About This File
Contains complete DUMP memory, including tuner memory. Source: Brand new motherboard. Software is often crashed. There is not much hardware failure. Under certain conditions, it may be necessary to upgrade the firmware. It is recommended, for example, in the event of signal failures on the satellite tuner (only some transponders). You will find this software in a separate submission. However, software upgrades require a functional board and the ability to boot from USB. An upgrade is not always necessary! Disassembly of the TV is not necessary for its implementation.
Kubík  0
Отвечено: 2 часа назад · IP
PI probably made the submission under the LG brand, it's supposed to be Vestel. LG will come later. Will I submit the USB upgrade file for this particular model in the same way? ATTENTION! is not freely available on the manufacturer's website. Allows installation even in completely crashed TVs (common phenomenon)
Цитата
 @ автор сообщения
LiVan  1 842
ждите я занят....
Цитата
 @ автор сообщения
LiVan  1 842
Отвечено: 1 час назад · IP
ваша прошивка не прошла проверку! Дамп NAND Flash считан неправильно и имеет данные FF 00 (99% )
Вашу загрузку ещё проверит один наш модератор, но я уверен что  MT29F4G08ABAEA@TSOP48_2952 считана не правильно!
Ждите...
Ваша загрузка  будет ещё раз проверена.
Цитата
 @ автор сообщения
LiVan  1 842
Вообщем так..
Ваша прошивка это 100% мусор!
И она удаляется из нашего архива!
Цитата
 @ автор сообщения
Kubík  0
Отвечено: 12 минут назад · IP
And why is this nonsense?
You are wrong!
If you don't explain it to me, there's no point in working together anymore. It is a fully functional and precisely processed data set from the three memories of a given TV. I don't know how to prove it to you. On what basis do you verify the functionality of what you receive and subsequently provide?
I have another submission from LG 50LF652V ready here. The file is so large that it cannot be inserted into your form and the link to the Cloud cannot be inserted either. I'm sorry.
Either you start cooperating and alert me to an error (which I don't see) and explain to me politely how to submit large files in your system, or I'm not interested in providing you with anything. It's a shame!! You and I could benefit. However, if you write to me that I have given 100% nonsense, then it will probably not be possible!
Цитата
 @ автор сообщения
LiVan  1 842
хорошо, мы этот вопрос перенес на форум итам решим ждите...
Kubík
And what will be expected?
I am also willing to provide a USB update for the given TV, including instructions that are not freely downloadable. It is used to put the TV into operation, which is completely dead without disassembling the TV. However, this cannot be submitted because the file is larger than your 117Mb limit. What I served today is NAND with a size of 552 960Kb. After the compressor zipper, the file is very small and it could be sent. I don't know how bigger. You already have my 2 regular submissions with fully functional software. I'll send the third one when you start talking to me.
Bye for now.
Есть тема для размышления, к нам в архив загружен  архив размером Размер файла1 МБ
И участник @Cubik  утверждает что рабочий комплект NAND Flash
А я считаю что это мусор...
Кто прав ?
Прошу скачать архив и высказаться, ваше мнение о данной загрузке.
На фото слева РАБОЧИЙ дамп, а справа ваш НЕ РАБОЧИЙ
В вашем дампе 9 строк информации вначале, а остальное пустота FF !
Язык форума РУССКИЙ !
@Kubík Вот вся информация в этом дампе, дальше одни FF, открой его сам и посмотри.
I have never added a link to anyone using text in a notebook. It's strangely complicated. After all, there could be a separate line for this as a file. Please download the file from my link in the previous message and replace it with the one in the original submission.
Thank you!
Thank you!
My friend
Your dump file is corrupt and that's what all the moderators say on our forum
So attach the correct and tested files so that we can provide the correct file exchange according to the forum rules.
The forum language is Russian so please adhere to the forum rules
