Помогите разобраться с логами 55PUS8109/12
31.10.2019 в 14:05, Mteor сказал:
Значит проц просто не может вычитать прошивку с emmc?
:ay:
magic num is not correct (0x482a4d49 != 0xeea8f2bc)
в разделе tbdzz ---- Ошибка Img_Ld_And_Start!
нужно было изначально прошить юзер
06.12.2019 в 14:19, AleksandrBurkov сказал:
:ay:
Юзер был прошит. На что получил ошибку
Скрытый текст
Start kernel at 0x40008000
Uncompressing Linux... done, booting the kernel.
[    0.170478] CPU1: Unknown IPI message 0x1
[    0.210429] CPU2: Unknown IPI message 0x1
[    0.250419] CPU3: Unknown IPI message 0x1
[    0.279569] gpio-regulator gpio-regulator.6: No 'states' property found
[    0.351910] marvell_tpv tpv.7: can't get vpuc regulator.
[    0.360793] berlin-ehci f7ed0000.usb: no pwr-gpio set
[    0.413626] berlin-ehci f7ee0000.usb: no pwr-gpio set
[    0.463534] berlin-ehci f7a30000.usb: no pwr-gpio set
[    0.538665] init: /init.googletv.rc: 44: ignored duplicate definition of service 'resourcemanager'
[    0.548321] init: /init.berlin.rc: 255: ignored duplicate definition of service 'ampaudioloopback'
[    2.463476] sd 0:0:0:0: [sda] No Caching mode page found
[    2.468964] sd 0:0:0:0: [sda] Assuming drive cache: write through
[    2.477850] sd 0:0:0:0: [sda] No Caching mode page found
[    2.483347] sd 0:0:0:0: [sda] Assuming drive cache: write through
[    2.492227] sd 0:0:0:0: [sda] No Caching mode page found
[    2.497744] sd 0:0:0:0: [sda] Assuming drive cache: write through
[    5.050470] fs_mgr: Cannot mount filesystem on /dev/block/mmcblk0p11 at /firmware
[    5.058218] init: fs_mgr_mount_all returned an error
[    5.064213] init: cannot find '/system/bin/logcatip', disabling 'logcatip'
[    5.071333] init: cannot find '/vendor/bin/ampservice', disabling 'galois_amp'
[    5.079515] fs_mgr: Running /system/bin/e2fsck on /dev/block/mmcblk0p12 since it's mounted to ro
[    5.088900] fs_mgr: Cannot run fs_mgr binary /system/bin/e2fsck
[    5.095264] tpvfsck: Checking partition /dev/block/mmcblk0p9
[    5.101111] tpvfsck: -p /dev/block/mmcblk0p9
[    5.105838] tpvfsck: Cannot run fs_mgr binary /system/bin/e2fsck
[    5.112047] tpvfsck: Check /dev/block/mmcblk0p9 ok, status 0
[    5.117934] tpvfsck: Partition /dev/block/mmcblk0p9 fs check done
[    5.124497] fs_mgr: Running /system/bin/e2fsck on /dev/block/mmcblk0p9 since it's mounted to ro
[    5.133793] fs_mgr: Cannot run fs_mgr binary /system/bin/e2fsck
[    5.140127] fs_mgr: Cannot mount filesystem on /dev/block/mmcblk0p9 at /user_setting
[    5.148156] init: fs_mgr_mount_all returned an error
[    5.153432] tpvfsck: /dev/block/mmcblk0p9 check failed with error 255
[    5.160086] tpvfsck: -pfD /dev/block/mmcblk0p9
[    5.164968] tpvfsck: Cannot run fs_mgr binary /system/bin/e2fsck
[    5.171177] tpvfsck: Check /dev/block/mmcblk0p9 ok, status 0
[    5.177147] tpvfsck: Partition /dev/block/mmcblk0p9 fs check done
[    5.183703] fs_mgr: Running /system/bin/e2fsck on /dev/block/mmcblk0p9 since it's mounted to ro
[    5.192993] fs_mgr: Cannot run fs_mgr binary /system/bin/e2fsck
[    5.199317] fs_mgr: Cannot mount filesystem on /dev/block/mmcblk0p9 at /user_setting
[    5.207346] init: fs_mgr_mount_all returned an error
[    5.212596] tpvfsck: /dev/block/mmcblk0p9 check failed with error 255
[    5.219628] tpvfsck: mke2fs did not exit properly
[    5.224504] tpvfsck: Partition /dev/block/mmcblk0p9 superblock not found
[    5.231425] tpvfsck: Partition /dev/block/mmcblk0p9 fs check done
[    5.237937] fs_mgr: Running /system/bin/e2fsck on /dev/block/mmcblk0p9 since it's mounted to ro
[    5.247214] fs_mgr: Cannot run fs_mgr binary /system/bin/e2fsck
[    5.253551] fs_mgr: Cannot mount filesystem on /dev/block/mmcblk0p9 at /user_setting
[    5.261565] init: fs_mgr_mount_all returned an error
[    5.266894] fs_mgr: Cannot mount filesystem on /dev/block/mmcblk0p12 at /factory_data
[    5.275115] init: fs_mgr_mount_all returned an error
[    5.280969] tpvfsck: Checking partition /dev/block/mmcblk0p13
[    5.286922] tpvfsck: -p /dev/block/mmcblk0p13
[    5.291702] tpvfsck: Cannot run fs_mgr binary /system/bin/e2fsck
[    5.297933] tpvfsck: Check /dev/block/mmcblk0p13 ok, status 0
[    5.303876] tpvfsck: Partition /dev/block/mmcblk0p13 fs check done
[    5.310506] fs_mgr: Running /system/bin/e2fsck on /dev/block/mmcblk0p13 since it's mounted to ro
[    5.319875] fs_mgr: Cannot run fs_mgr binary /system/bin/e2fsck
[    5.326247] tpvfsck: Checking partition /dev/block/mmcblk0p10
[    5.332183] tpvfsck: -p /dev/block/mmcblk0p10
[    5.336982] tpvfsck: Cannot run fs_mgr binary /system/bin/e2fsck
[    5.343206] tpvfsck: Check /dev/block/mmcblk0p10 ok, status 0
[    5.349141] tpvfsck: Partition /dev/block/mmcblk0p10 fs check done
[    5.355778] fs_mgr: Running /system/bin/e2fsck on /dev/block/mmcblk0p10 since it's mounted to ro
[    5.365155] fs_mgr: Cannot run fs_mgr binary /system/bin/e2fsck
[    5.371486] fs_mgr: Cannot mount filesystem on /dev/block/mmcblk0p10 at /cache
[    5.378979] init: fs_mgr_mount_all returned an error
[    5.384258] tpvfsck: /dev/block/mmcblk0p10 check failed with error 255
[    5.391003] tpvfsck: -pfD /dev/block/mmcblk0p10
[    5.395978] tpvfsck: Cannot run fs_mgr binary /system/bin/e2fsck
[    5.402186] tpvfsck: Check /dev/block/mmcblk0p10 ok, status 0
[    5.408135] tpvfsck: Partition /dev/block/mmcblk0p10 fs check done
[    5.414763] fs_mgr: Running /system/bin/e2fsck on /dev/block/mmcblk0p10 since it's mounted to ro
[    5.424135] fs_mgr: Cannot run fs_mgr binary /system/bin/e2fsck
[    5.430456] fs_mgr: Cannot mount filesystem on /dev/block/mmcblk0p10 at /cache
[    5.437947] init: fs_mgr_mount_all returned an error
[    5.443207] tpvfsck: /dev/block/mmcblk0p10 check failed with error 255
[    5.450320] tpvfsck: mke2fs did not exit properly
[    5.455201] tpvfsck: Partition /dev/block/mmcblk0p10 superblock not found
[    5.462211] tpvfsck: Partition /dev/block/mmcblk0p10 fs check done
[    5.468801] fs_mgr: Running /system/bin/e2fsck on /dev/block/mmcblk0p10 since it's mounted to ro
[    5.478168] fs_mgr: Cannot run fs_mgr binary /system/bin/e2fsck
[    5.484498] fs_mgr: Cannot mount filesystem on /dev/block/mmcblk0p10 at /cache
[    5.491974] init: fs_mgr_mount_all returned an error
[    5.497304] fs_mgr: Cannot mount filesystem on /dev/block/mmcblk0p13 at /data
[    5.504704] init: fs_mgr_mount_all returned an error
[    5.509967] tpvfsck: /dev/block/mmcblk0p13 check failed with error 255
[    5.516724] tpvfsck: -pfD /dev/block/mmcblk0p13
[    5.521683] tpvfsck: Cannot run fs_mgr binary /system/bin/e2fsck
[    5.527909] tpvfsck: Check /dev/block/mmcblk0p13 ok, status 0
[    5.533854] tpvfsck: Partition /dev/block/mmcblk0p13 fs check done
[    5.540483] fs_mgr: Running /system/bin/e2fsck on /dev/block/mmcblk0p13 since it's mounted to ro
[    5.549855] fs_mgr: Cannot run fs_mgr binary /system/bin/e2fsck
[    5.556197] tpvfsck: Checking partition /dev/block/mmcblk0p10
[    5.562134] tpvfsck: -p /dev/block/mmcblk0p10
[    5.566937] tpvfsck: Cannot run fs_mgr binary /system/bin/e2fsck
[    5.573159] tpvfsck: Check /dev/block/mmcblk0p10 ok, status 0
[    5.579094] tpvfsck: Partition /dev/block/mmcblk0p10 fs check done
[    5.585729] fs_mgr: Running /system/bin/e2fsck on /dev/block/mmcblk0p10 since it's mounted to ro
[    5.595096] fs_mgr: Cannot run fs_mgr binary /system/bin/e2fsck
[    5.601428] fs_mgr: Cannot mount filesystem on /dev/block/mmcblk0p10 at /cache
[    5.608920] init: fs_mgr_mount_all returned an error
[    5.614192] tpvfsck: /dev/block/mmcblk0p10 check failed with error 255
[    5.620936] tpvfsck: -pfD /dev/block/mmcblk0p10
[    5.625906] tpvfsck: Cannot run fs_mgr binary /system/bin/e2fsck
[    5.632115] tpvfsck: Check /dev/block/mmcblk0p10 ok, status 0
[    5.638064] tpvfsck: Partition /dev/block/mmcblk0p10 fs check done
[    5.644697] fs_mgr: Running /system/bin/e2fsck on /dev/block/mmcblk0p10 since it's mounted to ro
[    5.654067] fs_mgr: Cannot run fs_mgr binary /system/bin/e2fsck
[    5.660384] fs_mgr: Cannot mount filesystem on /dev/block/mmcblk0p10 at /cache
[    5.667876] init: fs_mgr_mount_all returned an error
[    5.673135] tpvfsck: /dev/block/mmcblk0p10 check failed with error 255
[    5.680246] tpvfsck: mke2fs did not exit properly
[    5.685126] tpvfsck: Partition /dev/block/mmcblk0p10 superblock not found
[    5.692136] tpvfsck: Partition /dev/block/mmcblk0p10 fs check done
[    5.698726] fs_mgr: Running /system/bin/e2fsck on /dev/block/mmcblk0p10 since it's mounted to ro
[    5.708088] fs_mgr: Cannot run fs_mgr binary /system/bin/e2fsck
[    5.714418] fs_mgr: Cannot mount filesystem on /dev/block/mmcblk0p10 at /cache
[    5.721893] init: fs_mgr_mount_all returned an error
[    5.727229] fs_mgr: Cannot mount filesystem on /dev/block/mmcblk0p13 at /data
[    5.734628] init: fs_mgr_mount_all returned an error
[    5.739880] tpvfsck: /dev/block/mmcblk0p13 check failed with error 255
[    5.747004] tpvfsck: mke2fs did not exit properly
[    5.751866] tpvfsck: Partition /dev/block/mmcblk0p13 superblock not found
[    5.758891] tpvfsck: Partition /dev/block/mmcblk0p13 fs check done
[    5.765490] fs_mgr: Running /system/bin/e2fsck on /dev/block/mmcblk0p13 since it's mounted to ro
[    5.774952] fs_mgr: Cannot run fs_mgr binary /system/bin/e2fsck
[    5.781273] tpvfsck: Checking partition /dev/block/mmcblk0p10
[    5.787223] tpvfsck: -p /dev/block/mmcblk0p10
[    5.792004] tpvfsck: Cannot run fs_mgr binary /system/bin/e2fsck
[    5.798235] tpvfsck: Check /dev/block/mmcblk0p10 ok, status 0
[    5.804179] tpvfsck: Partition /dev/block/mmcblk0p10 fs check done
[    5.810805] fs_mgr: Running /system/bin/e2fsck on /dev/block/mmcblk0p10 since it's mounted to ro
[    5.820173] fs_mgr: Cannot run fs_mgr binary /system/bin/e2fsck
[    5.826507] fs_mgr: Cannot mount filesystem on /dev/block/mmcblk0p10 at /cache
[    5.834002] init: fs_mgr_mount_all returned an error
[    5.839258] tpvfsck: /dev/block/mmcblk0p10 check failed with error 255
[    5.846016] tpvfsck: -pfD /dev/block/mmcblk0p10
[    5.850970] tpvfsck: Cannot run fs_mgr binary /system/bin/e2fsck
[    5.857194] tpvfsck: Check /dev/block/mmcblk0p10 ok, status 0
[    5.863140] tpvfsck: Partition /dev/block/mmcblk0p10 fs check done
[    5.869764] fs_mgr: Running /system/bin/e2fsck on /dev/block/mmcblk0p10 since it's mounted to ro
[    5.879134] fs_mgr: Cannot run fs_mgr binary /system/bin/e2fsck
[    5.885467] fs_mgr: Cannot mount filesystem on /dev/block/mmcblk0p10 at /cache
[    5.892959] init: fs_mgr_mount_all returned an error
[    5.898207] tpvfsck: /dev/block/mmcblk0p10 check failed with error 255
[    5.905330] tpvfsck: mke2fs did not exit properly
[    5.910193] tpvfsck: Partition /dev/block/mmcblk0p10 superblock not found
[    5.917218] tpvfsck: Partition /dev/block/mmcblk0p10 fs check done
[    5.923812] fs_mgr: Running /system/bin/e2fsck on /dev/block/mmcblk0p10 since it's mounted to ro
[    5.933171] fs_mgr: Cannot run fs_mgr binary /system/bin/e2fsck
[    5.939482] fs_mgr: Cannot mount filesystem on /dev/block/mmcblk0p10 at /cache
[    5.946979] init: fs_mgr_mount_all returned an error
[    5.952283] fs_mgr: Cannot mount filesystem on /dev/block/mmcblk0p13 at /data
[    5.959680] init: fs_mgr_mount_all returned an error
[    5.967226] init: cannot find '/system/bin/demome_perm.sh', disabling 'demomeservice'
[    5.975401] init: cannot find '/system/vendor/bin/fsservice_dbinit', disabling 'fs_dbinit'
[    5.984726] init: cannot find '/system/bin/ethconfig', disabling 'fix_mac'
[    5.991975] init: Unable to open persistent property directory /data/property errno: 2
[    6.000351] init: cannot find '/system/bin/gfxRotateApp', disabling 'gfxRotate'
[    6.007935] init: cannot find '/system/bin/droidtvtool', disabling 'droidtv_boot'
[    6.018242] init: cannot find '/system/bin/StartupApp', disabling 'StartupApp'
[    6.025730] init: cannot find '/system/bin/displayStartupApp', disabling 'displayStart'
[    6.034078] init: cannot find '/system/bin/servicemanager', disabling 'servicemanager'
[    6.042264] init: cannot find '/system/bin/droidtvtool', disabling 'droidtv_zipper'
[    6.050188] init: cannot find '/system/vendor/bin/test_disp_lvds', disabling 'panel_power_on'
[    6.059065] init: cannot find '/system/bin/nrddpiservice', disabling 'nrddpiservice'
[    6.067077] init: cannot find '/system/bin/boot_token_updater.sh', disabling 'boottokenupdater'
[    6.076076] init: cannot find '/system/bin/av_settings', disabling 'av_settings'
[    6.083729] init: cannot find '/system/bin/mrvl_boot_token', disabling 'mrvlboottoken'
[    6.091918] init: cannot find '/system/bin/memusage', disabling 'memusage'
[    6.099034] init: cannot find '/system/vendor/bin/monitord', disabling 'monitord'
[    6.106777] init: cannot find '/system/bin/netd', disabling 'netd'
[    6.113172] init: cannot find '/system/bin/debuggerd', disabling 'debuggerd'
[    6.120458] init: cannot find '/system/bin/rild', disabling 'ril-daemon'
[    6.127390] init: cannot find '/system/bin/drmserver', disabling 'drm'
[    6.134146] init: cannot find '/system/bin/installd', disabling 'installd'
[    6.141252] init: cannot find '/system/etc/install-recovery.sh', disabling 'flash_recovery'
[    6.149889] init: cannot find '/system/bin/keystore', disabling 'keystore'
[    6.157005] init: cannot find '/system/bin/tpvueventd', disabling 'tpvueventd'
[    6.164478] init: cannot find '/system/bin/resourcemanager', disabling 'resourcemanager'
[    6.172839] init: cannot find '/system/bin/suspend_utils', disabling 'suspend_utils'
[    6.180854] init: cannot find '/system/vendor/bin/cpusvc', disabling 'cpusvc'
[    6.188236] init: cannot find '/system/bin/bt_detect.sh', disabling 'bt_init'
[    6.195620] init: cannot find '/system/vendor/bin/voicecapture', disabling 'voicecapture'
[    6.204079] init: cannot find '/system/bin/MarvellWirelessDaemon', disabling 'mwirelessd'
[    6.212530] init: cannot find '/system/bin/dbus-daemon', disabling 'dbus'
[    6.219556] init: cannot find '/system/vendor/bin/ampaudioloopbackservice', disabling 'ampaudioloopback'
[    6.229359] init: cannot find '/system/bin/wfdavmgr', disabling 'wfdavmgr'
[    6.236474] init: cannot find '/system/bin/install_recovery', disabling 'install_recovery'
[   87499]F(SM): SM:Watchdog 1 time out (CPU0/1 dies)
Не был уверен в том что мой программатор прошил правильно еммс нашел в городе человека с ufi pro box сняли еммс перезаписали взяв конфиг,  бут 1 , бут 2 с родной еммс и другим юзером (хотя сровняли юзер родной и тот что мне удалось получить они были одинаковы)
и получил полный кирпич.
Скрытый текст
ёї€SAHХ
Code:0x656d6d31
log round 0x0000000a
@0xf8090444  0x9766dfb1 .f..  0x544f5554 TOUT  0xae786763 .xgc  0x43564f4c CVOL
@0xf8090454  0xae73970c .s..  0x49535243 ISRC  0x9a3749c9 .7I.  0x44494e54 DINT
@0xf8090464  0x54494e49 TINI  0x23498acd #I..  0x30444d43 0DMC  0xadb19283 ....
@0xf8090474  0x4b433437 KC47  0xa8646906 .di.  0x44414552 DAER  0x54494e49 TINI
@0xf8090484  0xa2384761 .8Ga  0x30444d43 0DMC  0x21398707 !9..  0x504f5453 POTS
@0xf8090494  0x29387469 )8ti  0xe8469087 .F..  0x494d444c IMDL  0x46565246 FVRF
@0xf80904a4  0xa3498676 .I.v  0x32545250 2TRP  0xbc9867ac ..g.  0x0030354d .05M
@0xf80904b4  0x1239084b .9.K  0x49525148 IRQH  0xff800500 ....  0x49474943 IGIC
@0xf80904c4  0x78365649 x6VI  0x67640208 gd..  0x42434c4b BCLK  0xcf127836 ..x6
@0xf80904d4  0x42524154 BRAT  0x9766dfb1 .f..  0x544f5554 TOUT  0xae786763 .xgc
@0xf80904e4  0x43564f4c CVOL  0xae73970c .s..  0x49535243 ISRC  0x9a3749c9 .7I.
@0xf80904f4  0x44494e54 DINT  0x54494e49 TINI  0x23498acd #I..  0x30444d43 0DMC
@0xf8090404  0xadb19283 ....  0x4b433437 KC47  0xa8646906 .di.  0x44414552 DAER
@0xf8090414  0x54494e49 TINI  0xa2384761 .8Ga  0x30444d43 0DMC  0x21398707 !9..
@0xf8090424  0x504f5453 POTS  0x29387469 )8ti  0xe8469087 .F..  0x494d444c IMDL
@0xf8090434  0x46565246 FVRF  0xa3498676 .I.v  0x31545250 1TRP  0x656d6d30 emm0
Подозрение пало на проблему с процом так как 3 новых еммс вели себя одинаково.
19 минут назад, Mteor сказал:
а конфиги какие записали при программировании ?
Конфиг взят с родной еммс.
1 минуту назад, Mteor сказал:
И CID тоже ?
Да и пробывали полностью клонировать родную. И получаю ошибку Code:0x656d6d31
log round 0x0000000a . Сейчас материнка зависла на ошибке и не реагирует ни на что. В мануале ненашел описания ошибок которые в логе могут быть и что означает Code:0x656d6d31 осталось только догадываться?
52 минуты назад, Mteor сказал:
не видит загрузочного раздела EMMC или нет связи с EMMC
пропаять всю мелочёвку рядом и под EMMC
Да простят админы не видел что вставленный текст был. Подскажите плиз номиналы элементов. Хотел бы сверить.Ряд где Д0-Д7 10ом вроде должно быть по схеме так ведь?
24 минуты назад, Mteor сказал:
где вы видели подтяжки по 10 ОМ !????? :ap:
на фото разве не эта часть
  • 4 недели спустя...
С Новым Годом товарищи и с наступающим Рождеством!
После последних постов было проделано.
Скрытый текст
mOVSdüø°[     0] sys_init start. boot_strap=0x00000514 (source=eMMC), boot_state=0x0
Перекатал проц и поставил
. Получил печальку в виде овоща. Кроме строки во вложении ничего не происходит.
Скрытый текст
ёї€SAHХ
Code:0x656d6d30
Если стереть еммс то выдает ошибку что во вложении.
После поразмыслив было куплено z3x Easy-Jtag Plus, и пару ssb не копаных.
Значит подкинул другой ssb и получил светит логом потом тухнет и включается на экране справа в низу квадрат небольшой на сером фоне и потом экран белеет и все.
лог прилагаю подскажите куда копать что бы не наделать лишних телодвижений .
Что означает данная строка TZ CPU3 ERROR ?
И судя по логу Exiting after checking for USB USB NOT FOUND он что то ищет на юзб.
Я пробовал флешку с прошивкой оф с сайта но он ищет
:/mnt/misc/usb0:File to search in Connected USB = :/mnt/misc/usb0/TPVisionDebug.cookie
Помогите советом.
Да совсем забыл если зажать джостик вниз что бы попытаться зайти в рекавери то он остается светить на логотипе и рекавери нет.
Изменено пользователем Mteor
Изучив все логи что есть на форуме с данной платформы то загрузка происходит правильная только есть бок в
Скрытый текст
[    0.289963] CPU1: Unknown IPI message 0x1
[    0.389960] CPU2: Unknown IPI message 0x1
[    0.489959] CPU3: Unknown IPI message 0x1
[    0.519371] gpio-regulator gpio-regulator.6: No 'states' property found
[    1.626453] marvell_tpv tpv.7: can't get vpuc regulator.
[    1.635355] berlin-ehci f7ed0000.usb: no pwr-gpio set
[    1.683215] berlin-ehci f7ee0000.usb: no pwr-gpio set
[    1.733165] berlin-ehci f7a30000.usb: no pwr-gpio set
<0>[    1.947468] fs_mgr: Cannot mount filesystem on /dev/block/mmcblk0p4 at /factory_setting
[    1.955763] init: fs_mgr_mount_all returned an error
TEEC_RegisterTA result = 0x00000000
[    2.036582] fs_mgr: Cannot open file /fstab.s2.mv88de3100
[    2.042174] init: fs_mgr_mount_all returned an error
[    2.047768] fs_mgr: Cannot open file /fstab.s3.mv88de3100
[    2.053376] init: fs_mgr_mount_all returned an error
[    2.095224] fusion: unable to register major 250. Registered 247 instead
[    2.103949] init: Unable to open persistent property directory /data/property errno: 2
[    2.696813] VID/PID = 1286/2043, Boot2 version = 4000
 ############ITM LAUNCHED ################
/bin/toolbox cp -f /bin/drmtest_a1 /bin/run_mpflow.sh /factory_setting/Ý<0><0>Ô<0><0>ITM UART READYITM UART READYITM UART READYITM UART READYITM UART READYITM UART READYITM UART READYITM UART READYITM UART READYITM UART READYITM UART READYITM UART READYITM UART READYITM UART READYITM UART READY<0>¥¥<<<<< CPU-1 OSAL InitMV_Time_Init OK.[    3.533477] leakage: 416
[    3.698178] FW is downloaded
[10.466744] TZ CPU3 ERROR[mr_find_region:67] buffer=0x00000000, size=0x00001ad0
[10.473846] TZ CPU3 ERROR[mr_find_region:67] buffer=0x00000000, size=0x00001ad0
MV_OPENCRYPTO_DeviceKey_Initialize, line: 299, otp_status = 0xff
MV_OPENCRYPTO_DeviceKey_Initialize, line: 301, tmp_test = 0xc
rkek be selected
BindInfo:
00000000 00000000 00000000 00000000 53564f6d b0f8fc64 00000000 48000000 3dffefea 00001a69 000000ff 6b2b5c8b 9e8906e1 078040e2
[    4.262574] usb_reset_device() successful.
[    4.524658] vmeta user count:0, set voltage 1150000:1150000
CIMAX_SPI_Init :SPI_Open returns 24CIMAX_SPI_Init: SPI_SetConfig returns 0CIMAX BOOT STATUS CHECK : FAIL(--> FW download)::::=Download CIMaX+ FW from /bin/cimax_spidvb_400.bin     :  Start FW execution                 :  ::Download Config::$Upgrade_semaphore initialisedSemaphore initialization successI2C_MasterEnable 296 - I2c bus = 0 I2C_MasterEnable 296 - I2c bus = 1000 I2C_MasterEnable 296 - I2c bus = 2000 I2C_MasterEnable 296 - I2c bus = 3000 insmod: init_module '/system/lib/tpvinput.ko' failed (File exists)Calling SetAD_SR.............................Calling SetAD_SR.............................*len = 1board.rev.id =  #### ***** Programming the TAS576 amplififer.***** #####Function : init_amp Programming the TAS576 amplififer Line : 101 Initializing the Native LibraryNative Init DoneSPI CONFIG INIT Calling screen rotation first and then request display stateDisplaystartup  displayStartupApp : screen attributes Rotated =1 displayctrl_requestDisplayState ON  State pending notification  I2C_MasterEnable 296 - I2c bus = 0 value recievd%%%%%%%% is ffffff inside amp_SetBackgroundColor value is ffffff, Fact_handle = 751906728 inside SetBgColor  is ffffff *****script 1, linenr 0<0><0><0><0><0>ª<0>IŠ NOW calling the logcat_start in separate pumpIn HomeTesterLogcat.....Exiting after checking for USB USB NOT FOUND, trying again <0><0><0><0><0>ª<0>IŠ NOW calling the logcat_start in separate pumpIn HomeTesterLogcat.....<0><0><0><0><0>ª<0>IŠExiting after checking for USB USB NOT FOUND, trying again  NOW calling the logcat_start in separate pumpIn HomeTesterLogcat.....Exiting after checking for USB USB NOT FOUND, trying again  NOW calling the logcat_start in separate pumpIn HomeTesterLogcat.....Exiting after checking for USB USB NOT FOUND, tryi NOW calling the logcat_start in separate pumpIn HomeTesterLogcat.....Exiting after checking for USB USB NOT FOUND, trying again  NOW calling the logcat_start in separate pumpIn HomeTesterLogcat.....Exiting after checking for USB USB NOT FOUND, trying again  NOW calling the logcat_start in separate pumpIn HomeTesterLogcat.....Exiting after checking for USB USB NOT FOUND, trying again NOW calling the logcat_start in separate pumpIn HomeTesterLogcat.....Exiting after checking for USB USB NOT FOUND, trying again  NOW calling the logcat_start in separate pumpIn HomeTesterLogcat.....Exiting after checking for USB USB NOT FOUND, trying again  NOW calling the logcat_start in separate pumpIn HomeTesterLogcat.....Exiting after checking for USB USB NOT FOUND, trying again  NOW calling the logcat_start in separate pumpIn HomeTesterLogcat.....Exiting after checking for USB USB NOT FOUND, trying again  NOW calling the logcat_start in separate pumpIn HomeTesterLogcat.....Exiting after checking for USB[   61000]I(SM): Chip Temperature: 48 degC(raw_data = 840)
[  121000]I(SM): Chip Temperature: 51 degC(raw_data = 849)
Если я правильно понимаю ему нужно дать файл на флешке TPVisionDebug.cookie  но где его взять интернет не дает ничего по запросу ?
Спасибо человеку с знанием который помог прояснить логи. Теперь вопрос к комрадам у которых везде указанно что они ремонтируют данную платформу.
TZ CPU3 ERROR как то лечиться или проц на помойку?
  • 5 месяцев спустя...
Огромное спасибо тем участникам форума, кто смог хоть немного открыть глаза на данную платформу и что с ней делать.
По сути вопроса, плата с телевизора ушла в шкафчик, как погибшая в неравном бою с "мастерами".  Под мастерами имею в веду себя.
Как писал выше, были куплены 2 платы на разборке.
Одна из плат была успешно на половину поднята, заменой микросхемы EMMC и прошивкой дампом пользовательской части с другой платы.
Что осталось не сделанным:
после установки в СЕМЕ, были прописаны набор функций и серийники плат. Но плата упорно не хочет подключаться к сервисам филипса. Ключ нетфликса и остальные вроде присутствуют. Все процедуры при замене платы, были соблюдены согласно сервису.
В плей майкерт, входит и приложения ставит.
Дабы не превращать плату в кусок запаянного текстолика, принято решения отстать от платы и оставить все как есть.
Вторая плата, упорно не хочет выдавать изображения. После попытки замены ЕММС и перепрошивки, пришел к выводу о том, что проблема в NT72314, так как она выдает сигналы LVDS. Но так как потеряв доступ к Паяльной станции, то тоже отправилась в долгий ящик.
Всем спасибо за участвия.
И если тема кому то будет полезна, то оставте.
Ребята, если не тяжело, тот кто очень хорошо знаком с платформой, не могли бы вы отписаться в личку, хотел несколько вопросов уточнить.
Промежуточное тестирование. Осталось добавить вентилятор для охлаждения и собирать в кучу.
Да совсем забыл, при попытке прописать 3 значный код для матрицы, виснет намертво.
Просьба к админам тему выкинуть в мусорку так как никто не отвечает считаю что она бесполезна.
08.06.2020 в 13:51, Mteor сказал:
09.06.2020 в 09:18, Mteor сказал:
12 минут назад, Mteor сказал:
@Mteor Не нужно ни кому указывать, что и как делать, тем более уходить в личные ото всех, и там решать свои вопросы, тогда для кого создавал тему?
26.11.2019 в 17:16, Mteor сказал:
Носом кто то тыкнет здесь на форуме рабочий дамп есть? Поиском найти не могу. Нужен дамп 100% рабочий  на 55PUS8109/12 шаси QV14.1E LA 715RLPCB0000000055
У меня есть с 55PFS8109, я его еще не выкладывал. Времени особо нет.
16 минут назад, manjak сказал:
Спасибо дамп уже добыл. Для меня остался не понятным вопрос с сервисами филипс.
25 минут назад, Aleh сказал:
Тему создавал для изучения платформы и понимания как и что. Но тема превратилась в разговор сам с собой. Так как гуру ремонта данных платформ не захотели и намека бросить что да как.((
13 минут назад, Mteor сказал:
Я не гуру, у меня сейчас тоже такой в ремонте. Сам пока разбираюсь. Перекатаю проц. будет видно что и как. У моего периодические перезагрузы, не видит тюнера. ПО однозначно в порядке. Похоже на отвал проца.
10 минут назад, Mteor сказал:
А ни кто и не скажет в открытую, что да как, даже в личку не скажут. Объяснить? Это не для открытых публикаций. А насчёт подсказок, так внимательно читай ответы, бывает в одном, двух словах оно. И не стоит ждать готового решения, по железу, думаю разобрался, по прошивке, раскладывай дамп, выдёргивай разделы и тусуй их. Так и находятся решения.
1 минуту назад, Aleh сказал:
вопрос только в одном какие условия для подключения к сервисам филипса. По чему сервис пускает телек к сервисам?
У принтеров серийник + мак! У ноутов серийники + маки.
11 минут назад, manjak сказал:
А что за трафарет? Я вручную шары ложыл. Трафарет на али нереальных денег стоит для трафарета?
42 минуты назад, Mteor сказал:
У меня трафарета нет, сам не рискнул. Отвез товарищу ноутбучнику, он откатает. В понедельник заберу.
