzdev mod ld(0xbe8fd000)
[1-3.9744] [FB:INIT] tzdev 0 end
[1-3.9744] [FB:INIT] cmd[tzdev:chmod]
[1-3.9745] [FB:INIT] [tzdev End time:63]
[1-3.9745] [FB:INIT] create path(/tmp/tzdev_insmod_done)
[3-3.9752] [FB:LOGO] logo mode(0)
Buffer main is set
[security-manager-launcher(174)]  > inotify event is received for /run/security-manager.socket
[PKGMGR] /opt/dbspace/.pkgmgr_parser.db file size 948
3) с отключенным и запущенным тэконом
<0>яzAC
V2
load tcon fail
444mA
d
boot-up
0084(6250644)
r
J001
S11
E11
0 p
GPT
D
DTB 0
xdt1.5G
SECDRV 0
or003.0
SECOS 0
kr003.0
KERNEL 0
[1-0.0670] [DEBUG] interregister base d
[1-0.0673] nvt,auth fd770000.auth: hw auth support fifo mode, 1090309
[0-0.0940] type=2000 audit(0.091:1): initialized
[1-0.1003] Novatek UART Direct I/O Driver Init.
[1-0.1003] nvt-udio fd092000.uart: io_base ed0a8000
[1-0.1003] nvt-udio fd092000.uart: clock rate 100000000
[1-0.1003] nvt-udio fd092000.uart: baud rate 115200
[1-0.1004] nvt-udio fd092000.uart: irq 11
[1-0.1005] nvt-udio fd092000.uart: probing completed
[1-0.1562] [NTKETHMAC]: synopGMAC_probe.
[1-0.1563] [NTKETHMAC]: Now Registering the netdevice
[1-0.1673] mmcblk0: mmc0:0001 4FTE4R 3.64 GiB
[0-0.1816]  Ver : 6340677, release
[0-0.1816]  TV, Kant.SU2-Tizen, release, Trunk_2020_MP
[0-0.1816]  Linux version 4.1.10 (abuild@A1312DKG) (gcc version 6.2.1 20161213 (Tizen/Linaro GCC 6.2.1 2016.12/VDCosmos-20190704 7.8) ) #1 SMP PREEMPT Fri Jan 8 11:04:50 UTC 2021
[0-0.1817]  dtsversion=6290398_kantsu2-1.5G-cma console=ttyS0,115200 rs232=0 earlyprintk maxcpus=4 no_console_suspend only_entry_model root=/dev/mmcblk0p18 KDUMP=16 SELP_ENABLE=20208724 _nvtca9-16m rootfstype=vdfs ro init=/sbin/init mem=808M@32M mem=56M@968M mem=256M@2048M vmalloc=300M rootwait quiet bdinfo=00000091 model=4kbtin   pba_none
[1-0.3626] vdfs4-WARN: SB: bad signature - , expected - VDFSmount: /mnt/systemrw: wrong fs type, bad option, bad superblock on /dev/mmcblk0p20, missing codepage or helper program, or other error.
[0-2.1602] [NTKETHMAC]: Trim RTER_RX = 0x3, 0368[70]
[0-2.1602] [NTKETHMAC]: Trim RTER_TX = 0x3, 0368[6c]
[0-2.1603] [NTKETHMAC]: Trim TX_ROUT = 0x4, 0374[25]
[0-2.1603] [NTKETHMAC]: Trim TX_SWING = 0x1, 0378[21]
[0-3.3820] vdfs4-WARN: SB: bad signature - , expected - VDFSmount: /mnt/systemrw: wrong fs type, bad option, bad superblock on /dev
error opening /sys/kernel/debug/tracing/options/[0-3.5092] init: logger
overwrite: No su[1-3.5100] init: lwipc
ch file or direc[0-3.5109] lwipc mod ld(0xbe818000)
tory (2)
Tags: [1-3.5123] logger mod ld(0xbe800000)
error opening /sys/kernel/debug/tracing/tracing_on: No such file or directory (2)
[cynara-launcher] launch cynara( 121 )
[0-3.5491] init: tztv_bootmode
Booting from tzt[0-3.5493] tztv_bootmode mod ld(0xbe81d000)
v mode
boot mode: normal
[eeprom open wait]
[0-3.6689] DynBoost3.1.8
[2-3.6772] [FB:INIT] fast init start
[2-3.6774] [FB:INIT] insmod file : index.json
[eeprom open wait]
build: 20210[2-3.6890] [FB:INIT] [prebasic Start]
108_144709
keymap: 20210108_144709
We have a keymap ca[2-3.6890] [FB:INIT] cmd[prebasic:insmod]
che version file
Set Buxton env
[eeprom open wait]
[prdv_attr: /dev[2-3.6890] [FB:INIT] prebasic 0 start
/tty]
[p[2-3.6963] init: PreInit
rdv_attr: /dev/u[2-3.6982] ================================================================================
input]
[2-3.6982]  Pre Initiation
cat: [eeprom ope[2-3.6982]  Version : Kantsu2_Onemain_2020_KantSU2_Trunk2020_MP_v0.201016.0_r93d41424e63.
n wait]
/run/us[2-3.6982] ================================================================================
er/5001/.launchp[0-3.7535] [TEMP_MSGBOX] #################
[eeprom open wait]
Cynara db[0-3.7535] [TEMP_MSGBOX] MessageBox Drive_init
 update success
[3.77 13.47][BXT] buxton2d started
[prdv_attr: /dev/eeprom]
[0-3.7559] genirq: Flags mismatch irq 11. 00000080 (ntk_serial) vs. 00000000 (fd092000.uart)
[0-3.7559] PreInit mod ld(0xbe821000)
FP_NVRAM_FASTBOO[0-3.7561] [FB:INIT] prebasic 0 end
T_IN_PRODUCTION [0-3.7561] [FB:INIT] prebasic 1 start
[0]
[3-3.7831] init: tztv_eeprom
[3-3.7837] client = 0xebdfe200
[3-3.7844] tztv_eeprom mod ld(0xbe88d000)
[3-3.7846] [FB:INIT] prebasic 1 end
[3-3.7846] [FB:INIT] prebasic 2 start
[prdv_attr: /dev[3-3.7885] init: tztv_micom
/micom-cec]
[3-3.8361] [MC:S][3.8352][kthread_watchdo]Rollback
[3-3.8485] [MC:A][3.8421]TV ver 1010_R(1)
[3-3.8518] [MC:A][3.8518][PwrOnMode:1][PrePOM:0][Res: 0][T-TV-1010_R(1)]
[3-3.8665] tztv_micom mod ld(0xbe893000)
[3-3.8670] [FB:INIT] prebasic 2 end
[3-3.8673] [FB:INIT] prebasic 3 start
[3-3.8769] init: videobuf2_core
[3-3.8774] videobuf2_core mod ld(0xbe8a5000)
[3-3.8775] [FB:INIT] prebasic 3 end
[3-3.8775] [FB:INIT] prebasic 4 start
[3-3.8814] init: videobuf2_memops
[3-3.8816] videobuf2_memops mod ld(0xbe816000)
[3-3.8817] [FB:INIT] prebasic 4 end
[3-3.8817] [FB:INIT] prebasic 5 start
[security-manager-launcher(272)]  > Starting Sec[2-3.8841] [MC:A][3.8841]boot_reason(0) [TV ver 1010_R(1)]
[prdv[1-3.8842] [SBH] get_boot_reason is (0)
_attr: /dev/dmab[3-3.8866] init: videobuf2_vmalloc
uf_kds]
[securi[3-3.8868] videobuf2_vmalloc mod ld(0xbe81b000)
ty-manager-launcher(272)]  > sec[3-3.8870] [FB:INIT] prebasic 5 end
urity-manager(pi[3-3.8870] [FB:INIT] [prebasic End time:198]
d : 276) is laun[3-3.8871] [FB:INIT] fi_util_mq_send_cmd: cmd(122)
ched successfull[3-3.8871] [FB:INIT] fi_util_mq_send_cmd: cmd(122)
y...
[prdv_attr[3-3.8871] [FB:INIT] [fi_depList_init:763] index_path [/tmp/FACTORY_PRODCU[FB:INIT] no flag file:/tmp/FACTORY_PRODCUTION
: /dev/mali0]
[3-3.8872] [FB:INIT] [fi_depList_init:763] index_path [/opt/usr/apps/MCS_m[FB:INIT] no flag file:/opt/usr/apps/MCS_mode
[3-3.8872] [FB:INIT] [fi_depList_init:763] index_path [/opt/usr/apps/org.t[FB:INIT] no flag file:/opt/usr/apps/org.tizen.btapp/data/tv_so[FB:INIT] [fi_depList_init:763] index_path []
[3-3.8872] [FB:INIT] no flag file:
[3-3.8872] [FB:INIT] Index path Null
[3-3.8873] [FB:INIT] INIT index_path[index]
cat: /opt/data/Device[1-3.8873] [FB:LOGO] panel_enable(1)
Tracker/htPolicy[3-3.8906] [FB:INIT] [tzdev Start]
State: No such f[3-3.8907] [FB:INIT] cmd[tzdev:insmod]
ile or directory
/usr/bin/firstsc[3-3.8908] [FB:INIT] tzdev 0 start
reen.sh: line 20[1-3.8925] [FB:LOGO] logo mode(0)
: /sys/kernel/de[0-3.9058] [FB:INIT] [fw Start]
[0-3.9059] [FB:INIT] cmd[fw:insmod]
bug/tracing/trac[0-3.9059] [FB:INIT] fw 0 start
e_marker: No suc[3-3.9079] init: tzdev
[0-3.9324] init: mali
[0-3.9500] mali mod ld(0xbe8d2000)
h file or direct[0-3.9501] [FB:INIT] fw 0 end
[0-3.9501] [FB:INIT] fw 1 start
ory
Buffer main[2-3.9693] tzdev mod ld(0xbe8ad000)
[2-3.9694] [FB:INIT] tzdev 0 end
 is set
argc = [2-3.9694] [FB:INIT] cmd[tzdev:chmod]
10, optind = 9, [2-3.9695] [FB:INIT] [tzdev End time:79]
Kb 1024, rotate [2-3.9696] [FB:INIT] create path(/tmp/tzdev_insmod_done)
1
[security-manager-launcher(272)]  > inotify event is received for /run/security-manager.socket
[1-4.2547] [SBH] bw_get_boot_mode() : 0, BOOT_TYPE_ISP(1) BOOT_TYPE_RVU(2)
[0-4.2667] msg-wt61p807 msg-wt61p807: received unknown cmd ack
[1-4.3376] [SBH] create boot mode file(/tmp/normal_mode)
netlink recv: No[3-4.3423] init: ntkdriver
[0-4.3539] [FB] fastvideo start
[0-4.3541] [FB] fb_insmod_wait_lock: mode(12) start
[0-4.3622] [FB] fb_insmod_wait_lock: mode(12) end
[1-4.3757] [FB] Hotel mode : 0:0
[1-4.3757] [FB] Hotel mode disable
[1-4.3777] [FB] fb_insmod_wait_lock: mode(13) start
[1-4.3887] [FB] fb_insmod_wait_lock: mode(13) end
[0-4.3954] ================================================================================
[0-4.3954]  NTK Driver
[prdv_attr: /dev[0-4.3954]  Version : Kantsu2_Onemain_2020_KantSU2_Trunk2020_MP_v0.201016.0_r93d41424e63.
/sdp_mem][0-4.3954] ================================================================================
[0-4.3954] ntkdrvs: NOVATEK drivers loaded begin.
[0-4.4029] [FB] boot_mode,channel_lock:3,0
[0-4.4029] [FB] invalied bootmode(3)!!
[1-4.4030] [FB] video_show_done(skip/fail)
[0-4.4042] nvt_dt cannot find video_es_tbl!
[0-4.4044] ksb cann't find video_es_tbl node
[PKGMGR] /opt/db[2-4.4115] [FB] fb_status_fail: fastvideo SKIP. ( reason : [ 8 ] )
[1-.L42o352]  [dHeDcMoId-CeMD] :Tirsimb.Vuaiildt= 1t
 14:25:1 May  5 2
coderevision: bd10666ebb1, 0200320
_CU_Initialize .. OK
_Reload_daa(12288) ... [1-4OK.4T2C 3=5]c 40[0a81D
MstI-aCrMtD .]:.E.
ARCTrim.Valid=1
[2-4.4412] Novatek FRE Driver loaded
/home/owner/.dotnet/corefx/cryptography/x509stores/ is already c[0-4.5205] ESTART(main) 4.51968
reated
[0-4.5206] ESTART: 0.00079 [0.00079] - Begin Startup
[0-4.5222] ESTART: 0.00241 [0.00162] - Signal Trap
[0-4.5224] ESTART: 0.00252 [0.00012] - Signal Trap Done
[0-4.5224] ESTART: 0.00254 [0.00001] - Eina Init
[[0-4.5289] ESTART: 0.00908 [0.00654] - Eina Init Done
mkdir: c[0-4.5289] ESTART: 0.00912 [0.00004] - E_Object Hash Init
annot create dir[1-4.5301] cma: [fastinit(263)] cma_alloc(): returned ec507800 range 81040 - 81048
ectory `/opt/usr[3-4.5313] [perfm]1.4.18
/home/owner/shar[0-4.5344] ESTART: 0.01455 [0.00543] - E_Object Hash Init Done
e/dotnet/': File[0-4.5344] ESTART: 0.01459 [0.00004] - E_Log Init
 exists
Recreat[0-4.5345] ESTART: 0.01465 [0.00007] - E_Log Init Done
e Seed
[0-4.5345] ESTART: 0.01466 [0.00001] - Determine Prefix
[1-4.5433] ESTART: 0.02348 [0.00881] - Determine Prefix Done
[PKGMGR] /opt/db[1-4.5433] ESTART: 0.02352 [0.00004] - Parse Arguments
space/.widget.db[1-4.5433] ESTART: 0.02353 [0.00001] - Parse Arguments Done
 file size 28
[0-4.5434] ESTART: 0.02355 [0.00003] - Eet Init
[0-4.5435] ESTART: 0.02367 [0.00012] - Eet Init Done
[0-4.5435] ESTART: 0.02369 [0.00002] - Ecore Init
[1-4.5483] ESTART: 0.02847 [0.00478] - Ecore Init Done
[1-4.5483] ESTART: 0.02851 [0.00004] - EIO Init
[0-4.5485] ESTART: 0.02868 [0.00018] - EIO Init Done
[0-4.5485] ESTART: 0.02870 [0.00002] - Ecore Event Handlers
[0-4.5485] ESTART: 0.02872 [0.00001] - Ecore Event Handlers Done
[0-4.5485] ESTART: 0.02873 [0.00001] - Ecore_File Init
[0-4.5625] ESTART: 0.04264 [0.01391] - Ecore_File Init Done
[prdv_attr: /dev[0-4.5625] ESTART: 0.04268 [0.00005] - E_Util_File_Monitor Init
/video28]
[0-4.5625] ESTART: 0.04272 [0.00003] - E_Util_File_Monitor Init Done
[0-4.5626] ESTART: 0.04279 [0.00007] - XDG_DATA_DIRS Init
[0-4.5627] ESTART: 0.04284 [0.00005] - XDG_DATA_DIRS Init Done
[0-4.5627] ESTART: 0.04286 [0.00001] - Ecore_Evas Init
[PKGMGR] /opt/usr/home/owner/.applications/dbspace/.widget.db file size 28
[2-4.5857] [hdmi leon2] hdmi_leon2 find pool node ERROR !!!
[2-4.5858] [hdmi leon2] driver loaded > ERROR !!!
[1-4.5903] ntkdriver mod ld(0xbe91e000)
[1-4.5904] [FB:INIT] fw 1 end
[PKGMGR] /opt/db[1-4.5904] [FB:INIT] [fw End time:685]
space/.appsvc.db[1-4.5906] [FB:INIT] [kfactory Start]
 file size 40
[1-4.5906] [FB:INIT] cmd[kfactory:insmod]
[PKGMGR] integri[1-4.5907] [FB:INIT] kfactory 0 start
ty : ok
[1-4.5907] [FB:INIT] [pq Start]
[1-4.5907] [FB:INIT] cmd[pq:insmod]
[1-4.5908] [FB:INIT] pq 0 start
[1-4.5985] init: ntkndp_pq
[1-4.6022] init: kfactory_drv
[1-4.6031] kfactory_drv mod ld(0xbf194000)
[1-4.6032] [FB:INIT] kfactory 0 end
[1-4.6032] [FB:INIT] cmd[kfactory:execute]
[0-4.6098] [FB:INIT] cmd[kfactory:insmod]
[0-4.6098] [FB:INIT] kfactory 0 start
[0-4.6099] [FB:INIT] kfactory 0 end
[0-4.6099] [FB:INIT] kfactory 1 start
[1-4.6196] init: system_drv_api
[1-4.6198] system_drv_api mod ld(0xbe81f000)
[1-4.6199] [FB:INIT] kfactory 1 end
[1-4.6199] [FB:INIT] kfactory 2 start
[1-4.6317] init: system_drv
[1-4.6398] system_drv mod ld(0xbf19d000)
[1-4.6400] [FB:INIT] kfactory 2 end
[1-4.6400] [FB:INIT] kfactory 3 start
[1-4.6400] [FB:INIT] kfactory 3 end
[1-4.6400] [FB:INIT] [kfactory End time:49]
[1-4.6403] [FB:INIT] [logo Start]
[1-4.6404] [FB:INIT] cmd[logo:insmod]
[1-4.6404] [FB:INIT] logo 0 start
[2-4.6405] [FB:INIT] [extin Start]
[2-4.6405] [FB:INIT] cmd[extin:insmod]
[2-4.6405] [FB:INIT] extin 0 start
[1-4.6454] init: ntkndplogo
[1-4.6515] init: ntkndpextin
[2-4.6971] ntkndplogo mod ld(0xbf1a5000)
[2-4.6973] [FB:INIT] logo 0 end
[2-4.6973] [FB:INIT] [logo End time:57]
[1-4.6975] [FB:INIT] [tuner Start]
[1-4.6976] [FB:INIT] [frc Start]
[1-4.6976] [FB:INIT] cmd[tuner:insmod]
[2-4.6977] [FB:INIT] tuner 0 start
[2-4.6978] [FB:INIT] cmd[frc:insmod]
[1-4.6978] [FB:INIT] [hdmi1 Start]
[2-4.6979] [FB:INIT] frc 0 start
[2-4.6980] [FB:INIT] cmd[hdmi1:insmod]
[2-4.6980] [FB:INIT] hdmi1 0 start
[1-4.6980] [FB:INIT] [audio Start]
[1-4.6981] [FB:INIT] fi_util_mq_send_cmd: cmd(108)
[1-4.6981] [FB:INIT] [alsa Start]
[1-4.6982] [FB:INIT] cmd[alsa:insmod]
[1-4.6982] [FB:INIT] alsa 0 start
[2-4.6982] [FB:INIT] cmd[audio:insmod]
[2-4.6982] [FB:INIT] audio 0 start
[2-4.7004] [MC:S][4.7004][fastlogo]Inv-1
[2-4.7044] ntkndp_pq mod ld(0xbf179000)
[2-4.7045] [FB:INIT] pq 0 end
[2-4.7046] [FB:INIT] pq 1 start
[0-4.7072] init: ntkndphdmi
[1-4.7081] [FB:LOGO] panel unmute
[2-4.7083] [MC:A][4.7060]I
Он кстати уже вылетал на других TU сериях, но не так хитро.
12 минут назад, san-vai сказал:
Он не греется ?
нет, не греется
Но насчет напряжений?
Возможно они такие и должны быть
Да по логу пофиг ему на панель, проверяй обвязку шим, чуйка что ноги из нее все растут.
Ведет себя как будто все в норме
Утечек нет
Какие эти напряжения в таком аппарате, кто мерял?
Все остальные сигналы тэкон в норме, проверил также осциллографом
18 минут назад, san-vai сказал:
Проц следит за этими напряжениями?
зачем ему это надо
Тем более что картинка в норме
И аппарат был включенным целый день
1 час назад, san-vai сказал:
Надо к eMMC подключаться .Или снимать ее и заливать user чужой.
Это у меня нет возможности
Система при запуске регистрирует большой ток шима.По записям 17 должно быть.
