Телевизор PHILIPS 32PHT5301/60 не включается
шасси: TPM16.1E LA
main: 715G8198-M01-B00-004T
PSU: 715G7734-P01-003-002H
panel: TPT315B5-WHBN0.K
Сервис-мануал
Пришел с диагнозом "не включается". Индикатор не светится, на кнопки и пульт не реагирует. Проверил питания - все в норме, согласно даташиту. Сигнал PS_ON - 3.3v.  Обратил особое внимание на питание ОЗУ. Никаких аномалий не обнаружил. 1.5V стабильно, без пульсаций и скачков. Смущает лог.
[17:36:12.805]
[17:36:12.814] Boot-
[17:36:12.816] DRAM Channel A Calibration.
[17:36:12.897] 1T = (72 - 15) = 57 delay cells
[17:36:12.897] Clock frequency = 900 MHz, Clock period = 1111 ps, 1 delay cell =19 ps
[17:36:12.928] Byte 0 : Gating(-27 ~ 27), Size=55 .
[17:36:12.928] Byte 1 : Gating(-27 ~ 27), Size=55 .
[17:36:12.928] Byte 2 : Gating(-26 ~ 27), Size=54 .
[17:36:12.928] Byte 3 : Gating(-26 ~ 27), Size=54 .
[17:36:13.077] error on bit 0 ,setup_time =hold_time =0!!
[17:36:13.077]  error on bit 1 ,setup_time =hold_time =0!!
[17:36:13.077]  error on bit 2 ,setup_time =hold_time =0!!
[17:36:13.077]  error on bit 3 ,setup_time =hold_time =0!!
[17:36:13.077]  error on bit 4 ,setup_time =hold_time =0!!
[17:36:13.077]  error on bit 5 ,setup_time =hold_time =0!!
[17:36:13.077]  error on bit 6 ,setup_time =hold_time =0!!
[17:36:13.077]  error on bit 7 ,setup_time =hold_time =0!!
[17:36:13.077]  error on bit 8 ,setup_time =hold_time =0!!
[17:36:13.077]  error on bit 9 ,setup_time =hold_time =0!!
[17:36:13.077]  error on bit 10 ,setup_time =hold_time =0!!
[17:36:13.077]  error on bit 11 ,setup_time =hold_time =0!!
[17:36:13.077]  error on bit 12 ,setup_time =hold_time =0!!
[17:36:13.077]  error on bit 13 ,setup_time =hold_time =0!!
[17:36:13.077]  error on bit 14 ,setup_time =hold_time =0!!
[17:36:13.077]  error on bit 15 ,setup_time =hold_time =0!!
[17:36:13.077]  error on bit 16 ,setup_time =hold_time =0!!
[17:36:13.077]  error on bit 17 ,setup_time =hold_time =0!!
[17:36:13.077]  error on bit 18 ,setup_time =hold_time =0!!
[17:36:13.077]  error on bit 19 ,setup_time =hold_time =0!!
[17:36:13.077]  error on bit 20 ,setup_time =hold_time =0!!
[17:36:13.077]  error on bit 21 ,setup_time =hold_time =0!!
[17:36:13.077]  error on bit 22 ,setup_time =hold_time =0!!
[17:36:13.077]  error on bit 23 ,setup_time =hold_time =0!!
[17:36:13.077]  error on bit 24 ,setup_time =hold_time =0!!
[17:36:13.077]  error on bit 25 ,setup_time =hold_time =0!!
[17:36:13.077]  error on bit 26 ,setup_time =hold_time =0!!
[17:36:13.077]  error on bit 27 ,setup_time =hold_time =0!!
[17:36:13.077]  error on bit 28 ,setup_time =hold_time =0!!
[17:36:13.077]  error on bit 29 ,setup_time =hold_time =0!!
[17:36:13.077]  error on bit 30 ,setup_time =hold_time =0!!
[17:36:13.077]  error on bit 31 ,setup_time =hold_time =0!!
[17:36:13.077]  HW Byte 0 : DQS(0 ~ 0), Size 0 , Set 0.
[17:36:13.077] HW Byte 1 : DQS(0 ~ 0), Size 0 , Set 0.
[17:36:13.077] HW Byte 2 : DQS(0 ~ 0), Size 0 , Set 0.
[17:36:13.077] HW Byte 3 : DQS(0 ~ 0), Size 0 , Set 0.
[17:36:13.077] RX DQ/DQS calibration fail!
[17:36:13.077] DATLAT calibration
[17:36:13.148] no DATLAT taps pass
[17:36:13.232] default tx dq PI delay value(16) is fail on bit 0!!
[17:36:13.232] default tx dq PI delay value(16) is fail on bit 1!!
[17:36:13.232] default tx dq PI delay value(16) is fail on bit 2!!
[17:36:13.232] default tx dq PI delay value(16) is fail on bit 3!!
[17:36:13.232] default tx dq PI delay value(16) is fail on bit 4!!
[17:36:13.232] default tx dq PI delay value(16) is fail on bit 5!!
[17:36:13.232] default tx dq PI delay value(16) is fail on bit 6!!
[17:36:13.232] default tx dq PI delay value(16) is fail on bit 7!!
[17:36:13.232] default tx dq PI delay value(16) is fail on bit 8!!
[17:36:13.232] default tx dq PI delay value(16) is fail on bit 9!!
[17:36:13.232] default tx dq PI delay value(16) is fail on bit 10!!
[17:36:13.232] default tx dq PI delay value(16) is fail on bit 11!!
[17:36:13.232] default tx dq PI delay value(16) is fail on bit 12!!
[17:36:13.232] default tx dq PI delay value(16) is fail on bit 13!!
[17:36:13.232] default tx dq PI delay value(16) is fail on bit 14!!
[17:36:13.232] default tx dq PI delay value(16) is fail on bit 15!!
[17:36:13.232] default tx dq PI delay value(16) is fail on bit 16!!
[17:36:13.232] default tx dq PI delay value(16) is fail on bit 17!!
[17:36:13.232] default tx dq PI delay value(16) is fail on bit 18!!
[17:36:13.232] default tx dq PI delay value(16) is fail on bit 19!!
[17:36:13.232] default tx dq PI delay value(16) is fail on bit 20!!
[17:36:13.232] default tx dq PI delay value(16) is fail on bit 21!!
[17:36:13.232] default tx dq PI delay value(16) is fail on bit 22!!
[17:36:13.232] default tx dq PI delay value(16) is fail on bit 23!!
[17:36:13.232] default tx dq PI delay value(16) is fail on bit 24!!
[17:36:13.232] default tx dq PI delay value(16) is fail on bit 25!!
[17:36:13.232] default tx dq PI delay value(16) is fail on bit 26!!
[17:36:13.232] default tx dq PI delay value(16) is fail on bit 27!!
[17:36:13.232] default tx dq PI delay value(16) is fail on bit 28!!
[17:36:13.232] default tx dq PI delay value(16) is fail on bit 29!!
[17:36:13.232] default tx dq PI delay value(16) is fail on bit 30!!
[17:36:13.232] default tx dq PI delay value(16) is fail on bit 31!!
[17:36:13.341] error: cannot find right boundary of DQM
[17:36:13.345] error: cannot find left boundary of DQM
[17:36:13.345] TX HW Byte 0 : DQS(-16 ~ -16), Size 1, Set 48.
[17:36:13.345] TX HW Byte 1 : DQS(-16 ~ -16), Size 1, Set 48.
[17:36:13.345] TX HW Byte 2 : DQS(-16 ~ -16), Size 1, Set 48.
[17:36:13.345] TX HW Byte 3 : DQS(-16 ~ -16), Size 1, Set 48.
[17:36:13.345] TX DQ/DQS calibration fail!
[17:36:13.345] Manual calibration of Rx Byte2 window size[1800].
Я так понимаю, неисправна оператива? Или я не прав?
Второй вопрос, если она неисправна, что могло послужить причиной выхода ее из строя?
Скажу сразу, резисторы 22 ома на шинах проверил, с ними все в порядке.
Оператива стоит - 2 шт. K4B4G1646E BCMA.
@manjak Посмотри похожая неисправность по 1.5V ТЫЦ.
8 минут назад, Aleh сказал:
Да эту я видел. Поэтому питание оперативы проверил в первую очередь. Никаких нареканий к нему как-раз и нет.Это-то и смущает в первую очередь. Судя по логу, оператива молчит совсем. Но с чего она умерла - непонятно. Перекатать то другую можно. Вопрос - не улетит ли и вторая? Вот и пишу, может кто сталкивался.
8 минут назад, GYV сказал:
Посмотри что пишут
Тут вообще не мой случай...
@manjak На сайте PHILIPS есть обновление ПО (прошивка) для модели 32PHT5301/60. Версия 012.002.050.001 (файл 320.4 MB) от 28 мая 2018 г.
замени стаб и перекатай другую (как вариант
 (537,2 MB)
@Aleh :privet: , но это не ко-мне:
Тема пока на паузе, заказал оперативку из Китая. Ждем прибытия...
Так, ладно. Пришли микросхемы из Китая и .... ставить не стал. :)
Мне тут сын говорит, " - а ты проц грел?".
Я говорю " - нет".
Он мне "- ну так погрей"
Ну я и погрел, (ну как погрел - на шарах шатанул), а он взял и запустился.
После подключения к WIFI даже ПО обновил, причем принудительно, без вопросов " а не хотите ли обновиться?"
И вот думаю, что пора мне в отпуск....
Короче, тема решена. Аппарат работает.
P.S. Ну и есть у меня теперь пара оперативки на филипс, пригодится. :)
  • Ха- ха- Ха! 1
